[U-Boot-Users] [Patch 10/17] U-Boot-V2:ARM:OMAP3: Add support for OMAP and Cortex A8
This patch adds support for OMAP3 platforms. This is mainly to setup the infrastructure. ARMV7 requires a different I/D cache cleanup code which is introduced in this patch.
Thanks to Laurent in pointing out the Cortex-A8 D-Cache issue with my first rev patch.
Signed-off-by: Nishanth Menonx0nishan@ti.com
--- arch/arm/Kconfig | 24 ++++++++++++++++++++ arch/arm/Makefile | 6 +++++ arch/arm/cpu/Makefile | 1 arch/arm/cpu/start-arm.S | 54 +++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 84 insertions(+), 1 deletion(-)
Index: u-boot-v2.git/arch/arm/Kconfig =================================================================== --- u-boot-v2.git.orig/arch/arm/Kconfig 2008-05-20 18:20:54.000000000 -0500 +++ u-boot-v2.git/arch/arm/Kconfig 2008-05-21 10:41:17.000000000 -0500 @@ -47,6 +47,9 @@ config ARM926EJS bool
+config ARMCORTEXA8 + bool + # i.MX1, i.MXL, i.MX27 and i.MX31 are quite similar and thus # handled in one arch config ARCH_IMX @@ -74,6 +77,10 @@ bool select ARM926EJS
+config ARCH_OMAP + bool +# ARM versions used varies on based on OMAP versions + choice prompt "Select your board"
@@ -135,6 +142,13 @@ Say Y here if your are using Phytec's phyCORE-i.MX31 (pcm037) equipped with a Freescale i.MX31 Processor
+config MACH_OMAP + bool "Texas Instruments' OMAP based platforms" + select ARCH_OMAP + select MACH_CAN_MODIFY_MALLOC_START + help + Say Y if you are using Texas Instrument's OMAP based platforms + endchoice
config IMX_CLKO @@ -144,8 +158,9 @@ The i.MX SoCs have a Pin which can output different reference frequencies. Say y here if you want to have the clko command which lets you select the frequency to output on this pin. - + source arch/arm/mach-netx/Kconfig +source arch/arm/mach-omap/Kconfig
menu "Arm specific settings "
@@ -190,6 +205,13 @@ Provide the alternate malloc start address. Remember that the area that will be used will be (this address) to (this address - CFG_MALLOC_LEN - CONFIG_STACKSIZE)
+config ARMCORTEXA8_DCACHE_SKIP + bool "Skip DCache Invlidate" + depends on ARMCORTEXA8 + default n + help + If your architecture configuration uses some other method of disabling caches, enable this + So that the D-Cache invalidation logic is skipped endmenu
source common/Kconfig Index: u-boot-v2.git/arch/arm/Makefile =================================================================== --- u-boot-v2.git.orig/arch/arm/Makefile 2008-05-20 18:20:54.000000000 -0500 +++ u-boot-v2.git/arch/arm/Makefile 2008-05-20 18:20:54.000000000 -0500 @@ -6,6 +6,7 @@ machine-$(CONFIG_ARCH_IMX) := imx machine-$(CONFIG_ARCH_NETX) := netx machine-$(CONFIG_ARCH_AT91RM9200) := at91rm9200 +machine-$(CONFIG_ARCH_OMAP) := omap board-$(CONFIG_MACH_MX1ADS) := mx1ads board-$(CONFIG_MACH_ECO920) := eco920 board-$(CONFIG_MACH_SCB9328) := scb9328 @@ -13,6 +14,7 @@ board-$(CONFIG_MACH_IMX27ADS) := imx27ads board-$(CONFIG_MACH_NXDB500) := netx board-$(CONFIG_MACH_PCM037) := pcm037 +board-$(CONFIG_MACH_OMAP) := omap # FIXME "cpu-y" never used on ARM! cpu-$(CONFIG_ARM920T) := arm920t cpu-$(CONFIG_ARM926EJS) := arm926ejs @@ -22,6 +24,10 @@ CPPFLAGS += -mabi=apcs-gnu -DTEXT_BASE=$(TEXT_BASE) -P CFLAGS += -Os
+# Add architecture specific flags +ifeq ($(CONFIG_ARMCORTEXA8),y) +CPPFLAGS += -march=armv7a +endif
# Add cleanup flags CPPFLAGS += -fdata-sections -ffunction-sections Index: u-boot-v2.git/arch/arm/cpu/Makefile =================================================================== --- u-boot-v2.git.orig/arch/arm/cpu/Makefile 2008-05-20 18:18:43.000000000 -0500 +++ u-boot-v2.git/arch/arm/cpu/Makefile 2008-05-20 18:20:54.000000000 -0500 @@ -6,4 +6,5 @@ # obj-$(CONFIG_ARM920T) += start-arm.o obj-$(CONFIG_ARM926EJS) += start-arm.o +obj-$(CONFIG_ARMCORTEXA8) += start-arm.o obj-$(CONFIG_ARCH_IMX31) += start-arm.o Index: u-boot-v2.git/arch/arm/cpu/start-arm.S =================================================================== --- u-boot-v2.git.orig/arch/arm/cpu/start-arm.S 2008-05-20 18:20:54.000000000 -0500 +++ u-boot-v2.git/arch/arm/cpu/start-arm.S 2008-05-21 10:44:14.000000000 -0500 @@ -143,12 +143,66 @@ #ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT bl arch_init_lowlevel #endif + +#ifdef CONFIG_ARMCORTEXA8 + /* + * Invalidate v7 I/D caches + */ + mov r0, #0 /* set up for MCR */ + mcr p15, 0, r0, c8, c7, 0 /* invalidate TLBs */ + mcr p15, 0, r0, c7, c5, 0 /* invalidate icache */ + /* Invalidate all Dcaches */ +#ifndef CONFIG_ARMCORTEXA8_DCACHE_SKIP + /* If Arch specific ROM code SMI handling does not exist */ + mrc p15, 1, r0, c0, c0, 1 /* read clidr */ + ands r3, r0, #0x7000000 /* extract loc from clidr */ + mov r3, r3, lsr #23 /* left align loc bit field */ + beq finished_inval /* if loc is 0, then no need to clean */ + mov r10, #0 /* start clean at cache level 0 */ +inval_loop1: + add r2, r10, r10, lsr #1 /* work out 3x current cache level */ + mov r1, r0, lsr r2 /* extract cache type bits from clidr */ + and r1, r1, #7 /* mask of the bits for current cache only */ + cmp r1, #2 /* see what cache we have at this level */ + blt skip_inval /* skip if no cache, or just i-cache */ + mcr p15, 2, r10, c0, c0, 0 /* select current cache level in cssr */ + isb /* isb to sych the new cssr&csidr */ + mrc p15, 1, r1, c0, c0, 0 /* read the new csidr */ + and r2, r1, #7 /* extract the length of the cache lines */ + add r2, r2, #4 /* add 4 (line length offset) */ + ldr r4, =0x3ff + ands r4, r4, r1, lsr #3 /* find maximum number on the way size*/ + clz r5, r4 /* find bit position of way size increment */ + ldr r7, =0x7fff + ands r7, r7, r1, lsr #13 /* extract max number of the index size */ +inval_loop2: + mov r9, r4 /* create working copy of max way size */ +inval_loop3: + orr r11, r10, r9, lsl r5 /* factor way and cache number into r11*/ + orr r11, r11, r7, lsl r2 /* factor index number into r11 */ + mcr p15, 0, r11, c7, c6, 2 /* invalidate by set/way */ + subs r9, r9, #1 /* decrement the way */ + bge inval_loop3 + subs r7, r7, #1 /* decrement the index */ + bge inval_loop2 +skip_inval: + add r10, r10, #2 /* increment cache number */ + cmp r3, r10 + bgt inval_loop1 +finished_inval: + mov r10, #0 /* swith back to cache level 0 */ + mcr p15, 2, r10, c0, c0, 0 /* select current cache level in cssr */ + isb +#endif /* CONFIG_ARMCORTEXA8_DCACHE_SKIP */ + +#else /* * flush v4 I/D caches */ mov r0, #0 mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ +#endif
/* * disable MMU stuff and caches
+config ARMCORTEXA8
- bool
+config ARCH_OMAP
- bool
+config MACH_OMAP
- bool "Texas Instruments' OMAP based platforms"
- select ARCH_OMAP
- select MACH_CAN_MODIFY_MALLOC_START
- help
endchoice
- bool "Skip DCache Invlidate"
- depends on ARMCORTEXA8
- default n
- help
endmenu
- mov r0, #0 /* set up for MCR */
- mcr p15, 0, r0, c8, c7, 0 /* invalidate TLBs */
- mcr p15, 0, r0, c7, c5, 0 /* invalidate icache */
- /* Invalidate all Dcaches */
- /* If Arch specific ROM code SMI handling does not exist */
- mrc p15, 1, r0, c0, c0, 1 /* read clidr */
- ands r3, r0, #0x7000000 /* extract loc from clidr */
- mov r3, r3, lsr #23 /* left align loc bit field */
- beq finished_inval /* if loc is 0, then no need to clean */
- mov r10, #0 /* start clean at cache level 0 */
+inval_loop1:
- add r2, r10, r10, lsr #1 /* work out 3x current cache level */
- mov r1, r0, lsr r2 /* extract cache type bits from clidr */
- and r1, r1, #7 /* mask of the bits for current cache only */
- cmp r1, #2 /* see what cache we have at this level */
- blt skip_inval /* skip if no cache, or just i-cache */
- mcr p15, 2, r10, c0, c0, 0 /* select current cache level in cssr */
- isb /* isb to sych the new cssr&csidr */
- mrc p15, 1, r1, c0, c0, 0 /* read the new csidr */
- and r2, r1, #7 /* extract the length of the cache lines */
- add r2, r2, #4 /* add 4 (line length offset) */
- ldr r4, =0x3ff
- ands r4, r4, r1, lsr #3 /* find maximum number on the way size*/
- clz r5, r4 /* find bit position of way size increment */
- ldr r7, =0x7fff
- ands r7, r7, r1, lsr #13 /* extract max number of the index size */
+inval_loop2:
- mov r9, r4 /* create working copy of max way size */
+inval_loop3:
- orr r11, r10, r9, lsl r5 /* factor way and cache number into r11*/
- orr r11, r11, r7, lsl r2 /* factor index number into r11 */
- mcr p15, 0, r11, c7, c6, 2 /* invalidate by set/way */
- subs r9, r9, #1 /* decrement the way */
- bge inval_loop3
- subs r7, r7, #1 /* decrement the index */
- bge inval_loop2
+skip_inval:
- add r10, r10, #2 /* increment cache number */
- cmp r3, r10
- bgt inval_loop1
+finished_inval:
- mov r10, #0 /* swith back to cache level 0 */
- isb
Is this really ARMCORTEX specific or arm v7 specific? Anyway, this looks like the start of another ifdef mess, we should create some generic hook here.
Sascha
This is not Cortex A8 specific, it's v7-A (and hopefully will be the same in upcoming ARM architectures).
You could perhaps mimic the way the Linux kernel handles cache stuff for the various ARM architectures.
Laurent
-----Original Message----- From: Laurent Desnogues [mailto:laurent.desnogues@gmail.com] Sent: Tuesday, June 03, 2008 3:23 AM To: Menon, Nishanth; u-boot-users@lists.sourceforge.net; Laurent Desnogues; dirk.behme@googlemail.com; philip.balister@gmail.com; Gopinath, Thara; Kamat, Nishant; Syed Mohammed, Khasim Subject: Re: [Patch 10/17] U-Boot-V2:ARM:OMAP3: Add support for OMAP and Cortex A8
Probably ARM arch definitions need to be cleaned up a bit more? Granularity is restricted today to ARM CPU and not architecture..
Probably not the extent.. but yes to a lesser extent might be helpful. Common code will still exist, probably CP15 stuff can move out?
Regards, Nishanth Menon
Sascha,
-----Original Message----- From: Menon, Nishanth Sent: Tuesday, June 03, 2008 10:38 AM To: 'Laurent Desnogues'; u-boot-users@lists.sourceforge.net; dirk.behme@googlemail.com; philip.balister@gmail.com; Gopinath, Thara; Kamat, Nishant; Syed Mohammed, Khasim Subject: RE: [Patch 10/17] U-Boot-V2:ARM:OMAP3: Add support for OMAP and Cortex A8
-----Original Message----- From: Laurent Desnogues [mailto:laurent.desnogues@gmail.com] Sent: Tuesday, June 03, 2008 3:23 AM To: Menon, Nishanth; u-boot-users@lists.sourceforge.net; Laurent Desnogues; dirk.behme@googlemail.com; philip.balister@gmail.com; Gopinath, Thara; Kamat, Nishant; Syed Subject: Re: [Patch 10/17] U-Boot-V2:ARM:OMAP3: Add support for OMAP and Cortex A8
Keeping the current code, but resyncing based on MALLOC changes. Need clean up of ARM proc specific changes pretty soon I guess. ARMV4, V6, V7 support to be independent of common code.
--- arch/arm/Kconfig | 23 +++++++++++++++++++- arch/arm/Makefile | 6 +++++ arch/arm/cpu/Makefile | 1 arch/arm/cpu/start-arm.S | 54 +++++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 83 insertions(+), 1 deletion(-)
Index: u-boot.v2/arch/arm/Kconfig =================================================================== --- u-boot.v2.orig/arch/arm/Kconfig 2008-06-03 20:27:47.000000000 -0500 +++ u-boot.v2/arch/arm/Kconfig 2008-06-03 20:45:08.000000000 -0500 @@ -47,6 +47,9 @@ config ARM926EJS bool
@@ -135,6 +142,12 @@ Say Y here if your are using Phytec's phyCORE-i.MX31 (pcm037) equipped with a Freescale i.MX31 Processor
+config MACH_OMAP + bool "Texas Instruments' OMAP based platforms" + select ARCH_OMAP + help + Say Y if you are using Texas Instrument's OMAP based platforms + endchoice
config IMX_CLKO @@ -144,8 +157,9 @@ The i.MX SoCs have a Pin which can output different reference frequencies. Say y here if you want to have the clko command which lets you select the frequency to output on this pin. - + source arch/arm/mach-netx/Kconfig +source arch/arm/mach-omap/Kconfig
@@ -168,6 +182,13 @@ If you want to start a 2.6 kernel and use an initrd image say y here.
source common/Kconfig Index: u-boot.v2/arch/arm/Makefile =================================================================== --- u-boot.v2.orig/arch/arm/Makefile 2008-06-03 20:28:20.000000000 -0500 +++ u-boot.v2/arch/arm/Makefile 2008-06-03 20:42:53.000000000 -0500 @@ -5,6 +5,7 @@ machine-$(CONFIG_ARCH_IMX) := imx machine-$(CONFIG_ARCH_NETX) := netx machine-$(CONFIG_ARCH_AT91RM9200) := at91rm9200 +machine-$(CONFIG_ARCH_OMAP) := omap board-$(CONFIG_MACH_MX1ADS) := mx1ads board-$(CONFIG_MACH_ECO920) := eco920 board-$(CONFIG_MACH_SCB9328) := scb9328 @@ -12,6 +13,7 @@ board-$(CONFIG_MACH_IMX27ADS) := imx27ads board-$(CONFIG_MACH_NXDB500) := netx board-$(CONFIG_MACH_PCM037) := pcm037 +board-$(CONFIG_MACH_OMAP) := omap # FIXME "cpu-y" never used on ARM! cpu-$(CONFIG_ARM920T) := arm920t cpu-$(CONFIG_ARM926EJS) := arm926ejs @@ -70,6 +72,10 @@ PHONY += maketools maketools: include/asm-arm/.arch
ifneq ($(board-y),) BOARD := board/$(board-y)/ Index: u-boot.v2/arch/arm/cpu/Makefile =================================================================== --- u-boot.v2.orig/arch/arm/cpu/Makefile 2008-06-03 20:27:44.000000000 -0500 +++ u-boot.v2/arch/arm/cpu/Makefile 2008-06-03 20:42:53.000000000 -0500 @@ -6,4 +6,5 @@ # obj-$(CONFIG_ARM920T) += start-arm.o obj-$(CONFIG_ARM926EJS) += start-arm.o +obj-$(CONFIG_ARMCORTEXA8) += start-arm.o obj-$(CONFIG_ARCH_IMX31) += start-arm.o Index: u-boot.v2/arch/arm/cpu/start-arm.S =================================================================== --- u-boot.v2.orig/arch/arm/cpu/start-arm.S 2008-06-03 20:42:42.000000000 -0500 +++ u-boot.v2/arch/arm/cpu/start-arm.S 2008-06-03 20:42:53.000000000 -0500 @@ -157,12 +157,66 @@ #ifdef CONFIG_ARCH_HAS_LOWLEVEL_INIT bl arch_init_lowlevel #endif + +#ifdef CONFIG_ARMCORTEXA8 + /* + * Invalidate v7 I/D caches + */ + mov r0, #0 /* set up for MCR */ + mcr p15, 0, r0, c8, c7, 0 /* invalidate TLBs */ + mcr p15, 0, r0, c7, c5, 0 /* invalidate icache */ + /* Invalidate all Dcaches */ +#ifndef CONFIG_ARMCORTEXA8_DCACHE_SKIP + /* If Arch specific ROM code SMI handling does not exist */ + mrc p15, 1, r0, c0, c0, 1 /* read clidr */ + ands r3, r0, #0x7000000 /* extract loc from clidr */ + mov r3, r3, lsr #23 /* left align loc bit field */ + beq finished_inval /* if loc is 0, then no need to clean */ + mov r10, #0 /* start clean at cache level 0 */ +inval_loop1: + add r2, r10, r10, lsr #1 /* work out 3x current cache level */ + mov r1, r0, lsr r2 /* extract cache type bits from clidr */ + and r1, r1, #7 /* mask of the bits for current cache only */ + cmp r1, #2 /* see what cache we have at this level */ + blt skip_inval /* skip if no cache, or just i-cache */ + mcr p15, 2, r10, c0, c0, 0 /* select current cache level in cssr */ + isb /* isb to sych the new cssr&csidr */ + mrc p15, 1, r1, c0, c0, 0 /* read the new csidr */ + and r2, r1, #7 /* extract the length of the cache lines */ + add r2, r2, #4 /* add 4 (line length offset) */ + ldr r4, =0x3ff + ands r4, r4, r1, lsr #3 /* find maximum number on the way size*/ + clz r5, r4 /* find bit position of way size increment */ + ldr r7, =0x7fff + ands r7, r7, r1, lsr #13 /* extract max number of the index size */ +inval_loop2: + mov r9, r4 /* create working copy of max way size */ +inval_loop3: + orr r11, r10, r9, lsl r5 /* factor way and cache number into r11*/ + orr r11, r11, r7, lsl r2 /* factor index number into r11 */ + mcr p15, 0, r11, c7, c6, 2 /* invalidate by set/way */ + subs r9, r9, #1 /* decrement the way */ + bge inval_loop3 + subs r7, r7, #1 /* decrement the index */ + bge inval_loop2 +skip_inval: + add r10, r10, #2 /* increment cache number */ + cmp r3, r10 + bgt inval_loop1 +finished_inval: + mov r10, #0 /* swith back to cache level 0 */ + mcr p15, 2, r10, c0, c0, 0 /* select current cache level in cssr */ + isb +#endif /* CONFIG_ARMCORTEXA8_DCACHE_SKIP */ + +#else /* * flush v4 I/D caches */ mov r0, #0 mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */ mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */ +#endif
Laurent Desnogues
Menon, Nishanth
Sascha Hauer
