[U-Boot] Where can I find the git repostory for mx51evk
Hi Denx,
I have cloned u-boot-imx and want to apply the patch "[U-Boot] [PATCH V4 11/11] Add initial support for Freescale mx51evk board" for a test.
But the patch can't be appled.
error: patch failed: MAINTAINERS:152 error: MAINTAINERS: patch does not apply
How can I get the repostory for mx51evk?
Thanks~~
Yours Terry
General Business Information Freescale Internal Use Only Freescale Confidential Proprietary
Dear "Lv Terry-R65388",
In message 1AE74F652ECB1440B73DD7C2C20842D1AC6D28@zch01exm27.fsl.freescale.net you wrote:
Why did you do that? u-boot-imx is currently in a pretty poor state, as the new custodian has nor picked up work yet, so this repository is very old.
Patches submitted on the mailing list are supposed to be applied against mainline (master branch). Did you try that?
Hi Denk,
I have tried to apply the patch on mainline.
The steps are:
1. Copy patch from http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74754. 2. Paste it to local text file patch. 3. Clone a new u-boot. 4. Try "git apply patch".
I encountered errors:
r65388@szx32-17[/home/r65388/uboot-imx]602% git apply patch error: patch failed: MAINTAINERS:152 error: MAINTAINERS: patch does not apply
Thanks~~
Yours Terry
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: 2010年2月26日 18:09 To: Lv Terry-R65388 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Where can I find the git repostory for mx51evk
Lv Terry-R65388 wrote:
Hi Denk,
Hi Terry,
- Try "git apply patch".
I think the normal way to do is to use "git am" getting the whole e-mail, but this is not your problem now.
The patch was sent some times ago, based on the u-boot master branch at the time it was sent. Of course, other boards went to the mainline in the meantime, patching the MAINTAINERS file again - you have probably to merge this file.
Regards, Stefano
Dear Stefano Babic,
There are no merge conflicts. git will happily apply your patch as is; I just verified this again. I used 'git-am' though, of course.
In message 1AE74F652ECB1440B73DD7C2C20842D1AC6D29@zch01exm27.fsl.freescale.net you wrote:
You must be doing something wrong, then.
I re-tested it, it applies cleanly:
-> git-am -3 -i -u --whitespace=strip ~/Mail/U-Boot/7647 Commit Body is: -------------------------- Add initial support for Freescale mx51evk board
The patch adds initial support for the Freescale mx51evk board. Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com -------------------------- Apply? [y]es/[n]o/[e]dit/[v]iew patch/[a]ccept all y Applying: Add initial support for Freescale mx51evk board ->
The steps are:
- Copy patch from > http://article.gmane.org/gmane.comp.boot-loaders.u-boot/74754.
- Paste it to local text file patch.
Eventually the patch gets mangled (white space corrupted) this way.
- Clone a new u-boot.
Try using "git am", and avoid the copy & paste - save the page as text file instead.
Hi Denk,
It seems that "git am" doesn't work for me.
The steps are:
1. Save the patch as txt file in outlook and copy to u-boot directory. 2. Use git am to apply the patch.
r65388@szx32-17[/home/r65388/uboot-imx]686% git am -i -u --whitespace=strip ./"U-Boot PATCH V4 1111 Add initial support for Freescale mx51evkboard.txt" Commit Body is: -------------------------- [sbabic@denx.de] Sent: 2010年2月5日星期五 22:14 To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH V4 11/11] Add initial support for Freescale mx51evkboard
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Fred Fan fanyefeng@gmail.com -------------------------- Apply? [y]es/[n]o/[e]dit/[v]iew patch/[a]ccept all y Applying: [sbabic@denx.de] /home/r65388/uboot-imx/.git/rebase-apply/patch:69: trailing whitespace. # Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de # # (C) /home/r65388/uboot-imx/.git/rebase-apply/patch:72: trailing whitespace. # This program is free software; you can redistribute it and/or # /home/r65388/uboot-imx/.git/rebase-apply/patch:73: trailing whitespace. modify it under the terms of the GNU General Public License as # /home/r65388/uboot-imx/.git/rebase-apply/patch:74: trailing whitespace. published by the Free Software Foundation; either version 2 of # the /home/r65388/uboot-imx/.git/rebase-apply/patch:77: trailing whitespace. # This program is distributed in the hope that it will be useful, # but fatal: corrupt patch at line 145 Patch failed at 0001. When you have resolved this problem run "git am -i --resolved". If you would prefer to skip this patch, instead run "git am -i --skip". To restore the original branch and stop patching run "git am -i --abort".
What's your git version? We're using 1.6.0.4. I don't know if it is the git version that cause the problem.
Thanks~~
Yours Terry
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: 2010年2月26日 20:33 To: Lv Terry-R65388 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] Where can I find the git repostory for mx51evk
The steps are:
In message 1AE74F652ECB1440B73DD7C2C20842D1AC6D5C@zch01exm27.fsl.freescale.net you wrote:
Well, I'm afraid there is little we can do to help you with that. Setting up a basic working tool chain is something you have to do yourself; we don't know your environment. If you don't succeed yourself, then ask another, more experienced engineer in your team for help, or some support guy.
The steps are:
- Save the patch as txt file in outlook and copy to u-boot directory.
- Use git am to apply the patch.
Maybe you should try and avoid working in a Windows based environment here. I have no way how many wonderful ways Outlook knows to mess up the messages it processes.
We are using git versions 1.6.2.5 and 1.6.6 (i. e. what comes with recent Fedora distributions).
The problems you report are not caused by git version differences.
Hi Denk,
Hi Terry,
The steps are:
directory.
Do not do it. Even if it for some strange seems working (it could be for an easy patch), you apply a patch different as the one sent to the ML. The correct step is to save the e-mail as it is. If your e-mail client does not support it, take another one.
This is really caused by your client and tells you that the e-mail was not correctly saved.
Regards, Stefano
Terry,
On 2/28/2010 8:48 PM, Lv Terry-R65388 wrote:
Hi Denk,
The steps are:
I sometimes have problems with Thunderbird whitespace-damaging patches in Windows, and find that stripping the '\r' carriage-return characters seems to work. My weapon of choice is 'dos2unix', but you could go old-school with 'tr' or even change the file type in vim.
HTH, Ben
Ben Warren
Lv Terry-R65388
Stefano Babic
