[GIT PULL] rpi: updates for v2024.04
Hi Tom,
Here come a small set of patches for v2024.04 for the RaspberryPi. It adds basic support for RPi5 to be able to boot on a SD card.
You can find the passing tests here: https://source.denx.de/u-boot/custodians/u-boot-raspberrypi/-/pipelines/1951...
It's the same commit ID as the tag, although it's not the same test-run.
Regards, Matthias
--- The following changes since commit 6faba41927bdc8973b59678649ef83c564cc421e:
Prepare v2024.04-rc1 (2024-01-29 20:53:19 -0500)
https://source.denx.de/u-boot/custodians/u-boot-raspberrypi.git tags/rpi-next-2024.04
for you to fetch changes up to 12d479d01849c164020e17c3ae921f974b96372d:
configs: rpi_arm64: build position independent code (2024-01-30 17:40:13 +0100)
---------------------------------------------------------------- Add RaspberryPi5 basic support.
---------------------------------------------------------------- Dmitry Malkin (2): rpi5: add initial memory map for bcm2712 rpi5: Use devicetree as alternative way to read IO base addresses
Ivan T. Ivanov (5): rpi5: Use devicetree to retrieve board revision bcm2835: Dynamically calculate bytes per pixel parameter mmc: bcmstb: Add support for bcm2712 SD controller configs: rpi_arm64: enable SDHCI BCMSTB driver configs: rpi_arm64: build position independent code
arch/arm/mach-bcm283x/include/mach/base.h | 5 +- arch/arm/mach-bcm283x/include/mach/mbox.h | 3 +- arch/arm/mach-bcm283x/include/mach/sdhci.h | 3 +- arch/arm/mach-bcm283x/include/mach/timer.h | 3 +- arch/arm/mach-bcm283x/include/mach/wdog.h | 3 +- arch/arm/mach-bcm283x/init.c | 74 ++++++++++++++++++++++++++---- board/raspberrypi/rpi/rpi.c | 22 +++++++-- configs/rpi_arm64_defconfig | 3 +- drivers/mmc/bcmstb_sdhci.c | 64 ++++++++++++++++++++++++-- drivers/video/bcm2835.c | 18 +++++++- 10 files changed, 171 insertions(+), 27 deletions(-)
On Wed, 31 Jan 2024 at 17:00, Matthias Brugger mbrugger@suse.com wrote:
Hi Tom,
Regards, Matthias
Acked-by: Peter Robinson pbrobinson@gmail.com
Hi Tom,
Regards, Matthias
Matthias Brugger
Peter Robinson
