[U-Boot] [PATCH] ARM: mx53: video: Add IPUv3 LCD support for M53EVK
This patch adds support for the AMPIRE 800x480 LCD panel that is available for M53EVK.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- board/denx/m53evk/m53evk.c | 73 ++++++++++++++++++++++++++++++++++++++++++++++ include/configs/m53evk.h | 16 ++++++++++ 2 files changed, 89 insertions(+)
diff --git a/board/denx/m53evk/m53evk.c b/board/denx/m53evk/m53evk.c index 3275170..a34b884 100644 --- a/board/denx/m53evk/m53evk.c +++ b/board/denx/m53evk/m53evk.c @@ -13,6 +13,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/clock.h> #include <asm/arch/iomux-mx53.h> +#include <asm/imx-common/mx5_video.h> #include <asm/arch/spl.h> #include <asm/errno.h> #include <netdev.h> @@ -22,6 +23,11 @@ #include <fsl_esdhc.h> #include <asm/gpio.h> #include <usb/ehci-fsl.h> +#include <linux/fb.h> +#include <ipu_pixfmt.h> + +/* Special MXCFB sync flags are here. */ +#include "../drivers/video/mxcfb.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -166,6 +172,32 @@ int board_mmc_init(bd_t *bis) } #endif
+#ifdef CONFIG_VIDEO +static struct fb_videomode const ampire_wvga = { + .name = "Ampire", + .refresh = 60, + .xres = 800, + .yres = 480, + .pixclock = 29851, /* picosecond (33.5 MHz) */ + .left_margin = 89, + .right_margin = 164, + .upper_margin = 23, + .lower_margin = 10, + .hsync_len = 10, + .vsync_len = 10, + .sync = FB_SYNC_CLK_LAT_FALL, +}; + +int board_video_skip(void) +{ + int ret; + ret = ipuv3_fb_init(&ire_wvga, 1, IPU_PIX_FMT_RGB666); + if (ret) + printf("Ampire LCD cannot be configured: %d\n", ret); + return ret; +} +#endif + #define I2C_PAD_CTRL (PAD_CTL_SRE_FAST | PAD_CTL_DSE_HIGH | \ PAD_CTL_PUS_100K_UP | PAD_CTL_ODE)
@@ -179,6 +211,46 @@ static void setup_iomux_i2c(void) imx_iomux_v3_setup_multiple_pads(i2c_pads, ARRAY_SIZE(i2c_pads)); }
+static void setup_iomux_video(void) +{ + static const iomux_v3_cfg_t lcd_pads[] = { + MX53_PAD_EIM_DA9__IPU_DISP1_DAT_0, + MX53_PAD_EIM_DA8__IPU_DISP1_DAT_1, + MX53_PAD_EIM_DA7__IPU_DISP1_DAT_2, + MX53_PAD_EIM_DA6__IPU_DISP1_DAT_3, + MX53_PAD_EIM_DA5__IPU_DISP1_DAT_4, + MX53_PAD_EIM_DA4__IPU_DISP1_DAT_5, + MX53_PAD_EIM_DA3__IPU_DISP1_DAT_6, + MX53_PAD_EIM_DA2__IPU_DISP1_DAT_7, + MX53_PAD_EIM_DA1__IPU_DISP1_DAT_8, + MX53_PAD_EIM_DA0__IPU_DISP1_DAT_9, + MX53_PAD_EIM_EB1__IPU_DISP1_DAT_10, + MX53_PAD_EIM_EB0__IPU_DISP1_DAT_11, + MX53_PAD_EIM_A17__IPU_DISP1_DAT_12, + MX53_PAD_EIM_A18__IPU_DISP1_DAT_13, + MX53_PAD_EIM_A19__IPU_DISP1_DAT_14, + MX53_PAD_EIM_A20__IPU_DISP1_DAT_15, + MX53_PAD_EIM_A21__IPU_DISP1_DAT_16, + MX53_PAD_EIM_A22__IPU_DISP1_DAT_17, + MX53_PAD_EIM_A23__IPU_DISP1_DAT_18, + MX53_PAD_EIM_A24__IPU_DISP1_DAT_19, + MX53_PAD_EIM_D31__IPU_DISP1_DAT_20, + MX53_PAD_EIM_D30__IPU_DISP1_DAT_21, + MX53_PAD_EIM_D26__IPU_DISP1_DAT_22, + MX53_PAD_EIM_D27__IPU_DISP1_DAT_23, + MX53_PAD_EIM_A16__IPU_DI1_DISP_CLK, + MX53_PAD_EIM_DA13__IPU_DI1_D0_CS, + MX53_PAD_EIM_DA14__IPU_DI1_D1_CS, + MX53_PAD_EIM_DA15__IPU_DI1_PIN1, + MX53_PAD_EIM_DA11__IPU_DI1_PIN2, + MX53_PAD_EIM_DA12__IPU_DI1_PIN3, + MX53_PAD_EIM_A25__IPU_DI1_PIN12, + MX53_PAD_EIM_DA10__IPU_DI1_PIN15, + }; + + imx_iomux_v3_setup_multiple_pads(lcd_pads, ARRAY_SIZE(lcd_pads)); +} + static void setup_iomux_nand(void) { static const iomux_v3_cfg_t nand_pads[] = { @@ -269,6 +341,7 @@ int board_early_init_f(void) setup_iomux_fec(); setup_iomux_i2c(); setup_iomux_nand(); + setup_iomux_video();
m53_set_clock();
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 8c54549..a344af4 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -37,6 +37,7 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_SATA #define CONFIG_CMD_USB +#define CONFIG_VIDEO
/* * Memory configurations @@ -201,6 +202,21 @@ #endif
/* + * LCD + */ +#ifdef CONFIG_VIDEO +#define CONFIG_VIDEO_IPUV3 +#define CONFIG_CFB_CONSOLE +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CONFIG_BMP_16BPP +#define CONFIG_VIDEO_LOGO +#define CONFIG_IPUV3_CLK 200000000 +#endif + +/* * Boot Linux */ #define CONFIG_CMDLINE_TAG
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Stefano Babic
