Re: [U-Boot] [PATCH v2 4/9] mmc: reworked version lookup in mmc_startup_v4
Hi Heribert,
you're right I messed up with the indexes. Thanks for catching it.
Next time you find something, please reply to all. It will help the maintainer, in this case Jaehoon.
Jaheoon,
The problem is that a version is missing in the table mmc_versions[] and it results in a shift of the indexes for all versions above or equal to MMC_VERSION_4_41.
I'll send a patch that fixes it this way:
static const u32 mmc_versions[] = { MMC_VERSION_4, MMC_VERSION_4_1, MMC_VERSION_4_2, MMC_VERSION_4_3,
+ MMC_VERSION_4_4,
MMC_VERSION_4_41, MMC_VERSION_4_5, MMC_VERSION_5_0, MMC_VERSION_5_1 };
JJ
On 09/02/2018 08:06, eil Eilmsteiner Heribert wrote:
Hello Jean-Jacques
I have problems with your patch for u-boot. I lacks a table-entry for "4", so every mmc higher than version 4.3 report a version "off by 1" The range check is also "off by 1", (it should be a >=), so (as in my case) MMC version 5.1 reports OK and complete nonsense (in my case this was lower than version 4.0 so it didn't work).
if (ext_csd[EXT_CSD_REV] >= ARRAY_SIZE(mmc_versions)) return -EINVAL;
Freundliche Grüße/Best regards Heribert Eilmsteiner Senior Software Engineer Development Center
KEBA AG A-4041 Linz, Austria Gewerbepark Urfahr Phone: +43 732 7090-27423 Fax: +43 732 7090-61711 Firmenbuchgericht Linz FN 184376 t mailto:eil@keba.com http://www.keba.com
On 02/09/2018 07:00 PM, Jean-Jacques Hiblot wrote:
Hi Heribert,
Jaheoon,
If you send a patch, then i will apply it.
Best Regards, Jaehoon Chung
+ MMC_VERSION_4_4,
JJ
Hello Jean-Jacques
Jaehoon Chung
Jean-Jacques Hiblot
