[U-Boot] [PATCH] pinctrl: imx: fix memory leak
Each time set_state is called, a new piece memory will be allocated for pin_data, but not freed, this will incur memory leak.
When error, the devm API could not free memory automatically. So need call devm_kfree when error.
Issue reported by Coverity
Signed-off-by: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Agner stefan.agner@toradex.com Cc: Stefano Babic sbabic@denx.de --- drivers/pinctrl/nxp/pinctrl-imx.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/pinctrl/nxp/pinctrl-imx.c b/drivers/pinctrl/nxp/pinctrl-imx.c index f0321c4..31a28e1 100644 --- a/drivers/pinctrl/nxp/pinctrl-imx.c +++ b/drivers/pinctrl/nxp/pinctrl-imx.c @@ -53,6 +53,7 @@ static int imx_pinctrl_set_state(struct udevice *dev, struct udevice *config) if (fdtdec_get_int_array(gd->fdt_blob, node, "fsl,pins", pin_data, size >> 2)) { dev_err(dev, "Error reading pin data.\n"); + devm_kfree(pin_data); return -EINVAL; }
@@ -78,6 +79,7 @@ static int imx_pinctrl_set_state(struct udevice *dev, struct udevice *config)
if ((mux_reg == -1) || (conf_reg == -1)) { dev_err(dev, "Error mux_reg or conf_reg\n"); + devm_kfree(pin_data); return -EINVAL; }
@@ -166,6 +168,8 @@ static int imx_pinctrl_set_state(struct udevice *dev, struct udevice *config) } }
+ devm_kfree(pin_data); + return 0; }
we need to specify the pointer from where to free?
thanks!
-----Original Message----- From: Jagan Teki [mailto:jagannadh.teki@gmail.com] Sent: Thursday, May 11, 2017 5:18 PM To: Peng Fan peng.fan@nxp.com Cc: Simon Glass sjg@chromium.org; u-boot@lists.denx.de; Stefan Agner stefan.agner@toradex.com Subject: Re: [U-Boot] [PATCH] pinctrl: imx: fix memory leak
Oh. Missed to add dev pointer here.
Thanks, Peng.
thanks!
Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
Jagan Teki
Peng Fan
