[U-Boot] [PATCH 2/2 V3] ppc4xx: Initialize magnetic couplers in PLU405
This patch fixes an ugly behavior of the IL712 magnetic couplers as used on PLU405. These parts will remember their last state over a power cycle which might cause unwanted behavior.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd.eu --- V2: - use C struct to access CAN controller registes
V3: - move SJA1000 stuff into separate header (see preceding patch) - some renaming
board/esd/plu405/plu405.c | 36 ++++++++++++++++++++++++++++++++++++ include/configs/PLU405.h | 3 ++- 2 files changed, 38 insertions(+), 1 deletions(-)
diff --git a/board/esd/plu405/plu405.c b/board/esd/plu405/plu405.c index 1841cda..fea7b26 100644 --- a/board/esd/plu405/plu405.c +++ b/board/esd/plu405/plu405.c @@ -26,6 +26,7 @@ #include <asm/io.h> #include <command.h> #include <malloc.h> +#include <sja1000.h>
#undef FPGA_DEBUG
@@ -45,6 +46,34 @@ const unsigned char fpgadata[] = */ #include "../common/fpga.c"
+/* + * generate a short spike on the CAN tx line + * to bring the couplers in sync + */ +void init_coupler(u32 addr) +{ + struct sja1000_basic_s *ctrl = (struct sja1000_basic_s *)addr; + + /* reset */ + out_8(&ctrl->cr, CR_RR); + + /* dominant */ + out_8(&ctrl->btr0, 0x00); /* btr setup is required */ + out_8(&ctrl->btr1, 0x14); /* we use 1Mbit/s */ + out_8(&ctrl->oc, OC_TP1 | OC_TN1 | OC_POL1 | + OC_TP0 | OC_TN0 | OC_POL0 | OC_MODE1); + out_8(&ctrl->cr, 0x00); + + /* delay */ + in_8(&ctrl->cr); + in_8(&ctrl->cr); + in_8(&ctrl->cr); + in_8(&ctrl->cr); + + /* reset */ + out_8(&ctrl->cr, CR_RR); +} + /* Prototypes */ int gunzip(void *, int, unsigned char *, unsigned long *);
@@ -198,6 +227,13 @@ int misc_init_r(void) out_8((void *)DUART1_BA + 1, fctr); /* write FCTR */ out_8((void *)DUART1_BA + 3, 0); /* write LCR */
+ /* + * Init magnetic couplers + */ + if (!getenv("noinitcoupler")) { + init_coupler(CAN0_BA); + init_coupler(CAN1_BA); + } return 0; }
diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 07fc715..b6740de 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -298,7 +298,8 @@ /* * External Bus Controller (EBC) Setup */ -#define CAN_BA 0xF0000000 /* CAN Base Address */ +#define CAN0_BA 0xF0000000 /* CAN0 Base Address */ +#define CAN1_BA 0xF0000100 /* CAN1 Base Address */ #define DUART0_BA 0xF0000400 /* DUART Base Address */ #define DUART1_BA 0xF0000408 /* DUART Base Address */ #define RTC_BA 0xF0000500 /* RTC Base Address */
Applied to u-boot-ppc4xx/master. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Matthias Fuchs
Stefan Roese
