[U-Boot] [PATCH] Remove inline qualifier from show_boot_progress()
The 'inline' is conflicting with the semantic of 'weak' attribute and with the way the show_boot_progress() function is used.
Also gcc 4.4 is complaining about it:
main.c:51: error: inline function 'show_boot_progress' cannot be declared weak
Signed-off-by: Emil Medve Emilian.Medve@Freescale.com --- common/main.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/common/main.c b/common/main.c index 905d40f..026edd1 100644 --- a/common/main.c +++ b/common/main.c @@ -48,7 +48,7 @@ DECLARE_GLOBAL_DATA_PTR; * Board-specific Platform code can reimplement show_boot_progress () if needed */ void inline __show_boot_progress (int val) {} -void inline show_boot_progress (int val) __attribute__((weak, alias("__show_boot_progress"))); +void show_boot_progress (int val) __attribute__((weak, alias("__show_boot_progress")));
#if defined(CONFIG_BOOT_RETRY_TIME) && defined(CONFIG_RESET_TO_RETRY) extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); /* for do_reset() prototype */
Dear Emil Medve,
In message 1242154112-26900-1-git-send-email-Emilian.Medve@Freescale.com you wrote:
Applied, thanks.
Emil Medve
