[PATCH] efi: test/py: repair authenticated capsules tests
The UEFI console initialisation has been modified by commit 68edbed454b8 ("efi_loader: initialize console size late"). A corresponding workaround is now necessary for the automated tests, as added to some of the tests already by commit e05bd68ed5fc ("test: work around for EFI terminal size probing").
Add the same workaround to the UEFI authenticated capsules tests to repair them.
This can be tested with sandbox_defconfig, sandbox64_defconfig or sandbox_flattree_defconfig, plus CONFIG_EFI_CAPSULE_AUTHENTICATE=y.
Signed-off-by: Vincent Stehlé vincent.stehle@arm.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de --- .../tests/test_efi_capsule/test_capsule_firmware_signed_fit.py | 3 +++ .../tests/test_efi_capsule/test_capsule_firmware_signed_raw.py | 2 ++ 2 files changed, 5 insertions(+)
diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py index 4400b8f1368..d6ca9b16745 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py @@ -40,6 +40,7 @@ class TestEfiCapsuleFirmwareSignedFit(object): with u_boot_console.log.section('Test Case 1-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, + 'printenv -e PlatformLangCodes', # workaround for terminal size determination 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', @@ -115,6 +116,7 @@ class TestEfiCapsuleFirmwareSignedFit(object): with u_boot_console.log.section('Test Case 2-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, + 'printenv -e PlatformLangCodes', # workaround for terminal size determination 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', @@ -192,6 +194,7 @@ class TestEfiCapsuleFirmwareSignedFit(object): with u_boot_console.log.section('Test Case 3-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, + 'printenv -e PlatformLangCodes', # workaround for terminal size determination 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py index 1b5a1bb42eb..2bbaa9cc55f 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_raw.py @@ -112,6 +112,7 @@ class TestEfiCapsuleFirmwareSignedRaw(object): with u_boot_console.log.section('Test Case 2-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, + 'printenv -e PlatformLangCodes', # workaround for terminal size determination 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004', @@ -189,6 +190,7 @@ class TestEfiCapsuleFirmwareSignedRaw(object): with u_boot_console.log.section('Test Case 3-a, before reboot'): output = u_boot_console.run_command_list([ 'host bind 0 %s' % disk_img, + 'printenv -e PlatformLangCodes', # workaround for terminal size determination 'efidebug boot add -b 1 TEST host 0:1 /helloworld.efi', 'efidebug boot order 1', 'env set -e -nv -bs -rt OsIndications =0x0000000000000004',
Why are these tests not run in Gitlab? Can't we permanently adjust one of said defconfigs for this purpose? Or do we need a new defconfig for testing?
Best regards
Heinrich
Heinrich,
Because we cannot turn on or off capsule authentication dynamically on a single U-Boot image, we cannot test non-signed test cases and signed test cases simultaneously in CI.
That is why I proposed a new config file for sandbox with EFI_CAPSULE_AUTHENTICATE, but the idea was rejected (if I remember correctly, by Simon).
That said, I also made a small change to unsigned test cases (test_efi_capsule_firmware(_*).py) so that they can *pass* even with EFI_CAPSULE_AUTHENTICATE enabled. (As you can image, however, actual capsule update never happens in this test environment.)
commit e012550cd7d6 ("test/py: efi_capsule: check the results in case of CAPSULE_AUTHENTICATE")
-Takahiro Akashi
Best regards
Heinrich
On 6/28/22 07:14, AKASHI Takahiro wrote:
Heinrich,
-Takahiro Akashi
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
AKASHI Takahiro
Vincent Stehlé
