[U-Boot] [PATCH 2/2] Add instruction file (based on the README for the sabrelite) for booting the Congatec board from SD-Card.
Signed-off-by: Leo Sartre lsartre@adeneo-embedded.com --- board/freescale/cgtqmx6/README | 35 +++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100644 board/freescale/cgtqmx6/README
diff --git a/board/freescale/cgtqmx6/README b/board/freescale/cgtqmx6/README new file mode 100644 index 0000000..bcacc71 --- /dev/null +++ b/board/freescale/cgtqmx6/README @@ -0,1 +1,35 @@ +U-Boot for the Congatec Conga-QEVAl Evaluation Carrier board + +This file contains information for the port of U-Boot to the Congatec +Conga-QEVAl Evaluation Carrier board. + +1. Boot source, boot from SD card +--------------------------------- + +This version of u-boot works only on the SD card. By default, the +Congatec board boot from the SPI-NOR. +With the uboot version provided with the board you can write boot +registers to force the board to reboot and boot from the SD slot: + +conga-QMX6 U-Boot > mw.l 0x20d8040 0x3850 +conga-QMX6 U-Boot > mw.l 0x020d8044 0x10000000 +conga-QMX6 U-Boot > reset +resetting ... + +The the board will reboot and, if you burnt your SD correctly the +board (see (2) for instructions) will use u-boot that live into the SD +card. + +2. Build +-------- + +To build U-Boot for the Congatec board: + + make cgtqmx6_config + make u-boot.imx + +To copy the resulting u-boot.imx to the SD card: + + sudo dd if=u-boot.imx of=/dev/sXx bs=512 seek=2&&sudo sync + +Note: Replace sXx with the device representing the SD card in your system.
Dear "SARTRE Leo",
In message 3465D313FDFB824F9A9C8CD24FA4F6BC0108CCF4@frontmail.adetel.com you wrote:
There is no good reason for making this a separate commit. Please squash with the other commit.
But is this not exactly the purpose of the "bmode" command ? Anyway, at next power-on, the board boots again from SPI-NOR. There should be indication here how to erase the SPI Flash
+2. Build +--------
- make cgtqmx6_config
- make u-boot.imx
You do not need it. This is the general instruction to build any board in u-boot, and u-boot.imx is automatically generated for i.MX6 boards.
- sudo dd if=u-boot.imx of=/dev/sXx bs=512 seek=2&&sudo sync
This can be wrong if the Linux PC uses /dev/mmcblk* instead of /dev/sXx
Best regards, Stefano Babic
SARTRE Leo
Stefano Babic
