[U-Boot-Users] reg u-boot 1.1.6 integeration to ISP 1561
Hi
Iam using ISP 1561 usb controller in a PPC board While trying to integrate the usb controller iam facing these problems
The OHCI root hub is detected but the usb mass storage device( usb flash stick) is not detected
I found the following
1. Under common/usb.c
struct usb_device * usb_get_dev_index(int index) { if(usb_dev[index].devnum==-1) return NULL; else return &usb_dev[index]; }
This structure is returning NULL for me ...
Whether the device number for the usb is not allocated ??
2. If i comment the if statement above and leave alone
it is proceding but it gets out once it comes to usb_storage_probe routine
The endianness is followed correctly becaz i used debug statements and i can see the OHCI registers are written with proper endianness
Can u help me to sort out the problem why the storage device is not detected ?
Thanks in advance Raja
--------------------------------- Heres a new way to find what you're looking for - Yahoo! Answers
mahendra varman
