[U-Boot] does it make sense to define misc_init_r() not conditional on CONFIG_MISC_INIT_R?
another oddity i noted in my travels ... in common/board_r.c, this:
#ifdef CONFIG_MISC_INIT_R misc_init_r, /* miscellaneous platform-dependent init */ #endif
suggests that any *definition* of a board's misc_init_r() routine should be similarly conditional, but there are well over a hundred counter-examples like, say, this from km83xx.c:
int misc_init_r(void) { ivm_read_eeprom(ivm_content, CONFIG_SYS_IVM_EEPROM_MAX_LEN); return 0; }
doesn't hurt, of course ... binary just ends up containing a superfluous misc_init_r() routine that's never called. i suspect there's a lot of that with other routines as well.
or is there something else going on here more subtle that i don't understand?
rday
Hi Robert,
Typically the board will define CONFIG_MISC_INIT_R and also provide the function. The board won't work properly without it. There is a linkage between the config and the code.
So I don't see any sense in adding #ifdef around the function, if that is what you are suggesting? But having the function present and not called does seem odd.
As time moves on and things move to driver model, I suspect a lot of this init will be turned down.
Robert P. J. Day
