[U-Boot] Upstream uboot and Arndale 5250 support
i've been trying to update the u-boot on my board (sd booting), from the Linaro one (2012.10) to a v2014.X, but so far had no luck:
make arndale_config export CROSS_COMPILE=/usr/bin/arm-linux-gnueabihf- make
dd if=arndale-bl1.bin of=/dev/sdc bs=512 skip=1 dd if=arndale-spl.bin of=/dev/sdc bs=512 skip=17 dd if=./u-boot-dtb.bin of=/dev/sdc bs=512 skip=49
u-boot 3.10rc3 (same happens with v2014.07 or 2014.04):
U-Boot 2014.10-rc3 (Oct 07 2014 - 13:26:48) for ARNDALE
CPU: Exynos5250@1000MHz
Board: Arndale I2C: i2c_init: failed to init bus 0 for speed = 100000 ready DRAM: 2 GiB trace: copying 00086db4 bytes of early data from 50000000 to beff0000 trace: enabled WARNING: Caches not enabled MMC: EXYNOS DWMMC: 0, EXYNOS DWMMC: 1 dwmci_send_cmd: DATA ERROR! i2c_init: failed to init bus 0 for speed = 100000 In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 ARNDALE # printenv baudrate=115200 bootargs=console=ttySAC2,115200n8 root=/dev/mmcblk1p1 rw rootwait debug earlyprintk bootcmd=run bootcmd_ubuntu bootcmd_ubuntu=run loadk; run loadf; run loadr; bootm ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} bootdelay=3 fdt_addr_r=0x41000000 filesize=5b9902 kernel_addr_r=0x40007000 loadf=ext2load mmc 1:1 ${fdt_addr_r} /boot/exynos5250-arndale.dtb loadk=ext2load mmc 1:1 ${kernel_addr_r} /boot/uImage loadr=ext2load mmc 1:1 ${ramdisk_addr_r} /boot/uInitrd ramdisk_addr_r=0x42000000 stderr=serial stdin=serial stdout=serial
Environment size: 589/16380 bytes ARNDALE # run loadk 6002946 bytes read in 1117 ms (5.1 MiB/s) ARNDALE # bootm ${kernel_addr_r} ## Booting kernel from Legacy Image at 40007000 ... Image Name: kernel 3.16.0-20-generic Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 6002882 Bytes = 5.7 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum ... OK Loading Kernel Image ... OK
Starting kernel ...(fake run for tracing)
Starting kernel ...
[stuck here]
here for a more complete log:
http://pastebin.ubuntu.com/8514108/plain/
Any idea what's going wrong? Did you try this board lately?
It's a kernel with the DTB concatenated (and it works fine with Linaro 2012 uboot), but the same happens if i explicitely pass the dtb:
U-Boot 2014.07 (Sep 30 2014 - 15:26:03) for ARNDALE
Board: Arndale I2C: i2c_init: failed to init bus 0 for speed = 100000 ready DRAM: 2 GiB trace: copying 00085818 bytes of early data from 50000000 to beff0000 trace: enabled WARNING: Caches not enabled MMC: EXYNOS DWMMC: 0, EXYNOS DWMMC: 1 i2c_init: failed to init bus 0 for speed = 100000 In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 ARNDALE # printenv baudrate=115200 bootargs=console=ttySAC2,115200n8 root=/dev/mmcblk1p1 rw rootwait debug earlyprintk bootcmd=run bootcmd_ubuntu bootcmd_ubuntu=run loadk; run loadf; run loadr; bootm ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} bootdelay=3 fdt_addr_r=0x41000000 filesize=5b9902 kernel_addr_r=0x40007000 loadf=ext2load mmc 1:1 ${fdt_addr_r} /boot/exynos5250-arndale.dtb loadk=ext2load mmc 1:1 ${kernel_addr_r} /boot/uImage loadr=ext2load mmc 1:1 ${ramdisk_addr_r} /boot/uInitrd ramdisk_addr_r=0x42000000 stderr=serial stdin=serial stdout=serial
Environment size: 589/16380 bytes ARNDALE # run loadk 6002946 bytes read in 1114 ms (5.1 MiB/s) ARNDALE # run loadf 35450 bytes read in 34 ms (1017.6 KiB/s) ARNDALE # bootm ${kernel_addr_r} - ${fdt_addr_r} ## Booting kernel from Legacy Image at 40007000 ... Image Name: kernel 3.16.0-20-generic Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 6002882 Bytes = 5.7 MiB Load Address: 40008000 Entry Point: 40008000 Verifying Checksum ... OK ## Flattened Device Tree blob at 41000000 Booting using the fdt blob at 0x41000000 Loading Kernel Image ... OK Loading Device Tree to 4fff4000, end 4ffffa79 ... OK
Starting kernel ...
[stuck again]
(please cc: me as i'm off list)
Starting kernel ...
[stuck here]
I faced this problem some times ago. Try to modify kernel, initrd and fdt addresses.
Guillaume
those are the addresses suggested by u-boot and yes, i already tried moving stuff around but it didn't fix it: what's the working config with your board? u-boot version?
On Tue, Oct 7, 2014 at 4:34 PM, Guillaume Gardet guillaume.gardet@free.fr wrote:
Starting kernel ...
[stuck here]
Guillaume
I used the following values with 2014.10-rc2: kerneladdr=0x44000000 ramdiskaddr=0x45000000 fdtaddr=0x4c000000
But I used a zImage. If you use a uImage, you need to modify the kernel load addr.
Guillaume
Starting kernel ...
[stuck here]
Guillaume
that's weird, because i don't have bootz:
U-Boot 2014.10-rc3 (Oct 08 2014 - 11:34:33) for ARNDALE
Board: Arndale I2C: i2c_init: failed to init bus 0 for speed = 100000 ready DRAM: 2 GiB trace: copying 00086db4 bytes of early data from 50000000 to beff0000 trace: enabled WARNING: Caches not enabled MMC: EXYNOS DWMMC: 0, EXYNOS DWMMC: 1 dwmci_send_cmd: DATA ERROR! i2c_init: failed to init bus 0 for speed = 100000 In: serial Out: serial Err: serial Net: Net Initialization Skipped No ethernet found. Hit any key to stop autoboot: 0 ARNDALE # help bootz Unknown command 'bootz' - try 'help' without arguments for list of all known commands
ARNDALE #
are you using a patched u-boot?
i'm using the default arndale_defconfig.
anyhow, can i have your full working config? i'm starting to feel i'm chasing ghosts here.
On Wed, Oct 8, 2014 at 10:00 AM, Guillaume Gardet guillaume.gardet@free.fr wrote:
Guillaume
Starting kernel ...
[stuck here]
Guillaume
I used this patch for -rc2 (which will not apply on -rc3 because of changes on arndale config between -rc2 and -rc3): https://patchwork.ozlabs.org/patch/391247/raw/ with arndale_defconfig.
Then, I used a bootscript which defined and used the values I gave you: kerneladdr=0x44000000 ramdiskaddr=0x45000000 fdtaddr=0x4c000000
But you can define those values manually, of courses.
Hope it will help you.
Guillaume
Guillaume Gardet
Paolo Pisati
