[U-Boot] [PATCH] [v2] mtd/nand: Fix IFC driver to support 2K NAND page
1) OOB area should be updated irrespective of NAND page size. Earlier it was updated only for 512byte NAND page.
2) During OOB update fbcr should be equal to OOB size.
Signed-off-by: Poonam Aggrwal poonam.aggrwal@freescale.com Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Based upon git://git.denx.de/u-boot.git (branch master)
Changes for v2- Incorporated Scott's comments from linuxppc-dev mailing list http://patchwork.ozlabs.org/patch/135010/ - Added missed NAND_CMD_READOOB - Updated function as per Scott's advice
drivers/mtd/nand/fsl_ifc_nand.c | 27 +++++++++++++-------------- 1 files changed, 13 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index cd1a434..27d2028 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -452,21 +452,19 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, out_be32(&ifc->ifc_nand.nand_fir1, (IFC_FIR_OP_CW1 << IFC_NAND_FIR1_OP5_SHIFT));
- if (column >= mtd->writesize) { - /* OOB area --> READOOB */ - column -= mtd->writesize; - nand_fcr0 |= NAND_CMD_READOOB << - IFC_NAND_FCR0_CMD0_SHIFT; - ctrl->oob = 1; - } else if (column < 256) { - /* First 256 bytes --> READ0 */ - nand_fcr0 |= NAND_CMD_READ0 << FCR_CMD0_SHIFT; - } else { - /* Second 256 bytes --> READ1 */ - nand_fcr0 |= NAND_CMD_READ1 << FCR_CMD0_SHIFT; - } + if (column >= mtd->writesize) + nand_fcr0 |= + NAND_CMD_READOOB << IFC_NAND_FCR0_CMD0_SHIFT; + else + nand_fcr0 |= + NAND_CMD_READ0 << IFC_NAND_FCR0_CMD0_SHIFT; }
+ if (column >= mtd->writesize) { + /* OOB area --> READOOB */ + column -= mtd->writesize; + ctrl->oob = 1; + } out_be32(&ifc->ifc_nand.nand_fcr0, nand_fcr0); set_addr(mtd, column, page_addr, ctrl->oob); return; @@ -475,7 +473,8 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, /* PAGEPROG reuses all of the setup from SEQIN and adds the length */ case NAND_CMD_PAGEPROG: if (ctrl->oob) - out_be32(&ifc->ifc_nand.nand_fbcr, ctrl->index); + out_be32(&ifc->ifc_nand.nand_fbcr, + ctrl->index - ctrl->column); else out_be32(&ifc->ifc_nand.nand_fbcr, 0);
On Fri, Jan 20, 2012 at 06:39:05PM +0530, Prabhakar Kushwaha wrote:
- OOB area should be updated irrespective of NAND page size. Earlier it was
- During OOB update fbcr should be equal to OOB size.
Applied to u-boot-nand-flash
-Scott
Prabhakar Kushwaha
Scott Wood
