[U-Boot] [RFC] arm926ejs, at91: add common phy_reset function
add common phy reset code into a common function.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Andreas Bießmann andreas.devel@googlemail.com Cc: Bo Shen voice.shen@atmel.com Cc: Jens Scharsig esw@bus-elektronik.de Cc: Sergey Lapin slapin@ossfans.org Cc: Stelian Pop stelian@popies.net Cc: Albin Tonnerre albin.tonnerre@free-electrons.com Cc: Eric Benard eric@eukrea.com Cc: Markus Hubig mhubig@imko.de
--- Patch based on the spl patchset from Bo Shen (as I want to collect this function in at91-common directory), see: http://lists.denx.de/pipermail/u-boot/2013-November/166272.html (reworked this against newest Kconfig Makefile changes ... @Bo: Do you plan an update for this patchset for the Kconfig changes?
Maybe my change in arch/arm/cpu/at91-common/Makefile could be done better... Do we have a common define for all this variants?
--- arch/arm/cpu/Makefile | 1 + arch/arm/cpu/at91-common/Makefile | 5 +++ arch/arm/cpu/at91-common/phy.c | 48 +++++++++++++++++++++++++ arch/arm/include/asm/arch-at91/at91_common.h | 1 + board/BuS/vl_ma2sc/vl_ma2sc.c | 18 ++-------- board/afeb9260/afeb9260.c | 18 +--------- board/atmel/at91sam9260ek/at91sam9260ek.c | 19 +--------- board/atmel/at91sam9263ek/at91sam9263ek.c | 19 ++-------- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 19 +--------- board/bluewater/snapper9260/snapper9260.c | 16 +-------- board/calao/sbc35_a9g20/sbc35_a9g20.c | 19 +--------- board/eukrea/cpu9260/cpu9260.c | 18 +--------- board/taskit/stamp9g20/stamp9g20.c | 31 +--------------- spl/Makefile | 4 --- 14 files changed, 66 insertions(+), 170 deletions(-) create mode 100644 arch/arm/cpu/at91-common/phy.c
diff --git a/arch/arm/cpu/Makefile b/arch/arm/cpu/Makefile index fd0da53..886347d 100644 --- a/arch/arm/cpu/Makefile +++ b/arch/arm/cpu/Makefile @@ -1,2 +1,3 @@ obj-$(CONFIG_TEGRA) += $(SOC)-common/ obj-$(CONFIG_TEGRA) += tegra-common/ +obj-$(CONFIG_AT91FAMILY) += at91-common/ diff --git a/arch/arm/cpu/at91-common/Makefile b/arch/arm/cpu/at91-common/Makefile index 040b956..255c7b9 100644 --- a/arch/arm/cpu/at91-common/Makefile +++ b/arch/arm/cpu/at91-common/Makefile @@ -8,5 +8,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
+obj-$(CONFIG_AT91SAM9260) += phy.o +obj-$(CONFIG_AT91SAM9G20) += phy.o +obj-$(CONFIG_AT91SAM9263) += phy.o +obj-$(CONFIG_AT91SAM9XE) += phy.o +obj-$(CONFIG_AT91SAM9M10G45) += phy.o obj-$(CONFIG_SPL_BUILD) += mpddrc.o obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/arm/cpu/at91-common/phy.c b/arch/arm/cpu/at91-common/phy.c new file mode 100644 index 0000000..4706635 --- /dev/null +++ b/arch/arm/cpu/at91-common/phy.c @@ -0,0 +1,48 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian@popies.net + * Lead Tech Design <www.leadtechdesign.com> + * + * Copyright (C) 2013 DENX Software Engineering, hs@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/sizes.h> +#include <asm/arch/at91_pmc.h> +#include <asm/arch/at91_rstc.h> +#include <watchdog.h> + +void at91_phy_reset(void) +{ + unsigned long erstl; + unsigned long start = get_timer(0); + unsigned long timeout = 1000; /* 1000ms */ + at91_rstc_t *rstc = (at91_rstc_t *)ATMEL_BASE_RSTC; + + erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; + + /* Need to reset PHY -> 500ms reset */ + writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0x0D) | + AT91_RSTC_MR_URSTEN, &rstc->mr); + + writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); + + /* Wait for end of hardware reset */ + while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) { + /* avoid shutdown by watchdog */ + WATCHDOG_RESET(); + mdelay(10); + + /* timeout for not getting stuck in an endless loop */ + if (get_timer(start) >= timeout) { + puts("*** ERROR: Timeout waiting for PHY reset!\n"); + break; + } + }; + + /* Restore NRST value */ + writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); +} diff --git a/arch/arm/include/asm/arch-at91/at91_common.h b/arch/arm/include/asm/arch-at91/at91_common.h index 3ca4d5b..59e2f43 100644 --- a/arch/arm/include/asm/arch-at91/at91_common.h +++ b/arch/arm/include/asm/arch-at91/at91_common.h @@ -26,5 +26,6 @@ void at91_plla_init(u32 pllar); void at91_mck_init(u32 mckr); void at91_pmc_init(void); void mem_init(void); +void at91_phy_reset(void);
#endif /* AT91_COMMON_H */ diff --git a/board/BuS/vl_ma2sc/vl_ma2sc.c b/board/BuS/vl_ma2sc/vl_ma2sc.c index e2ae6fd..412ff3b 100644 --- a/board/BuS/vl_ma2sc/vl_ma2sc.c +++ b/board/BuS/vl_ma2sc/vl_ma2sc.c @@ -16,7 +16,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_pmc.h> #include <asm/arch/at91_pio.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/at91sam9263.h> #include <asm/arch/gpio.h> #include <asm/arch/at91_common.h> @@ -76,25 +75,12 @@ static void vl_ma2sc_nand_hw_init(void) #ifdef CONFIG_MACB static void vl_ma2sc_macb_hw_init(void) { - unsigned long erstl; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_rstc_t *rstc = (at91_rstc_t *) ATMEL_BASE_RSTC; + /* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0x0D) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + at91_phy_reset();
at91_macb_hw_init(); } diff --git a/board/afeb9260/afeb9260.c b/board/afeb9260/afeb9260.c index e1b1c10..ea9575d 100644 --- a/board/afeb9260/afeb9260.c +++ b/board/afeb9260/afeb9260.c @@ -13,7 +13,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/io.h> #include <asm/arch/hardware.h> @@ -67,8 +66,6 @@ static void afeb9260_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable EMAC clock */ @@ -94,20 +91,7 @@ static void afeb9260_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, - &rstc->mr); - + at91_phy_reset();
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/board/atmel/at91sam9260ek/at91sam9260ek.c b/board/atmel/at91sam9260ek/at91sam9260ek.c index 263de49..7f14af1 100644 --- a/board/atmel/at91sam9260ek/at91sam9260ek.c +++ b/board/atmel/at91sam9260ek/at91sam9260ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <atmel_mci.h>
@@ -73,8 +72,6 @@ static void at91sam9260ek_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable EMAC clock */ writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); @@ -98,21 +95,7 @@ static void at91sam9260ek_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, - &rstc->mr); + at91_phy_reset();
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/board/atmel/at91sam9263ek/at91sam9263ek.c b/board/atmel/at91sam9263ek/at91sam9263ek.c index 2e9246f..d42a173 100644 --- a/board/atmel/at91sam9263ek/at91sam9263ek.c +++ b/board/atmel/at91sam9263ek/at91sam9263ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> @@ -82,10 +81,9 @@ static void at91sam9263ek_nand_hw_init(void) #ifdef CONFIG_MACB static void at91sam9263ek_macb_hw_init(void) { - unsigned long erstl; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; at91_pio_t *pio = (at91_pio_t *) ATMEL_BASE_PIO; - at91_rstc_t *rstc = (at91_rstc_t *) ATMEL_BASE_RSTC; + /* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer);
@@ -97,23 +95,10 @@ static void at91sam9263ek_macb_hw_init(void) * * PHY has internal pull-down */ - writel(1 << 25, &pio->pioc.pudr); writel((1 << 25) | (1 <<26), &pio->pioe.pudr);
/* Re-enable pull-up */ writel(1 << 25, &pio->pioc.puer); diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index 6a071f6..b7e2efd 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -12,7 +12,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> @@ -88,8 +87,6 @@ static void at91sam9m10g45ek_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable clock */ writel(1 << ATMEL_ID_EMAC, &pmc->pcer); @@ -107,21 +104,7 @@ static void at91sam9m10g45ek_macb_hw_init(void) pin_to_mask(AT91_PIN_PA13), &pioa->pudr);
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA15) | diff --git a/board/bluewater/snapper9260/snapper9260.c b/board/bluewater/snapper9260/snapper9260.c index 8a6919d..bfde129 100644 --- a/board/bluewater/snapper9260/snapper9260.c +++ b/board/bluewater/snapper9260/snapper9260.c @@ -14,7 +14,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <net.h> #include <netdev.h> @@ -31,8 +30,6 @@ static void macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable clock */ writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); @@ -54,18 +51,7 @@ static void macb_hw_init(void) /* Enable ethernet power */ pca953x_set_val(0x28, IO_EXP_ETH_POWER, 0);
- /* Need to reset PHY -> 500ms reset */ - erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(13) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, &rstc->mr); + at91_phy_reset();
/* Bring the ethernet out of reset */ pca953x_set_val(0x28, IO_EXP_ETH_RESET, 1); diff --git a/board/calao/sbc35_a9g20/sbc35_a9g20.c b/board/calao/sbc35_a9g20/sbc35_a9g20.c index ecf261c..2074a93 100644 --- a/board/calao/sbc35_a9g20/sbc35_a9g20.c +++ b/board/calao/sbc35_a9g20/sbc35_a9g20.c @@ -15,7 +15,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h>
#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) @@ -77,8 +76,6 @@ static void sbc35_a9g20_macb_hw_init(void) { struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable EMAC clock */ writel(1 << ATMEL_ID_EMAC0, &pmc->pcer); @@ -102,21 +99,7 @@ static void sbc35_a9g20_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/board/eukrea/cpu9260/cpu9260.c b/board/eukrea/cpu9260/cpu9260.c index 5e1524e..274f72d 100644 --- a/board/eukrea/cpu9260/cpu9260.c +++ b/board/eukrea/cpu9260/cpu9260.c @@ -17,7 +17,6 @@ #include <asm/arch/at91_common.h> #include <asm/arch/at91_matrix.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/at91_pio.h> #include <asm/arch/clk.h> #include <asm/arch/hardware.h> @@ -89,29 +88,14 @@ static void cpu9260_nand_hw_init(void) #ifdef CONFIG_MACB static void cpu9260_macb_hw_init(void) { - unsigned long rstcmr; at91_pmc_t *pmc = (at91_pmc_t *) ATMEL_BASE_PMC; - at91_rstc_t *rstc = (at91_rstc_t *) ATMEL_BASE_RSTC;
at91_set_pio_pullup(AT91_PIO_PORTA, 17, 1);
- rstcmr = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | AT91_RSTC_MR_ERSTL(0xD) | - AT91_RSTC_MR_URSTEN, &rstc->mr); - - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end hardware reset */ - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) - ; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | rstcmr | AT91_RSTC_MR_URSTEN, &rstc->mr); + at91_phy_reset();
at91_macb_hw_init(); } diff --git a/board/taskit/stamp9g20/stamp9g20.c b/board/taskit/stamp9g20/stamp9g20.c index 704a63b..27cdf77 100644 --- a/board/taskit/stamp9g20/stamp9g20.c +++ b/board/taskit/stamp9g20/stamp9g20.c @@ -19,7 +19,6 @@ #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> #include <asm/arch/at91_pmc.h> -#include <asm/arch/at91_rstc.h> #include <asm/arch/gpio.h> #include <watchdog.h>
@@ -67,8 +66,6 @@ static void stamp9G20_nand_hw_init(void) static void stamp9G20_macb_hw_init(void) { struct at91_port *pioa = (struct at91_port *)ATMEL_BASE_PIOA; - struct at91_rstc *rstc = (struct at91_rstc *)ATMEL_BASE_RSTC; - unsigned long erstl;
/* Enable the PHY Chip via PA26 on the Stamp 2 Adaptor */ at91_set_gpio_output(AT91_PIN_PA26, 0); @@ -91,33 +88,7 @@ static void stamp9G20_macb_hw_init(void) pin_to_mask(AT91_PIN_PA28), &pioa->pudr);
- erstl = readl(&rstc->mr) & AT91_RSTC_MR_ERSTL_MASK; - - /* Need to reset PHY -> 500ms reset */ - writel(AT91_RSTC_KEY | (AT91_RSTC_MR_ERSTL(13) & - ~AT91_RSTC_MR_URSTEN), &rstc->mr); - writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST, &rstc->cr); - - /* Wait for end of hardware reset */ - unsigned long start = get_timer(0); - unsigned long timeout = 1000; /* 1000ms */ - - while (!(readl(&rstc->sr) & AT91_RSTC_SR_NRSTL)) { - - /* avoid shutdown by watchdog */ - WATCHDOG_RESET(); - mdelay(10); - - /* timeout for not getting stuck in an endless loop */ - if (get_timer(start) >= timeout) { - puts("*** ERROR: Timeout waiting for PHY reset!\n"); - break; - }; - }; - - /* Restore NRST value */ - writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN, - &rstc->mr); + at91_phy_reset();
/* Re-enable pull-up */ writel(pin_to_mask(AT91_PIN_PA14) | diff --git a/spl/Makefile b/spl/Makefile index 736c6ca..cbd3d27 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -111,10 +111,6 @@ ifneq ($(CONFIG_MX23)$(CONFIG_MX35),) LIBS-y += arch/$(ARCH)/imx-common/libimx-common.o endif
-ifeq ($(SOC),at91) -LIBS-y += arch/$(ARCH)/cpu/at91-common/libat91-common.o -endif - # Add GCC lib ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") PLATFORM_LIBGCC = $(SPLTREE)/arch/$(ARCH)/lib/libgcc.o
Hello Heiko,
@Bo: I'll review the patches also these days.
I think not, but how about defining a new one?
How about defining some CONFIG_AT91_WANTS_PHY_RESET or CONFIG_AT91_WANTS_COMMON_PHY?
- (C) Copyright 2007-2008
- Stelian Pop stelian@popies.net
- Lead Tech Design <www.leadtechdesign.com>
- Copyright (C) 2013 DENX Software Engineering, hs@denx.de
I'd constify timeout, it could give a hint to the compiler and it doesn't hurt here.
- at91_rstc_t *rstc = (at91_rstc_t *)ATMEL_BASE_RSTC;
As there where discussion about this trick here could you please add some comments:
---8<--- Reset PHY by pulling the NRST line for 500ms to low. To do so disable user reset for low level on NRST pin and poll the NRST level in reset status register. --->8---
WATCHDOG_RESET();
mdelay(10);
break;
<snip>
WATCHDOG_RESET();
mdelay(10);
break;
Your code looks like this one, you should add Markus Hubig to your Copyright list.
&rstc->mr);
at91_phy_reset();
That should not be removed here.
Looks good to me. Hopefully some board maintainers send their tested-by ...
Best regards
Andreas Bießmann
Hello Andreas,
Am 12.11.2013 13:56, schrieb Andreas Bießmann:
Hello Heiko,
Signed-off-by: Heiko Schocherhs@denx.de Cc: Andreas Bießmannandreas.devel@googlemail.com Cc: Bo Shenvoice.shen@atmel.com Cc: Jens Scharsigesw@bus-elektronik.de Cc: Sergey Lapinslapin@ossfans.org Cc: Stelian Popstelian@popies.net Cc: Albin Tonnerrealbin.tonnerre@free-electrons.com Cc: Eric Benarderic@eukrea.com Cc: Markus Hubigmhubig@imko.de
Perfect!
I am fine with this too...
I vote for CONFIG_AT91_WANTS_COMMON_PHY
- Stelian Popstelian@popies.net
- Lead Tech Design<www.leadtechdesign.com>
+#include<common.h> +#include<asm/io.h> +#include<asm/sizes.h> +#include<asm/arch/at91_pmc.h> +#include<asm/arch/at91_rstc.h> +#include<watchdog.h>
Ok.
- erstl = readl(&rstc->mr)& AT91_RSTC_MR_ERSTL_MASK;
Ok.
AT91_RSTC_MR_URSTEN,&rstc->mr);
- writel(AT91_RSTC_KEY | AT91_RSTC_CR_EXTRST,&rstc->cr);
- while (!(readl(&rstc->sr)& AT91_RSTC_SR_NRSTL)) {
WATCHDOG_RESET();
mdelay(10);
if (get_timer(start)>= timeout) {
break;
- writel(AT91_RSTC_KEY | erstl | AT91_RSTC_MR_URSTEN,&rstc->mr);
<snip>
diff --git a/board/taskit/stamp9g20/stamp9g20.c b/board/taskit/stamp9g20/stamp9g20.c index 704a63b..27cdf77 100644 --- a/board/taskit/stamp9g20/stamp9g20.c +++ b/board/taskit/stamp9g20/stamp9g20.c @@ -19,7 +19,6 @@ #include<asm/arch/at91sam9_smc.h> #include<asm/arch/at91_common.h> #include<asm/arch/at91_pmc.h> -#include<asm/arch/at91_rstc.h> #include<asm/arch/gpio.h> #include<watchdog.h>
- writel(AT91_RSTC_KEY | (AT91_RSTC_MR_ERSTL(13)&
~AT91_RSTC_MR_URSTEN),&rstc->mr);
WATCHDOG_RESET();
mdelay(10);
break;
Ok.
&rstc->mr);
at91_phy_reset();
See my change in arch/arm/cpu/Makefile
With this change, this in the spl/Makefile is not needed ... I did this, because arch/arm/cpu/at91-common/ contains not only spl code. But maybe this should be changed in the spl patchset from bo?
I am too...
bye, Heiko
Hi Heiko,
On 11/12/2013 09:50 PM, Heiko Schocher wrote:
Hello Andreas,
Hello Heiko,
After Andreas finish reviewing the code, I will update this patchset for the Kconfig changes if needed.
Perfect!
<snip>
I am not fully got your means. what should I change?
I am too...
bye, Heiko
Best Regards, Bo Shen
Hello Bo,
Am 13.11.2013 02:35, schrieb Bo Shen:
Hi Heiko,
Hello Andreas,
Hello Heiko,
Great, so I wait for your update, before I sent my updated patch, thanks!
Perfect!
<snip>
Could you add to your patchset the following change?
diff --git a/arch/arm/cpu/Makefile b/arch/arm/cpu/Makefile index fd0da53..886347d 100644 --- a/arch/arm/cpu/Makefile +++ b/arch/arm/cpu/Makefile @@ -1,2 +1,3 @@ obj-$(CONFIG_TEGRA) += $(SOC)-common/ obj-$(CONFIG_TEGRA) += tegra-common/ +obj-$(CONFIG_AT91FAMILY) += at91-common/ diff --git a/spl/Makefile b/spl/Makefile index 736c6ca..cbd3d27 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -111,10 +111,6 @@ ifneq ($(CONFIG_MX23)$(CONFIG_MX35),) LIBS-y += arch/$(ARCH)/imx-common/libimx-common.o endif
bye, Heiko
Hi Heiko,
On 11/13/2013 01:04 PM, Heiko Schocher wrote:
Hello Bo,
Hi Heiko,
Hello Andreas,
Hello Heiko,
Perfect!
<snip>
OK. I will add this after reviewing. Thanks.
bye, Heiko
Andreas Bießmann
Bo Shen
Heiko Schocher
