Please pull u-boot-samsung master
Dear Tom,
The following changes since commit 46ff00bea5dd2dd247d5e2fdadbf5dcf8653cd9a:
Merge tag 'tpm-master-27052024' of https://source.denx.de/u-boot/custodians/u-boot-tpm (2024-05-27 08:56:02 -0600)
for you to fetch changes up to 7045c4dd04648fd2ba1806b75e139d941db0d6c5:
arm: exynos: Map iRAM APM area for Exynos850 SoC (2024-05-28 11:54:07 +0900)
---------------------------------------------------------------- Sam Protsenko (3): arm: exynos: Migrate E850-96 board to OF_UPSTREAM arm: dts: e850-96: Remove not needed bootph-all flags arm: exynos: Map iRAM APM area for Exynos850 SoC
MAINTAINERS | 7 +- arch/arm/dts/Makefile | 1 - arch/arm/dts/exynos850-e850-96-u-boot.dtsi | 28 -- arch/arm/dts/exynos850-e850-96.dts | 273 ------------------- arch/arm/dts/exynos850-pinctrl.dtsi | 663 ---------------------------------------------- arch/arm/dts/exynos850.dtsi | 809 -------------------------------------------------------- arch/arm/mach-exynos/Kconfig | 1 + arch/arm/mach-exynos/mmu-arm64.c | 8 + board/samsung/e850-96/MAINTAINERS | 1 - configs/e850-96_defconfig | 2 +- doc/device-tree-bindings/clock/samsung,exynos850-clock.yaml | 307 --------------------- doc/device-tree-bindings/soc/samsung/exynos-usi.yaml | 162 ------------ include/dt-bindings/clock/exynos850.h | 337 ----------------------- include/dt-bindings/soc/samsung,exynos-usi.h | 17 -- 14 files changed, 11 insertions(+), 2605 deletions(-) delete mode 100644 arch/arm/dts/exynos850-e850-96.dts delete mode 100644 arch/arm/dts/exynos850-pinctrl.dtsi delete mode 100644 arch/arm/dts/exynos850.dtsi delete mode 100644 doc/device-tree-bindings/clock/samsung,exynos850-clock.yaml delete mode 100644 doc/device-tree-bindings/soc/samsung/exynos-usi.yaml delete mode 100644 include/dt-bindings/clock/exynos850.h delete mode 100644 include/dt-bindings/soc/samsung,exynos-usi.h
Thanks, Minkyu Kang.
On Mon, Jun 03, 2024 at 03:08:53PM +0900, Minkyu Kang wrote:
Dear Tom,
Minkyu Kang
