[U-Boot] [PATCH v4 0/5] Arm: meson: add support for p200 and p201 boards
This adds support for p200 and p201 reference boards from amlogic
Mohammad Rasim (5): ARM: board: meson: rename odroid-c2 to p200 ARM: dts: meson: add p200 and p201 boards Arm: dts: meson: add u-boot.dtsi for p200 and p201 ARM: board: meson: add p200 board ARM: board: meson: add p201 board
arch/arm/dts/Makefile | 2 + arch/arm/dts/meson-gxbb-p200-u-boot.dtsi | 7 + arch/arm/dts/meson-gxbb-p200.dts | 99 +++++++ arch/arm/dts/meson-gxbb-p201-u-boot.dtsi | 7 + arch/arm/dts/meson-gxbb-p201.dts | 26 ++ arch/arm/dts/meson-gxbb-p20x.dtsi | 247 ++++++++++++++++++ arch/arm/mach-meson/Kconfig | 2 +- board/amlogic/{odroid-c2 => p200}/MAINTAINERS | 6 +- board/amlogic/{odroid-c2 => p200}/Makefile | 2 +- .../{odroid-c2 => p200}/README.nanopi-k2 | 0 .../{odroid-c2 => p200}/README.odroid-c2 | 0 board/amlogic/p200/README.p200 | 103 ++++++++ .../{odroid-c2/odroid-c2.c => p200/p200.c} | 0 board/amlogic/p201/MAINTAINERS | 5 + board/amlogic/p201/Makefile | 5 + board/amlogic/p201/README.p201 | 103 ++++++++ board/amlogic/p201/p201.c | 43 +++ configs/nanopi-k2_defconfig | 1 + configs/odroid-c2_defconfig | 1 + configs/p200_defconfig | 41 +++ configs/p201_defconfig | 41 +++ 21 files changed, 736 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/meson-gxbb-p200-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxbb-p200.dts create mode 100644 arch/arm/dts/meson-gxbb-p201-u-boot.dtsi create mode 100644 arch/arm/dts/meson-gxbb-p201.dts create mode 100644 arch/arm/dts/meson-gxbb-p20x.dtsi rename board/amlogic/{odroid-c2 => p200}/MAINTAINERS (70%) rename board/amlogic/{odroid-c2 => p200}/Makefile (82%) rename board/amlogic/{odroid-c2 => p200}/README.nanopi-k2 (100%) rename board/amlogic/{odroid-c2 => p200}/README.odroid-c2 (100%) create mode 100644 board/amlogic/p200/README.p200 rename board/amlogic/{odroid-c2/odroid-c2.c => p200/p200.c} (100%) create mode 100644 board/amlogic/p201/MAINTAINERS create mode 100644 board/amlogic/p201/Makefile create mode 100644 board/amlogic/p201/README.p201 create mode 100644 board/amlogic/p201/p201.c create mode 100644 configs/p200_defconfig create mode 100644 configs/p201_defconfig
-- 2.21.0
This renames the odroid-c2 to p200 and set it as the default GXBB board Other boards (odroid-c2 and nanopi-k2) will inherit from p200
Signed-off-by: Mohammad Rasim mohammad.rasim96@gmail.com --- arch/arm/mach-meson/Kconfig | 2 +- board/amlogic/{odroid-c2 => p200}/MAINTAINERS | 6 +- board/amlogic/{odroid-c2 => p200}/Makefile | 2 +- .../{odroid-c2 => p200}/README.nanopi-k2 | 0 .../{odroid-c2 => p200}/README.odroid-c2 | 0 board/amlogic/p200/README.p200 | 103 ++++++++++++++++++ .../{odroid-c2/odroid-c2.c => p200/p200.c} | 0 configs/nanopi-k2_defconfig | 1 + configs/odroid-c2_defconfig | 1 + 9 files changed, 110 insertions(+), 5 deletions(-) rename board/amlogic/{odroid-c2 => p200}/MAINTAINERS (70%) rename board/amlogic/{odroid-c2 => p200}/Makefile (82%) rename board/amlogic/{odroid-c2 => p200}/README.nanopi-k2 (100%) rename board/amlogic/{odroid-c2 => p200}/README.odroid-c2 (100%) create mode 100644 board/amlogic/p200/README.p200 rename board/amlogic/{odroid-c2/odroid-c2.c => p200/p200.c} (100%)
diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index 11077bc6cc24..1b1d0aef0d22 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -61,7 +61,7 @@ config SYS_VENDOR
config SYS_BOARD string "Board name" - default "odroid-c2" if MESON_GXBB + default "p200" if MESON_GXBB default "p212" if MESON_GXL default "q200" if MESON_GXM default "s400" if MESON_AXG diff --git a/board/amlogic/odroid-c2/MAINTAINERS b/board/amlogic/p200/MAINTAINERS similarity index 70% rename from board/amlogic/odroid-c2/MAINTAINERS rename to board/amlogic/p200/MAINTAINERS index 6a853066d781..96fe92dd0874 100644 --- a/board/amlogic/odroid-c2/MAINTAINERS +++ b/board/amlogic/p200/MAINTAINERS @@ -1,8 +1,8 @@ -ODROID-C2 +P200 M: Beniamino Galvani b.galvani@gmail.com M: Neil Armstrong narmstrong@baylibre.com S: Maintained -F: board/amlogic/odroid-c2/ -F: include/configs/odroid-c2.h +F: board/amlogic/p200/ F: configs/nanopi-k2_defconfig F: configs/odroid-c2_defconfig +F: configs/p200_defconfig diff --git a/board/amlogic/odroid-c2/Makefile b/board/amlogic/p200/Makefile similarity index 82% rename from board/amlogic/odroid-c2/Makefile rename to board/amlogic/p200/Makefile index a6a3db755f21..f82a7ea9ca6b 100644 --- a/board/amlogic/odroid-c2/Makefile +++ b/board/amlogic/p200/Makefile @@ -2,4 +2,4 @@ # # (C) Copyright 2016 Beniamino Galvani b.galvani@gmail.com
-obj-y := odroid-c2.o +obj-y := p200.o diff --git a/board/amlogic/odroid-c2/README.nanopi-k2 b/board/amlogic/p200/README.nanopi-k2 similarity index 100% rename from board/amlogic/odroid-c2/README.nanopi-k2 rename to board/amlogic/p200/README.nanopi-k2 diff --git a/board/amlogic/odroid-c2/README.odroid-c2 b/board/amlogic/p200/README.odroid-c2 similarity index 100% rename from board/amlogic/odroid-c2/README.odroid-c2 rename to board/amlogic/p200/README.odroid-c2 diff --git a/board/amlogic/p200/README.p200 b/board/amlogic/p200/README.p200 new file mode 100644 index 000000000000..01d82d1e79e3 --- /dev/null +++ b/board/amlogic/p200/README.p200 @@ -0,0 +1,103 @@ +U-Boot for Amlogic P200 +======================= + +P200 is a reference board manufactured by Amlogic with the following +specifications: + + - Amlogic S905 ARM Cortex-A53 quad-core SoC @ 1.5GHz + - ARM Mali 450 GPU + - 2GB DDR3 SDRAM + - Gigabit Ethernet + - HDMI 2.0 4K/60Hz display + - 2 x USB 2.0 Host + - eMMC, microSD + - Infrared receiver + - SDIO WiFi Module + - CVBS+Stereo Audio Jack + +Schematics are available from Amlogic on demand. + +Currently the u-boot port supports the following devices: + - serial + - eMMC, microSD + - Ethernet + - I2C + - Regulators + - Reset controller + - Clock controller + - USB Host + - ADC + +u-boot compilation +================== + + > export ARCH=arm + > export CROSS_COMPILE=aarch64-none-elf- + > make p200_defconfig + > make + +Image creation +============== + +Amlogic doesn't provide sources for the firmware and for tools needed +to create the bootloader image, so it is necessary to obtain them from +the git tree published by the board vendor: + + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... + > tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz + > tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz + > export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH + > git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot + > cd amlogic-u-boot + > make gxb_p200_v1_defconfig + > make + > export FIPDIR=$PWD/fip + +Go back to mainline U-boot source tree then : + > mkdir fip + + > cp $FIPDIR/gxl/bl2.bin fip/ + > cp $FIPDIR/gxl/acs.bin fip/ + > cp $FIPDIR/gxl/bl21.bin fip/ + > cp $FIPDIR/gxl/bl30.bin fip/ + > cp $FIPDIR/gxl/bl301.bin fip/ + > cp $FIPDIR/gxl/bl31.img fip/ + > cp u-boot.bin fip/bl33.bin + + > $FIPDIR/blx_fix.sh \ + fip/bl30.bin \ + fip/zero_tmp \ + fip/bl30_zero.bin \ + fip/bl301.bin \ + fip/bl301_zero.bin \ + fip/bl30_new.bin \ + bl30 + + > $FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 + + > $FIPDIR/blx_fix.sh \ + fip/bl2_acs.bin \ + fip/zero_tmp \ + fip/bl2_zero.bin \ + fip/bl21.bin \ + fip/bl21_zero.bin \ + fip/bl2_new.bin \ + bl2 + + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img + > $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin + > $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig + > $FIPDIR/gxl/aml_encrypt_gxl --bootmk \ + --output fip/u-boot.bin \ + --bl2 fip/bl2.n.bin.sig \ + --bl30 fip/bl30_new.bin.enc \ + --bl31 fip/bl31.img.enc \ + --bl33 fip/bl33.bin.enc + +and then write the image to SD with: + + > DEV=/dev/your_sd_device + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 + > dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444 diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/p200/p200.c similarity index 100% rename from board/amlogic/odroid-c2/odroid-c2.c rename to board/amlogic/p200/p200.c diff --git a/configs/nanopi-k2_defconfig b/configs/nanopi-k2_defconfig index 8bbf48f41f7d..a513bc7cf8ce 100644 --- a/configs/nanopi-k2_defconfig +++ b/configs/nanopi-k2_defconfig @@ -38,3 +38,4 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_BOARD="p200" diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 747da184b3ad..f19b291164b7 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -39,3 +39,4 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_SYS_BOARD="p200" -- 2.21.0
This new file should go in patch 4
- default "p200" if MESON_GXBB default "p212" if MESON_GXL default "q200" if MESON_GXM default "s400" if MESON_AXG
Good catch here
You should add this one in patch 4
- ARM Mali 450 GPU
- 2GB DDR3 SDRAM
- Gigabit Ethernet
- 2 x USB 2.0 Host
- eMMC, microSD
- Infrared receiver
- SDIO WiFi Module
- serial
- eMMC, microSD
- Ethernet
- I2C
- Regulators
- Reset controller
- Clock controller
- USB Host
- ADC
export ARCH=arm export CROSS_COMPILE=aarch64-none-elf- make p200_defconfig make+Image creation +==============
wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... wget https://releases.linaro.org/archive/13.11/components/toolchain/binaries/gcc-... tar xvfJ gcc-linaro-aarch64-none-elf-4.8-2013.11_linux.tar.xz tar xvfJ gcc-linaro-arm-none-eabi-4.8-2013.11_linux.tar.xz export PATH=$PWD/gcc-linaro-aarch64-none-elf-4.8-2013.11_linux/bin:$PWD/gcc-linaro-arm-none-eabi-4.8-2013.11_linux/bin:$PATH git clone https://github.com/BayLibre/u-boot.git -b n-amlogic-openlinux-20170606 amlogic-u-boot cd amlogic-u-boot make gxb_p200_v1_defconfig make export FIPDIR=$PWD/fip+Go back to mainline U-boot source tree then :
mkdir fip cp $FIPDIR/gxl/bl2.bin fip/ cp $FIPDIR/gxl/acs.bin fip/ cp $FIPDIR/gxl/bl21.bin fip/ cp $FIPDIR/gxl/bl30.bin fip/ cp $FIPDIR/gxl/bl301.bin fip/ cp $FIPDIR/gxl/bl31.img fip/ cp u-boot.bin fip/bl33.bin $FIPDIR/blx_fix.sh \- fip/bl30.bin \
- fip/zero_tmp \
- fip/bl30_zero.bin \
- fip/bl301.bin \
- fip/bl301_zero.bin \
- fip/bl30_new.bin \
- bl30
$FIPDIR/acs_tool.pyc fip/bl2.bin fip/bl2_acs.bin fip/acs.bin 0 $FIPDIR/blx_fix.sh \- fip/bl2_acs.bin \
- fip/zero_tmp \
- fip/bl2_zero.bin \
- fip/bl21.bin \
- fip/bl21_zero.bin \
- fip/bl2_new.bin \
- bl2
$FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl30_new.bin $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl31.img $FIPDIR/gxl/aml_encrypt_gxl --bl3enc --input fip/bl33.bin $FIPDIR/gxl/aml_encrypt_gxl --bl2sig --input fip/bl2_new.bin --output fip/bl2.n.bin.sig $FIPDIR/gxl/aml_encrypt_gxl --bootmk \--output fip/u-boot.bin \
DEV=/dev/your_sd_device dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=512 skip=1 seek=1 dd if=fip/u-boot.bin.sd.bin of=$DEV conv=fsync,notrunc bs=1 count=444
No need for these last two changes, you changed the default SYS_BOARD config to p200
-- 2.21.0
Neil
-- 2.21.0
With the two small changes and the p200 changes from patch 1 to patch 4, I'll apply this to u-boot-amlogic !
Neil
Mohammad Rasim
Neil Armstrong
