[PATCH 0/4] Add New Devices for RGxx3
This patch series is to clean up a few issues found with the RGxx3, add support for a new device, and add a board specific ADC button check routine to the SPL stage. The ADC button routine was part of a previous patch series that was partially accepted, though making the ADC button routine board generic was rejected by the Rockchip maintainer.
Chris Morgan (4): arm: dts: rockchip: rk3566: Remove unnecessary clks from rgxx3 board: rockchip: Add support for Powkiddy RGB10MAX3 configs: Remove unnecessary options from RGxx3 config board: rockchip: Add early ADC button detect for RGxx3
.../arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 31 -------- arch/arm/dts/rk3566-anbernic-rgxx3.dts | 16 ++++- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 72 +++++++++++++++++++ configs/anbernic-rgxx3-rk3566_defconfig | 15 ++-- doc/board/anbernic/rgxx3.rst | 1 + 5 files changed, 97 insertions(+), 38 deletions(-)
Remove unnecessary clock frequency defines from the RGxx3 u-boot dts. Move the necessary defines to the RGxx3 main dts file.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- .../arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi | 31 ------------------- arch/arm/dts/rk3566-anbernic-rgxx3.dts | 7 +++++ 2 files changed, 7 insertions(+), 31 deletions(-)
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi index f986e1941e..ef4f81500b 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi +++ b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi @@ -15,37 +15,6 @@ }; };
-&cru { - assigned-clocks = - <&pmucru CLK_RTC_32K>, - <&pmucru PLL_PPLL>, - <&pmucru PCLK_PMU>, <&cru PLL_CPLL>, - <&cru PLL_GPLL>, - <&cru ACLK_BUS>, <&cru PCLK_BUS>, - <&cru ACLK_TOP_HIGH>, <&cru ACLK_TOP_LOW>, - <&cru HCLK_TOP>, <&cru PCLK_TOP>, - <&cru ACLK_PERIMID>, <&cru HCLK_PERIMID>, - <&cru CPLL_500M>, <&cru CPLL_333M>, - <&cru CPLL_250M>, <&cru CPLL_125M>, - <&cru CPLL_100M>, <&cru CPLL_62P5M>, - <&cru CPLL_50M>, <&cru CPLL_25M>; - assigned-clock-rates = - <32768>, - <200000000>, - <100000000>, <1000000000>, - <1188000000>, - <150000000>, <100000000>, - <500000000>, <400000000>, - <150000000>, <100000000>, - <300000000>, <150000000>, - <500000000>, <333333333>, - <250000000>, <125000000>, - <100000000>, <62500000>, - <50000000>, <25000000>; - assigned-clock-parents = - <&pmucru CLK_RTC32K_FRAC>; -}; - &dsi_dphy0 { status = "okay"; }; diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dts b/arch/arm/dts/rk3566-anbernic-rgxx3.dts index 404dddfafb..9e0aa9e63b 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3.dts +++ b/arch/arm/dts/rk3566-anbernic-rgxx3.dts @@ -16,3 +16,10 @@ "anbernic,rg353v", "anbernic,rg353vs", "anbernic,rg503", "rockchip,rk3566"; }; + +&cru { + assigned-clocks = <&pmucru CLK_RTC_32K>, <&cru PLL_GPLL>, + <&pmucru PLL_PPLL>, <&cru PLL_VPLL>; + assigned-clock-rates = <32768>, <1200000000>, + <200000000>, <241500000>; +};
Hi Chris,
First of all, the dts should follow the one in mainline kernel;
and why you need to over write the cru in U-Boot for this board, I didn't see this change
in other boards.
Thanks,
- Kever
-&cru {
- assigned-clocks =
<&pmucru PLL_PPLL>,
<&cru PLL_GPLL>,
<32768>,
<200000000>,
<1188000000>,
+&cru {
- assigned-clocks = <&pmucru CLK_RTC_32K>, <&cru PLL_GPLL>,
- assigned-clock-rates = <32768>, <1200000000>,
On Tue, Feb 06, 2024 at 10:38:40AM +0800, Kever Yang wrote:
Hi Chris,
in other boards.
This is kind of a special case, because these devices are so similar they can all use the same bootloader. So as a result I have all 11 of them (and counting) pretending to be a "pseudo" device in U-Boot called the RGxx3. The only reason I'm setting the clock here is to set the PLL_VPLL value to something so I can start addressing the DSI panel. This way, I'm able to probe it and send a panel ID request. The problem is the manufacturer (Anbernic) has 2 versions of devices with no distinguishing characteristics.
The specific ask here though is to simplify the clock definition. When mainlining a different device (the Powkiddy X55) I was asked to not define so many clocks, especially if they weren't like that in mainline. It turns out this device also does not need so many definitions, so this specific patch is to undo them and make it more simple.
Let me know if you have any other questions. Thank you. Chris
Thanks,
- Kever
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi index f986e1941e..ef4f81500b 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi +++ b/arch/arm/dts/rk3566-anbernic-rgxx3-u-boot.dtsi @@ -15,37 +15,6 @@ }; }; -&cru {
- assigned-clocks =
<&pmucru PLL_PPLL>,
<&cru PLL_GPLL>,
<32768>,
<200000000>,
<1188000000>,
+&cru {
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
-&cru {
- assigned-clocks =
<&pmucru PLL_PPLL>,
<&cru PLL_GPLL>,
<32768>,
<200000000>,
<1188000000>,
+&cru {
Add support to the RGxx3 device for the Powkiddy RGB10MAX3. This device is extremely similar to all the other devices and can use the same bootloader with the same detection logic.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- arch/arm/dts/rk3566-anbernic-rgxx3.dts | 9 ++++++--- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 8 ++++++++ doc/board/anbernic/rgxx3.rst | 1 + 3 files changed, 15 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dts b/arch/arm/dts/rk3566-anbernic-rgxx3.dts index 9e0aa9e63b..c393c8d07a 100644 --- a/arch/arm/dts/rk3566-anbernic-rgxx3.dts +++ b/arch/arm/dts/rk3566-anbernic-rgxx3.dts @@ -12,9 +12,12 @@ * set the correct dtb name for loading mainline Linux automatically. */ model = "RGXX3"; - compatible = "anbernic,rg353m", "anbernic,rg353p", - "anbernic,rg353v", "anbernic,rg353vs", - "anbernic,rg503", "rockchip,rk3566"; + compatible = "anbernic,rg-arc-d", "anbernic,rg-arc-s", + "anbernic,rg353m", "anbernic,rg353p", + "anbernic,rg353ps", "anbernic,rg353v", + "anbernic,rg353vs", "anbernic,rg503", + "powkiddy,rgb10max3", "powkiddy,rgb30", + "powkiddy,rk2023", "rockchip,rk3566"; };
&cru { diff --git a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c index d05502f67a..5c57b902d1 100644 --- a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c +++ b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c @@ -50,6 +50,7 @@ enum rgxx3_device_id { RGB30, RK2023, RGARCD, + RGB10MAX3, /* Devices with duplicate ADC value */ RG353PS, RG353VS, @@ -107,6 +108,13 @@ static const struct rg3xx_model rg3xx_model_details[] = { .fdtfile = DTB_DIR "rk3566-anbernic-rg-arc-d.dtb", .detect_panel = 0, }, + [RGB10MAX3] = { + .adc_value = 765, /* Observed average from device */ + .board = "rk3566-powkiddy-rgb10max3", + .board_name = "Powkiddy RGB10MAX3", + .fdtfile = DTB_DIR "rk3566-powkiddy-rgb10max3.dtb", + .detect_panel = 0, + }, /* Devices with duplicate ADC value */ [RG353PS] = { .adc_value = 860, /* Observed average from device */ diff --git a/doc/board/anbernic/rgxx3.rst b/doc/board/anbernic/rgxx3.rst index d159ed2f76..1e63e6951e 100644 --- a/doc/board/anbernic/rgxx3.rst +++ b/doc/board/anbernic/rgxx3.rst @@ -17,6 +17,7 @@ This allows U-Boot to boot the following Anbernic devices: Additionally, the following very similar non-Anbernic devices are also supported:
+ - Powkiddy RGB10MAX3 - Powkiddy RGB30 - Powkiddy RK2023
Thanks, - Kever
- set the correct dtb name for loading mainline Linux automatically.
*/ model = "RGXX3";
&cru {
- RGB10MAX3, /* Devices with duplicate ADC value */ RG353PS, RG353VS,
- [RGB10MAX3] = {
.detect_panel = 0,
- }, /* Devices with duplicate ADC value */ [RG353PS] = { .adc_value = 860, /* Observed average from device */
- Powkiddy RGB30
- Powkiddy RK2023
Based on feedback from the mailing list while adding support for a new device (the Powkiddy X55), correct the config options for the RGxx3 as well to remove unnecessary drivers and increase the SPL stack size.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- configs/anbernic-rgxx3-rk3566_defconfig | 15 +++++++++++---- 1 file changed, 11 insertions(+), 4 deletions(-)
diff --git a/configs/anbernic-rgxx3-rk3566_defconfig b/configs/anbernic-rgxx3-rk3566_defconfig index ed6643d9d4..d52a0d48f2 100644 --- a/configs/anbernic-rgxx3-rk3566_defconfig +++ b/configs/anbernic-rgxx3-rk3566_defconfig @@ -3,6 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 @@ -24,7 +25,9 @@ CONFIG_SYS_LOAD_ADDR=0xc00800 CONFIG_DEBUG_UART=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-anbernic-rgxx3.dtb" @@ -32,7 +35,7 @@ CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-anbernic-rgxx3.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_BOARD_RNG_SEED=y -CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_MAX_SIZE=0x40000 CONFIG_SPL_PAD_TO=0x7f8000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x4000000 @@ -41,6 +44,7 @@ CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_STACK_R=y +CONFIG_SPL_POWER=y CONFIG_SPL_ATF=y CONFIG_CMD_PWM=y CONFIG_CMD_GPT=y @@ -50,8 +54,10 @@ CONFIG_CMD_MMC=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_NET is not set +CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPL_REGMAP=y CONFIG_SPL_SYSCON=y CONFIG_SPL_CLK=y @@ -67,13 +73,13 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_DSIDPHY=y +CONFIG_SPL_PINCTRL=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_FAN53555=y CONFIG_PMIC_RK8XX=y -CONFIG_REGULATOR_PWM=y -CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y -CONFIG_DM_REGULATOR_SCMI=y CONFIG_PWM_ROCKCHIP=y CONFIG_SPL_RAM=y # CONFIG_RAM_ROCKCHIP_DEBUG is not set @@ -89,5 +95,6 @@ CONFIG_VIDEO_ROCKCHIP=y CONFIG_DISPLAY_ROCKCHIP_DW_MIPI=y CONFIG_VIDEO_BRIDGE=y CONFIG_REGEX=y +# CONFIG_RSA is not set CONFIG_ERRNO_STR=y # CONFIG_EFI_LOADER is not set
Thanks, - Kever
Add ADC button detect for early SPL stage for RGxx3 device. This is important because on at least the RG353P and RG353V a clk pin is not exposed that would allow us to take the eMMC out of the boot path.
Signed-off-by: Chris Morgan macromorgan@hotmail.com --- board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c | 64 ++++++++++++++++++++++ 1 file changed, 64 insertions(+)
diff --git a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c index 5c57b902d1..099eea60c3 100644 --- a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c +++ b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c @@ -6,12 +6,14 @@ #include <abuf.h> #include <adc.h> #include <asm/io.h> +#include <command.h> #include <display.h> #include <dm.h> #include <dm/lists.h> #include <env.h> #include <fdt_support.h> #include <linux/delay.h> +#include <linux/iopoll.h> #include <mipi_dsi.h> #include <mmc.h> #include <panel.h> @@ -19,6 +21,8 @@ #include <stdlib.h> #include <video_bridge.h>
+#define BOOT_BROM_DOWNLOAD 0xef08a53c + #define GPIO0_BASE 0xfdd60000 #define GPIO4_BASE 0xfe770000 #define GPIO_SWPORT_DR_L 0x0000 @@ -32,6 +36,14 @@
#define GPIO_WRITEMASK(bits) ((bits) << 16)
+#define SARADC_BASE 0xfe720000 +#define SARADC_DATA 0x0000 +#define SARADC_STAS 0x0004 +#define SARADC_ADC_STATUS BIT(0) +#define SARADC_CTRL 0x0008 +#define SARADC_INPUT_SRC_MSK 0x7 +#define SARADC_POWER_CTRL BIT(3) + #define DTB_DIR "rockchip/"
struct rg3xx_model { @@ -157,12 +169,64 @@ static const struct rg353_panel rg353_panel_details[] = { }, };
+/* + * The device has internal eMMC, and while some devices have an exposed + * clk pin you can ground to force a bypass not all devices do. As a + * result it may be possible for some devices to become a perma-brick + * if a corrupted TPL or SPL stage with a valid header is flashed to + * the internal eMMC. Add functionality to read ADC channel 0 (the func + * button) as early as possible in the boot process to provide some + * protection against this. If we ever get an open TPL stage, we should + * consider moving this function there. + */ +void read_func_button(void) +{ + int ret; + u32 reg; + + /* Turn off SARADC to reset it. */ + writel(0, (SARADC_BASE + SARADC_CTRL)); + + /* Enable channel 0 and power on SARADC. */ + writel(((0 & SARADC_INPUT_SRC_MSK) | SARADC_POWER_CTRL), + (SARADC_BASE + SARADC_CTRL)); + + /* + * Wait for data to be ready. Use timeout of 20000us from + * rockchip_saradc driver. + */ + ret = readl_poll_timeout((SARADC_BASE + SARADC_STAS), reg, + !(reg & SARADC_ADC_STATUS), 20000); + if (ret) { + printf("ADC Timeout"); + return; + } + + /* Read the data from the SARADC. */ + reg = readl((SARADC_BASE + SARADC_DATA)); + + /* Turn the SARADC back off so it's ready to be used again. */ + writel(0, (SARADC_BASE + SARADC_CTRL)); + + /* + * If the value is less than 30 the button is being pressed. + * Reset the device back into Rockchip download mode. + */ + if (reg <= 30) { + printf("download key pressed, entering download mode..."); + writel(BOOT_BROM_DOWNLOAD, CONFIG_ROCKCHIP_BOOT_MODE_REG); + do_reset(NULL, 0, 0, NULL); + } +}; + /* * Start LED very early so user knows device is on. Set color * to red. */ void spl_board_init(void) { + read_func_button(); + /* Set GPIO0_C5, GPIO0_C6, and GPIO0_C7 to output. */ writel(GPIO_WRITEMASK(GPIO_C7 | GPIO_C6 | GPIO_C5) | \ (GPIO_C7 | GPIO_C6 | GPIO_C5),
This is another version of below patch, right?
https://patchwork.ozlabs.org/project/uboot/patch/20240102154654.191055-5-mac...
Compare to this one, I would prefer previous version :(
Thanks,
- Kever
- #define GPIO0_BASE 0xfdd60000 #define GPIO4_BASE 0xfe770000 #define GPIO_SWPORT_DR_L 0x0000
@@ -32,6 +36,14 @@
- The device has internal eMMC, and while some devices have an exposed
- clk pin you can ground to force a bypass not all devices do. As a
- result it may be possible for some devices to become a perma-brick
- if a corrupted TPL or SPL stage with a valid header is flashed to
- the internal eMMC. Add functionality to read ADC channel 0 (the func
- button) as early as possible in the boot process to provide some
- protection against this. If we ever get an open TPL stage, we should
- consider moving this function there.
- int ret;
- u32 reg;
- /* Turn off SARADC to reset it. */
- writel(0, (SARADC_BASE + SARADC_CTRL));
- /* Enable channel 0 and power on SARADC. */
- writel(((0 & SARADC_INPUT_SRC_MSK) | SARADC_POWER_CTRL),
- ret = readl_poll_timeout((SARADC_BASE + SARADC_STAS), reg,
- if (ret) {
return;
- /* Read the data from the SARADC. */
- reg = readl((SARADC_BASE + SARADC_DATA));
- /* Turn the SARADC back off so it's ready to be used again. */
- if (reg <= 30) {
- Start LED very early so user knows device is on. Set color
- to red.
- read_func_button();
- /* Set GPIO0_C5, GPIO0_C6, and GPIO0_C7 to output. */ writel(GPIO_WRITEMASK(GPIO_C7 | GPIO_C6 | GPIO_C5) | \ (GPIO_C7 | GPIO_C6 | GPIO_C5),
It is another version of the patch. I did (redid) this in response to comments on that patch series.
I basically face a unique set of constraints, and am trying to solve for it. Those constraints are 1) I have a few boards, namely the Anbernic RG353P and RG353V that do not have exposed pads that would allow me to remove the eMMC from the boot path, 2) The SDMMC slot present is after the eMMC in the boot path, and 3) after the binary A-TF loads the reset to usb loader fails to work properly and simply resets the board (but not to maskrom as needed/requested).
Your past comments suggested it would not be needed/useful to have this done in a board generic way, which I understand; so I'm simply doing it again in a board specific way. Note that I will shortly be resubmitting another U-Boot request for the Powkiddy X55 which also needs this; I'm not aware of any other boards currently that will though.
So I guess my questions that would answer the path forward are 1) should this be done in a board specific way (like so) or should I go back to the board generic method. 2) Will the binary A-TF be fixed to allow me to reboot to maskrom mode or is that by design?
Note I've tested this also with the pending A-TF source at trustedfirmware.org. Sadly I need SCMI clk support before I can replace the binary A-TF with the open source one.
Thank you, Chris
Thanks,
- Kever
diff --git a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c index 5c57b902d1..099eea60c3 100644 --- a/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c +++ b/board/anbernic/rgxx3_rk3566/rgxx3-rk3566.c @@ -6,12 +6,14 @@ #include <abuf.h> #include <adc.h> #include <asm/io.h> +#include <command.h> #include <display.h> #include <dm.h> #include <dm/lists.h> #include <env.h> #include <fdt_support.h> #include <linux/delay.h> +#include <linux/iopoll.h> #include <mipi_dsi.h> #include <mmc.h> #include <panel.h> @@ -19,6 +21,8 @@ #include <stdlib.h> #include <video_bridge.h> +#define BOOT_BROM_DOWNLOAD 0xef08a53c
@@ -32,6 +36,14 @@ #define GPIO_WRITEMASK(bits) ((bits) << 16) +#define SARADC_BASE 0xfe720000 +#define SARADC_DATA 0x0000 +#define SARADC_STAS 0x0004 +#define SARADC_ADC_STATUS BIT(0) +#define SARADC_CTRL 0x0008 +#define SARADC_INPUT_SRC_MSK 0x7 +#define SARADC_POWER_CTRL BIT(3)
- #define DTB_DIR "rockchip/" struct rg3xx_model {
@@ -157,12 +169,64 @@ static const struct rg353_panel rg353_panel_details[] = { }, }; +/*
- int ret;
- u32 reg;
- if (ret) {
return;
- if (reg <= 30) {
- to red.
Thanks, - Kever
@@ -32,6 +36,14 @@
- int ret;
- u32 reg;
- if (ret) {
return;
- if (reg <= 30) {
- to red.
Chris Morgan
Chris Morgan
Kever Yang
