[U-Boot] [PATCH 3/4] rapidio: add documentation for RapidIO boot
This commit adds the RapidIO boot functionality documentation. Its explains what RapidIO boot feature does, how to use it and the basic API that must be provided by a RapidIO hw controller driver.
Signed-off-by: Aurelien Jacquiot a-jacquiot@ti.com --- doc/README.rapidio | 158 ++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 158 insertions(+), 0 deletions(-) create mode 100644 doc/README.rapidio
diff --git a/doc/README.rapidio b/doc/README.rapidio new file mode 100644 index 0000000..e360a7f --- /dev/null +++ b/doc/README.rapidio @@ -0,0 +1,158 @@ + RapidIO support for TI KeyStone devices + ======================================= + + +This feature allows to boot a device through RapidIO using DirectI/O (DIO). +A new set of commands is added to U-Boot for this purpose. + +This feature is today designed to work with Texas Instruments KeyStone devices +but may be easily extended to be used on different architectures. + +How it works +------------ + +This booting mechanism uses the DirectI/O functionality which allows a +remote devices to directly read and write into the device address space +(so basically here into the DDR or any mapped memory such as MSM). + +The boot sequence is pretty simple. The RIO boot initializes the RapidIO +controller then the link partner needs to push the various images (kernel, +fdt, ...). When images are loaded into their respective locations by the peer, +U-Boot can start the images normally like with any other boot mechanismes. + +It is the link partner responsability to push the various images in the device +memory then signaling U-Boot that images have been loaded. + +for that purpose, the simpler way is to use the 'mwait' U-Boot command which +allows to wait a defined value in memory. The link partner has only to write +the expected value at a given address when it has pushed all images. + +Basically the sequence should be the following (A is the device to be booted, B +is the link partner device which pushes the images to boot): + + [B]: board is up and booted, RapidIO controller is initialized but not the link + [A]: board is powered on, entering U-Boot + [A]: the 'rio init' command is called + [A]: U-Boot configures the local RapidIO controller and hardware waits the link + establishement + [B]: Linux kernel starts the RapidIO link configuration and eventually the + RapidIO enumeration/discovery process (see Linux kernel RapidIO subsytem + driver for more information) + [AB]: RapidIO link is now established between the both link partners + [A]: the 'mwait 0x80000000 0xbadface' command is called + [A]: U-Boot reads the first word at beginning of the DDR in loop and waits + until it is set to 0xbadface + [B]: system pushes the kernel image using DIO + [B]: system pushes the dtb image using DIO + [B]: system pushes the skern image using DIO + [B]: system set the 0xbadface value at the first word of the remote DDR + [A]: U-Boot detects that first DDR word has changed to 0xbadface and exits the + mwait command + [A]: skern, fdt and kernel can be installed and started normally with the + 'mon_install' and 'bootm' U-Boot commands + +RapidIO subsystem commands +-------------------------- + + - rio init [dev_id] [id_size] [port_mask] [pathmode] [baudrate]: + This command is used to initialize the RapidIO controller. Optional + parameters are used to define the RapidIO configuration. + Note that environment variables can be instead of parameters. + + 1) dev_id ('riohdid' environment variable) to set the host device Id. + By default if not specified it is set to -1. + + 2) id_size ('riosize' environment variable) to indicate the Ids size + (0 for small, 1 for big). By default it is set to 0 (small Ids). + + 3) port_mask ('rioports' environment variable) is a bitmask of ports to use. + By default it is set to 0x1 (port 0). + + 4) pathmode ('riopathmode' environment variable) defines the port path mode + (mapping of ports over lanes). The default mode is 0 (4 independent ports + in 1x). + + 5) baudrate ('riobaudrate' environment variable) defines the port speed: + 0 for 1.25Gbps, 1 for 2.5Gbps, 2 for 3.125Gbps, 3 for 5Gbps and 4 for + 6.25Gpbs (if supported). It is set by default to 2 (2.5Gbps). + + - rio shutdown: It disables the RapidIO controller. + + - rio r port dev_id hopcount offset: This command allows to read the remote + RapidIO configuration space by performing a maintenance read request. + + - rio w port dev_id hopcount offset value: This command allows to write into + the remote RapidIO configuration space by performing a maintenance write + request. + + - rio lr offset: This performs a local RapidIO configuration space read. + + - rio lw offset value: This performs a local RapidIO configuration space write. + +Device support +-------------- + +The RapidIO controller of the KeyStone devices is supported through the +drivers/rapidio/keystone_rio.c device driver. + +The RapidIO driver must export the following functions (see include/rio.h for +full prototypes). + + - rio_init() : initialize RapidIO controller + - rio_shutdown(): shutdown RapidIO controller + - rio_config_read(): perform a RapidIO maintenance read transaction + - rio_config_write(): perform a RapidIO maintenance read transaction + - rio_local_config_read(): local configuration space read + - rio_local_config_write(): local configuration space write + +Booting with RapidIO +-------------------- + +Example of RapidIO booting with U-Boot: + +K2HK EVM # rio init -1 0 0x1 4 3 +rioboot: waiting for link up ... +KeyStone RapidIO driver v1.1, hdid=-1 +RIO: initializing 5.00 Gbps interface with port configuration 4 +RIO: port RIO0 ready +K2HK EVM # mwait 0x80000000 0xbadface +waiting 0xbadface at 0x80000000... +K2HK EVM # mon_install ${addr_mon} +## installed monitor, freq [200000000], status 0 +K2HK EVM # bootm ${addr_kern} ${addr_uninitrd} ${addr_fdt} +## Booting kernel from Legacy Image at 88000000 ... + Image Name: Linux-3.8.4 + Created: 2014-01-27 17:48:10 UTC + Image Type: ARM Linux Kernel Image (uncompressed) + Data Size: 3990680 Bytes = 3.8 MiB + Load Address: 80008000 + Entry Point: 80008000 + Verifying Checksum ... OK + +----- + +Here is an example under Linux using the riodio utility and the riodev feature +of the booting of a remote device which uses U-Boot RapidIO booting mechanism +(like the example above): + +# riodio -f uImage /dev/rio0.1 0x88000000 +# riodio -f k2hk-evm.dtb /dev/rio0.1 0x87000000 +# riodio -f skern-keystone-evm.bin /dev/rio0.1 0xc5f0000 +# riodio -v 0xbadface /dev/rio0.1 0x80000000 + +This will push the various images and notify U-Boot. + +----- + +Example of (local and remote) read/write commands: + +K2HK EVM # rio r 0 -1 1 0x0 +00000000: b9810030 0... +K2HK EVM # rio r 0 -1 1 0x4 +00000004: 00000000 .... +K2HK EVM # rio r 0 -1 1 0x8 +00000008: 00000030 0... +K2HK EVM # rio lr 0 +00000000: b9810030 0... +K2HK EVM # rio lr 8 +00000008: 00000030 0...
Please fold this into the last patch in the series, thanks!
