The following changes since commit 1f4ae66eaab29bfb5d1eb44996f7826c9cd01ed1:
Merge tag 'arc-for-2019.07' of git://git.denx.de/u-boot-arc (2019-04-18 12:12:16 -0400)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 7fd9f31c6bd13609da61b985cf8f5f65ebebd913:
usb: dwc2: fix gadget disconnect (2019-04-21 10:26:52 +0200)
---------------------------------------------------------------- Alex Kiernan (3): configs: Migrate USB_MUSB_DISABLE_BULK_COMBINE_SPLIT to Kconfig usb: Select USB_MUSB_DSPS with USB_MUSB_TI fastboot: Replace literal 32 with PART_NAME_LEN
Andy Shevchenko (1): dfu: Avoid declaring unused variables and absent parameters
Eugeniu Rosca (3): fastboot: getvar: correct/rename "has_slot" to "has-slot" fastboot: Improve error reporting on 'getvar partition-{size, type}' fastboot: add support for 'getvar platform'
Fabrice Gasnier (1): usb: dwc2: fix gadget disconnect
Patrice Chotard (1): usb: dwc2_udc_otg: Add tx_fifo_sz array support
Patrick Delaunay (16): phy: usbphyc: remove unused variable index phy: usbphyc: update xlate with DT binding phy: usbphyc: Binding update of vdda supply phy: usbphyc: move vdda1v1 and vdda1v8 in phy_init phy: usbphyc: increase PLL wait timeout usb: dwc2: remove unused variable regs_otg usb: dwc2: convert driver to DM_USB_GADGET usb: dwc2: force reset assert before to probe the driver usb: dwc2: Add force-b-session-valid support usb: dwc2: Add function for session B check usb: dwc2_udc_otg: Read MAX_HW_ENDPOINT from HWCFG4 register usb: dwc2: add support for STM32MP1 stm32mp1: remove CONFIG_USB_DWC2, HOST support for USBO stm32mp1: migrate USBOTG device to driver model stm32mp1: add stusb1600 support for DK1 and DK2 board usb: reload watchdog during ums command
arch/arm/dts/stm32mp157-pinctrl.dtsi | 7 +++ arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 3 +- arch/arm/dts/stm32mp157a-dk1.dts | 34 +++++++++++- arch/arm/dts/stm32mp157c-ed1.dts | 8 --- arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 1 + arch/arm/dts/stm32mp157c.dtsi | 5 +- board/st/stm32mp1/stm32mp1.c | 185 ++++++++++++++++++----------------------------------------------- cmd/dfu.c | 3 ++ cmd/usb_mass_storage.c | 3 ++ configs/am335x_boneblack_vboot_defconfig | 1 - configs/am335x_evm_defconfig | 1 - configs/am335x_hs_evm_defconfig | 1 - configs/am335x_hs_evm_uart_defconfig | 1 - configs/brppt1_mmc_defconfig | 1 - configs/brppt1_nand_defconfig | 1 - configs/brppt1_spi_defconfig | 1 - configs/chiliboard_defconfig | 1 - configs/stm32mp15_basic_defconfig | 2 +- configs/stm32mp15_trusted_defconfig | 2 +- doc/device-tree-bindings/phy/phy-stm32-usbphyc.txt | 4 +- doc/device-tree-bindings/usb/dwc2.txt | 58 +++++++++++++++++++++ drivers/fastboot/fb_getvar.c | 16 +++++- drivers/fastboot/fb_mmc.c | 10 ++-- drivers/phy/phy-stm32-usbphyc.c | 111 ++++++++++++++++++++------------------- drivers/usb/gadget/dwc2_udc_otg.c | 388 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++--- drivers/usb/gadget/dwc2_udc_otg_priv.h | 1 - drivers/usb/gadget/dwc2_udc_otg_regs.h | 37 ++++++++++--- drivers/usb/gadget/dwc2_udc_otg_xfer_dma.c | 14 ++++- drivers/usb/musb-new/Kconfig | 10 ++++ include/configs/am335x_evm.h | 1 - include/configs/baltos.h | 1 - include/configs/bav335x.h | 1 - include/configs/brppt1.h | 3 -- include/configs/brxre1.h | 3 -- include/configs/chiliboard.h | 1 - include/configs/pengwyn.h | 1 - include/configs/siemens-am33x-common.h | 2 - include/usb/dwc2_udc.h | 7 +++ scripts/config_whitelist.txt | 1 - 39 files changed, 680 insertions(+), 251 deletions(-) create mode 100644 doc/device-tree-bindings/usb/dwc2.txt
