[U-Boot] Pull request: u-boot-riscv/master
Hi Tom,
Please pull some riscv updates:
- Skip unavailable hart in the get_count(). - fu540 set serial env from otp. - fu540 add mmc0 as a boot target device. - Update fix_rela_dyn and add absolute reloc addend. - Andestech PLIC driver will skip unavailable hart. - Support Andestech V5L2 cache driver.
https://travis-ci.org/rickchen36/u-boot-riscv/builds/579707002
Thanks Rick
The following changes since commit d22c8be964a870f59d2fdab6c67cefa0c4799364:
Merge branch 'master' of git://git.denx.de/u-boot-sh (2019-09-01 13:33:12 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to 61ce84b2cf1a6672c8e402ce8174554b25629692:
riscv: cache: use CCTL to flush d-cache (2019-09-03 09:31:03 +0800)
---------------------------------------------------------------- Alistair Francis (1): sifive-fu540: config: Add mmc0 as a boot target device
Bin Meng (1): riscv: cpu: Skip unavailable hart in the get_count() op
Marcus Comstedt (2): riscv: tools: Handle addend to absolute reloc in prelink-riscv riscv: update fix_rela_dyn
Rick Chen (9): riscv: andes_plic: init plic by scanning each cpu node dm: cache: Add enable and disable ops for cache uclass dm: cache: Add enable and disable ops for sandbox and test dm: cache: add v5l2 cache controller driver riscv: ae350: use the v5l2 driver to configure the cache riscv: ax25: add imply v5l2 cache controller riscv: cache: Flush L2 cache before jump to linux riscv: dts: move out AE350 L2 node from cpus node riscv: cache: use CCTL to flush d-cache
Sagar Shrikant Kadam (1): riscv: sifive: fu540: set serial environment variable from otp
arch/riscv/cpu/ax25/Kconfig | 1 + arch/riscv/cpu/ax25/cache.c | 39 +++++++++++++++++------ arch/riscv/cpu/start.S | 10 +++--- arch/riscv/dts/ae350_32.dts | 17 ++++++---- arch/riscv/dts/ae350_64.dts | 17 ++++++---- arch/riscv/lib/andes_plic.c | 36 ++++++++++++++------- board/AndesTech/ax25-ae350/ax25-ae350.c | 9 ++++++ board/sifive/fu540/fu540.c | 18 ++++++++--- drivers/cache/Kconfig | 9 ++++++ drivers/cache/Makefile | 1 + drivers/cache/cache-uclass.c | 20 ++++++++++++ drivers/cache/cache-v5l2.c | 186 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/cache/sandbox_cache.c | 13 ++++++++ drivers/cpu/riscv_cpu.c | 4 +++ include/cache.h | 31 +++++++++++++++++++ include/configs/sifive-fu540.h | 1 + test/dm/cache.c | 2 ++ tools/prelink-riscv.inc | 8 +++-- 18 files changed, 379 insertions(+), 43 deletions(-) create mode 100644 drivers/cache/cache-v5l2.c
On Tue, Sep 03, 2019 at 10:15:42AM +0800, uboot@andestech.com wrote:
Hi Tom,
Thanks Rick
uboot@andestech.com
