[U-Boot] [PATCH v2] net: mvgbe: extract common code for SMI wait
Combine repeated code from smi_reg_read/smi_reg_write into a common function smi_wait_ready.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Chris Packham judge.packham@gmail.com ---
Changes in v2: - collect review from Stefan - use wait_for_bit_le32()
drivers/net/mvgbe.c | 47 ++++++++++++++++++++++----------------------- drivers/net/mvgbe.h | 1 + 2 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index 4e1aff6e3a86..e6585ef8b3e7 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -15,6 +15,7 @@ #include <net.h> #include <malloc.h> #include <miiphy.h> +#include <wait_bit.h> #include <asm/io.h> #include <linux/errno.h> #include <asm/types.h> @@ -40,10 +41,24 @@ DECLARE_GLOBAL_DATA_PTR; #define MVGBE_SMI_REG (((struct mvgbe_registers *)MVGBE0_BASE)->smi)
#if defined(CONFIG_PHYLIB) || defined(CONFIG_MII) || defined(CONFIG_CMD_MII) +static int smi_wait_ready(struct mvgbe_device *dmvgbe) +{ + int ret; + + ret = wait_for_bit_le32(&MVGBE_SMI_REG, MVGBE_PHY_SMI_BUSY_MASK, false, + MVGBE_PHY_SMI_TIMEOUT_MS, false); + if (ret) { + printf("Error: SMI busy timeout\n"); + return ret; + } + + return 0; +} + /* * smi_reg_read - miiphy_read callback function. * - * Returns 16bit phy register value, or 0xffff on error + * Returns 16bit phy register value, or -EFAULT on error */ static int smi_reg_read(struct mii_dev *bus, int phy_adr, int devad, int reg_ofs) @@ -74,16 +89,9 @@ static int smi_reg_read(struct mii_dev *bus, int phy_adr, int devad, return -EFAULT; }
- timeout = MVGBE_PHY_SMI_TIMEOUT; /* wait till the SMI is not busy */ - do { - /* read smi register */ - smi_reg = MVGBE_REG_RD(MVGBE_SMI_REG); - if (timeout-- == 0) { - printf("Err..(%s) SMI busy timeout\n", __func__); - return -EFAULT; - } - } while (smi_reg & MVGBE_PHY_SMI_BUSY_MASK); + if (smi_wait_ready(dmvgbe) < 0) + return -EFAULT;
/* fill the phy address and regiser offset and read opcode */ smi_reg = (phy_adr << MVGBE_PHY_SMI_DEV_ADDR_OFFS) @@ -119,10 +127,9 @@ static int smi_reg_read(struct mii_dev *bus, int phy_adr, int devad, }
/* - * smi_reg_write - imiiphy_write callback function. + * smi_reg_write - miiphy_write callback function. * - * Returns 0 if write succeed, -EINVAL on bad parameters - * -ETIME on timeout + * Returns 0 if write succeed, -EFAULT on error */ static int smi_reg_write(struct mii_dev *bus, int phy_adr, int devad, int reg_ofs, u16 data) @@ -131,7 +138,6 @@ static int smi_reg_write(struct mii_dev *bus, int phy_adr, int devad, struct mvgbe_device *dmvgbe = to_mvgbe(dev); struct mvgbe_registers *regs = dmvgbe->regs; u32 smi_reg; - u32 timeout;
/* Phyadr write request*/ if (phy_adr == MV_PHY_ADR_REQUEST && @@ -147,19 +153,12 @@ static int smi_reg_write(struct mii_dev *bus, int phy_adr, int devad, } if (reg_ofs > PHYREG_MASK) { printf("Err..(%s) Invalid register offset\n", __func__); - return -EINVAL; + return -EFAULT; }
/* wait till the SMI is not busy */ - timeout = MVGBE_PHY_SMI_TIMEOUT; - do { - /* read smi register */ - smi_reg = MVGBE_REG_RD(MVGBE_SMI_REG); - if (timeout-- == 0) { - printf("Err..(%s) SMI busy timeout\n", __func__); - return -ETIME; - } - } while (smi_reg & MVGBE_PHY_SMI_BUSY_MASK); + if (smi_wait_ready(dmvgbe) < 0) + return -EFAULT;
/* fill the phy addr and reg offset and write opcode and data */ smi_reg = (data << MVGBE_PHY_SMI_DATA_OFFS); diff --git a/drivers/net/mvgbe.h b/drivers/net/mvgbe.h index c20d1d7edf7b..1dc9bbea2f42 100644 --- a/drivers/net/mvgbe.h +++ b/drivers/net/mvgbe.h @@ -216,6 +216,7 @@
/* SMI register fields */ #define MVGBE_PHY_SMI_TIMEOUT 10000 +#define MVGBE_PHY_SMI_TIMEOUT_MS 1000 #define MVGBE_PHY_SMI_DATA_OFFS 0 /* Data */ #define MVGBE_PHY_SMI_DATA_MASK (0xffff << MVGBE_PHY_SMI_DATA_OFFS) #define MVGBE_PHY_SMI_DEV_ADDR_OFFS 16 /* PHY device address */
Hi Chris,
https://patchwork.ozlabs.org/patch/927112/ was applied to http://git.denx.de/?p=u-boot/u-boot-net.git
Thanks! -Joe
Chris Packham
Joe Hershberger
