[U-Boot] [PATCH v3] Remove static type from gunzip_bmp()
The current bmp routines support gzipped files, but compilation fails (under AVR32) due to the gunzip_bmp() function being defined as static.
This patch fixes this problem.
The gunzip_bmp routine has also now been defined in the lcd.h header file.
Signed-off-by: Mark Jackson mpfj@mimc.co.uk ---
common/cmd_bmp.c | 4 ++-- common/lcd.c | 4 ---- include/lcd.h | 4 ++++ 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/common/cmd_bmp.c b/common/cmd_bmp.c index bc08b26..084ef98 100644 --- a/common/cmd_bmp.c +++ b/common/cmd_bmp.c @@ -46,7 +46,7 @@ int gunzip(void *, int, unsigned char *, unsigned long *); * didn't contain a valid BMP signature. */ #ifdef CONFIG_VIDEO_BMP_GZIP -static bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) +bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) { void *dst; unsigned long len; @@ -85,7 +85,7 @@ static bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) return bmp; } #else -static bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) +bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp) { return NULL; } diff --git a/common/lcd.c b/common/lcd.c index 8cbb540..23196d6 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -789,10 +789,6 @@ int lcd_display_bitmap(ulong bmp_image, int x, int y) } #endif
-#ifdef CONFIG_VIDEO_BMP_GZIP -extern bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp); -#endif - static void *lcd_logo (void) { #ifdef CONFIG_SPLASH_SCREEN diff --git a/include/lcd.h b/include/lcd.h index 3184803..41ee6bc 100644 --- a/include/lcd.h +++ b/include/lcd.h @@ -208,6 +208,10 @@ void lcd_show_board_info(void); # include <asm/byteorder.h> #endif
+#ifdef CONFIG_VIDEO_BMP_GZIP +extern bmp_image_t *gunzip_bmp(unsigned long addr, unsigned long *lenp); +#endif + /* * Information about displays we are using. This is for configuring * the LCD controller and memory allocation. Someone has to know what
Dear Mark Jackson,
Sorry, this patch does not apply - not even after fixing the line wrpping done by your mailer.
Please fix your mailer setup, rebase the patch and resubmit.
Mark Jackson
