[PATCH v2 00/12] stm32: add new board support, defconfig and documentation
Add new stm32746g-eval board support Add defconfig for SPL and none SPL mode for STM32F7 boards. Add documentation on how to build and flash STM32 MCUs.
Changes in v2: - fix documentation file stm32_MCU.rst
Patrice Chotard (12): configs: stm32f746-disco: Concatenate spl and u-boot binaries configs: stm32f746-disco: Rename stm32f746-disco_defconfig to stm32f746-disco_spl_defconfig configs: stm32f746-disco: Add stm32f746-disco_defconfig configs: stm32f769-disco: Rename stm32f769-disco_defconfig to stm32f769-disco_spl_defconfig configs: stm32f769-disco: Add stm32f769-disco_defconfig configs: stm32f769-disco: Migrate SPL flags to defconfig configs: stm32f746-disco: Migrate SPL flags to defconfig board: stm32f746-disco: Fix dram_init() in none SPL config configs: stm32f746-disco: use CONFIG_DEFAULT_DEVICE_TREE as fdtfile configs: stm32746g-eval: Add stm32746g-eval_defconfig configs: stm32746g-eval: Add stm32746g-eval_spl_defconfig doc: Add documentation for STM32 MCUs
arch/arm/mach-stm32/Kconfig | 20 --- board/st/stm32f429-discovery/MAINTAINERS | 1 + board/st/stm32f429-evaluation/MAINTAINERS | 1 + board/st/stm32f469-discovery/MAINTAINERS | 1 + board/st/stm32f746-disco/MAINTAINERS | 5 + board/st/stm32f746-disco/stm32f746-disco.c | 2 +- board/st/stm32h743-disco/MAINTAINERS | 1 + board/st/stm32h743-eval/MAINTAINERS | 1 + board/st/stm32h750-art-pi/MAINTAINERS | 1 + configs/stm32746g-eval_defconfig | 64 +++++++ configs/stm32746g-eval_spl_defconfig | 86 ++++++++++ configs/stm32f746-disco_defconfig | 9 +- configs/stm32f746-disco_spl_defconfig | 86 ++++++++++ configs/stm32f769-disco_defconfig | 9 +- configs/stm32f769-disco_spl_defconfig | 87 ++++++++++ doc/board/st/index.rst | 1 + doc/board/st/stm32_MCU.rst | 186 +++++++++++++++++++++ include/configs/stm32f746-disco.h | 3 +- 18 files changed, 528 insertions(+), 36 deletions(-) create mode 100644 configs/stm32746g-eval_defconfig create mode 100644 configs/stm32746g-eval_spl_defconfig create mode 100644 configs/stm32f746-disco_spl_defconfig create mode 100644 configs/stm32f769-disco_spl_defconfig create mode 100644 doc/board/st/stm32_MCU.rst
This allows to concatenate spl and u-boot binaries together. Previously, both binaries has to be flashed separately at the correct offset (spl at offset 0 and u-boot at offset 0x8000). With this patch, only one binary is generated (u-boot-with-spl.bin) and has to be copied in flash at offset 0 using openocd for example or simply copied in exported mass storage.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
(no changes since v1)
configs/stm32f746-disco_defconfig | 1 + include/configs/stm32f746-disco.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 130b90fae3..0133867942 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="stm32f746-disco" CONFIG_SPL_TEXT_BASE=0x8000000 CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_BUILD_TARGET="u-boot-with-spl.bin" CONFIG_SYS_LOAD_ADDR=0x8008000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 8ad4bb99c8..b93acdcc1f 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -49,6 +49,7 @@ #define CONFIG_SYS_UBOOT_START 0x080083FD #define CONFIG_SYS_UBOOT_BASE (CONFIG_SYS_FLASH_BASE + \ CONFIG_SYS_SPL_LEN) +#define CONFIG_SPL_PAD_TO 0x8000
/* DT blob (fdt) address */ #define CONFIG_SYS_FDT_BASE (CONFIG_SYS_FLASH_BASE + \
Applied to u-boot-stm32
Thanks Patrice
The current stm32f746-disco_defconfig file supports SPL, rename it to stm32f746-disco_spl_defconfig to reflect the supported configuration.
board/st/stm32f746-disco/MAINTAINERS | 1 + .../{stm32f746-disco_defconfig => stm32f746-disco_spl_defconfig} | 0 2 files changed, 1 insertion(+) rename configs/{stm32f746-disco_defconfig => stm32f746-disco_spl_defconfig} (100%)
diff --git a/board/st/stm32f746-disco/MAINTAINERS b/board/st/stm32f746-disco/MAINTAINERS index 3bbb513ad7..06d366e8a2 100644 --- a/board/st/stm32f746-disco/MAINTAINERS +++ b/board/st/stm32f746-disco/MAINTAINERS @@ -4,4 +4,5 @@ S: Maintained F: board/st/stm32f746-disco F: include/configs/stm32f746-disco.h F: configs/stm32f746-disco_defconfig +F: configs/stm32f746-disco_spl_defconfig F: configs/stm32f769-disco_defconfig diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_spl_defconfig similarity index 100% rename from configs/stm32f746-disco_defconfig rename to configs/stm32f746-disco_spl_defconfig
Thanks Patrice
Add stm32f746-disco_defconfig for stm32f746 discovery board to build U-Boot proper.
configs/stm32f746-disco_defconfig | 64 +++++++++++++++++++++++++++++++ 1 file changed, 64 insertions(+) create mode 100644 configs/stm32f746-disco_defconfig
diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig new file mode 100644 index 0000000000..2c70bac9cd --- /dev/null +++ b/configs/stm32f746-disco_defconfig @@ -0,0 +1,64 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32=y +CONFIG_SYS_TEXT_BASE=0x08000000 +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="stm32f746-disco" +CONFIG_STM32F7=y +CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_BOOTDELAY=3 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_LATE_INIT=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_STM32_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_SMSC=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MII=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_MAX_XRES=480 +CONFIG_VIDEO_STM32_MAX_YRES=640 +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y
Thanks Patrice
The current stm32f769-disco_defconfig file supports SPL, rename it to stm32f769-disco_spl_defconfig to reflect the supported configuration.
board/st/stm32f746-disco/MAINTAINERS | 1 + .../{stm32f769-disco_defconfig => stm32f769-disco_spl_defconfig} | 0 2 files changed, 1 insertion(+) rename configs/{stm32f769-disco_defconfig => stm32f769-disco_spl_defconfig} (100%)
diff --git a/board/st/stm32f746-disco/MAINTAINERS b/board/st/stm32f746-disco/MAINTAINERS index 06d366e8a2..68f61fd5ff 100644 --- a/board/st/stm32f746-disco/MAINTAINERS +++ b/board/st/stm32f746-disco/MAINTAINERS @@ -6,3 +6,4 @@ F: include/configs/stm32f746-disco.h F: configs/stm32f746-disco_defconfig F: configs/stm32f746-disco_spl_defconfig F: configs/stm32f769-disco_defconfig +F: configs/stm32f769-disco_spl_defconfig diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_spl_defconfig similarity index 100% rename from configs/stm32f769-disco_defconfig rename to configs/stm32f769-disco_spl_defconfig
Thanks Patrice
Add stm32f769-disco_defconfig for stm32f769 discovery board to build U-Boot proper.
configs/stm32f769-disco_defconfig | 65 +++++++++++++++++++++++++++++++ 1 file changed, 65 insertions(+) create mode 100644 configs/stm32f769-disco_defconfig
diff --git a/configs/stm32f769-disco_defconfig b/configs/stm32f769-disco_defconfig new file mode 100644 index 0000000000..3c112882cc --- /dev/null +++ b/configs/stm32f769-disco_defconfig @@ -0,0 +1,65 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32=y +CONFIG_SYS_TEXT_BASE=0x08000000 +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="stm32f769-disco" +CONFIG_STM32F7=y +CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_BOOTDELAY=3 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_STM32_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_SMSC=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MII=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_DSI=y +CONFIG_VIDEO_STM32_MAX_XRES=480 +CONFIG_VIDEO_STM32_MAX_YRES=800 +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y
Thanks Patrice
Migrate SPL flags to stm32f769-disco_spl_defconfig
configs/stm32f769-disco_spl_defconfig | 25 +++++++++++++++++++++---- 1 file changed, 21 insertions(+), 4 deletions(-)
diff --git a/configs/stm32f769-disco_spl_defconfig b/configs/stm32f769-disco_spl_defconfig index f151dab04f..672c1ec065 100644 --- a/configs/stm32f769-disco_spl_defconfig +++ b/configs/stm32f769-disco_spl_defconfig @@ -3,12 +3,19 @@ CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08008000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="stm32f769-disco" CONFIG_SPL_TEXT_BASE=0x8000000 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_SPL=y +CONFIG_BUILD_TARGET="u-boot-with-spl.bin" CONFIG_SYS_LOAD_ADDR=0x8008000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=3 @@ -18,6 +25,11 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_XIP_SUPPORT=y +CONFIG_SPL_DM_RESET=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CMD_GPT=y # CONFIG_RANDOM_UUID is not set @@ -29,15 +41,16 @@ CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y -# CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y -# CONFIG_SPL_BLK is not set -# CONFIG_SPL_DM_MMC is not set +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_SPL_CLK=y CONFIG_ARM_PL180_MMCI=y CONFIG_MTD=y CONFIG_DM_MTD=y @@ -51,9 +64,13 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y # CONFIG_PINCTRL_FULL is not set +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_RAM=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y +CONFIG_SPL_TIMER=y CONFIG_DM_VIDEO=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y
Thanks Patrice
Migrate SPL flags to stm32f746-disco_spl_defconfig
arch/arm/mach-stm32/Kconfig | 20 -------------------- configs/stm32f746-disco_spl_defconfig | 24 ++++++++++++++++++++---- 2 files changed, 20 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-stm32/Kconfig b/arch/arm/mach-stm32/Kconfig index a439dbd10f..a44ebf2597 100644 --- a/arch/arm/mach-stm32/Kconfig +++ b/arch/arm/mach-stm32/Kconfig @@ -25,26 +25,6 @@ config STM32F7 select PINCTRL select PINCTRL_STM32 select RAM - select SPL - select SPL_BOARD_INIT - select SPL_CLK - select SPL_DM - select SPL_DM_RESET - select SPL_DM_SEQ_ALIAS - select SPL_DRIVERS_MISC - select SPL_GPIO - select SPL_LIBCOMMON_SUPPORT - select SPL_LIBGENERIC_SUPPORT - select SPL_MTD_SUPPORT - select SPL_OF_CONTROL - select SPL_OF_LIBFDT - select SPL_OF_TRANSLATE - select SPL_PINCTRL - select SPL_RAM - select SPL_SERIAL - select SPL_SYS_MALLOC_SIMPLE - select SPL_TIMER - select SPL_XIP_SUPPORT select STM32_RCC select STM32_RESET select STM32_SDRAM diff --git a/configs/stm32f746-disco_spl_defconfig b/configs/stm32f746-disco_spl_defconfig index 0133867942..9fef65fa7b 100644 --- a/configs/stm32f746-disco_spl_defconfig +++ b/configs/stm32f746-disco_spl_defconfig @@ -3,12 +3,18 @@ CONFIG_ARCH_STM32=y CONFIG_SYS_TEXT_BASE=0x08008000 CONFIG_SYS_MALLOC_LEN=0x100000 CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="stm32f746-disco" CONFIG_SPL_TEXT_BASE=0x8000000 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_SPL=y CONFIG_BUILD_TARGET="u-boot-with-spl.bin" CONFIG_SYS_LOAD_ADDR=0x8008000 CONFIG_DISTRO_DEFAULTS=y @@ -20,6 +26,11 @@ CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_XIP_SUPPORT=y +CONFIG_SPL_DM_RESET=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_CMD_GPT=y # CONFIG_RANDOM_UUID is not set @@ -31,15 +42,16 @@ CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIMER=y -# CONFIG_SPL_DOS_PARTITION is not set # CONFIG_ISO_PARTITION is not set -# CONFIG_SPL_EFI_PARTITION is not set CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y -# CONFIG_SPL_BLK is not set -# CONFIG_SPL_DM_MMC is not set +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_SPL_CLK=y CONFIG_ARM_PL180_MMCI=y CONFIG_MTD=y CONFIG_DM_MTD=y @@ -53,9 +65,13 @@ CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_MII=y # CONFIG_PINCTRL_FULL is not set +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_RAM=y +CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y +CONFIG_SPL_TIMER=y CONFIG_DM_VIDEO=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_STM32=y
- select SPL
- select SPL_CLK
- select SPL_DM
- select SPL_GPIO
- select SPL_RAM
- select SPL_SERIAL
- select SPL_TIMER
Thanks Patrice
Replace CONFIG_SUPPORT_SPL by CONFIG_SPL_BUILD to allow dram_init() execution when using none SPL defconfig (stm32f746-disco_defconfig).
board/st/stm32f746-disco/stm32f746-disco.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index 69f657c54b..2ab23f2f4f 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -29,7 +29,7 @@ DECLARE_GLOBAL_DATA_PTR;
int dram_init(void) { -#ifndef CONFIG_SUPPORT_SPL +#ifndef CONFIG_SPL_BUILD int rv; struct udevice *dev; rv = uclass_get_device(UCLASS_RAM, 0, &dev);
Thanks Patrice
As stm32f46-disco, stm32f769-disco and stm32746g-eval are very similar except their respective device tree file. These 3 boards uses the same TARGET_STM32F746_DISCO flag (so same include/configs/stm32f746-disco.h and same board file board/st/stm32f746-disco/stm32f746-disco.c)
To be able to compile these 3 boards, replace the hard-coded device-tree name in include/configs/stm32f746-disco.h by CONFIG_DEFAULT_DEVICE_TREE which is set in each board defconfig file with the correct value.
include/configs/stm32f746-disco.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index b93acdcc1f..cc3d4b4449 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -34,7 +34,7 @@ #include <config_distro_bootcmd.h> #define CONFIG_EXTRA_ENV_SETTINGS \ "kernel_addr_r=0xC0008000\0" \ - "fdtfile=stm32f746-disco.dtb\0" \ + "fdtfile="CONFIG_DEFAULT_DEVICE_TREE".dtb\0" \ "fdt_addr_r=0xC0408000\0" \ "scriptaddr=0xC0418000\0" \ "pxefile_addr_r=0xC0428000\0" \
Thanks Patrice
Add stm32746g-eval_defconfig for stm32746g evaluation board to build U-Boot proper.
Full board description can be found here : https://www.st.com/en/evaluation-tools/stm32746g-eval.html
board/st/stm32f746-disco/MAINTAINERS | 1 + configs/stm32746g-eval_defconfig | 64 ++++++++++++++++++++++++++++ 2 files changed, 65 insertions(+) create mode 100644 configs/stm32746g-eval_defconfig
diff --git a/board/st/stm32f746-disco/MAINTAINERS b/board/st/stm32f746-disco/MAINTAINERS index 68f61fd5ff..7f128a8b69 100644 --- a/board/st/stm32f746-disco/MAINTAINERS +++ b/board/st/stm32f746-disco/MAINTAINERS @@ -5,5 +5,6 @@ F: board/st/stm32f746-disco F: include/configs/stm32f746-disco.h F: configs/stm32f746-disco_defconfig F: configs/stm32f746-disco_spl_defconfig +F: configs/stm32746g-eval_defconfig F: configs/stm32f769-disco_defconfig F: configs/stm32f769-disco_spl_defconfig diff --git a/configs/stm32746g-eval_defconfig b/configs/stm32746g-eval_defconfig new file mode 100644 index 0000000000..9f79b5a2b4 --- /dev/null +++ b/configs/stm32746g-eval_defconfig @@ -0,0 +1,64 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32=y +CONFIG_SYS_TEXT_BASE=0x08000000 +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="stm32746g-eval" +CONFIG_STM32F7=y +CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_BOOTDELAY=3 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_LATE_INIT=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_STM32_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_SMSC=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MII=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_MAX_XRES=480 +CONFIG_VIDEO_STM32_MAX_YRES=640 +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y
Thanks Patrice
Add stm32746g-eval_spl_defconfig for stm32746g evaluation board to build SPL.
board/st/stm32f746-disco/MAINTAINERS | 1 + configs/stm32746g-eval_spl_defconfig | 86 ++++++++++++++++++++++++++++ 2 files changed, 87 insertions(+) create mode 100644 configs/stm32746g-eval_spl_defconfig
diff --git a/board/st/stm32f746-disco/MAINTAINERS b/board/st/stm32f746-disco/MAINTAINERS index 7f128a8b69..bc0952c563 100644 --- a/board/st/stm32f746-disco/MAINTAINERS +++ b/board/st/stm32f746-disco/MAINTAINERS @@ -6,5 +6,6 @@ F: include/configs/stm32f746-disco.h F: configs/stm32f746-disco_defconfig F: configs/stm32f746-disco_spl_defconfig F: configs/stm32746g-eval_defconfig +F: configs/stm32746g-eval_spl_defconfig F: configs/stm32f769-disco_defconfig F: configs/stm32f769-disco_spl_defconfig diff --git a/configs/stm32746g-eval_spl_defconfig b/configs/stm32746g-eval_spl_defconfig new file mode 100644 index 0000000000..169a9c5b23 --- /dev/null +++ b/configs/stm32746g-eval_spl_defconfig @@ -0,0 +1,86 @@ +CONFIG_ARM=y +CONFIG_ARCH_STM32=y +CONFIG_SYS_TEXT_BASE=0x08008000 +CONFIG_SYS_MALLOC_LEN=0x100000 +CONFIG_SYS_MALLOC_F_LEN=0xE00 +CONFIG_SPL_GPIO=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="stm32746g-eval" +CONFIG_SPL_TEXT_BASE=0x8000000 +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_STM32F7=y +CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_SPL=y +CONFIG_BUILD_TARGET="u-boot-with-spl.bin" +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x8008000 +CONFIG_BOOTDELAY=3 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 earlyprintk consoleblank=0 ignore_loglevel" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_MTD_SUPPORT=y +CONFIG_SPL_XIP_SUPPORT=y +CONFIG_SPL_DM_RESET=y +CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y +CONFIG_CMD_BMP=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIMER=y +# CONFIG_ISO_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_NETCONSOLE=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_SPL_CLK=y +CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y +CONFIG_DM_MTD=y +CONFIG_MTD_NOR_FLASH=y +CONFIG_STM32_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHY_SMSC=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_MII=y +# CONFIG_PINCTRL_FULL is not set +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_RAM=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y +CONFIG_SPL_TIMER=y +CONFIG_DM_VIDEO=y +CONFIG_BACKLIGHT_GPIO=y +CONFIG_VIDEO_STM32=y +CONFIG_VIDEO_STM32_MAX_XRES=480 +CONFIG_VIDEO_STM32_MAX_YRES=640 +CONFIG_SPLASH_SCREEN=y +CONFIG_SPLASH_SCREEN_ALIGN=y +CONFIG_VIDEO_BMP_RLE8=y +CONFIG_BMP_16BPP=y +CONFIG_BMP_24BPP=y +CONFIG_BMP_32BPP=y +CONFIG_OF_LIBFDT_OVERLAY=y
Thanks Patrice
Add documentation for STM32 MCUs (F4, F7 and H7 series).
board/st/stm32f429-discovery/MAINTAINERS | 1 + board/st/stm32f429-evaluation/MAINTAINERS | 1 + board/st/stm32f469-discovery/MAINTAINERS | 1 + board/st/stm32f746-disco/MAINTAINERS | 1 + board/st/stm32h743-disco/MAINTAINERS | 1 + board/st/stm32h743-eval/MAINTAINERS | 1 + board/st/stm32h750-art-pi/MAINTAINERS | 1 + doc/board/st/index.rst | 1 + doc/board/st/stm32_MCU.rst | 186 ++++++++++++++++++++++ 9 files changed, 194 insertions(+) create mode 100644 doc/board/st/stm32_MCU.rst
diff --git a/board/st/stm32f429-discovery/MAINTAINERS b/board/st/stm32f429-discovery/MAINTAINERS index fdb62e98e8..7661a15fdd 100644 --- a/board/st/stm32f429-discovery/MAINTAINERS +++ b/board/st/stm32f429-discovery/MAINTAINERS @@ -1,6 +1,7 @@ STM32F429-DISCOVERY BOARD M: Kamil Lulko kamil.lulko@gmail.com S: Maintained +F: doc/board/st/ F: board/st/stm32f429-discovery/ F: include/configs/stm32f429-discovery.h F: configs/stm32f429-discovery_defconfig diff --git a/board/st/stm32f429-evaluation/MAINTAINERS b/board/st/stm32f429-evaluation/MAINTAINERS index 29d00ef27e..b272893ef7 100644 --- a/board/st/stm32f429-evaluation/MAINTAINERS +++ b/board/st/stm32f429-evaluation/MAINTAINERS @@ -1,6 +1,7 @@ STM32F429-EVALUATION BOARD M: Patrice Chotard patrice.chotard@foss.st.com S: Maintained +F: doc/board/st/ F: board/st/stm32f429-evaluation/ F: include/configs/stm32f429-evaluation.h F: configs/stm32f429-evaluation_defconfig diff --git a/board/st/stm32f469-discovery/MAINTAINERS b/board/st/stm32f469-discovery/MAINTAINERS index 5a6a78b39e..a95f93f6f6 100644 --- a/board/st/stm32f469-discovery/MAINTAINERS +++ b/board/st/stm32f469-discovery/MAINTAINERS @@ -1,6 +1,7 @@ STM32F469-DISCOVERY BOARD M: Patrice Chotard patrice.chotard@foss.st.com S: Maintained +F: doc/board/st/ F: board/st/stm32f469-discovery/ F: include/configs/stm32f469-discovery.h F: configs/stm32f469-discovery_defconfig diff --git a/board/st/stm32f746-disco/MAINTAINERS b/board/st/stm32f746-disco/MAINTAINERS index bc0952c563..18e4c99c4f 100644 --- a/board/st/stm32f746-disco/MAINTAINERS +++ b/board/st/stm32f746-disco/MAINTAINERS @@ -1,6 +1,7 @@ STM32F746 DISCOVERY BOARD M: Vikas Manocha vikas.manocha@st.com S: Maintained +F: doc/board/st/ F: board/st/stm32f746-disco F: include/configs/stm32f746-disco.h F: configs/stm32f746-disco_defconfig diff --git a/board/st/stm32h743-disco/MAINTAINERS b/board/st/stm32h743-disco/MAINTAINERS index 60fbe344f8..f4ecef3aa5 100644 --- a/board/st/stm32h743-disco/MAINTAINERS +++ b/board/st/stm32h743-disco/MAINTAINERS @@ -1,6 +1,7 @@ STM32H743 DISCOVERY BOARD M: Patrice Chotard patrice.chotard@foss.st.com S: Maintained +F: doc/board/st/ F: board/st/stm32h743-disco F: include/configs/stm32h743-disco.h F: configs/stm32h743-disco_defconfig diff --git a/board/st/stm32h743-eval/MAINTAINERS b/board/st/stm32h743-eval/MAINTAINERS index fda93db777..b69e0d4abb 100644 --- a/board/st/stm32h743-eval/MAINTAINERS +++ b/board/st/stm32h743-eval/MAINTAINERS @@ -1,6 +1,7 @@ STM32H743 EVALUATION BOARD M: Patrice Chotard patrice.chotard@foss.st.com S: Maintained +F: doc/board/st/ F: board/st/stm32h743-eval F: include/configs/stm32h743-eval.h F: configs/stm32h743-eval_defconfig diff --git a/board/st/stm32h750-art-pi/MAINTAINERS b/board/st/stm32h750-art-pi/MAINTAINERS index 9578833068..2fd69e6d1c 100644 --- a/board/st/stm32h750-art-pi/MAINTAINERS +++ b/board/st/stm32h750-art-pi/MAINTAINERS @@ -1,6 +1,7 @@ STM32H750 ART PI BOARD M: Dillon Min dillon.minfei@gmail.com S: Maintained +F: doc/board/st/ F: board/st/stm32h750-art-pi F: include/configs/stm32h750-art-pi.h F: configs/stm32h750-art-pi_defconfig diff --git a/doc/board/st/index.rst b/doc/board/st/index.rst index 9bba42f1da..2a8a4ef3b8 100644 --- a/doc/board/st/index.rst +++ b/doc/board/st/index.rst @@ -8,3 +8,4 @@ STMicroelectronics
st-dt stm32mp1 + stm32_MCU diff --git a/doc/board/st/stm32_MCU.rst b/doc/board/st/stm32_MCU.rst new file mode 100644 index 0000000000..7ff7c730fa --- /dev/null +++ b/doc/board/st/stm32_MCU.rst @@ -0,0 +1,186 @@ +.. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +.. sectionauthor:: Patrice Chotard patrice.chotardy@foss.st.com + +STM32 MCU boards +================= + +This is a quick instruction for setup STM32 MCU boards. + +Supported devices +----------------- + +U-Boot supports the following STMP32 MCU SoCs: + + - STM32F429 + - STM32F469 + - STM32F746 + - STM32F769 + - STM32H743 + - STM32H750 + +SoCs information: +----------------- +STM32F4 series are Cortex-M4 MCU. +STM32F7 and STM32H7 series are Cortex-M7 MCU. + + + STM32F4 series: https://www.st.com/en/microcontrollers-microprocessors/stm32f4-series.html + + STM32F7 series: https://www.st.com/en/microcontrollers-microprocessors/stm32f7-series.html + + STM32H7 series: https://www.st.com/en/microcontrollers-microprocessors/stm32h7-series.html + +Currently the following boards are supported: + + + stm32f429-discovery + + stm32f469-discovery + + stm32746g-evaluation + + stm32f746-discovery + + stm32f769-discovery + + stm32h743i-discovery + + stm32h743i-evaluation + + stm32h750i-art-pi + +Boot Sequences +-------------- + +For STM32F7 series, 2 boot configurations are supported with and without SPL + ++------------------------+-------------------------+--------------+ +| **FSBL** | **SSBL** | **OS** | ++------------------------+-------------------------+--------------+ +| First Stage Bootloader | Second Stage Bootloader | Linux Kernel | ++------------------------+-------------------------+--------------+ +| embedded Flash | DDR | ++------------------------+-------------------------+--------------+ + +The boot chain with SPL +``````````````````````` + +defconfig_file : + + **stm32746g-eval_spl_defconfig** + + **stm32f746-disco_spl_defconfig** + + **stm32f769-disco_spl_defconfig** + ++------------+------------+-------+ +| FSBL | SSBL | OS | ++------------+------------+-------+ +|U-Boot SPL | U-Boot | Linux | ++------------+------------+-------+ + +The boot chain without SPL +`````````````````````````` + +defconfig_file : + + **stm32f429-discovery_defconfig** + + **stm32f429-evaluation_defconfig** + + **stm32f469-discovery_defconfig** + + **stm32746g-eval_defconfig** + + **stm32f746-disco_defconfig** + + **stm32f769-disco_defconfig** + + **stm32h743-disco_defconfig** + + **stm32h743-eval_defconfig** + + **stm32h750-art-pi_defconfig** + ++-----------+-------+ +| FSBL | OS | ++-----------+-------+ +|U-Boot | Linux | ++-----------+-------+ + +Build Procedure +--------------- + +1. Install the required tools for U-Boot + + * install package needed in U-Boot makefile + (libssl-dev, swig, libpython-dev...) + + * install ARMv7 toolchain for 32bit Cortex-A (from Linaro, + from SDK for STM32MP15x, or any crosstoolchains from your distribution) + (you can use any gcc cross compiler compatible with U-Boot) + +2. Set the cross compiler:: + + # export CROSS_COMPILE=/path/to/toolchain/arm-linux-gnueabi- + +3. Select the output directory (optional):: + + # export KBUILD_OUTPUT=/path/to/output + + for example: use one output directory for each configuration:: + + # export KBUILD_OUTPUT=stm32f4 + # export KBUILD_OUTPUT=stm32f7 + # export KBUILD_OUTPUT=stm32h7 + + you can build outside of code directory:: + + # export KBUILD_OUTPUT=../build/stm32f4 + +4. Configure U-Boot:: + + # make <defconfig_file> + + For example with <defconfig_file>: + + - For **stm32f429 discovery** board : **stm32f429-discovery_defconfig** + - For **stm32f769 discovery** board with SPL: **stm32f769-disco_spl_defconfig** + - For **stm32f769 discovery** board without SPL: **stm32f769-disco_defconfig** + +5. Configure the device-tree and build the U-Boot image:: + + # make DEVICE_TREE=<name> all + + Examples: + + a) boot with SPL on stm32f746 discovery board:: + + # export KBUILD_OUTPUT=stm32f746-disco + # make stm32f746-disco_spl_defconfig + # make all + + b) boot without SPL on stm32f746 discovery board:: + + # export KBUILD_OUTPUT=stm32f746-disco + # make stm32f746-disco_defconfig + # make all + + c) boot on stm32h743 discovery board:: + + # export KBUILD_OUTPUT=stm32h743-disco + # make stm32h743-disco_defconfig + # make all + + d) boot on stm32h743 evaluation board:: + + # export KBUILD_OUTPUT=stm32h743-disco + # make stm32h743-eval_defconfig + # make all + +6. U-Boot Output files + + So in the output directory (selected by KBUILD_OUTPUT), + you can found the needed U-Boot files, for example:: + + - stm32f746-disco_defconfig = **u-boot-dtb.bin** and **u-boot.dtb** + + - FSBL = u-boot-dtb.bin + + - stm32f746-disco_spl_defconfig = **u-boot-dtb.bin**, **u-boot.dtb** and **u-boot-with-spl.bin** + + - FSBL + SSBL = u-boot-with-spl.bin + - SSBL = u-boot-dtb.bin + +7. Flash U-Boot files + +Plug STM32 MCUs board using the USB ST-Link connector, hence it will expose +the flash area as a mass-storage. In this mass-storage you will find the +following files: + +- DETAILS.TXT: give the bootrom version and build +- MBED.HTM: shortcul to the hardware board description web page from st.com. + +Copy/paste the u-boot.bin or u-boot-with-spl.bin (in case of bootchain with SPL) +to this mass-storage. The "COM" LED will blink alternatively red and green during +the flash process. When done the board will reboot automatically. + +In case of boot with SPL, by default SPL will try to load either a Linux +kernel (falcon mode) or, if the key "c" is maintained pressed, the main U-Boot.
Thanks Patrick
Changes in v2:
st-dt stm32mp1
- stm32_MCU
- STM32F429
- STM32F469
- STM32F746
- STM32F769
- STM32H743
- STM32H750
- stm32f429-discovery
- stm32f469-discovery
- stm32746g-evaluation
- stm32f746-discovery
- stm32f769-discovery
- stm32h743i-discovery
- stm32h743i-evaluation
- stm32h750i-art-pi
+defconfig_file :
- **stm32746g-eval_spl_defconfig**
- **stm32f746-disco_spl_defconfig**
- **stm32f769-disco_spl_defconfig**
+defconfig_file :
- **stm32f429-discovery_defconfig**
- **stm32f429-evaluation_defconfig**
- **stm32f469-discovery_defconfig**
- **stm32746g-eval_defconfig**
- **stm32f746-disco_defconfig**
- **stm32f769-disco_defconfig**
- **stm32h743-disco_defconfig**
- **stm32h743-eval_defconfig**
- **stm32h750-art-pi_defconfig**
- install package needed in U-Boot makefile
- install ARMv7 toolchain for 32bit Cortex-A (from Linaro,
- # export CROSS_COMPILE=/path/to/toolchain/arm-linux-gnueabi-
- # export KBUILD_OUTPUT=/path/to/output
- for example: use one output directory for each configuration::
- # export KBUILD_OUTPUT=stm32f4
- # export KBUILD_OUTPUT=stm32f7
- # export KBUILD_OUTPUT=stm32h7
- you can build outside of code directory::
- # export KBUILD_OUTPUT=../build/stm32f4
- # make <defconfig_file>
- For example with <defconfig_file>:
- # make DEVICE_TREE=<name> all
- Examples:
- a) boot with SPL on stm32f746 discovery board::
# make all
- b) boot without SPL on stm32f746 discovery board::
# make all
- c) boot on stm32h743 discovery board::
# make all
- d) boot on stm32h743 evaluation board::
# make all
- So in the output directory (selected by KBUILD_OUTPUT),
- you can found the needed U-Boot files, for example::
Thanks Patrice
Patrice CHOTARD
Patrice Chotard
Patrick DELAUNAY
