[U-Boot] [PATCH] ppc4xx: Enable PCIe support without PCI support on PPC440/460
By not defining CONFIG_SYS_PCI_MASTER_INIT and CONFIG_SYS_PCI_TARGET_INIT, PCI support (host and adapter) will not be enabled. But it's still possible to use the U-Boot PCI infrastructure for the PCIe ports.
This configuration option is needed for a new 460GT board, which uses PCIe but has PCI disabled.
Signed-off-by: Stefan Roese sr@denx.de --- arch/powerpc/cpu/ppc4xx/4xx_pci.c | 12 +++++++++++- 1 files changed, 11 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/ppc4xx/4xx_pci.c b/arch/powerpc/cpu/ppc4xx/4xx_pci.c index eed4534..bfba952 100644 --- a/arch/powerpc/cpu/ppc4xx/4xx_pci.c +++ b/arch/powerpc/cpu/ppc4xx/4xx_pci.c @@ -476,7 +476,9 @@ void pci_init_board(void) *-----------------------------------------------------------------------------*/ #if defined(CONFIG_440)
+#if defined(CONFIG_SYS_PCI_MASTER_INIT) || defined(CONFIG_SYS_PCI_TARGET_INIT) static struct pci_controller ppc440_hose = {0}; +#endif
/* * This routine is called to determine if a pci scan should be @@ -704,6 +706,7 @@ void pci_master_init(struct pci_controller *hose) __attribute__((weak, alias("__pci_master_init"))); #endif /* CONFIG_SYS_PCI_MASTER_INIT */
+#if defined(CONFIG_SYS_PCI_MASTER_INIT) || defined(CONFIG_SYS_PCI_TARGET_INIT) int pci_440_init (struct pci_controller *hose) { int reg_num = 0; @@ -845,12 +848,19 @@ int pci_440_init (struct pci_controller *hose) } return hose->last_busno; } +#endif
void pci_init_board(void) { - int busno; + int busno = 0;
+ /* + * Only init PCI when either master or target functionality + * is selected. + */ +#if defined(CONFIG_SYS_PCI_MASTER_INIT) || defined(CONFIG_SYS_PCI_TARGET_INIT) busno = pci_440_init (&ppc440_hose); +#endif #if (defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT)) && \ !defined(CONFIG_PCI_DISABLE_PCIE)
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
