[U-Boot] [GIT PULL] u-boot-uniphier/master
Hi Tom,
Please pull UniPhier updates.
Thanks!
The following changes since commit f88b6facb87dc4a52f1630eb9d858c0f54c6628e:
Prepare v2018.09 (2018-09-10 17:46:42 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to e39eed8f476b6f8861318fc122b546158edce259:
ARM: uniphier: remove ad-hoc clock enabling for EHCI (2018-09-11 20:37:19 +0900)
---------------------------------------------------------------- Masahiro Yamada (5): ARM: dts: uniphier: sync DT with Linux 4.19-rc1 ARM: uniphier: increase CONFIG_SYS_MONITOR_LEN again ARM: uniphier: enable CONFIG_CMD_UBI mmc: uniphier-sd: sync with Linux ARM: uniphier: remove ad-hoc clock enabling for EHCI
arch/arm/dts/uniphier-ld11-global.dts | 3 ++- arch/arm/dts/uniphier-ld11.dtsi | 2 +- arch/arm/dts/uniphier-ld20-global.dts | 3 ++- arch/arm/dts/uniphier-ld20.dtsi | 6 ++++-- arch/arm/dts/uniphier-ld4.dtsi | 17 ++++++++--------- arch/arm/dts/uniphier-pinctrl.dtsi | 12 +----------- arch/arm/dts/uniphier-pro4-ref.dts | 4 ---- arch/arm/dts/uniphier-pro4.dtsi | 26 +++++++++++--------------- arch/arm/dts/uniphier-pro5.dtsi | 15 +++++++-------- arch/arm/dts/uniphier-pxs2.dtsi | 18 ++++++++++-------- arch/arm/dts/uniphier-pxs3.dtsi | 10 +++++++--- arch/arm/dts/uniphier-sld8.dtsi | 17 ++++++++--------- arch/arm/mach-uniphier/clk/clk-ld11.c | 6 ------ arch/arm/mach-uniphier/clk/clk-ld4.c | 3 --- arch/arm/mach-uniphier/clk/clk-pro4.c | 3 --- arch/arm/mach-uniphier/sc-regs.h | 3 --- configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_v7_defconfig | 1 + drivers/mmc/uniphier-sd.c | 4 +++- include/configs/uniphier.h | 4 ++-- 20 files changed, 68 insertions(+), 90 deletions(-)
On Tue, Sep 11, 2018 at 08:44:41PM +0900, Masahiro Yamada wrote:
Hi Tom,
Thanks!
Masahiro Yamada
