[U-Boot] [Patch V6 0/4] QSPI bug fixing patches
This patchset is mainly related with Freescale QSPI and tested on LS1043AQDS board.
The version 6 patchset has fixes to: - Use min() to simplify the code in QSPI driver.
[Patch V6 1/4] spi: fsl_qspi: fix compile warning for 64-bit platform [Patch V6 2/4] spi: fsl_qspi: Fix qspi_op_rdid memcpy issue [Patch V6 3/4] spi: fsl_qspi: Fix qspi_op_rdsr memcpy issue [Patch V6 4/4] dm: env_sf: fix saveenv() to use driver model
Regards, Qianyu
This patch fixes the following compile warning: drivers/spi/fsl_qspi.c: In function 'fsl_qspi_probe': drivers/spi/fsl_qspi.c:937:15: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] priv->regs = (struct fsl_qspi_regs *)plat->reg_base; ^ Just make the cast explicit.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - Use uintptr_t instead of unsigned long. V4: - Revise the commit message. V2-V3: - No change.
drivers/spi/fsl_qspi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 542b6cf..38e5900 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -936,7 +936,7 @@ static int fsl_qspi_probe(struct udevice *bus)
dm_spi_bus->max_hz = plat->speed_hz;
- priv->regs = (struct fsl_qspi_regs *)plat->reg_base; + priv->regs = (struct fsl_qspi_regs *)(uintptr_t)plat->reg_base; priv->flags = plat->flags;
priv->speed_hz = plat->speed_hz;
In current driver everytime we memcpy 4 bytes to the dest memory regardless of the remaining length. This patch adds checking the remaining length before memcpy. If the length is shorter than 4 bytes, memcpy the actual length of data to the dest memory.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - Use min() to simplify code. V2-V5: - No change.
drivers/spi/fsl_qspi.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 38e5900..3fe80d3 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -500,7 +500,7 @@ static void qspi_op_rdid(struct fsl_qspi_priv *priv, u32 *rxbuf, u32 len) if (rbsr_reg & QSPI_RBSR_RDBFL_MASK) { data = qspi_read32(priv->flags, ®s->rbdr[i]); data = qspi_endian_xchg(data); - memcpy(rxbuf, &data, 4); + memcpy(rxbuf, &data, min(size, 4)); rxbuf++; size -= 4; i++;
In current driver, we always copy 4 bytes to the dest memory. Actually the dest memory may be shorter than 4 bytes. Add an argument to indicate the dest memory length. Avoid writing memory outside of the bounds.
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V3-V6: - No change. V2: - New patch.
drivers/spi/fsl_qspi.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 3fe80d3..1cee1d7 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -639,7 +639,7 @@ static void qspi_op_write(struct fsl_qspi_priv *priv, u8 *txbuf, u32 len) qspi_write32(priv->flags, ®s->mcr, mcr_reg); }
-static void qspi_op_rdsr(struct fsl_qspi_priv *priv, u32 *rxbuf) +static void qspi_op_rdsr(struct fsl_qspi_priv *priv, void *rxbuf, u32 len) { struct fsl_qspi_regs *regs = priv->regs; u32 mcr_reg, reg, data; @@ -662,7 +662,7 @@ static void qspi_op_rdsr(struct fsl_qspi_priv *priv, u32 *rxbuf) if (reg & QSPI_RBSR_RDBFL_MASK) { data = qspi_read32(priv->flags, ®s->rbdr[0]); data = qspi_endian_xchg(data); - memcpy(rxbuf, &data, 4); + memcpy(rxbuf, &data, len); qspi_write32(priv->flags, ®s->mcr, qspi_read32(priv->flags, ®s->mcr) | QSPI_MCR_CLR_RXF_MASK); @@ -751,7 +751,7 @@ int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, } else if (priv->cur_seqid == QSPI_CMD_RDID) qspi_op_rdid(priv, din, bytes); else if (priv->cur_seqid == QSPI_CMD_RDSR) - qspi_op_rdsr(priv, din); + qspi_op_rdsr(priv, din, bytes); #ifdef CONFIG_SPI_FLASH_BAR else if ((priv->cur_seqid == QSPI_CMD_BRRD) || (priv->cur_seqid == QSPI_CMD_RDEAR)) {
It might be missed when converting spi_flash_probe() in cmd_sf.c.
This patch refers to commit fbb099183e3a ("dm: Convert spi_flash_probe() and 'sf probe' to use driver model").
Signed-off-by: Gong Qianyu Qianyu.Gong@freescale.com --- V6: - No change. V5: - Revise commit message. V4: - Use CONFIG_ENV_* instead of CONFIG_SF_*. - Remove the variables and call the macros directly. - Use set_default_env instead of print info. V3: - Remove redundant operations for saveenv() V2: - New patch.
common/env_sf.c | 29 +++++++++++++++++++++++++++++ 1 file changed, 29 insertions(+)
diff --git a/common/env_sf.c b/common/env_sf.c index 9409831..892e6cb 100644 --- a/common/env_sf.c +++ b/common/env_sf.c @@ -16,6 +16,7 @@ #include <spi_flash.h> #include <search.h> #include <errno.h> +#include <dm/device-internal.h>
#ifndef CONFIG_ENV_SPI_BUS # define CONFIG_ENV_SPI_BUS 0 @@ -51,6 +52,19 @@ int saveenv(void) char *saved_buffer = NULL, flag = OBSOLETE_FLAG; u32 saved_size, saved_offset, sector = 1; int ret; +#ifdef CONFIG_DM_SPI_FLASH + struct udevice *new; + + ret = spi_flash_probe_bus_cs(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, + CONFIG_ENV_SPI_MODE, &new); + if (ret) { + set_default_env("!spi_flash_probe_bus_cs() failed"); + return 1; + } + + env_flash = dev_get_uclass_priv(new); +#else
if (!env_flash) { env_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, @@ -61,6 +75,7 @@ int saveenv(void) return 1; } } +#endif
ret = env_export(&env_new); if (ret) @@ -227,6 +242,19 @@ int saveenv(void) char *saved_buffer = NULL; int ret = 1; env_t env_new; +#ifdef CONFIG_DM_SPI_FLASH + struct udevice *new; + + ret = spi_flash_probe_bus_cs(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, + CONFIG_ENV_SPI_MODE, &new); + if (ret) { + set_default_env("!spi_flash_probe_bus_cs() failed"); + return 1; + } + + env_flash = dev_get_uclass_priv(new); +#else
if (!env_flash) { env_flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, @@ -237,6 +265,7 @@ int saveenv(void) return 1; } } +#endif
/* Is the sector larger than the env (i.e. embedded) */ if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) {
Gong Qianyu
