[U-Boot] [PATCH 1/2] phy: export genphy_parse_link()
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- drivers/net/phy/phy.c | 2 +- include/phy.h | 1 + 2 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 1ffa791..c28ea70 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -279,7 +279,7 @@ int genphy_update_link(struct phy_device *phydev) * * Stolen from Linux's mii.c and phy_device.c */ -static int genphy_parse_link(struct phy_device *phydev) +int genphy_parse_link(struct phy_device *phydev) { int mii_reg = phy_read(phydev, MDIO_DEVAD_NONE, MII_BMSR);
diff --git a/include/phy.h b/include/phy.h index 3c30f11..1342ef7 100644 --- a/include/phy.h +++ b/include/phy.h @@ -209,6 +209,7 @@ int phy_register(struct phy_driver *drv); int genphy_config_aneg(struct phy_device *phydev); int genphy_restart_aneg(struct phy_device *phydev); int genphy_update_link(struct phy_device *phydev); +int genphy_parse_link(struct phy_device *phydev); int genphy_config(struct phy_device *phydev); int genphy_startup(struct phy_device *phydev); int genphy_shutdown(struct phy_device *phydev);
The driver code was taken from Linux kernel source: drivers/net/phy/icplus.c
Signed-off-by: Yegor Yefremov yegorslists@googlemail.com --- drivers/net/phy/Makefile | 1 + drivers/net/phy/icplus.c | 90 ++++++++++++++++++++++++++++++++++++++++++++++ drivers/net/phy/phy.c | 3 ++ 3 files changed, 94 insertions(+), 0 deletions(-) create mode 100644 drivers/net/phy/icplus.c
diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index 5e90d70..2c5ab5f 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_PHYLIB_10G) += generic_10g.o COBJS-$(CONFIG_PHY_ATHEROS) += atheros.o COBJS-$(CONFIG_PHY_BROADCOM) += broadcom.o COBJS-$(CONFIG_PHY_DAVICOM) += davicom.o +COBJS-$(CONFIG_PHY_ICPLUS) += icplus.o COBJS-$(CONFIG_PHY_LXT) += lxt.o COBJS-$(CONFIG_PHY_MARVELL) += marvell.o COBJS-$(CONFIG_PHY_MICREL) += micrel.o diff --git a/drivers/net/phy/icplus.c b/drivers/net/phy/icplus.c new file mode 100644 index 0000000..85b9720 --- /dev/null +++ b/drivers/net/phy/icplus.c @@ -0,0 +1,90 @@ +/* + * ICPlus PHY drivers + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + * Copyright (c) 2007 Freescale Semiconductor, Inc. + * + */ +#include <phy.h> + +/* IP101A/G - IP1001 */ +#define IP10XX_SPEC_CTRL_STATUS 16 /* Spec. Control Register */ +#define IP1001_SPEC_CTRL_STATUS_2 20 /* IP1001 Spec. Control Reg 2 */ +#define IP1001_PHASE_SEL_MASK 3 /* IP1001 RX/TXPHASE_SEL */ +#define IP1001_APS_ON 11 /* IP1001 APS Mode bit */ +#define IP101A_G_APS_ON 2 /* IP101A/G APS Mode bit */ +#define IP101A_G_IRQ_CONF_STATUS 0x11 /* Conf Info IRQ & Status Reg */ +#define IP101A_G_IRQ_PIN_USED (1<<15) /* INTR pin used */ +#define IP101A_G_IRQ_DEFAULT IP101A_G_IRQ_PIN_USED + +static int ip1001_config(struct phy_device *phydev) +{ + int c; + + /* Enable Auto Power Saving mode */ + c = phy_read(phydev, MDIO_DEVAD_NONE,IP1001_SPEC_CTRL_STATUS_2); + if (c < 0) + return c; + c |= IP1001_APS_ON; + c = phy_write(phydev, MDIO_DEVAD_NONE,IP1001_SPEC_CTRL_STATUS_2, c); + if (c < 0) + return c; + + /* INTR pin used: speed/link/duplex will cause an interrupt */ + c = phy_write(phydev, MDIO_DEVAD_NONE,IP101A_G_IRQ_CONF_STATUS, IP101A_G_IRQ_DEFAULT); + if (c < 0) + return c; + + if (phydev->interface == PHY_INTERFACE_MODE_RGMII) { + /* Additional delay (2ns) used to adjust RX clock phase + * at RGMII interface */ + c = phy_read(phydev, MDIO_DEVAD_NONE,IP10XX_SPEC_CTRL_STATUS); + if (c < 0) + return c; + + c |= IP1001_PHASE_SEL_MASK; + c = phy_write(phydev, MDIO_DEVAD_NONE,IP10XX_SPEC_CTRL_STATUS, c); + if (c < 0) + return c; + } + + return 0; +} + +static int ip1001_startup(struct phy_device *phydev) +{ + genphy_update_link(phydev); + genphy_parse_link(phydev); + + return 0; +} +static struct phy_driver IP1001_driver = { + .name = "ICPlus IP1001", + .uid = 0x02430d90, + .mask = 0x0ffffff0, + .features = PHY_GBIT_FEATURES, + .config = &ip1001_config, + .startup = &ip1001_startup, + .shutdown = &genphy_shutdown, +}; + +int phy_icplus_init(void) +{ + phy_register(&IP1001_driver); + + return 0; +} diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index c28ea70..9eccf40 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -429,6 +429,9 @@ int phy_init(void) #ifdef CONFIG_PHY_DAVICOM phy_davicom_init(); #endif +#ifdef CONFIG_PHY_ICPLUS + phy_icplus_init(); +#endif #ifdef CONFIG_PHY_LXT phy_lxt_init(); #endif
Dear yegorslists@googlemail.com,
Is there any user for this PHY please?
Best regards, Marek Vasut
Yes, our new device, that will be soon introduced. The successor of this one http://www.visionsystems.de/produkte/6806.html.
Yegor
Dear Yegor Yefremov,
Good, ok ... just make sure the board support also hits u-boot, so we won't have dead code.
tor 2012-11-29 klockan 07:27 +0100 skrev Marek Vasut:
I don't have one, but know at least one user having one in an A10 based "netbook".
http://linux-sunxi.org/File:H6-netbook-mainboard.jpg
Regards Henrik
On Thu, Nov 29, 2012 at 8:53 AM, Henrik Nordström henrik@henriknordstrom.net wrote:
I found these boards in kernel:
arch/mips/configs/malta_defconfig:CONFIG_ICPLUS_PHY=m arch/mips/configs/bcm47xx_defconfig:CONFIG_ICPLUS_PHY=m arch/mips/configs/ip27_defconfig:CONFIG_ICPLUS_PHY=m arch/mips/configs/sead3_defconfig:CONFIG_ICPLUS_PHY=y arch/powerpc/configs/mpc512x_defconfig:CONFIG_ICPLUS_PHY=y arch/powerpc/configs/52xx/motionpro_defconfig:CONFIG_ICPLUS_PHY=y arch/powerpc/configs/83xx/mpc832x_rdb_defconfig:CONFIG_ICPLUS_PHY=y arch/powerpc/configs/mpc83xx_defconfig:CONFIG_ICPLUS_PHY=y arch/powerpc/configs/ppc6xx_defconfig:CONFIG_ICPLUS_PHY=m
Yegor
Sure, but the question/point is ... won't this be dead code in u-boot? It won't once you add at least one board that actually uses it ... adding it only so it's there will only cause it to bitrot and it'll actually only add more burden to maintainers.
It won't be dead code, because we will use it :-) Our board is derivative of BeagleBone & Co, so the whole support stuff is already in u-boot. I can also image that some system didn't require network support in u-boot and didn't bother with implementing the phy driver. x86 systems are likely to have this phy too. And the driver is really small and uses mostly generic routines.
Yegor
You need to enable it for that board though ;-)
Yegor
> From: Yegor Yefremov yegorslists@googlemail.com > > The driver code was taken from Linux kernel source: > drivers/net/phy/icplus.c > > Signed-off-by: Yegor Yefremov yegorslists@googlemail.com
Will do this as soon as we come near to the release. I'd like to have basic stuff mainlined before.
Yegor
tor 2012-11-29 klockan 07:27 +0100 skrev Marek Vasut: > Dear yegorslists@googlemail.com, > > > From: Yegor Yefremov yegorslists@googlemail.com > > > > The driver code was taken from Linux kernel source: > > drivers/net/phy/icplus.c > > > > Signed-off-by: Yegor Yefremov yegorslists@googlemail.com > > [...] > > Is there any user for this PHY please?
Release of what? The hardware?
Well, I'll leave that up to Joe anyway
henrik@henriknordstrom.net wrote: > tor 2012-11-29 klockan 07:27 +0100 skrev Marek Vasut: >> Dear yegorslists@googlemail.com, >> >> > From: Yegor Yefremov yegorslists@googlemail.com >> > >> > The driver code was taken from Linux kernel source: >> > drivers/net/phy/icplus.c >> > >> > Signed-off-by: Yegor Yefremov yegorslists@googlemail.com >> >> [...] >> >> Is there any user for this PHY please? > > I don't have one, but know at least one user having one in an A10 > based "netbook". > > http://linux-sunxi.org/File:H6-netbook-mainboard.jpg
Release of hardware and when two more patches hit main line u-boot:
http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/147860 http://permalink.gmane.org/gmane.comp.boot-loaders.u-boot/147859
O.K.
Yegor
Applied, Thanks. -Joe
- Stolen from Linux's mii.c and phy_device.c
diff --git a/include/phy.h b/include/phy.h index 3c30f11..1342ef7 100644 --- a/include/phy.h +++ b/include/phy.h @@ -209,6 +209,7 @@ int phy_register(struct phy_driver *drv); int genphy_config_aneg(struct phy_device *phydev); int genphy_restart_aneg(struct phy_device *phydev); int genphy_update_link(struct phy_device *phydev); +int genphy_parse_link(struct phy_device *phydev); int genphy_config(struct phy_device *phydev); int genphy_startup(struct phy_device *phydev); int genphy_shutdown(struct phy_device *phydev); -- 1.7.7
Hi Joe,
could you please take a look at this patch series (the second patch is about adding ICPlus phy)?
Yegor
On Tue, Jan 15, 2013 at 4:41 AM, Yegor Yefremov yegorslists@googlemail.com wrote:
participants (5)
Henrik Nordström
Joe Hershberger
Yegor Yefremov
