[PATCH] board: phytec: k3: k3_ddrss_patch: Add ddr phy reg count
Add and use the correct number of ddr phy registers to update the corresponding settings.
Fixes: cbf5c99ef317 ("board: phytec: common: Introduce a method to inject DDR timings deltas") Signed-off-by: Dominik Haller d.haller@phytec.de --- board/phytec/common/k3/k3_ddrss_patch.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/board/phytec/common/k3/k3_ddrss_patch.c b/board/phytec/common/k3/k3_ddrss_patch.c index 39f7be8dc922..5afe5a20c7f3 100644 --- a/board/phytec/common/k3/k3_ddrss_patch.c +++ b/board/phytec/common/k3/k3_ddrss_patch.c @@ -12,6 +12,7 @@ #ifdef CONFIG_K3_AM64_DDRSS #define LPDDR4_INTR_CTL_REG_COUNT (423U) #define LPDDR4_INTR_PHY_INDEP_REG_COUNT (345U) +#define LPDDR4_INTR_PHY_REG_COUNT (1406U) #endif
static int fdt_setprop_inplace_idx_u32(void *fdt, int nodeoffset, @@ -54,7 +55,7 @@ int fdt_apply_ddrss_timings_patch(void *fdt, struct ddrss *ddrss) return ret; }
- for (i = 0; i < LPDDR4_INTR_PHY_INDEP_REG_COUNT; i++) + for (i = 0; i < LPDDR4_INTR_PHY_REG_COUNT; i++) for (j = 0; j < ddrss->phy_regs_num; j++) if (i == ddrss->phy_regs[j].off) { ret = fdt_setprop_inplace_idx_u32(fdt,
Am 02.07.24 um 11:22 schrieb Dominik Haller:
Reviewed-by: Wadim Egorov w.egorov@phytec.de
- for (i = 0; i < LPDDR4_INTR_PHY_REG_COUNT; i++) for (j = 0; j < ddrss->phy_regs_num; j++) if (i == ddrss->phy_regs[j].off) { ret = fdt_setprop_inplace_idx_u32(fdt,
Dominik Haller
Wadim Egorov
