[PATCH v1] misc: nuvoton: Add host interface configuartion driver
add nuvoton BMC npcm750 host configuartion driver
Signed-off-by: Jim Liu JJLIU0@nuvoton.com --- drivers/misc/Makefile | 1 + drivers/misc/npcm_host_intf.c | 110 ++++++++++++++++++++++++++++++++++ 2 files changed, 111 insertions(+) create mode 100644 drivers/misc/npcm_host_intf.c
diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 29fbf5640d..5f9cb1f053 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -54,6 +54,7 @@ obj-$(CONFIG_MPC83XX_SERDES) += mpc83xx_serdes.o obj-$(CONFIG_$(SPL_)MXC_OCOTP) += mxc_ocotp.o obj-$(CONFIG_MXS_OCOTP) += mxs_ocotp.o obj-$(CONFIG_NPCM_OTP) += npcm_otp.o +obj-$(CONFIG_ARCH_NPCM) += npcm_host_intf.o obj-$(CONFIG_NUVOTON_NCT6102D) += nuvoton_nct6102d.o obj-$(CONFIG_P2SB) += p2sb-uclass.o obj-$(CONFIG_PCA9551_LED) += pca9551_led.o diff --git a/drivers/misc/npcm_host_intf.c b/drivers/misc/npcm_host_intf.c new file mode 100644 index 0000000000..0244e40457 --- /dev/null +++ b/drivers/misc/npcm_host_intf.c @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Host interface (LPC or eSPI) configuration on Nuvoton BMC + * Copyright (c) 2022 Nuvoton Technology Corp. + */ + +#include <common.h> +#include <dm.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <dm/device_compat.h> +#include <linux/bitfield.h> + +#define SMC_CTL_REG_ADDR 0xc0001001 +#define SMC_CTL_HOSTWAIT 0x80 + +/* GCR Register Offsets */ +#define HIFCR 0x50 +#define MFSEL1 0x260 +#define MFSEL4 0x26c + +/* ESPI Register offsets */ +#define ESPICFG 0x4 +#define ESPIHINDP 0x80 + +/* MFSEL bit fileds */ +#define MFSEL1_LPCSEL BIT(26) +#define MFSEL4_ESPISEL BIT(8) + +/* ESPICFG bit fileds */ +#define CHSUPP_MASK GENMASK(27, 24) +#define IOMODE_MASK GENMASK(9, 8) +#define IOMODE_SDQ FIELD_PREP(IOMODE_MASK, 3) +#define MAXFREQ_MASK GENMASK(12, 10) +#define MAXFREQ_33MHZ FIELD_PREP(MAXFREQ_MASK, 2) + +/* ESPIHINDP bit fileds */ +#define AUTO_SBLD BIT(4) +#define AUTO_HS1 BIT(8) +#define AUTO_HS2 BIT(12) +#define AUTO_HS3 BIT(16) + +static int npcm_host_intf_bind(struct udevice *dev) +{ + struct regmap *syscon; + void __iomem *base; + u32 ch_supp, val; + u32 ioaddr; + const char *type; + int ret; + + /* Release host wait */ + setbits_8(SMC_CTL_REG_ADDR, SMC_CTL_HOSTWAIT); + + syscon = syscon_regmap_lookup_by_phandle(dev, "syscon"); + if (IS_ERR(syscon)) { + dev_err(dev, "%s: unable to get syscon, dev %s\n", __func__, dev->name); + return PTR_ERR(syscon); + } + + ioaddr = dev_read_u32_default(dev, "ioaddr", 0); + if (ioaddr) + regmap_write(syscon, HIFCR, ioaddr); + + type = dev_read_string(dev, "type"); + if (!type) + return -EINVAL; + + if (!strcmp(type, "espi")) { + base = dev_read_addr_ptr(dev); + if (!base) + return -EINVAL; + + ret = dev_read_u32(dev, "channel-support", &ch_supp); + if (ret) + return ret; + + /* Select eSPI pins function */ + regmap_update_bits(syscon, MFSEL1, MFSEL1_LPCSEL, 0); + regmap_update_bits(syscon, MFSEL4, MFSEL4_ESPISEL, MFSEL4_ESPISEL); + + val = AUTO_SBLD | AUTO_HS1 | AUTO_HS2 | AUTO_HS3 | ch_supp; + writel(val, base + ESPIHINDP); + + val = readl(base + ESPICFG); + val &= ~(CHSUPP_MASK | IOMODE_MASK | MAXFREQ_MASK); + val |= IOMODE_SDQ | MAXFREQ_33MHZ | FIELD_PREP(CHSUPP_MASK, ch_supp); + writel(val, base + ESPICFG); + } else if (!strcmp(type, "lpc")) { + /* Select LPC pin function */ + regmap_update_bits(syscon, MFSEL4, MFSEL4_ESPISEL, 0); + regmap_update_bits(syscon, MFSEL1, MFSEL1_LPCSEL, MFSEL1_LPCSEL); + } + + return 0; +} + +static const struct udevice_id npcm_hostintf_ids[] = { + { .compatible = "nuvoton,npcm750-host-intf" }, + { .compatible = "nuvoton,npcm845-host-intf" }, + { } +}; + +U_BOOT_DRIVER(npcm_host_intf) = { + .name = "npcm_host_intf", + .id = UCLASS_MISC, + .of_match = npcm_hostintf_ids, + .bind = npcm_host_intf_bind, +};
This needs to add a Kconfig option and that in turn needs to select or depends on the infrastructure it needs: arm-linux-gnueabi-ld.bfd: drivers/misc/npcm_host_intf.o: in function `npcm_host_intf_bind': drivers/misc/npcm_host_intf.c:56: undefined reference to `syscon_regmap_lookup_by_phandle' arm-linux-gnueabi-ld.bfd: drivers/misc/npcm_host_intf.c:64: undefined reference to `regmap_write' arm-linux-gnueabi-ld.bfd: drivers/misc/npcm_host_intf.c:80: undefined reference to `regmap_update_bits' arm-linux-gnueabi-ld.bfd: drivers/misc/npcm_host_intf.c:81: undefined reference to `regmap_update_bits' arm-linux-gnueabi-ld.bfd: drivers/misc/npcm_host_intf.c:92: undefined reference to `regmap_update_bits' arm-linux-gnueabi-ld.bfd: drivers/misc/npcm_host_intf.c:93: undefined reference to `regmap_update_bits' make[1]: *** [Makefile:1813: u-boot] Error 1
Jim Liu
