[U-Boot] Please pull u-boot-marvell/master
Hi Tom,
please pull the first Marvell patches in this merge window with the following changes:
---------------------------------------------------------------- - Sync Armada-38x dts with Linux 4.20 from Chris - Misc changes and enhancements to Turris Mox (v4) from Marek - Reserve PSCI area for Armada 8k from Heinrich - New Allied Telesis x530 board (Armada-385) from Chris - Misc minor changes (defconfig etc) ----------------------------------------------------------------
Thanks, Stefan
The following changes since commit 2acc24fc28ef782f4baef1aa0193d520ee9610b9:
Kconfig: Migrate BOUNCE_BUFFER (2019-01-19 09:49:26 -0500)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to 0e31666dfa043ab71fb1fbbba4feacfe8af3e06b:
ARM: mvebu: add support for Allied Telesis x530 (2019-01-21 11:39:50 +0100)
---------------------------------------------------------------- Baruch Siach (1): board: mvebu: drop unused ETH_PHY macro definitions
Chris Packham (2): ARM: mvebu: sync Armada-38x dts with Linux 4.20 ARM: mvebu: add support for Allied Telesis x530
Heinrich Schuchardt (2): arm64: dts: marvell: armada-ap806: reserve PSCI area arm64: mvebu: defconfig: enable CONFIG_CMD_NVME
Marek Behún (10): arm: mvebu: turris_mox: Cosmetic restructurization arm: mvebu: turris_mox: Change SERDES map depending on module topology arm: mvebu: turris_mox: Check and configure modules arm: mvebu: dts: Fix Turris Mox device tree arm: mvebu: turris_mox: Update defconfig watchdog: armada_37xx: Fix compliance with kernel's driver MAINTAINERS: Add entry for CZ.NIC's Turris project arm: mvebu: turris_mox: Read info (and ethaddrs) from OTP arm: mvebu: turris_mox: Support 1 GB version of Turris Mox arm: mvebu: configs: turris_mox: Add 64 MiB of boot memory
MAINTAINERS | 8 + arch/arm/dts/Makefile | 4 +- arch/arm/dts/armada-3720-turris-mox.dts | 23 +- arch/arm/dts/armada-380.dtsi | 44 +-- arch/arm/dts/armada-385-atl-x530-u-boot.dtsi | 13 + arch/arm/dts/armada-385-atl-x530.dts | 50 +++ arch/arm/dts/armada-385-atl-x530.dtsi | 266 +++++++++++++++ arch/arm/dts/armada-385-atl-x530DP.dts | 51 +++ arch/arm/dts/armada-385-atl-x530DP.dtsi | 149 +++++++++ arch/arm/dts/armada-385.dtsi | 63 +--- arch/arm/dts/armada-388-clearfog.dts | 25 +- arch/arm/dts/armada-388.dtsi | 43 +-- arch/arm/dts/armada-38x-controlcenterdc.dts | 68 ++-- arch/arm/dts/armada-38x.dtsi | 283 +++++++++------- arch/arm/dts/armada-ap806.dtsi | 11 + arch/arm/mach-mvebu/Kconfig | 7 + arch/arm/mach-mvebu/arm64-common.c | 4 +- board/CZ.NIC/turris_mox/Makefile | 2 +- board/CZ.NIC/turris_mox/mox_sp.c | 136 ++++++++ board/CZ.NIC/turris_mox/mox_sp.h | 15 + board/CZ.NIC/turris_mox/turris_mox.c | 462 +++++++++++++++++++++++--- board/Marvell/db-88f6820-amc/db-88f6820-amc.c | 4 - board/Marvell/db-88f6820-gp/db-88f6820-gp.c | 4 - board/alliedtelesis/common/gpio_hog.c | 36 ++ board/alliedtelesis/common/gpio_hog.h | 13 + board/alliedtelesis/x530/MAINTAINERS | 12 + board/alliedtelesis/x530/Makefile | 9 + board/alliedtelesis/x530/kwbimage.cfg | 12 + board/alliedtelesis/x530/x530.c | 161 +++++++++ board/gdsys/a38x/controlcenterdc.c | 4 - board/kobol/helios4/helios4.c | 4 - board/solidrun/clearfog/clearfog.c | 4 - configs/clearfog_gt_8k_defconfig | 2 + configs/mvebu_db_armada8k_defconfig | 2 + configs/mvebu_mcbin-88f8040_defconfig | 2 + configs/turris_mox_defconfig | 6 + configs/x530_defconfig | 71 ++++ drivers/watchdog/armada-37xx-wdt.c | 109 +++--- include/configs/turris_mox.h | 2 + include/configs/x530.h | 134 ++++++++ 40 files changed, 1918 insertions(+), 400 deletions(-) create mode 100644 arch/arm/dts/armada-385-atl-x530-u-boot.dtsi create mode 100644 arch/arm/dts/armada-385-atl-x530.dts create mode 100644 arch/arm/dts/armada-385-atl-x530.dtsi create mode 100644 arch/arm/dts/armada-385-atl-x530DP.dts create mode 100644 arch/arm/dts/armada-385-atl-x530DP.dtsi create mode 100644 board/CZ.NIC/turris_mox/mox_sp.c create mode 100644 board/CZ.NIC/turris_mox/mox_sp.h create mode 100644 board/alliedtelesis/common/gpio_hog.c create mode 100644 board/alliedtelesis/common/gpio_hog.h create mode 100644 board/alliedtelesis/x530/MAINTAINERS create mode 100644 board/alliedtelesis/x530/Makefile create mode 100644 board/alliedtelesis/x530/kwbimage.cfg create mode 100644 board/alliedtelesis/x530/x530.c create mode 100644 configs/x530_defconfig create mode 100644 include/configs/x530.h
Stefan Roese
