[PATCH] WIP: Nokia RX-51: Convert to CONFIG_DM_VIDEO
--- I had to comment "return -ENOSPC;" in video-uclass.c because without it DM_VIDEO does not work and I do not know why. This looks like either false-positive test or a bug in DM_VIDEO code. I have already set PRE_RELOC flag but it has no effect on that code.
Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it is enabled in config file. I do not know why too.
Any idea?
Othwise framebuffer works. --- board/nokia/rx51/rx51.c | 41 ++++++++++++++++++++++-------------- configs/nokia_rx51_defconfig | 7 ++++-- drivers/video/video-uclass.c | 4 +++- include/configs/nokia_rx51.h | 11 ++-------- 4 files changed, 35 insertions(+), 28 deletions(-)
diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index a52691509da4..e2fe411b34be 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -30,7 +30,7 @@ #include <malloc.h> #include <twl4030.h> #include <i2c.h> -#include <video_fb.h> +#include <video.h> #include <keyboard.h> #include <asm/global_data.h> #include <asm/io.h> @@ -62,8 +62,6 @@ struct emu_hal_params_rx51 {
DECLARE_GLOBAL_DATA_PTR;
-GraphicDevice gdev; - const omap3_sysinfo sysinfo = { DDR_STACKED, "Nokia RX-51", @@ -342,22 +340,29 @@ void setup_board_tags(struct tag **in_params) *in_params = params; }
-/* - * Routine: video_hw_init - * Description: Set up the GraphicDevice depending on sys_boot. - */ -void *video_hw_init(void) +static int rx51_video_probe(struct udevice *dev) { - /* fill in Graphic Device */ - gdev.frameAdrs = 0x8f9c0000; - gdev.winSizeX = 800; - gdev.winSizeY = 480; - gdev.gdfBytesPP = 2; - gdev.gdfIndex = GDF_16BIT_565RGB; - memset((void *)gdev.frameAdrs, 0, 0xbb800); - return (void *) &gdev; + struct video_uc_plat *uc_plat = dev_get_uclass_plat(dev); + struct video_priv *uc_priv = dev_get_uclass_priv(dev); + + uc_plat->base = 0x8f9c0000; + uc_plat->size = 800 * 480 * sizeof(u16); + uc_priv->xsize = 800; + uc_priv->ysize = 480; + uc_priv->bpix = VIDEO_BPP16; + + video_set_flush_dcache(dev, true); + + return 0; }
+U_BOOT_DRIVER(rx51_video) = { + .name = "rx51_video", + .id = UCLASS_VIDEO, + .probe = rx51_video_probe, + .flags = DM_FLAG_PRE_RELOC, +}; + /* * Routine: twl4030_regulator_set_mode * Description: Set twl4030 regulator mode over i2c powerbus. @@ -777,6 +782,10 @@ U_BOOT_DRVINFOS(rx51_watchdog) = { { "rx51_watchdog" }, };
+U_BOOT_DRVINFOS(rx51_video) = { + { "rx51_video" }, +}; + U_BOOT_DRVINFOS(rx51_kp) = { { "rx51_kp" }, }; diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 47b7bc3b4f03..1d64981afc46 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -77,8 +77,11 @@ CONFIG_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y -CONFIG_CFB_CONSOLE=y -CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_LOGO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP32 is not set +CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_SPLASH_SCREEN=y CONFIG_WATCHDOG_TIMEOUT_MSECS=31000 CONFIG_WDT=y diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 7d499bcec51d..98cc5c0b17da 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -3,6 +3,8 @@ * Copyright (c) 2015 Google, Inc */
+#define DEBUG + #define LOG_CATEGORY UCLASS_VIDEO
#include <common.h> @@ -438,7 +440,7 @@ static int video_post_bind(struct udevice *dev) */ printf("Video device '%s' cannot allocate frame buffer memory -ensure the device is set up before relocation\n", dev->name); - return -ENOSPC; +// return -ENOSPC; } debug("%s: Claiming %lx bytes at %lx for video device '%s'\n", __func__, size, addr, dev->name); diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 9be64c3d3f87..e837b12b568f 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -70,19 +70,12 @@
#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP
-/* - * Framebuffer - */ -/* Video console */ -#define VIDEO_FB_16BPP_PIXEL_SWAP -#define VIDEO_FB_16BPP_WORD_SWAP - /* Environment information */ #define CONFIG_EXTRA_ENV_SETTINGS \ "usbtty=cdc_acm\0" \ "stdin=usbtty,serial,keyboard\0" \ - "stdout=usbtty,serial,vga\0" \ - "stderr=usbtty,serial,vga\0" \ + "stdout=usbtty,serial,vidconsole\0" \ + "stderr=usbtty,serial,vidconsole\0" \ "slide=gpio input " __stringify(GPIO_SLIDE) "\0" \ "switchmmc=mmc dev ${mmcnum}\0" \ "kernaddr=0x82008000\0" \
Hi Pali,
Probably the frame buffer memory allocation did not work. Could you please try with a bind callback, i.e.:
static int rx51_video_bind(struct udevice *dev) { struct video_uc_plat *plat = dev_get_uclass_plat(dev);
plat->size = 800 * 480 * 2; return 0; } ... U_BOOT_DRIVER(rx51_video) = { .name = "rx51_video", .id = UCLASS_VIDEO, .bind = rx51_video_bind, .probe = rx51_video_probe, .flags = DM_FLAG_PRE_RELOC, };
Any idea?
Not yet. There were some logo related changes recently, but if I remember correctly, I tested them on wandboard and nitrogen6q targets and with sandbox, and logo drawing worked there.
-- Anatolij
On Thursday 17 February 2022 09:53:39 Anatolij Gustschin wrote:
Hi Pali,
Hello! It does not work too. Here is the output:
U-Boot 2022.04-rc2-00002-ga2c1a9878375-dirty (Jan 01 1970 - 00:00:00 +0000)
OMAP35XX-GP ES3.1, CPU-OPP2, L3-165MHz, Max CPU Clock 600 MHz DRAM: Video frame buffers from 8fe30000 to 8fe30000 256 MiB Video device 'rx51_video' cannot allocate frame buffer memory -ensure the device is set up before relocation
If "return -ENOSPC;" is not commented then this is the last printed line. If it is commented then output continues with:
video_post_bind: Claiming 130000 bytes at 8fd00000 for video device 'rx51_video'
And framebuffer is working fine like without above rx51_video_bind() change.
Any idea?
-- Anatolij
PING?
Hi Pali,
Any idea?
-- Anatolij
Hi Pali,
On Sun, 6 Mar 2022 at 04:51, Pali Rohár pali@kernel.org wrote:
PING?
Hi Pali,
It looks like you are hard-coding the address of the video buffers. Is that intentional? If so, you may need to disable U-Boot's automatic allocation.
One way to do that is to set the frame buffer address and size in your bind() routine (post relocation) and update video_post_bind() to check if the address is non-zero (plat->base I mean) and skip its allocation if so.
Any idea?
Can you be more specific than 'broken'? What is broken about it?
On Sunday 06 March 2022 05:51:34 Simon Glass wrote:
Hi Pali,
PING?
Hi Pali,
This is how it works, signed bootloader which loads U-Boot initialize and prepare framebuffer.
Ok, I have tried it and following change makes framebuffer in qemu working:
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 7d499bcec51d..f4d8d395e714 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -78,6 +80,9 @@ static ulong alloc_fb(struct udevice *dev, ulong *addrp) if (!plat->size) return 0;
+ if (plat->base) + return 0; + align = plat->align ? plat->align : 1 << 20; base = *addrp - plat->size; base &= ~(align - 1);
Is this what you mean?
Any idea?
Does not work, logo is not drown on the screen.
Hi Pali,
Hi Pali,
PING?
Hi Pali,
if (plat->base)
Yes let's go with that.
Any idea?
See video_bmp_display() - I wonder if the particular depth you are using is not supported? Anyway you should be able to debug it there or using the bmp command. The file is drivers/video/u_boot_logo.bmp
Done, I sent final version of the patch.
> Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > is enabled in config file. I do not know why too. > > Any idea?
Depth is 16bit which should be supported.
CONFIG_CMD_BMP=y is broken too. When I enable it then U-Boot freeze after the line 'Loading Environment from <NULL>... OK'.
Hi Pali,
> > Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > > is enabled in config file. I do not know why too. > > > > Any idea? > > Not yet. There were some logo related changes recently, but if I > remember correctly, I tested them on wandboard and nitrogen6q > targets and with sandbox, and logo drawing worked there.
But apparently isn't , at least in this case :-)
OK I'm not sure why, but please investigate if you have time.
On Sunday 06 March 2022 11:44:22 Simon Glass wrote:
Hi Pali,
> > > Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > > > is enabled in config file. I do not know why too. > > > > > > Any idea? > > > > Not yet. There were some logo related changes recently, but if I > > remember correctly, I tested them on wandboard and nitrogen6q > > targets and with sandbox, and logo drawing worked there.
Yea, something is broken there.
I have looked at it and do not know. But probably it is because I somehow have not caught how this new video code works...
Anyway, I sent documentation update how to run u-boot for n900 in qemu: https://patchwork.ozlabs.org/project/uboot/patch/20220308175956.4522-1-pali@...
So it could help other people to look at issues which do not work correctly in n900's u-boot without need to have n900 hardware.
Hi Pali,
Hi Pali,
> > > > Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > > > > is enabled in config file. I do not know why too. > > > > > > > > Any idea? > > > > > > Not yet. There were some logo related changes recently, but if I > > > remember correctly, I tested them on wandboard and nitrogen6q > > > targets and with sandbox, and logo drawing worked there.
I've tested your v2 patches, and logo drawing works, but the logo appears for short time. Then it is later overwritten by boot menu.
-- Anatolij
On Wednesday 09 March 2022 23:20:11 Anatolij Gustschin wrote:
Hi Pali,
Hi Pali,
> > > > > Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > > > > > is enabled in config file. I do not know why too. > > > > > > > > > > Any idea? > > > > > > > > Not yet. There were some logo related changes recently, but if I > > > > remember correctly, I tested them on wandboard and nitrogen6q > > > > targets and with sandbox, and logo drawing worked there. > > Can you be more specific than 'broken'? What is broken about it?
-- Anatolij
Hello! Thank you for checking. It is possible that qemu rending is slower and reason why I did not see any logo.
Anyway, this is now how CONFIG_VIDEO_LOGO worked. In previous U-Boot version it drew logo on the screen and it was visible also in the boot menu.
Any idea what was changed? Or is there missing some another config option to make logo visible?
Hi Pali,
Hi Pali,
Hi Pali,
> > > > > > Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > > > > > > is enabled in config file. I do not know why too. > > > > > > > > > > > > Any idea? > > > > > > > > > > Not yet. There were some logo related changes recently, but if I > > > > > remember correctly, I tested them on wandboard and nitrogen6q > > > > > targets and with sandbox, and logo drawing worked there. > > > > Can you be more specific than 'broken'? What is broken about it? > > Does not work, logo is not drown on the screen.
-- Anatolij
I believe the cfb_console code had a way to keep the logo at the top with the text scrolling underneath. This has not been implemented in the video/vidconsole uclasses, although I suppose it could be.
On Friday 11 March 2022 22:02:39 Simon Glass wrote:
Hi Pali,
Hi Pali,
Hi Pali,
On Sunday 06 March 2022 07:42:03 Simon Glass wrote: > Yes let's go with that.
> > > > > > > Second thing is that CONFIG_VIDEO_LOGO is broken and does not work even it > > > > > > > is enabled in config file. I do not know why too. > > > > > > > > > > > > > > Any idea? > > > > > > > > > > > > Not yet. There were some logo related changes recently, but if I > > > > > > remember correctly, I tested them on wandboard and nitrogen6q > > > > > > targets and with sandbox, and logo drawing worked there. > > > > > > Can you be more specific than 'broken'? What is broken about it? > > > > Does not work, logo is not drown on the screen. > > See video_bmp_display() - I wonder if the particular depth you are > using is not supported?
> Anyway you should be able to debug it there or > using the bmp command. The file is drivers/video/u_boot_logo.bmp
-- Anatolij
Ok!
Mechanically convert video_hw_init() function to UCLASS_VIDEO probe callback and replace CONFIG_CFB_CONSOLE by CONFIG_DM_VIDEO.
As framebuffer base address is setup by the bootloader which loads U-Boot, set it into plat->base. And do not allocate framebuffer in video_post_bind function when base address is already specified.
This change was tested in qemu n900 machine and is working fine.
What does not work is CONFIG_VIDEO_LOGO, seems to be buggy.
Signed-off-by: Pali Rohár pali@kernel.org --- board/nokia/rx51/rx51.c | 40 +++++++++++++++++++++--------------- configs/nokia_rx51_defconfig | 7 +++++-- drivers/video/video-uclass.c | 3 +++ include/configs/nokia_rx51.h | 11 ++-------- 4 files changed, 34 insertions(+), 27 deletions(-)
diff --git a/board/nokia/rx51/rx51.c b/board/nokia/rx51/rx51.c index a52691509da4..621cff095619 100644 --- a/board/nokia/rx51/rx51.c +++ b/board/nokia/rx51/rx51.c @@ -30,7 +30,7 @@ #include <malloc.h> #include <twl4030.h> #include <i2c.h> -#include <video_fb.h> +#include <video.h> #include <keyboard.h> #include <asm/global_data.h> #include <asm/io.h> @@ -62,8 +62,6 @@ struct emu_hal_params_rx51 {
-GraphicDevice gdev; - const omap3_sysinfo sysinfo = { DDR_STACKED, "Nokia RX-51", @@ -342,22 +340,28 @@ void setup_board_tags(struct tag **in_params) *in_params = params; }
+U_BOOT_DRIVER(rx51_video) = { + .name = "rx51_video", + .id = UCLASS_VIDEO, + .probe = rx51_video_probe, +}; + /* * Routine: twl4030_regulator_set_mode * Description: Set twl4030 regulator mode over i2c powerbus. @@ -777,6 +781,10 @@ U_BOOT_DRVINFOS(rx51_watchdog) = { { "rx51_watchdog" }, };
+U_BOOT_DRVINFOS(rx51_video) = { + { "rx51_video" }, +}; + U_BOOT_DRVINFOS(rx51_kp) = { { "rx51_kp" }, }; diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 47b7bc3b4f03..1d64981afc46 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -77,8 +77,11 @@ CONFIG_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y -CONFIG_CFB_CONSOLE=y -CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_LOGO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP32 is not set +CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_SPLASH_SCREEN=y CONFIG_WATCHDOG_TIMEOUT_MSECS=31000 CONFIG_WDT=y diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 7d499bcec51d..c2f7d97e93e3 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -78,6 +78,9 @@ static ulong alloc_fb(struct udevice *dev, ulong *addrp) if (!plat->size) return 0;
+ if (plat->base) + return 0; + align = plat->align ? plat->align : 1 << 20; base = *addrp - plat->size; base &= ~(align - 1); diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 9be64c3d3f87..e837b12b568f 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -70,19 +70,12 @@
Hi Pali,
- Routine: video_hw_init
- Description: Set up the GraphicDevice depending on sys_boot.
How is this calculated?
More correctly this should be in the bind() method, but in fact I don't think it matters. We can always adjust it later if needed.
.id = UCLASS_VIDEO,
- Routine: twl4030_regulator_set_mode
- Description: Set twl4030 regulator mode over i2c powerbus.
{ "rx51_video" },
if (plat->base)
How about a comment there like:
/* Allow drivers to allocate the frame buffer themselves */
Please put this change in its own video: patch and update the comment at the top of video-uclass.c and the comment for @base in video.h so the next person can figure this out.
- Framebuffer
-- 2.20.1
I do not remember. This seems to be fixed address set by the code which loads U-Boot. I do not have any notes about this stuff.
Ok. I let it in probe, so all initialization is done at one place. If something is needed to adjust, it can be done later.
When plat->base is set by driver then skip frame buffer reservation and allocation.
Signed-off-by: Pali Rohár pali@kernel.org --- drivers/video/video-uclass.c | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 7d499bcec51d..88797d4a21c2 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -33,7 +33,8 @@ * information represents the requires size and alignment of the frame buffer * for the device. The values can be an over-estimate but cannot be too * small. The actual values will be suppled (in the same manner) by the bind() - * method after relocation. + * method after relocation. Additionally driver can allocate frame buffer + * itself by setting plat->base. * * This information is then picked up by video_reserve() which works out how * much memory is needed for all devices. This is allocated between @@ -78,6 +79,10 @@ static ulong alloc_fb(struct udevice *dev, ulong *addrp) if (!plat->size) return 0;
+ /* Allow drivers to allocate the frame buffer themselves */ + if (plat->base) + return 0; + align = plat->align ? plat->align : 1 << 20; base = *addrp - plat->size; base &= ~(align - 1);
As framebuffer base address is setup by the bootloader which loads U-Boot, set plat->base to that fixed framebuffer address.
Signed-off-by: Pali Rohár pali@kernel.org --- board/nokia/rx51/rx51.c | 40 +++++++++++++++++++++--------------- configs/nokia_rx51_defconfig | 7 +++++-- include/configs/nokia_rx51.h | 11 ++-------- 3 files changed, 31 insertions(+), 27 deletions(-)
+U_BOOT_DRVINFOS(rx51_video) = { + { "rx51_video" }, +}; + U_BOOT_DRVINFOS(rx51_kp) = { { "rx51_kp" }, }; diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index 47b7bc3b4f03..1d64981afc46 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -77,8 +77,11 @@ CONFIG_SPI=y CONFIG_USB=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y -CONFIG_CFB_CONSOLE=y -CONFIG_CFB_CONSOLE_ANSI=y +CONFIG_DM_VIDEO=y +CONFIG_VIDEO_LOGO=y +# CONFIG_VIDEO_BPP8 is not set +# CONFIG_VIDEO_BPP32 is not set +CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_SPLASH_SCREEN=y CONFIG_WATCHDOG_TIMEOUT_MSECS=31000 CONFIG_WDT=y diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 9be64c3d3f87..e837b12b568f 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -70,19 +70,12 @@
On Wed, 9 Mar 2022 20:46:01 +0100 Pali Rohár pali@kernel.org wrote: ...
applied to u-boot-video/master, thanks!
-- Anatolij
-- Anatolij
Anatolij Gustschin
Pali Rohár
