[U-Boot] [PATCH 1/3] dm: timer: refuse timers with zero clock_rate
If a timer has a zero clock_rate, get_tbclk() will return zero for it, which will cause tick_to_time() to perform a division-by-zero, which will crash U-Boot.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/timer/timer-uclass.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index aca421bdea33..0771562c600d 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -47,6 +47,16 @@ static int timer_pre_probe(struct udevice *dev) return 0; }
+static int timer_post_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + if (!uc_priv->clock_rate) + return -EINVAL; + + return 0; +} + u64 timer_conv_64(u32 count) { /* increment tbh if tbl has rolled over */ @@ -60,5 +70,6 @@ UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer", .pre_probe = timer_pre_probe, + .post_probe = timer_post_probe, .per_device_auto_alloc_size = sizeof(struct timer_dev_priv), };
A default invocation of sandbox U-Boot apparently uses no device tree, which means that no timer is registers, which in turn means that the sleep shell command hangs.
Fix the sandbox timer code to register a device when there's no DT, just like e.g. the sandbox reset driver does. When there's no DT, the DM uclass can't initialize clock_rate from DT, so set a default value in the timer code instead.
Signed-off-by: Stephen Warren swarren@nvidia.com --- drivers/timer/sandbox_timer.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/timer/sandbox_timer.c b/drivers/timer/sandbox_timer.c index 00a9944f78e6..a8da93634949 100644 --- a/drivers/timer/sandbox_timer.c +++ b/drivers/timer/sandbox_timer.c @@ -27,6 +27,11 @@ static int sandbox_timer_get_count(struct udevice *dev, u64 *count)
static int sandbox_timer_probe(struct udevice *dev) { + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + if (!uc_priv->clock_rate) + uc_priv->clock_rate = 1000000; + return 0; }
@@ -47,3 +52,8 @@ U_BOOT_DRIVER(sandbox_timer) = { .ops = &sandbox_timer_ops, .flags = DM_FLAG_PRE_RELOC, }; + +/* This is here in case we don't have a device tree */ +U_BOOT_DEVICE(sandbox_timer_non_fdt) = { + .name = "sandbox_timer", +};
Applied to u-boot-dm, thanks!
Execute "sleep", and validate that it sleeps for approximately the correct amount of time.
Signed-off-by: Stephen Warren swarren@nvidia.com --- This patch depends on both the two previous patches, and on my unrelated series which adds the test/py code. If I resend that series, I can add this patch into it. --- test/py/tests/test_sleep.py | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+) create mode 100644 test/py/tests/test_sleep.py
diff --git a/test/py/tests/test_sleep.py b/test/py/tests/test_sleep.py new file mode 100644 index 000000000000..64f1ddf9a09f --- /dev/null +++ b/test/py/tests/test_sleep.py @@ -0,0 +1,24 @@ +# Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved. +# +# SPDX-License-Identifier: GPL-2.0 + +import pytest +import time + +def test_sleep(u_boot_console): + '''Test the sleep command, and validate that it sleeps for approximately + the correct amount of time.''' + + # Do this before we time anything, to make sure U-Boot is already running. + # Otherwise, the system boot time is included in the time measurement. + u_boot_console.ensure_spawned() + + # 3s isn't too long, but is enough to cross a few second boundaries. + sleep_time = 3 + tstart = time.time() + u_boot_console.run_command('sleep %d' % sleep_time) + tend = time.time() + elapsed = tend - tstart + delta_to_expected = abs(elapsed - sleep_time) + # 0.25s margin is hopefully enough to account for any system overhead. + assert delta_to_expected < 0.25
FYI, I've reposted the series that implements the test/py code, and bundled this patch 3/3 in this series into that series.
As such, I believe patches 1/3 and 2/3 in this series can be applied through whatever path sandbox (or DM or timer) patches would normally go through.
Hi Stephen,
I've applied them to u-boot-dm.
return -EINVAL;
Should we just panic here?
Regards, Bin
return -EINVAL;
That would prevent the system operating correctly if multiple timers happened to be registered and the other one didn't have this issue. Still, it does seem reasonable to highlight this error. Simon, what do you think here?
return -EINVAL;
I don't think so - there may be multiple timers, and this error should be reported. If you like you could use a strange error number so it is more obvious (e.g. -ETIME).
Regards, Bin
return -EINVAL;
Bin Meng
Stephen Warren
