[U-Boot] [PATCH] mkenvimage: Fix compiler warning
Fix the compiler warning
mkenvimage.c: In function ‘main’: mkenvimage.c:218: warning: format ‘%ld’ expects type ‘long int’, but argument 3 has type ‘unsigned int’ mkenvimage.c:226: warning: format ‘%ld’ expects type ‘long int’, but argument 3 has type ‘unsigned int’
introduced with the commit
mkenvimage: Use mmap() when reading from a regular file 6ee39f8055680654f9cc97b98dcce9588f1ab71e
Signed-off-by: Dirk Behme dirk.behme@googlemail.com CC: David Wagner david.wagner@free-electrons.com CC: Anatolij Gustschin agust@denx.de CC: Mike Frysinger vapier@gentoo.org --- tools/mkenvimage.c | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/mkenvimage.c b/tools/mkenvimage.c index 9dbb3b2..1298998 100644 --- a/tools/mkenvimage.c +++ b/tools/mkenvimage.c @@ -213,7 +213,7 @@ int main(int argc, char **argv) filebuf = mmap(NULL, sizeof(*envptr) * filesize, PROT_READ, MAP_PRIVATE, txt_fd, 0); if (filebuf == MAP_FAILED) { - fprintf(stderr, "mmap (%ld bytes) failed: %s\n", + fprintf(stderr, "mmap (%d bytes) failed: %s\n", sizeof(*envptr) * filesize, strerror(errno)); fprintf(stderr, "Falling back to read()\n"); @@ -221,7 +221,7 @@ int main(int argc, char **argv) filebuf = malloc(sizeof(*envptr) * filesize); ret = read(txt_fd, filebuf, sizeof(*envptr) * filesize); if (ret != sizeof(*envptr) * filesize) { - fprintf(stderr, "Can't read the whole input file (%ld bytes): %s\n", + fprintf(stderr, "Can't read the whole input file (%d bytes): %s\n", sizeof(*envptr) * filesize, strerror(errno));
Signed-off-by: Dirk Behmedirk.behme@googlemail.com CC: David Wagnerdavid.wagner@free-electrons.com CC: Anatolij Gustschinagust@denx.de CC: Mike Frysingervapier@gentoo.org
this patch would now trigger a -Wformat on 64-bit hosts. you should use the size_t formatter '%zu'.
ditto!
br -h
Dirk Behme
Horst Kronstorfer
