[U-Boot] [PATCH 0/2] Sync compiler*.h with Linux 3.16
Masahiro Yamada (2): compiler*.h: sync include/linux/compiler*.h with Linux 3.16 standalone: use GCC_VERSION defined in compiler-gcc.h
examples/standalone/stubs.c | 7 +--- include/linux/compiler-clang.h | 12 ++++++ include/linux/compiler-gcc.h | 57 ++++++++++++++++++-------- include/linux/compiler-gcc3.h | 20 ++++----- include/linux/compiler-gcc4.h | 59 +++++++++++++++++++-------- include/linux/compiler-intel.h | 40 ++++++++++++++++++ include/linux/compiler.h | 92 +++++++++++++++++++++++++++++++++++++++++- 7 files changed, 238 insertions(+), 49 deletions(-) create mode 100644 include/linux/compiler-clang.h create mode 100644 include/linux/compiler-intel.h
Copy them from Linux v3.16 tag. My main motivation of this commit is to add compiler-clang.h.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Jeroen Hofstee jeroen@myspectrum.nl ---
I built all the supported board and compared MD5SUM. I confirmed this patch does not change the produced binaries.
include/linux/compiler-clang.h | 12 ++++++ include/linux/compiler-gcc.h | 57 ++++++++++++++++++-------- include/linux/compiler-gcc3.h | 20 ++++----- include/linux/compiler-gcc4.h | 59 +++++++++++++++++++-------- include/linux/compiler-intel.h | 40 ++++++++++++++++++ include/linux/compiler.h | 92 +++++++++++++++++++++++++++++++++++++++++- 6 files changed, 236 insertions(+), 44 deletions(-) create mode 100644 include/linux/compiler-clang.h create mode 100644 include/linux/compiler-intel.h
diff --git a/include/linux/compiler-clang.h b/include/linux/compiler-clang.h new file mode 100644 index 0000000..d1e49d5 --- /dev/null +++ b/include/linux/compiler-clang.h @@ -0,0 +1,12 @@ +#ifndef __LINUX_COMPILER_H +#error "Please don't include <linux/compiler-clang.h> directly, include <linux/compiler.h> instead." +#endif + +/* Some compiler specific definitions are overwritten here + * for Clang compiler + */ + +#ifdef uninitialized_var +#undef uninitialized_var +#define uninitialized_var(x) x = *(&(x)) +#endif diff --git a/include/linux/compiler-gcc.h b/include/linux/compiler-gcc.h index 9896e54..02ae99e 100644 --- a/include/linux/compiler-gcc.h +++ b/include/linux/compiler-gcc.h @@ -5,6 +5,9 @@ /* * Common definitions for all gcc versions go here. */ +#define GCC_VERSION (__GNUC__ * 10000 \ + + __GNUC_MINOR__ * 100 \ + + __GNUC_PATCHLEVEL__)
/* Optimization barrier */ @@ -34,9 +37,15 @@ __asm__ ("" : "=r"(__ptr) : "0"(ptr)); \ (typeof(ptr)) (__ptr + (off)); })
+/* Make the optimizer believe the variable can be manipulated arbitrarily. */ +#define OPTIMIZER_HIDE_VAR(var) __asm__ ("" : "=r" (var) : "0" (var)) + +#ifdef __CHECKER__ +#define __must_be_array(arr) 0 +#else /* &a[0] degrades to a pointer: a different type from an array */ -#define __must_be_array(a) \ - BUILD_BUG_ON_ZERO(__builtin_types_compatible_p(typeof(a), typeof(&a[0]))) +#define __must_be_array(a) BUILD_BUG_ON_ZERO(__same_type((a), &(a)[0])) +#endif
/* * Force always-inline if the user requests it so via the .config, @@ -44,15 +53,18 @@ */ #if !defined(CONFIG_ARCH_SUPPORTS_OPTIMIZED_INLINING) || \ !defined(CONFIG_OPTIMIZE_INLINING) || (__GNUC__ < 4) -# define inline inline __attribute__((always_inline)) -# define __inline__ __inline__ __attribute__((always_inline)) -# define __inline __inline __attribute__((always_inline)) +# define inline inline __attribute__((always_inline)) notrace +# define __inline__ __inline__ __attribute__((always_inline)) notrace +# define __inline __inline __attribute__((always_inline)) notrace +#else +/* A lot of inline functions can cause havoc with function tracing */ +# define inline inline notrace +# define __inline__ __inline__ notrace +# define __inline __inline notrace #endif
#define __deprecated __attribute__((deprecated)) -#ifndef __packed -# define __packed __attribute__((packed)) -#endif +#define __packed __attribute__((packed)) #define __weak __attribute__((weak))
/* @@ -60,8 +72,12 @@ * naked functions because then mcount is called without stack and frame pointer * being set up and there is no chance to restore the lr register to the value * before mcount was called. + * + * The asm() bodies of naked functions often depend on standard calling conventions, + * therefore they must be noinline and noclone. GCC 4.[56] currently fail to enforce + * this, so we must do so ourselves. See GCC PR44290. */ -#define __naked __attribute__((naked)) notrace +#define __naked __attribute__((naked)) noinline __noclone notrace
#define __noreturn __attribute__((noreturn))
@@ -75,13 +91,10 @@ * would be. * [...] */ -#ifndef __pure -# define __pure __attribute__((pure)) -#endif -#ifndef __aligned -# define __aligned(x) __attribute__((aligned(x))) -#endif -#define __printf(a,b) __attribute__((format(printf,a,b))) +#define __pure __attribute__((pure)) +#define __aligned(x) __attribute__((aligned(x))) +#define __printf(a, b) __attribute__((format(printf, a, b))) +#define __scanf(a, b) __attribute__((format(scanf, a, b))) #define noinline __attribute__((noinline)) #define __attribute_const__ __attribute__((__const__)) #define __maybe_unused __attribute__((unused)) @@ -91,3 +104,15 @@ #define _gcc_header(x) __gcc_header(linux/compiler-gcc##x.h) #define gcc_header(x) _gcc_header(x) #include gcc_header(__GNUC__) + +#if !defined(__noclone) +#define __noclone /* not needed */ +#endif + +/* + * A trick to suppress uninitialized variable warning without generating any + * code + */ +#define uninitialized_var(x) x = x + +#define __always_inline inline __attribute__((always_inline)) diff --git a/include/linux/compiler-gcc3.h b/include/linux/compiler-gcc3.h index 2befe65..7d89feb 100644 --- a/include/linux/compiler-gcc3.h +++ b/include/linux/compiler-gcc3.h @@ -2,20 +2,22 @@ #error "Please don't include <linux/compiler-gcc3.h> directly, include <linux/compiler.h> instead." #endif
-#if __GNUC_MINOR__ >= 3 +#if GCC_VERSION < 30200 +# error Sorry, your compiler is too old - please upgrade it. +#endif + +#if GCC_VERSION >= 30300 # define __used __attribute__((__used__)) #else # define __used __attribute__((__unused__)) #endif
-#if __GNUC_MINOR__ >= 4 +#if GCC_VERSION >= 30400 #define __must_check __attribute__((warn_unused_result)) #endif
-/* - * A trick to suppress uninitialized variable warning without generating any - * code - */ -#define uninitialized_var(x) x = x - -#define __always_inline inline __attribute__((always_inline)) +#ifdef CONFIG_GCOV_KERNEL +# if GCC_VERSION < 30400 +# error "GCOV profiling support for gcc versions below 3.4 not included" +# endif /* __GNUC_MINOR__ */ +#endif /* CONFIG_GCOV_KERNEL */ diff --git a/include/linux/compiler-gcc4.h b/include/linux/compiler-gcc4.h index 27d11ca..2507fd2 100644 --- a/include/linux/compiler-gcc4.h +++ b/include/linux/compiler-gcc4.h @@ -4,7 +4,7 @@
/* GCC 4.1.[01] miscompiles __weak */ #ifdef __KERNEL__ -# if __GNUC_MINOR__ == 1 && __GNUC_PATCHLEVEL__ <= 1 +# if GCC_VERSION >= 40100 && GCC_VERSION <= 40101 # error Your version of gcc miscompiles the __weak directive # endif #endif @@ -12,17 +12,12 @@ #define __used __attribute__((__used__)) #define __must_check __attribute__((warn_unused_result)) #define __compiler_offsetof(a,b) __builtin_offsetof(a,b) -#ifndef __always_inline -# define __always_inline inline __attribute__((always_inline)) -#endif
-/* - * A trick to suppress uninitialized variable warning without generating any - * code - */ -#define uninitialized_var(x) x = x +#if GCC_VERSION >= 40100 && GCC_VERSION < 40600 +# define __compiletime_object_size(obj) __builtin_object_size(obj, 0) +#endif
-#if __GNUC_MINOR__ >= 3 +#if GCC_VERSION >= 40300 /* Mark functions as cold. gcc will assume any path leading to a call to them will be unlikely. This means a lot of manual unlikely()s are unnecessary now for any paths leading to the usual suspects @@ -38,8 +33,15 @@ the kernel context */ #define __cold __attribute__((__cold__))
+#define __UNIQUE_ID(prefix) __PASTE(__PASTE(__UNIQUE_ID_, prefix), __COUNTER__)
-#if __GNUC_MINOR__ >= 5 +#ifndef __CHECKER__ +# define __compiletime_warning(message) __attribute__((warning(message))) +# define __compiletime_error(message) __attribute__((error(message))) +#endif /* __CHECKER__ */ +#endif /* GCC_VERSION >= 40300 */ + +#if GCC_VERSION >= 40500 /* * Mark a position in code as unreachable. This can be used to * suppress control flow warnings after asm blocks that transfer @@ -50,14 +52,37 @@ * unreleased. Really, we need to have autoconf for the kernel. */ #define unreachable() __builtin_unreachable() -#endif
+/* Mark a function definition as prohibited from being cloned. */ +#define __noclone __attribute__((__noclone__)) + +#endif /* GCC_VERSION >= 40500 */ + +#if GCC_VERSION >= 40600 +/* + * Tell the optimizer that something else uses this function or variable. + */ +#define __visible __attribute__((externally_visible)) #endif
-#if __GNUC_MINOR__ > 0 -#define __compiletime_object_size(obj) __builtin_object_size(obj, 0) +/* + * GCC 'asm goto' miscompiles certain code sequences: + * + * http://gcc.gnu.org/bugzilla/show_bug.cgi?id=58670 + * + * Work it around via a compiler barrier quirk suggested by Jakub Jelinek. + * Fixed in GCC 4.8.2 and later versions. + * + * (asm goto is automatically volatile - the naming reflects this.) + */ +#define asm_volatile_goto(x...) do { asm goto(x); asm (""); } while (0) + +#ifdef CONFIG_ARCH_USE_BUILTIN_BSWAP +#if GCC_VERSION >= 40400 +#define __HAVE_BUILTIN_BSWAP32__ +#define __HAVE_BUILTIN_BSWAP64__ #endif -#if __GNUC_MINOR__ >= 4 -#define __compiletime_warning(message) __attribute__((warning(message))) -#define __compiletime_error(message) __attribute__((error(message))) +#if GCC_VERSION >= 40800 || (defined(__powerpc__) && GCC_VERSION >= 40600) +#define __HAVE_BUILTIN_BSWAP16__ #endif +#endif /* CONFIG_ARCH_USE_BUILTIN_BSWAP */ diff --git a/include/linux/compiler-intel.h b/include/linux/compiler-intel.h new file mode 100644 index 0000000..ba147a1 --- /dev/null +++ b/include/linux/compiler-intel.h @@ -0,0 +1,40 @@ +#ifndef __LINUX_COMPILER_H +#error "Please don't include <linux/compiler-intel.h> directly, include <linux/compiler.h> instead." +#endif + +#ifdef __ECC + +/* Some compiler specific definitions are overwritten here + * for Intel ECC compiler + */ + +#include <asm/intrinsics.h> + +/* Intel ECC compiler doesn't support gcc specific asm stmts. + * It uses intrinsics to do the equivalent things. + */ +#undef RELOC_HIDE +#undef OPTIMIZER_HIDE_VAR + +#define RELOC_HIDE(ptr, off) \ + ({ unsigned long __ptr; \ + __ptr = (unsigned long) (ptr); \ + (typeof(ptr)) (__ptr + (off)); }) + +/* This should act as an optimization barrier on var. + * Given that this compiler does not have inline assembly, a compiler barrier + * is the best we can do. + */ +#define OPTIMIZER_HIDE_VAR(var) barrier() + +/* Intel ECC compiler doesn't support __builtin_types_compatible_p() */ +#define __must_be_array(a) 0 + +#endif + +#ifndef __HAVE_BUILTIN_BSWAP16__ +/* icc has this, but it's called _bswap16 */ +#define __HAVE_BUILTIN_BSWAP16__ +#define __builtin_bswap16 _bswap16 +#endif + diff --git a/include/linux/compiler.h b/include/linux/compiler.h index 5be3dab..d5ad7b1 100644 --- a/include/linux/compiler.h +++ b/include/linux/compiler.h @@ -5,16 +5,23 @@
#ifdef __CHECKER__ # define __user __attribute__((noderef, address_space(1))) -# define __kernel /* default address space */ +# define __kernel __attribute__((address_space(0))) # define __safe __attribute__((safe)) # define __force __attribute__((force)) # define __nocast __attribute__((nocast)) # define __iomem __attribute__((noderef, address_space(2))) +# define __must_hold(x) __attribute__((context(x,1,1))) # define __acquires(x) __attribute__((context(x,0,1))) # define __releases(x) __attribute__((context(x,1,0))) # define __acquire(x) __context__(x,1) # define __release(x) __context__(x,-1) # define __cond_lock(x,c) ((c) ? ({ __acquire(x); 1; }) : 0) +# define __percpu __attribute__((noderef, address_space(3))) +#ifdef CONFIG_SPARSE_RCU_POINTER +# define __rcu __attribute__((noderef, address_space(4))) +#else +# define __rcu +#endif extern void __chk_user_ptr(const volatile void __user *); extern void __chk_io_ptr(const volatile void __iomem *); #else @@ -27,13 +34,20 @@ extern void __chk_io_ptr(const volatile void __iomem *); # define __chk_user_ptr(x) (void)0 # define __chk_io_ptr(x) (void)0 # define __builtin_warning(x, y...) (1) +# define __must_hold(x) # define __acquires(x) # define __releases(x) # define __acquire(x) (void)0 # define __release(x) (void)0 # define __cond_lock(x,c) (c) +# define __percpu +# define __rcu #endif
+/* Indirect macros required for expanded argument pasting, eg. __LINE__. */ +#define ___PASTE(a,b) a##b +#define __PASTE(a,b) ___PASTE(a,b) + #ifdef __KERNEL__
#ifdef __GNUC__ @@ -49,6 +63,13 @@ extern void __chk_io_ptr(const volatile void __iomem *); # include <linux/compiler-intel.h> #endif
+/* Clang compiler defines __GNUC__. So we will overwrite implementations + * coming from above header files here + */ +#ifdef __clang__ +#include <linux/compiler-clang.h> +#endif + /* * Generic compiler-dependent macros required for kernel * build go below this comment. Actual compiler/compiler version @@ -156,6 +177,15 @@ void ftrace_likely_update(struct ftrace_branch_data *f, int val, int expect); (typeof(ptr)) (__ptr + (off)); }) #endif
+#ifndef OPTIMIZER_HIDE_VAR +#define OPTIMIZER_HIDE_VAR(var) barrier() +#endif + +/* Not-quite-unique ID. */ +#ifndef __UNIQUE_ID +# define __UNIQUE_ID(prefix) __PASTE(__PASTE(__UNIQUE_ID_, prefix), __LINE__) +#endif + #endif /* __KERNEL__ */
#endif /* __ASSEMBLY__ */ @@ -228,7 +258,7 @@ void ftrace_likely_update(struct ftrace_branch_data *f, int val, int expect);
/* * Rather then using noinline to prevent stack consumption, use - * noinline_for_stack instead. For documentaiton reasons. + * noinline_for_stack instead. For documentation reasons. */ #define noinline_for_stack noinline
@@ -270,11 +300,20 @@ void ftrace_likely_update(struct ftrace_branch_data *f, int val, int expect); # define __section(S) __attribute__ ((__section__(#S))) #endif
+#ifndef __visible +#define __visible +#endif + /* Are two types/vars the same type (ignoring qualifiers)? */ #ifndef __same_type # define __same_type(a, b) __builtin_types_compatible_p(typeof(a), typeof(b)) #endif
+/* Is this type a native word size -- useful for atomic operations */ +#ifndef __native_word +# define __native_word(t) (sizeof(t) == sizeof(int) || sizeof(t) == sizeof(long)) +#endif + /* Compile time object size, -1 for unknown */ #ifndef __compiletime_object_size # define __compiletime_object_size(obj) -1 @@ -284,8 +323,49 @@ void ftrace_likely_update(struct ftrace_branch_data *f, int val, int expect); #endif #ifndef __compiletime_error # define __compiletime_error(message) +/* + * Sparse complains of variable sized arrays due to the temporary variable in + * __compiletime_assert. Unfortunately we can't just expand it out to make + * sparse see a constant array size without breaking compiletime_assert on old + * versions of GCC (e.g. 4.2.4), so hide the array from sparse altogether. + */ +# ifndef __CHECKER__ +# define __compiletime_error_fallback(condition) \ + do { ((void)sizeof(char[1 - 2 * condition])); } while (0) +# endif +#endif +#ifndef __compiletime_error_fallback +# define __compiletime_error_fallback(condition) do { } while (0) #endif
+#define __compiletime_assert(condition, msg, prefix, suffix) \ + do { \ + bool __cond = !(condition); \ + extern void prefix ## suffix(void) __compiletime_error(msg); \ + if (__cond) \ + prefix ## suffix(); \ + __compiletime_error_fallback(__cond); \ + } while (0) + +#define _compiletime_assert(condition, msg, prefix, suffix) \ + __compiletime_assert(condition, msg, prefix, suffix) + +/** + * compiletime_assert - break build and emit msg if condition is false + * @condition: a compile-time constant condition to check + * @msg: a message to emit if condition is false + * + * In tradition of POSIX assert, this macro will break the build if the + * supplied condition is *false*, emitting the supplied error message if the + * compiler has support to do so. + */ +#define compiletime_assert(condition, msg) \ + _compiletime_assert(condition, msg, __compiletime_assert_, __LINE__) + +#define compiletime_assert_atomic_type(t) \ + compiletime_assert(__native_word(t), \ + "Need native word sized stores/loads for atomicity.") + /* * Prevent the compiler from merging or refetching accesses. The compiler * is also forbidden from reordering successive instances of ACCESS_ONCE(), @@ -300,4 +380,12 @@ void ftrace_likely_update(struct ftrace_branch_data *f, int val, int expect); */ #define ACCESS_ONCE(x) (*(volatile typeof(x) *)&(x))
+/* Ignore/forbid kprobes attach on very low level functions marked by this attribute: */ +#ifdef CONFIG_KPROBES +# define __kprobes __attribute__((__section__(".kprobes.text"))) +# define nokprobe_inline __always_inline +#else +# define __kprobes +# define nokprobe_inline inline +#endif #endif /* __LINUX_COMPILER_H */
Now GCC_VERSION is defined in include/linux/compiler-gcc.h (with a little different definition). Use it and delete the one in examples/standlone/stub.c.
This should work on Clang too because __GNUC__, __GNUC_MINOR__, __GNUC_PATCHLEVEL__ are also defined on Clang.
examples/standalone/stubs.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/examples/standalone/stubs.c b/examples/standalone/stubs.c index c5c025d..0bf690e 100644 --- a/examples/standalone/stubs.c +++ b/examples/standalone/stubs.c @@ -1,9 +1,6 @@ #include <common.h> #include <exports.h> - -#ifndef GCC_VERSION -#define GCC_VERSION (__GNUC__ * 1000 + __GNUC_MINOR__) -#endif /* GCC_VERSION */ +#include <linux/compiler.h>
#if defined(CONFIG_X86) /* @@ -237,7 +234,7 @@ gd_t *global_data; * implementation. On the other hand, asm() statements with * arguments can be used only inside the functions (gcc limitation) */ -#if GCC_VERSION < 3004 +#if GCC_VERSION < 30400 static #endif /* GCC_VERSION */ void __attribute__((unused)) dummy(void)
Masahiro Yamada
