[U-Boot] [PATCH v2 1/1] avb2.0: add get_size_of_partition()
Implement get_size_of_partition() operation, which is required by the latest upstream libavb [1].
[1] https://android.googlesource.com/platform/external/avb/+/master/README.md
Signed-off-by: Igor Opaniuk igor.opaniuk@linaro.org ---
Changes for v2: - changed the return code for the case when out_size_num_bytes is NULL (s/AVB_IO_RESULT_ERROR_IO/AVB_IO_RESULT_ERROR_INSUFFICIENT_SPACE/g)
common/avb_verify.c | 33 ++++++++++++++++++++++++++++++++- 1 file changed, 32 insertions(+), 1 deletion(-)
diff --git a/common/avb_verify.c b/common/avb_verify.c index f9a00f8..ab5f9aa 100644 --- a/common/avb_verify.c +++ b/common/avb_verify.c @@ -699,6 +699,37 @@ static AvbIOResult get_unique_guid_for_partition(AvbOps *ops, }
/** + * get_size_of_partition() - gets the size of a partition identified + * by a string name + * + * @ops: contains AVB ops handlers + * @partition: partition name (NUL-terminated UTF-8 string) + * @out_size_num_bytes: returns the value of a partition size + * + * @return: + * AVB_IO_RESULT_OK, on success (GUID found) + * AVB_IO_RESULT_ERROR_IO, out_size_num_bytes is NULL + * AVB_IO_RESULT_ERROR_NO_SUCH_PARTITION, if partition was not found + */ +static AvbIOResult get_size_of_partition(AvbOps *ops, + const char *partition, + u64 *out_size_num_bytes) +{ + struct mmc_part *part; + + if (!out_size_num_bytes) + return AVB_IO_RESULT_ERROR_INSUFFICIENT_SPACE; + + part = get_partition(ops, partition); + if (!part) + return AVB_IO_RESULT_ERROR_NO_SUCH_PARTITION; + + *out_size_num_bytes = part->info.blksz * part->info.size; + + return AVB_IO_RESULT_OK; +} + +/** * ============================================================================ * AVB2.0 AvbOps alloc/initialisation/free * ============================================================================ @@ -721,7 +752,7 @@ AvbOps *avb_ops_alloc(int boot_device) ops_data->ops.read_is_device_unlocked = read_is_device_unlocked; ops_data->ops.get_unique_guid_for_partition = get_unique_guid_for_partition; - + ops_data->ops.get_size_of_partition = get_size_of_partition; ops_data->mmc_dev = boot_device;
return &ops_data->ops;
Changes for v2:
- get_size_of_partition() - gets the size of a partition identified
- by a string name
- @ops: contains AVB ops handlers
- @partition: partition name (NUL-terminated UTF-8 string)
- @out_size_num_bytes: returns the value of a partition size
- @return:
This needs updated, other than that,
Acked-by: Andrew F. Davis afd@ti.com
- struct mmc_part *part;
- if (!out_size_num_bytes)
- part = get_partition(ops, partition);
- if (!part)
- *out_size_num_bytes = part->info.blksz * part->info.size;
- return AVB_IO_RESULT_OK;
- AVB2.0 AvbOps alloc/initialisation/free
FWIW, any living repository is a moving target, so there is nothing more volatile than the "latest" state of such repository. Kind request to use specific revision/commit next time. Thank you.
Best regards, Eugeniu.
Andrew F. Davis
Eugeniu Rosca
Igor Opaniuk
