[PATCH 0/3] sunxi: dts: Update H3/H5/H6 devicetree from Linux
This syncs the SoC .dtsi and board .dts files from the Linux 5.12 release. For the H3 and H5 this brings us the proper RGMII modes for the boards with Gigabit Ethernet PHYs. The rest are smaller updates, but bring us port 0 USB support on the H6 boards in U-Boot.
I know it's a bit late in the game, but those changes look innocent enough to make it into the v2021.07 release still. This way we have all 64-bit boards using Linux 5.12 DTs.
Cheers, Andre
Andre Przywara (3): arm: dts: sunxi: h6: Update DT files arm: dts: sunxi: h5: Update DT files arm: dts: sunxi: h3: Update DT files
.../dts/sun50i-h5-bananapi-m2-plus-v1.2.dts | 1 + arch/arm/dts/sun50i-h5-cpu-opp.dtsi | 79 +++++++++++++++ .../arm/dts/sun50i-h5-libretech-all-h3-cc.dts | 1 + .../arm/dts/sun50i-h5-libretech-all-h5-cc.dts | 2 +- arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts | 6 +- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 4 +- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 27 +++++- arch/arm/dts/sun50i-h5-orangepi-prime.dts | 6 +- arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 4 +- .../arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 38 ++++++++ arch/arm/dts/sun50i-h5.dtsi | 61 ++++++++++-- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 6 +- arch/arm/dts/sun50i-h6-cpu-opp.dtsi | 20 ++-- arch/arm/dts/sun50i-h6-orangepi-3.dts | 4 +- arch/arm/dts/sun50i-h6-orangepi.dtsi | 4 +- arch/arm/dts/sun50i-h6-pine-h64.dts | 7 +- arch/arm/dts/sun50i-h6.dtsi | 26 +++++ .../dts/sun8i-h2-plus-bananapi-m2-zero.dts | 96 ++++++++++++++++++- arch/arm/dts/sun8i-h3-beelink-x2.dts | 4 +- arch/arm/dts/sun8i-h3-nanopi-duo2.dts | 4 +- arch/arm/dts/sun8i-h3-nanopi-neo-air.dts | 4 +- arch/arm/dts/sun8i-h3-nanopi.dtsi | 4 +- arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts | 5 - arch/arm/dts/sun8i-h3-orangepi-plus2e.dts | 2 +- arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts | 38 ++++++++ arch/arm/dts/sun8i-h3.dtsi | 49 +++++++++- arch/arm/dts/sunxi-h3-h5.dtsi | 42 +++++++- 27 files changed, 483 insertions(+), 61 deletions(-) create mode 100644 arch/arm/dts/sun50i-h5-cpu-opp.dtsi
Update the H6 DT files from the Linux 5.12 release.
The changes are minimal (many LED node renames), but also help to enable USB port 0 in U-Boot (later), enable the RSB device (not yet used in U-Boot), and also introduce an MMC frequency limit.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 6 +----- arch/arm/dts/sun50i-h6-cpu-opp.dtsi | 20 ++++++++++---------- arch/arm/dts/sun50i-h6-orangepi-3.dts | 4 ++-- arch/arm/dts/sun50i-h6-orangepi.dtsi | 4 ++-- arch/arm/dts/sun50i-h6-pine-h64.dts | 7 ++++--- arch/arm/dts/sun50i-h6.dtsi | 26 ++++++++++++++++++++++++++ 6 files changed, 45 insertions(+), 22 deletions(-)
diff --git a/arch/arm/dts/sun50i-h6-beelink-gs1.dts b/arch/arm/dts/sun50i-h6-beelink-gs1.dts index 7c9dbde645b..b5808047d6e 100644 --- a/arch/arm/dts/sun50i-h6-beelink-gs1.dts +++ b/arch/arm/dts/sun50i-h6-beelink-gs1.dts @@ -43,7 +43,7 @@ leds { compatible = "gpio-leds";
- power { + led { label = "beelink:white:power"; gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ default-state = "on"; @@ -289,10 +289,6 @@ vcc-pm-supply = <®_aldo1>; };
-&rtc { - clocks = <&ext_osc32k>; -}; - &spdif { status = "okay"; }; diff --git a/arch/arm/dts/sun50i-h6-cpu-opp.dtsi b/arch/arm/dts/sun50i-h6-cpu-opp.dtsi index 1a5eddc5a40..8c6e8536b69 100644 --- a/arch/arm/dts/sun50i-h6-cpu-opp.dtsi +++ b/arch/arm/dts/sun50i-h6-cpu-opp.dtsi @@ -8,7 +8,7 @@ nvmem-cells = <&cpu_speed_grade>; opp-shared;
- opp@480000000 { + opp-480000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <480000000>;
@@ -17,7 +17,7 @@ opp-microvolt-speed2 = <820000 820000 1200000>; };
- opp@720000000 { + opp-720000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <720000000>;
@@ -26,7 +26,7 @@ opp-microvolt-speed2 = <820000 820000 1200000>; };
- opp@816000000 { + opp-816000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <816000000>;
@@ -35,7 +35,7 @@ opp-microvolt-speed2 = <820000 820000 1200000>; };
- opp@888000000 { + opp-888000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <888000000>;
@@ -44,7 +44,7 @@ opp-microvolt-speed2 = <820000 820000 1200000>; };
- opp@1080000000 { + opp-1080000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <1080000000>;
@@ -53,7 +53,7 @@ opp-microvolt-speed2 = <880000 880000 1200000>; };
- opp@1320000000 { + opp-1320000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <1320000000>;
@@ -62,7 +62,7 @@ opp-microvolt-speed2 = <940000 940000 1200000>; };
- opp@1488000000 { + opp-1488000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <1488000000>;
@@ -71,7 +71,7 @@ opp-microvolt-speed2 = <1000000 1000000 1200000>; };
- opp@1608000000 { + opp-1608000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <1608000000>;
@@ -80,7 +80,7 @@ opp-microvolt-speed2 = <1030000 1030000 1200000>; };
- opp@1704000000 { + opp-1704000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <1704000000>;
@@ -89,7 +89,7 @@ opp-microvolt-speed2 = <1060000 1060000 1200000>; };
- opp@1800000000 { + opp-1800000000 { clock-latency-ns = <244144>; /* 8 32k periods */ opp-hz = /bits/ 64 <1800000000>;
diff --git a/arch/arm/dts/sun50i-h6-orangepi-3.dts b/arch/arm/dts/sun50i-h6-orangepi-3.dts index 15c9dd8c447..7e83f6146f8 100644 --- a/arch/arm/dts/sun50i-h6-orangepi-3.dts +++ b/arch/arm/dts/sun50i-h6-orangepi-3.dts @@ -43,13 +43,13 @@ leds { compatible = "gpio-leds";
- power { + led-0 { label = "orangepi:red:power"; gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ default-state = "on"; };
- status { + led-1 { label = "orangepi:green:status"; gpios = <&r_pio 0 7 GPIO_ACTIVE_HIGH>; /* PL7 */ }; diff --git a/arch/arm/dts/sun50i-h6-orangepi.dtsi b/arch/arm/dts/sun50i-h6-orangepi.dtsi index ebc120a9232..da0875bd38d 100644 --- a/arch/arm/dts/sun50i-h6-orangepi.dtsi +++ b/arch/arm/dts/sun50i-h6-orangepi.dtsi @@ -42,13 +42,13 @@ leds { compatible = "gpio-leds";
- status { + led-1 { label = "orangepi:green:status"; gpios = <&r_pio 0 7 GPIO_ACTIVE_HIGH>; /* PL7 */ }; diff --git a/arch/arm/dts/sun50i-h6-pine-h64.dts b/arch/arm/dts/sun50i-h6-pine-h64.dts index 961732c52aa..b868ad17af8 100644 --- a/arch/arm/dts/sun50i-h6-pine-h64.dts +++ b/arch/arm/dts/sun50i-h6-pine-h64.dts @@ -44,17 +44,17 @@ leds { compatible = "gpio-leds";
- heartbeat { + led-0 { label = "pine-h64:green:heartbeat"; gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ };
- link { + led-1 { label = "pine-h64:white:link"; gpios = <&r_pio 0 3 GPIO_ACTIVE_HIGH>; /* PL3 */ };
- status { + led-2 { label = "pine-h64:blue:status"; gpios = <&r_pio 0 7 GPIO_ACTIVE_HIGH>; /* PL7 */ }; @@ -142,6 +142,7 @@ vqmmc-supply = <®_bldo2>; non-removable; cap-mmc-hw-reset; + mmc-hs200-1_8v; bus-width = <8>; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-h6.dtsi b/arch/arm/dts/sun50i-h6.dtsi index 8a62a9fbe34..af8b7d0ef75 100644 --- a/arch/arm/dts/sun50i-h6.dtsi +++ b/arch/arm/dts/sun50i-h6.dtsi @@ -436,6 +436,7 @@ interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&mmc0_pins>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -452,6 +453,7 @@ interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -468,6 +470,7 @@ interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; pinctrl-names = "default"; pinctrl-0 = <&mmc2_pins>; + max-frequency = <150000000>; status = "disabled"; #address-cells = <1>; #size-cells = <0>; @@ -680,6 +683,8 @@ <&ccu CLK_USB_OHCI0>; resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_BUS_EHCI0>; + phys = <&usb2phy 0>; + phy-names = "usb"; status = "disabled"; };
@@ -690,6 +695,8 @@ clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>; resets = <&ccu RST_BUS_OHCI0>; + phys = <&usb2phy 0>; + phy-names = "usb"; status = "disabled"; };
@@ -949,6 +956,11 @@ pins = "PL9"; function = "s_cir_rx"; }; + + r_rsb_pins: r-rsb-pins { + pins = "PL0", "PL1"; + function = "s_rsb"; + }; };
r_ir: ir@7040000 { @@ -979,6 +991,20 @@ #size-cells = <0>; };
+ r_rsb: rsb@7083000 { + compatible = "allwinner,sun8i-a23-rsb"; + reg = <0x07083000 0x400>; + interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_R_APB2_RSB>; + clock-frequency = <3000000>; + resets = <&r_ccu RST_R_APB2_RSB>; + pinctrl-names = "default"; + pinctrl-0 = <&r_rsb_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + ths: thermal-sensor@5070400 { compatible = "allwinner,sun50i-h6-ths"; reg = <0x05070400 0x100>;
Update the H5 DT files from the Linux 5.12 release.
The changes don't affect U-Boot at all, but fix Gigabit Ethernet when this DT is passed on to the Linux kernel. It also introduces DVFS.
This also updates the shared sunxi-h3-h5.dtsi, but that only adds nodes that are of no concern to U-Boot.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- .../dts/sun50i-h5-bananapi-m2-plus-v1.2.dts | 1 + arch/arm/dts/sun50i-h5-cpu-opp.dtsi | 79 +++++++++++++++++++ .../arm/dts/sun50i-h5-libretech-all-h3-cc.dts | 1 + .../arm/dts/sun50i-h5-libretech-all-h5-cc.dts | 2 +- arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts | 6 +- arch/arm/dts/sun50i-h5-nanopi-neo2.dts | 4 +- arch/arm/dts/sun50i-h5-orangepi-pc2.dts | 27 ++++++- arch/arm/dts/sun50i-h5-orangepi-prime.dts | 6 +- arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts | 4 +- .../arm/dts/sun50i-h5-orangepi-zero-plus2.dts | 38 +++++++++ arch/arm/dts/sun50i-h5.dtsi | 61 ++++++++++++-- arch/arm/dts/sun8i-h3.dtsi | 49 +++++++++++- arch/arm/dts/sunxi-h3-h5.dtsi | 42 +++++++++- 13 files changed, 296 insertions(+), 24 deletions(-) create mode 100644 arch/arm/dts/sun50i-h5-cpu-opp.dtsi
diff --git a/arch/arm/dts/sun50i-h5-bananapi-m2-plus-v1.2.dts b/arch/arm/dts/sun50i-h5-bananapi-m2-plus-v1.2.dts index 2e2b14c0ae7..8857a379159 100644 --- a/arch/arm/dts/sun50i-h5-bananapi-m2-plus-v1.2.dts +++ b/arch/arm/dts/sun50i-h5-bananapi-m2-plus-v1.2.dts @@ -3,6 +3,7 @@
/dts-v1/; #include "sun50i-h5.dtsi" +#include "sun50i-h5-cpu-opp.dtsi" #include <arm/sunxi-bananapi-m2-plus-v1.2.dtsi>
/ { diff --git a/arch/arm/dts/sun50i-h5-cpu-opp.dtsi b/arch/arm/dts/sun50i-h5-cpu-opp.dtsi new file mode 100644 index 00000000000..b2657201957 --- /dev/null +++ b/arch/arm/dts/sun50i-h5-cpu-opp.dtsi @@ -0,0 +1,79 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +// Copyright (C) 2020 Chen-Yu Tsai wens@csie.org + +/ { + cpu_opp_table: cpu-opp-table { + compatible = "operating-points-v2"; + opp-shared; + + opp-408000000 { + opp-hz = /bits/ 64 <408000000>; + opp-microvolt = <1000000 1000000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-648000000 { + opp-hz = /bits/ 64 <648000000>; + opp-microvolt = <1040000 1040000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-816000000 { + opp-hz = /bits/ 64 <816000000>; + opp-microvolt = <1080000 1080000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-912000000 { + opp-hz = /bits/ 64 <912000000>; + opp-microvolt = <1120000 1120000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-960000000 { + opp-hz = /bits/ 64 <960000000>; + opp-microvolt = <1160000 1160000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1008000000 { + opp-hz = /bits/ 64 <1008000000>; + opp-microvolt = <1200000 1200000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1056000000 { + opp-hz = /bits/ 64 <1056000000>; + opp-microvolt = <1240000 1240000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1104000000 { + opp-hz = /bits/ 64 <1104000000>; + opp-microvolt = <1260000 1260000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + + opp-1152000000 { + opp-hz = /bits/ 64 <1152000000>; + opp-microvolt = <1300000 1300000 1310000>; + clock-latency-ns = <244144>; /* 8 32k periods */ + }; + }; +}; + +&cpu0 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu1 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu2 { + operating-points-v2 = <&cpu_opp_table>; +}; + +&cpu3 { + operating-points-v2 = <&cpu_opp_table>; +}; diff --git a/arch/arm/dts/sun50i-h5-libretech-all-h3-cc.dts b/arch/arm/dts/sun50i-h5-libretech-all-h3-cc.dts index a91806618e6..016da3ec321 100644 --- a/arch/arm/dts/sun50i-h5-libretech-all-h3-cc.dts +++ b/arch/arm/dts/sun50i-h5-libretech-all-h3-cc.dts @@ -4,6 +4,7 @@
/dts-v1/; #include "sun50i-h5.dtsi" +#include "sun50i-h5-cpu-opp.dtsi" #include <sunxi-libretech-all-h3-cc.dtsi>
/ { diff --git a/arch/arm/dts/sun50i-h5-libretech-all-h5-cc.dts b/arch/arm/dts/sun50i-h5-libretech-all-h5-cc.dts index df1b9263ad0..6e30a564c87 100644 --- a/arch/arm/dts/sun50i-h5-libretech-all-h5-cc.dts +++ b/arch/arm/dts/sun50i-h5-libretech-all-h5-cc.dts @@ -36,7 +36,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; /delete-property/ allwinner,leds-active-low; status = "okay"; }; diff --git a/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts b/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts index 4f9ba53ffaa..4c3921ac236 100644 --- a/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts +++ b/arch/arm/dts/sun50i-h5-nanopi-neo-plus2.dts @@ -25,13 +25,13 @@ leds { compatible = "gpio-leds";
- pwr { + led-0 { label = "nanopi:green:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; default-state = "on"; };
- status { + led-1 { label = "nanopi:red:status"; gpios = <&pio 0 20 GPIO_ACTIVE_HIGH>; }; @@ -96,7 +96,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts index b059e20813b..02f8e72f0ca 100644 --- a/arch/arm/dts/sun50i-h5-nanopi-neo2.dts +++ b/arch/arm/dts/sun50i-h5-nanopi-neo2.dts @@ -22,13 +22,13 @@ leds { compatible = "gpio-leds";
- status { + led-1 { label = "nanopi:blue:status"; gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; }; diff --git a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts index 70b5f099842..1010c1b22d2 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-pc2.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-pc2.dts @@ -42,13 +42,13 @@ leds { compatible = "gpio-leds";
- pwr { + led-0 { label = "orangepi:green:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; default-state = "on"; };
- status { + led-1 { label = "orangepi:red:status"; gpios = <&pio 0 20 GPIO_ACTIVE_HIGH>; }; @@ -61,6 +61,7 @@ label = "sw4"; linux,code = <BTN_0>; gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>; + wakeup-source; }; };
@@ -93,6 +94,10 @@ status = "okay"; };
+&cpu0 { + cpu-supply = <®_vdd_cpux>; +}; + &de { status = "okay"; }; @@ -118,7 +123,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
@@ -168,6 +173,22 @@ status = "okay"; };
+&r_i2c { + status = "okay"; + + reg_vdd_cpux: regulator@65 { + compatible = "silergy,sy8106a"; + reg = <0x65>; + regulator-name = "vdd-cpux"; + silergy,fixed-microvolt = <1100000>; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-ramp-delay = <200>; + regulator-boot-on; + regulator-always-on; + }; +}; + &spi0 { status = "okay";
diff --git a/arch/arm/dts/sun50i-h5-orangepi-prime.dts b/arch/arm/dts/sun50i-h5-orangepi-prime.dts index cb44bfa5981..74e0444af19 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-prime.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-prime.dts @@ -36,13 +36,13 @@ leds { compatible = "gpio-leds";
- status { + led-1 { label = "orangepi:red:status"; gpios = <&pio 0 20 GPIO_ACTIVE_HIGH>; }; @@ -124,7 +124,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
diff --git a/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts b/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts index ef5ca644422..d13980ed7a7 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-zero-plus.dts @@ -33,13 +33,13 @@ leds { compatible = "gpio-leds";
- pwr { + led-0 { label = "orangepi:green:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PA10 */ default-state = "on"; };
- status { + led-1 { label = "orangepi:red:status"; gpios = <&pio 0 17 GPIO_ACTIVE_HIGH>; /* PA17 */ }; diff --git a/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts b/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts index c95a6854130..22530ace12d 100644 --- a/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts +++ b/arch/arm/dts/sun50i-h5-orangepi-zero-plus2.dts @@ -30,6 +30,21 @@ }; };
+ leds { + compatible = "gpio-leds"; + + led-0 { + label = "orangepi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + led-1 { + label = "orangepi:red:status"; + gpios = <&pio 0 17 GPIO_ACTIVE_HIGH>; + }; + }; + reg_vcc3v3: vcc3v3 { compatible = "regulator-fixed"; regulator-name = "vcc3v3"; @@ -48,6 +63,10 @@ status = "okay"; };
+&ehci0 { + status = "okay"; +}; + &hdmi { status = "okay"; }; @@ -92,6 +111,10 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pa_pins>; @@ -103,3 +126,18 @@ pinctrl-0 = <&uart1_pins>, <&uart1_rts_cts_pins>; status = "okay"; }; + +&usb_otg { + /* + * According to schematics CN1 MicroUSB port can be used to take + * external 5V to power up the board VBUS. On the contrary CN1 MicroUSB + * port cannot provide power externally even if the board is powered + * via GPIO pins. It thus makes sense to force peripheral mode. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +}; diff --git a/arch/arm/dts/sun50i-h5.dtsi b/arch/arm/dts/sun50i-h5.dtsi index 3a1c8b2efd6..ab860e20d08 100644 --- a/arch/arm/dts/sun50i-h5.dtsi +++ b/arch/arm/dts/sun50i-h5.dtsi @@ -3,6 +3,8 @@
#include <sunxi-h3-h5.dtsi>
+#include <dt-bindings/thermal/thermal.h> + / { cpus { #address-cells = <1>; @@ -13,6 +15,9 @@ device_type = "cpu"; reg = <0>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; };
cpu1: cpu@1 { @@ -20,6 +25,9 @@ device_type = "cpu"; reg = <1>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; };
cpu2: cpu@2 { @@ -27,6 +35,9 @@ device_type = "cpu"; reg = <2>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; };
cpu3: cpu@3 { @@ -34,12 +45,14 @@ device_type = "cpu"; reg = <3>; enable-method = "psci"; + clocks = <&ccu CLK_CPUX>; + clock-latency-ns = <244144>; /* 8 32k periods */ + #cooling-cells = <2>; }; };
pmu { - compatible = "arm,cortex-a53-pmu", - "arm,armv8-pmuv3"; + compatible = "arm,cortex-a53-pmu"; interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, @@ -54,6 +67,7 @@
timer { compatible = "arm,armv8-timer"; + arm,no-tick-in-suspend; interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, <GIC_PPI 14 @@ -107,6 +121,19 @@ resets = <&ccu RST_BUS_CE>; };
+ deinterlace: deinterlace@1e00000 { + compatible = "allwinner,sun8i-h3-deinterlace"; + reg = <0x01e00000 0x20000>; + clocks = <&ccu CLK_BUS_DEINTERLACE>, + <&ccu CLK_DEINTERLACE>, + <&ccu CLK_DRAM_DEINTERLACE>; + clock-names = "bus", "mod", "ram"; + resets = <&ccu RST_BUS_DEINTERLACE>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + interconnects = <&mbus 9>; + interconnect-names = "dma-mem"; + }; + mali: gpu@1e80000 { compatible = "allwinner,sun50i-h5-mali", "arm,mali-450"; reg = <0x01e80000 0x30000>; @@ -126,8 +153,7 @@ <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "gp", "gpmmu", "pp", @@ -138,8 +164,7 @@ "pp2", "ppmmu2", "pp3", - "ppmmu3", - "pmu"; + "ppmmu3"; clocks = <&ccu CLK_BUS_GPU>, <&ccu CLK_GPU>; clock-names = "bus", "core"; resets = <&ccu RST_BUS_GPU>; @@ -166,6 +191,30 @@ polling-delay-passive = <0>; polling-delay = <0>; thermal-sensors = <&ths 0>; + + trips { + cpu_hot_trip: cpu-hot { + temperature = <80000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_very_hot_trip: cpu-very-hot { + temperature = <100000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + cpu-hot-limit { + trip = <&cpu_hot_trip>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; };
gpu_thermal { diff --git a/arch/arm/dts/sun8i-h3.dtsi b/arch/arm/dts/sun8i-h3.dtsi index 20217e2ca4d..4e89701df91 100644 --- a/arch/arm/dts/sun8i-h3.dtsi +++ b/arch/arm/dts/sun8i-h3.dtsi @@ -41,6 +41,7 @@ */
#include "sunxi-h3-h5.dtsi" +#include <dt-bindings/thermal/thermal.h>
/ { cpu0_opp_table: opp_table0 { @@ -111,6 +112,26 @@ }; };
+ gpu_opp_table: gpu-opp-table { + compatible = "operating-points-v2"; + + opp-120000000 { + opp-hz = /bits/ 64 <120000000>; + }; + + opp-312000000 { + opp-hz = /bits/ 64 <312000000>; + }; + + opp-432000000 { + opp-hz = /bits/ 64 <432000000>; + }; + + opp-576000000 { + opp-hz = /bits/ 64 <576000000>; + }; + }; + pmu { compatible = "arm,cortex-a7-pmu"; interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, @@ -204,9 +225,7 @@ clocks = <&ccu CLK_BUS_GPU>, <&ccu CLK_GPU>; clock-names = "bus", "core"; resets = <&ccu RST_BUS_GPU>; - - assigned-clocks = <&ccu CLK_GPU>; - assigned-clock-rates = <384000000>; + operating-points-v2 = <&gpu_opp_table>; };
ths: thermal-sensor@1c25000 { @@ -227,6 +246,30 @@ polling-delay-passive = <0>; polling-delay = <0>; thermal-sensors = <&ths 0>; + + trips { + cpu_hot_trip: cpu-hot { + temperature = <80000>; + hysteresis = <2000>; + type = "passive"; + }; + + cpu_very_hot_trip: cpu-very-hot { + temperature = <100000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + cpu-hot-limit { + trip = <&cpu_hot_trip>; + cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, + <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; + }; + }; }; }; }; diff --git a/arch/arm/dts/sunxi-h3-h5.dtsi b/arch/arm/dts/sunxi-h3-h5.dtsi index 5e9c3060aa0..9be13378d4d 100644 --- a/arch/arm/dts/sunxi-h3-h5.dtsi +++ b/arch/arm/dts/sunxi-h3-h5.dtsi @@ -114,7 +114,7 @@
display_clocks: clock@1000000 { /* compatible is in per SoC .dtsi file */ - reg = <0x01000000 0x100000>; + reg = <0x01000000 0x10000>; clocks = <&ccu CLK_BUS_DE>, <&ccu CLK_DE>; clock-names = "bus", @@ -239,6 +239,16 @@ }; };
+ msgbox: mailbox@1c17000 { + compatible = "allwinner,sun8i-h3-msgbox", + "allwinner,sun6i-a31-msgbox"; + reg = <0x01c17000 0x1000>; + clocks = <&ccu CLK_BUS_MSGBOX>; + resets = <&ccu RST_BUS_MSGBOX>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + #mbox-cells = <1>; + }; + usb_otg: usb@1c19000 { compatible = "allwinner,sun8i-h3-musb"; reg = <0x01c19000 0x400>; @@ -560,6 +570,8 @@ compatible = "allwinner,sun8i-h3-mbus"; reg = <0x01c62000 0x1000>; clocks = <&ccu CLK_MBUS>; + #address-cells = <1>; + #size-cells = <1>; dma-ranges = <0x00000000 0x40000000 0xc0000000>; #interconnect-cells = <1>; }; @@ -650,6 +662,19 @@ status = "disabled"; };
+ i2s2: i2s@1c22800 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun8i-h3-i2s"; + reg = <0x01c22800 0x400>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2S2>, <&ccu CLK_I2S2>; + clock-names = "apb", "mod"; + dmas = <&dma 27>; + resets = <&ccu RST_BUS_I2S2>; + dma-names = "tx"; + status = "disabled"; + }; + codec: codec@1c22c00 { #sound-dai-cells = <0>; compatible = "allwinner,sun8i-h3-codec"; @@ -892,6 +917,21 @@ pins = "PL0", "PL1"; function = "s_i2c"; }; + + r_pwm_pin: r-pwm-pin { + pins = "PL10"; + function = "s_pwm"; + }; + }; + + r_pwm: pwm@1f03800 { + compatible = "allwinner,sun8i-h3-pwm"; + reg = <0x01f03800 0x8>; + pinctrl-names = "default"; + pinctrl-0 = <&r_pwm_pin>; + clocks = <&osc24M>; + #pwm-cells = <3>; + status = "disabled"; }; }; };
Update the H3 DT files from the Linux 5.12 release.
The changes update some boards, and don't affect U-Boot, but fix Gigabit Ethernet when this DT is passed on to the Linux kernel.
Signed-off-by: Andre Przywara andre.przywara@arm.com --- .../dts/sun8i-h2-plus-bananapi-m2-zero.dts | 96 ++++++++++++++++++- arch/arm/dts/sun8i-h3-beelink-x2.dts | 4 +- arch/arm/dts/sun8i-h3-nanopi-duo2.dts | 4 +- arch/arm/dts/sun8i-h3-nanopi-neo-air.dts | 4 +- arch/arm/dts/sun8i-h3-nanopi.dtsi | 4 +- arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts | 5 - arch/arm/dts/sun8i-h3-orangepi-plus2e.dts | 2 +- arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts | 38 ++++++++ 8 files changed, 142 insertions(+), 15 deletions(-)
diff --git a/arch/arm/dts/sun8i-h2-plus-bananapi-m2-zero.dts b/arch/arm/dts/sun8i-h2-plus-bananapi-m2-zero.dts index d277d043031..f3f7a2c912a 100644 --- a/arch/arm/dts/sun8i-h2-plus-bananapi-m2-zero.dts +++ b/arch/arm/dts/sun8i-h2-plus-bananapi-m2-zero.dts @@ -31,7 +31,7 @@
pwr_led { label = "bananapi-m2-zero:red:pwr"; - gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ + gpios = <&r_pio 0 10 GPIO_ACTIVE_LOW>; /* PL10 */ default-state = "on"; }; }; @@ -62,6 +62,35 @@ states = <1100000 0>, <1300000 1>; };
+ reg_vcc_dram: vcc-dram { + compatible = "regulator-fixed"; + regulator-name = "vcc-dram"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + gpio = <&r_pio 0 9 GPIO_ACTIVE_HIGH>; /* PL9 */ + vin-supply = <®_vcc5v0>; + }; + + reg_vcc1v2: vcc1v2 { + compatible = "regulator-fixed"; + regulator-name = "vcc1v2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-boot-on; + enable-active-high; + gpio = <&r_pio 0 8 GPIO_ACTIVE_HIGH>; /* PL8 */ + vin-supply = <®_vcc5v0>; + }; + + poweroff { + compatible = "regulator-poweroff"; + cpu-supply = <®_vcc1v2>; + }; + wifi_pwrseq: wifi_pwrseq { compatible = "mmc-pwrseq-simple"; reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */ @@ -125,6 +154,7 @@
bluetooth { compatible = "brcm,bcm43438-bt"; + max-speed = <1500000>; clocks = <&rtc 1>; clock-names = "lpo"; vbat-supply = <®_vcc3v3>; @@ -136,6 +166,70 @@
+&pio { + gpio-line-names = + /* PA */ + "CON2-P13", "CON2-P11", "CON2-P22", "CON2-P15", + "CON3-P03", "CON3-P02", "CON2-P07", "CON2-P29", + "CON2-P31", "CON2-P33", "CON2-P35", "CON2-P05", + "CON2-P03", "CON2-P08", "CON2-P10", "CON2-P16", + "CON2-P12", "CON2-P37", "CON2-P28", "CON2-P27", + "CON2-P40", "CON2-P38", "", "", + "", "", "", "", "", "", "", "", + + /* PB */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + + /* PC */ + "CON2-P19", "CON2-P21", "CON2-P23", "CON2-P24", + "CON2-P18", "", "", "CON2-P26", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + + /* PD */ + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "CSI-PWR-EN", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + + /* PE */ + "CN3-P17", "CN3-P13", "CN3-P09", "CN3-P07", + "CN3-P19", "CN3-P21", "CN3-P22", "CN3-P20", + "CN3-P18", "CN3-P16", "CN3-P14", "CN3-P12", + "CN3-P05", "CN3-P03", "CN3-P06", "CN3-P08", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + + /* PF */ + "SDC0-D1", "SDC0-D0", "SDC0-CLK", "SDC0-CMD", "SDC0-D3", + "SDC0-D2", "SDC0-DET", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", "", + + /* PG */ + "WL-SDIO-CLK", "WL-SDIO-CMD", "WL-SDIO-D0", "WL-SDIO-D1", + "WL-SDIO-D2", "WL-SDIO-D3", "BT-UART-TX", "BT-UART-RX", + "BT-UART-RTS", "BT-UART-CTS", "WL-WAKE-AP", "BT-WAKE-AP", + "BT-RST-N", "AP-WAKE-BT", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + +&r_pio { + gpio-line-names = + /* PL */ + "", "CPUX-SET", "CON2-P32", "POWER-KEY", "CON2-P36", + "VCC-IO-EN", "USB0-ID", "WL-PWR-EN", + "PWR-STB", "PWR-DRAM", "PWR-LED", "IR-RX", "", "", "", "", + "", "", "", "", "", "", "", "", + "", "", "", "", "", "", "", ""; +}; + &usb_otg { dr_mode = "otg"; status = "okay"; diff --git a/arch/arm/dts/sun8i-h3-beelink-x2.dts b/arch/arm/dts/sun8i-h3-beelink-x2.dts index 45a24441ff1..62b5280ec09 100644 --- a/arch/arm/dts/sun8i-h3-beelink-x2.dts +++ b/arch/arm/dts/sun8i-h3-beelink-x2.dts @@ -75,13 +75,13 @@ leds { compatible = "gpio-leds";
- blue { + led-0 { label = "beelink-x2:blue:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ default-state = "on"; };
- red { + led-1 { label = "beelink-x2:red:standby"; gpios = <&pio 0 15 GPIO_ACTIVE_HIGH>; /* PA15 */ }; diff --git a/arch/arm/dts/sun8i-h3-nanopi-duo2.dts b/arch/arm/dts/sun8i-h3-nanopi-duo2.dts index 6b149271ef1..8e7dfcffe1f 100644 --- a/arch/arm/dts/sun8i-h3-nanopi-duo2.dts +++ b/arch/arm/dts/sun8i-h3-nanopi-duo2.dts @@ -25,13 +25,13 @@ leds { compatible = "gpio-leds";
- pwr { + led-0 { label = "nanopi:red:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ default-state = "on"; };
- status { + led-1 { label = "nanopi:green:status"; gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; /* PA10 */ }; diff --git a/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts b/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts index 07867a0d569..be49eabbff9 100644 --- a/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts +++ b/arch/arm/dts/sun8i-h3-nanopi-neo-air.dts @@ -61,13 +61,13 @@ leds { compatible = "gpio-leds";
- pwr { + led-0 { label = "nanopi:green:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; /* PL10 */ default-state = "on"; };
- status { + led-1 { label = "nanopi:blue:status"; gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; /* PA10 */ }; diff --git a/arch/arm/dts/sun8i-h3-nanopi.dtsi b/arch/arm/dts/sun8i-h3-nanopi.dtsi index 4df29a65316..c7c3e7d8b3c 100644 --- a/arch/arm/dts/sun8i-h3-nanopi.dtsi +++ b/arch/arm/dts/sun8i-h3-nanopi.dtsi @@ -60,13 +60,13 @@ leds { compatible = "gpio-leds";
- status { + led-0 { label = "nanopi:blue:status"; gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>; linux,default-trigger = "heartbeat"; };
- pwr { + led-1 { label = "nanopi:green:pwr"; gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; default-state = "on"; diff --git a/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts b/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts index 71fb7320893..babf4cf1b2f 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts @@ -53,11 +53,6 @@ }; };
-&emac { - /* LEDs changed to active high on the plus */ - /delete-property/ allwinner,leds-active-low; -}; - &mmc1 { vmmc-supply = <®_vcc3v3>; bus-width = <4>; diff --git a/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts b/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts index 6dbf7b2e0c1..b6ca45d18e5 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-plus2e.dts @@ -67,7 +67,7 @@ pinctrl-0 = <&emac_rgmii_pins>; phy-supply = <®_gmac_3v3>; phy-handle = <&ext_rgmii_phy>; - phy-mode = "rgmii"; + phy-mode = "rgmii-id"; status = "okay"; };
diff --git a/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts b/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts index b8f46e2802f..561ea1d2f86 100644 --- a/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts +++ b/arch/arm/dts/sun8i-h3-orangepi-zero-plus2.dts @@ -70,6 +70,21 @@ }; };
+ leds { + compatible = "gpio-leds"; + + led-0 { + label = "orangepi:green:pwr"; + gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + led-1 { + label = "orangepi:red:status"; + gpios = <&pio 0 17 GPIO_ACTIVE_HIGH>; + }; + }; + reg_vcc3v3: vcc3v3 { compatible = "regulator-fixed"; regulator-name = "vcc3v3"; @@ -88,6 +103,10 @@ status = "okay"; };
+&ehci0 { + status = "okay"; +}; + &hdmi { status = "okay"; }; @@ -132,8 +151,27 @@ status = "okay"; };
+&ohci0 { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pa_pins>; status = "okay"; }; + +&usb_otg { + /* + * According to schematics CN1 MicroUSB port can be used to take + * external 5V to power up the board VBUS. On the contrary CN1 MicroUSB + * port cannot provide power externally even if the board is powered + * via GPIO pins. It thus makes sense to force peripheral mode. + */ + dr_mode = "peripheral"; + status = "okay"; +}; + +&usbphy { + status = "okay"; +};
Andre Przywara
