[U-Boot] [PATCH] MX3: make additional hardware and clocks available
This patch is in preparation for the contribution of our board support. More to follow ...
diff --git a/arch/arm/cpu/arm1136/mx31/devices.c b/arch/arm/cpu/arm1136/mx31/devices.c index 1e7d48f..ace48f4 100644 --- a/arch/arm/cpu/arm1136/mx31/devices.c +++ b/arch/arm/cpu/arm1136/mx31/devices.c @@ -38,7 +38,21 @@ void mx31_uart1_hw_init(void) } #endif
+#ifdef CONFIG_SYS_MX31_UART2 +void mx31_uart2_hw_init(void) +{ + /* setup pins for UART2 */ + mx31_gpio_mux(MUX_RXD2__UART2_RXD_MUX); + mx31_gpio_mux(MUX_TXD2__UART2_TXD_MUX); + mx31_gpio_mux(MUX_RTS2__UART2_RTS_B); + mx31_gpio_mux(MUX_CTS2__UART2_CTS_B); +} +#endif + #ifdef CONFIG_MXC_SPI +/* note: putting several spi setups here makes no sense as they may differ + * at board level (physical pin SS0 of CSPI2 may aswell be used as SS0 of CSPI3) + */ void mx31_spi2_hw_init(void) { /* SPI2 */ diff --git a/arch/arm/cpu/arm1136/mx31/generic.c b/arch/arm/cpu/arm1136/mx31/generic.c index 4ebf38d..92dd8d6 100644 --- a/arch/arm/cpu/arm1136/mx31/generic.c +++ b/arch/arm/cpu/arm1136/mx31/generic.c @@ -71,6 +71,18 @@ u32 mx31_get_ipg_clk(void) return freq; }
+/* hsp is the clock for the ipu */ +u32 mx31_get_hsp_clk(void) +{ + u32 freq = mx31_get_mcu_main_clk(); + u32 pdr0 = __REG(CCM_PDR0); + + /* divided by HSP_PODF in PDR0 */ + freq /= ((pdr0 >> 11) & 0x7) + 1; + + return freq; +} + void mx31_dump_clocks(void) { u32 cpufreq = mx31_get_mcu_main_clk(); diff --git a/arch/arm/include/asm/arch-mx31/clock.h b/arch/arm/include/asm/arch-mx31/clock.h old mode 100644 new mode 100755 index 9f7ae80..980bec1 --- a/arch/arm/include/asm/arch-mx31/clock.h +++ b/arch/arm/include/asm/arch-mx31/clock.h @@ -26,10 +26,11 @@
extern u32 mx31_get_ipg_clk(void); #define imx_get_uartclk mx31_get_ipg_clk +extern u32 mx31_get_hsp_clk(void); extern void mx31_gpio_mux(unsigned long mode); extern void mx31_set_pad(enum iomux_pins pin, u32 config); - void mx31_uart1_hw_init(void); +void mx31_uart2_hw_init(void); void mx31_spi2_hw_init(void); void mxc_hw_watchdog_enable(void); void mxc_hw_watchdog_reset(void); diff --git a/arch/arm/include/asm/arch-mx31/imx-regs.h b/arch/arm/include/asm/arch-mx31/imx-regs.h old mode 100644 new mode 100755 index 306f966..af163cd --- a/arch/arm/include/asm/arch-mx31/imx-regs.h +++ b/arch/arm/include/asm/arch-mx31/imx-regs.h @@ -604,12 +604,41 @@ enum iomux_pins {
/* Register offsets based on IOMUXC_BASE */ /* 0x00 .. 0x7b */ +#define MUX_CTL_CSPI3_MISO 0x0c +#define MUX_CTL_CSPI3_SCLK 0x0d +#define MUX_CTL_CSPI3_SPI_RDY 0x0e +#define MUX_CTL_TTM_PAD 0x0f +#define MUX_CTL_ATA_RESET_B 0x10 +#define MUX_CTL_CE_CONTROL 0x11 +#define MUX_CTL_CLKSS 0x12 +#define MUX_CTL_CSPI3_MOSI 0x13 + +#define MUX_CTL_SD1_DATA1 0x18 +#define MUX_CTL_SD1_DATA2 0x19 +#define MUX_CTL_SD1_DATA3 0x1a +#define MUX_CTL_SD1_CMD 0x1d +#define MUX_CTL_SD1_CLK 0x1e +#define MUX_CTL_SD1_DATA0 0x1f + #define MUX_CTL_USBH2_DATA1 0x40 #define MUX_CTL_USBH2_DIR 0x44 #define MUX_CTL_USBH2_STP 0x45 #define MUX_CTL_USBH2_NXT 0x46 #define MUX_CTL_USBH2_DATA0 0x47 #define MUX_CTL_USBH2_CLK 0x4B + +#define MUX_CTL_TXD2 0x70 +#define MUX_CTL_RTS2 0x71 +#define MUX_CTL_CTS2 0x72 +#define MUX_CTL_BATT_LINE 0x73 +#define MUX_CTL_RI_DTE1 0x74 +#define MUX_CTL_DCD_DTE1 0x75 +#define MUX_CTL_DTR_DCE2 0x76 +#define MUX_CTL_RXD2 0x77 +#define MUX_CTL_RI_DCE1 0x78 +#define MUX_CTL_DCD_DCE1 0x79 +#define MUX_CTL_DTR_DTE1 0x7a +#define MUX_CTL_DSR_DTE1 0x7b #define MUX_CTL_RTS1 0x7c #define MUX_CTL_CTS1 0x7d #define MUX_CTL_DTR_DCE1 0x7e @@ -667,6 +696,11 @@ enum iomux_pins { #define MUX_RTS1__UART1_RTS_B IOMUX_MODE(MUX_CTL_RTS1, MUX_CTL_FUNC) #define MUX_CTS1__UART1_CTS_B IOMUX_MODE(MUX_CTL_CTS1, MUX_CTL_FUNC)
+#define MUX_RXD2__UART2_RXD_MUX IOMUX_MODE(MUX_CTL_RXD2, MUX_CTL_FUNC) +#define MUX_TXD2__UART2_TXD_MUX IOMUX_MODE(MUX_CTL_TXD2, MUX_CTL_FUNC) +#define MUX_RTS2__UART2_RTS_B IOMUX_MODE(MUX_CTL_RTS2, MUX_CTL_FUNC) +#define MUX_CTS2__UART2_CTS_B IOMUX_MODE(MUX_CTL_CTS2, MUX_CTL_FUNC) + #define MUX_CSPI2_SS0__CSPI2_SS0_B IOMUX_MODE(MUX_CTL_CSPI2_SS0, MUX_CTL_FUNC) #define MUX_CSPI2_SS1__CSPI2_SS1_B IOMUX_MODE(MUX_CTL_CSPI2_SS1, MUX_CTL_FUNC) #define MUX_CSPI2_SS2__CSPI2_SS2_B IOMUX_MODE(MUX_CTL_CSPI2_SS2, MUX_CTL_FUNC) @@ -739,6 +773,10 @@ enum iomux_pins { */ #define NFC_BASE_ADDR 0xB8000000
+/* SD card controller */ +#define SDHC1_BASE_ADDR 0x50004000 +#define SDHC2_BASE_ADDR 0x50008000 + /* * Internal RAM (16KB) */ diff --git a/include/fsl_pmic.h b/include/fsl_pmic.h old mode 100644 new mode 100755 index e3abde6..e0ef810 --- a/include/fsl_pmic.h +++ b/include/fsl_pmic.h @@ -121,6 +121,8 @@ enum { /* Interrupt status 1 */ #define RTCRSTI (1 << 7)
+struct spi_slave *pmic_spi_probe(void); +void pmic_spi_free(struct spi_slave *slave); void pmic_show_pmic_info(void); void pmic_reg_write(u32 reg, u32 value); u32 pmic_reg_read(u32 reg);
-- Scanned by MailScanner.
Hi Helmut,
please replace this with a useful comment for the commit, describing what the patch is thought to do or which issue should solve.
You must add your Signed-off-by line to your patch. Your patch seems corrupt and cannot be apply without errors. Think about using git send-email to post patches, as this avoid mail corruption generated by mailer.
Please submit your patches together in a single patchset, including support for your board. This makes everything more readable and easier to understand why you need some changes.
You should run checkpatch before submitting patches and fix for errors the tool reports:
ERROR: trailing whitespace #40: FILE: arch/arm/cpu/arm1136/mx31/devices.c:54: + * at board level (physical pin SS0 of CSPI2 may aswell be used as SS0 $
ERROR: patch seems to be corrupt (line wrapped?) #41: FILE: arch/arm/cpu/arm1136/mx31/devices.c:54: of CSPI3)
ERROR: Missing Signed-off-by: line(s)
total: 3 errors, 0 warnings, 124 lines checked
- #ifdef CONFIG_MXC_SPI
- at board level (physical pin SS0 of CSPI2 may aswell be used as SS0
of CSPI3)
- */ void mx31_spi2_hw_init(void) { /* SPI2 */
return freq;
Use the same interface implemented on other i.MX processors (MX5, MX35) to ask for clocks. If you need to get a clock, you should implement mxc_get_clock(). If you need to get the ipu clock, does it mean you plan to change the IPU driver, too ?
It seems to me you define a lot of this stuff, but you use only a few of them.
The two functions are used internally to fsl_pmic. At least pmic_spi_probe is automatically called by the read/write helper if the spi slave is not set. Why do you need to export them ?
Best regards, Stefano Babic
Hi Helmut,
... looks like I hit a standard disclaimer, sorry for the noise, I'll check.
Helmut
Helmut Raiger
Stefano Babic
