[U-Boot] [PATCH] Add support for the digsy MTC board.
This is the InterControl custom device based on the MPC5200B chip.
Signed-off-by: Grzegorz Bernacki gjb@semihalf.com
diff --git a/MAKEALL b/MAKEALL index 530fe82..530651d 100755 --- a/MAKEALL +++ b/MAKEALL @@ -47,6 +47,7 @@ LIST_5xxx=" \ BC3450 \ cm5200 \ cpci5200 \ + digsymtc \ EVAL5200 \ fo300 \ icecube_5100 \ diff --git a/Makefile b/Makefile index 8c73586..db60e93 100644 --- a/Makefile +++ b/Makefile @@ -527,6 +527,22 @@ cm5200_config: unconfig cpci5200_config: unconfig @$(MKCONFIG) -a cpci5200 ppc mpc5xxx cpci5200 esd
+digsymtc_config \ +digsymtc_LOWBOOT_config \ +digsymtc_RAMBOOT_config: unconfig + @mkdir -p $(obj)include + @mkdir -p $(obj)board/digsymtc + @ >$(obj)include/config.h + @[ -z "$(findstring LOWBOOT_,$@)" ] || \ + { echo "TEXT_BASE = 0xFF000000" >$(obj)board/digsymtc/config.tmp ; \ + echo "... with LOWBOOT configuration" ; \ + } + @[ -z "$(findstring RAMBOOT_,$@)" ] || \ + { echo "TEXT_BASE = 0x00100000" >$(obj)board/digsymtc/config.tmp ; \ + echo "... with RAMBOOT configuration" ; \ + } + @$(MKCONFIG) -a digsymtc ppc mpc5xxx digsymtc + hmi1001_config: unconfig @$(MKCONFIG) hmi1001 ppc mpc5xxx hmi1001
diff --git a/board/digsymtc/Makefile b/board/digsymtc/Makefile new file mode 100644 index 0000000..4bcb233 --- /dev/null +++ b/board/digsymtc/Makefile @@ -0,0 +1,51 @@ + +# +# (C) Copyright 2003-2009 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := $(BOARD).o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/digsymtc/config.mk b/board/digsymtc/config.mk new file mode 100644 index 0000000..f160674 --- /dev/null +++ b/board/digsymtc/config.mk @@ -0,0 +1,43 @@ +# +# (C) Copyright 2003-2009 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +# +# digsyMTC board: +# +# Valid values for TEXT_BASE are: +# +# 0xFFF00000 boot high (standard configuration) +# 0xFE000000 boot low +# 0x00100000 boot from RAM (for testing only) +# + +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp + +ifndef TEXT_BASE +## Standard: boot high +TEXT_BASE = 0xFFF00000 +## For testing: boot from RAM +# TEXT_BASE = 0x00100000 +endif + +PLATFORM_CPPFLAGS += -DTEXT_BASE=$(TEXT_BASE) -I$(TOPDIR)/board diff --git a/board/digsymtc/digsymtc.c b/board/digsymtc/digsymtc.c new file mode 100644 index 0000000..bd7d0cd --- /dev/null +++ b/board/digsymtc/digsymtc.c @@ -0,0 +1,316 @@ +/* + * (C) Copyright 2003 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2004 + * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. + * + * (C) Copyright 2005-2009 + * Modified for InterControl digsyMTC MPC5200 board by + * Frank Bodammer, GCD Hard- & Software GmbH, + * frank.bodammer@gcd-solutions.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <mpc5xxx.h> +#include <pci.h> +#include <asm/processor.h> +#include <i2c.h> +#include "eeprom.h" + +DECLARE_GLOBAL_DATA_PTR; + +#include "is42s16800a-7t.h" + +#ifndef CONFIG_SYS_RAMBOOT +static void sdram_start(int hi_addr) +{ + long hi_addr_bit = hi_addr ? 0x01000000 : 0; + long control = SDRAM_CONTROL | hi_addr_bit; + + /* unlock mode register */ + *(vu_long *)MPC5XXX_SDRAM_CTRL = control | 0x80000000; + __asm__ volatile ("sync"); + + /* precharge all banks */ + *(vu_long *)MPC5XXX_SDRAM_CTRL = control | 0x80000002; + __asm__ volatile ("sync"); + + /* auto refresh */ + *(vu_long *)MPC5XXX_SDRAM_CTRL = control | 0x80000004; + __asm__ volatile ("sync"); + + /* set mode register */ + *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE; + __asm__ volatile ("sync"); + + /* normal operation */ + *(vu_long *)MPC5XXX_SDRAM_CTRL = control; + __asm__ volatile ("sync"); +} +#endif + +/* + * ATTENTION: Although partially referenced initdram does NOT make real use + * use of CONFIG_SYS_SDRAM_BASE. The code does not work if + * CONFIG_SYS_SDRAM_BASE is something else than 0x00000000. + */ + +phys_size_t initdram(int board_type) +{ + ulong dramsize = 0; + ulong dramsize2 = 0; + uint svr, pvr; +#ifndef CONFIG_SYS_RAMBOOT + ulong test1, test2; + + /* setup SDRAM chip selects */ + *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x0000001C; /* 512MB at 0x0 */ + *(vu_long *)MPC5XXX_SDRAM_CS1CFG = 0x80000000; /* disabled */ + __asm__ volatile ("sync"); + + /* setup config registers */ + *(vu_long *)MPC5XXX_SDRAM_CONFIG1 = SDRAM_CONFIG1; + *(vu_long *)MPC5XXX_SDRAM_CONFIG2 = SDRAM_CONFIG2; + __asm__ volatile ("sync"); + + /* find RAM size using SDRAM CS0 only */ + sdram_start(0); + test1 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x08000000); + sdram_start(1); + test2 = get_ram_size((long *)CONFIG_SYS_SDRAM_BASE, 0x08000000); + if (test1 > test2) { + sdram_start(0); + dramsize = test1; + } else { + dramsize = test2; + } + + /* memory smaller than 1MB is impossible */ + if (dramsize < (1 << 20)) { + dramsize = 0; + } + + /* set SDRAM CS0 size according to the amount of RAM found */ + if (dramsize > 0) { + *(vu_long *)MPC5XXX_SDRAM_CS0CFG = + 0x13 + __builtin_ffs(dramsize >> 20) - 1; + } else { + *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0; /* disabled */ + } + + /* let SDRAM CS1 start right after CS0 */ + *(vu_long *)MPC5XXX_SDRAM_CS1CFG = dramsize + 0x0000001C;/* 512MB */ + + /* find RAM size using SDRAM CS1 only */ + test1 = get_ram_size((long *)(CONFIG_SYS_SDRAM_BASE + dramsize), + 0x08000000); + dramsize2 = test1; + + /* memory smaller than 1MB is impossible */ + if (dramsize2 < (1 << 20)) { + dramsize2 = 0; + } + + /* set SDRAM CS1 size according to the amount of RAM found */ + if (dramsize2 > 0) { + *(vu_long *)MPC5XXX_SDRAM_CS1CFG = dramsize + | (0x13 + __builtin_ffs(dramsize2 >> 20) - 1); + } else { + *(vu_long *)MPC5XXX_SDRAM_CS1CFG = dramsize; /* disabled */ + } + +#else /* CONFIG_SYS_RAMBOOT */ + + /* retrieve size of memory connected to SDRAM CS0 */ + dramsize = *(vu_long *)MPC5XXX_SDRAM_CS0CFG & 0xFF; + if (dramsize >= 0x13) { + dramsize = (1 << (dramsize - 0x13)) << 20; + } else { + dramsize = 0; + } + + /* retrieve size of memory connected to SDRAM CS1 */ + dramsize2 = *(vu_long *)MPC5XXX_SDRAM_CS1CFG & 0xFF; + if (dramsize2 >= 0x13) { + dramsize2 = (1 << (dramsize2 - 0x13)) << 20; + } else { + dramsize2 = 0; + } + +#endif /* CONFIG_SYS_RAMBOOT */ + + /* + * On MPC5200B we need to set the special configuration delay in the + * DDR controller. Please refer to Freescale's AN3221 "MPC5200B SDRAM + * Initialization and Configuration", 3.3.1 SDelay--MBAR + 0x0190: + * + * "The SDelay should be written to a value of 0x00000004. It is + * required to account for changes caused by normal wafer processing + * parameters." + */ + svr = get_svr(); + pvr = get_pvr(); + if ((SVR_MJREV(svr) >= 2) && + (PVR_MAJ(pvr) == 1) && (PVR_MIN(pvr) == 4)) { + + *(vu_long *)MPC5XXX_SDRAM_SDELAY = 0x04; + __asm__ volatile ("sync"); + } + + return dramsize + dramsize2; +} + +int checkboard(void) +{ + char *s = getenv("serial#"); + + puts ("Board: InterControl digsyMTC"); + if (s != NULL) { puts(", "); puts(s); } + putc('\n'); + + return 0; +} + +int board_early_init_r(void) +{ + /* + * Now, when we are in RAM, enable flash write access for detection + * process. Note that CS_BOOT cannot be cleared when executing in + * flash. + */ + *(vu_long *)MPC5XXX_ADDECR &= ~(1 << 25); /* disable CS_BOOT */ + *(vu_long *)MPC5XXX_ADDECR |= (1 << 17); /* enable CS1 */ + *(vu_long *)MPC5XXX_ADDECR |= (1 << 16); /* enable CS0 */ + + return (0); +} + +void set_ethaddr(void) +{ + char str_eth_addr[20]; + uchar eth_addr[6]; + ulong n; + ushort read = 0; + ushort addr = 0; + ushort chip = 0; + ushort addr_of_eth_addr = 0; + ushort len_sys = 0; + ushort len_sys_cfg = 0; + + /* check identification word */ + i2c_read(EEPROM_ADDR, EEPROM_ADDR_IDENT, 1, (uchar *)&read, 2); + if (read != EEPROM_IDENT) + return; + + /* calculate offset of config area */ + i2c_read(EEPROM_ADDR, EEPROM_ADDR_LEN_SYS, 1, (uchar *)&len_sys, 2); + i2c_read(EEPROM_ADDR, EEPROM_ADDR_LEN_SYSCFG, 1, + (uchar *)&len_sys_cfg, 2); + addr_of_eth_addr = (len_sys + len_sys_cfg + EEPROM_OFF_ETHADDR) << 1; + if (addr_of_eth_addr >= EEPROM_LEN) + return; + + for (n = 0; n < 6 ; n++) { + addr = addr_of_eth_addr + n; + chip = EEPROM_ADDR + ((addr & 0x300)>>8); + i2c_read(chip, (addr & 0xFF), 1, (uchar *)ð_addr[n], 1); + } + + sprintf(str_eth_addr, "%02X:%02X:%02X:%02X:%02X:%02X", + eth_addr[0], eth_addr[1], eth_addr[2], + eth_addr[3], eth_addr[4], eth_addr[5]); + setenv("ethaddr", str_eth_addr); +} + +int last_stage_init (void) +{ + set_ethaddr(); + return 0; +} + +#ifdef CONFIG_PCI +static struct pci_controller hose; + +extern void pci_mpc5xxx_init(struct pci_controller *); + +void pci_init_board(void) +{ + pci_mpc5xxx_init(&hose); +} +#endif + +#ifdef CONFIG_CMD_IDE + +#ifdef CONFIG_IDE_RESET + +void init_ide_reset(void) +{ + debug ("init_ide_reset\n"); + + /* set gpio output value to 1 */ + *(vu_long *)MPC5XXX_WU_GPIO_DATA_O |= (1 << 25); + /* open drain output */ + *(vu_long *)MPC5XXX_WU_GPIO_ODE |= (1 << 25); + /* direction output */ + *(vu_long *)MPC5XXX_WU_GPIO_DIR |= (1 << 25); + /* enable gpio */ + *(vu_long *)MPC5XXX_WU_GPIO_ENABLE |= (1 << 25); + +} + +void ide_set_reset(int idereset) +{ + + debug ("ide_reset(%d)\n", idereset); + + /* set gpio output value to 0 */ + *(vu_long *)MPC5XXX_WU_GPIO_DATA_O &= ~(1 << 25); + /* open drain output */ + *(vu_long *)MPC5XXX_WU_GPIO_ODE |= (1 << 25); + /* direction output */ + *(vu_long *)MPC5XXX_WU_GPIO_DIR |= (1 << 25); + /* enable gpio */ + *(vu_long *)MPC5XXX_WU_GPIO_ENABLE |= (1 << 25); + + udelay(10000); + + /* set gpio output value to 1 */ + *(vu_long *)MPC5XXX_WU_GPIO_DATA_O |= (1 << 25); + /* open drain output */ + *(vu_long *)MPC5XXX_WU_GPIO_ODE |= (1 << 25); + /* direction output */ + *(vu_long *)MPC5XXX_WU_GPIO_DIR |= (1 << 25); + /* enable gpio */ + *(vu_long *)MPC5XXX_WU_GPIO_ENABLE |= (1 << 25); + +} +#endif /* CONFIG_IDE_RESET */ + +#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} +#endif /* defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) */ + +#endif /* CONFIG_CMD_IDE */ + diff --git a/board/digsymtc/eeprom.h b/board/digsymtc/eeprom.h new file mode 100644 index 0000000..2efed4a --- /dev/null +++ b/board/digsymtc/eeprom.h @@ -0,0 +1,32 @@ +/* + * (C) Copyright 2009 Semihalf. + * Written by: Grzegorz Bernacki gjb@semihalf.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the anty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ +#ifndef CMD_EEPROM_H +#define CMD_EEPROM_H + +#define EEPROM_ADDR CONFIG_SYS_I2C_EEPROM_ADDR +#define EEPROM_LEN 1024 +#define EEPROM_IDENT 2408 +#define EEPROM_ADDR_IDENT 0x0000 +#define EEPROM_ADDR_LEN_SYS 0x0002 +#define EEPROM_ADDR_LEN_SYSCFG 0x0004 +#define EEPROM_OFF_ETHADDR 23 + +#endif diff --git a/board/digsymtc/is42s16800a-7t.h b/board/digsymtc/is42s16800a-7t.h new file mode 100644 index 0000000..1873ea7 --- /dev/null +++ b/board/digsymtc/is42s16800a-7t.h @@ -0,0 +1,28 @@ +/* + * (C) Copyright 2004-2009 + * Mark Jonas, Freescale Semiconductor, mark.jonas@motorola.com. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#define SDRAM_MODE 0x00CD0000 +#define SDRAM_CONTROL 0x505F0000 +#define SDRAM_CONFIG1 0xD2322900 +#define SDRAM_CONFIG2 0x8AD70000 + diff --git a/cpu/mpc5xxx/ide.c b/cpu/mpc5xxx/ide.c index df5b4ac..07d33e3 100644 --- a/cpu/mpc5xxx/ide.c +++ b/cpu/mpc5xxx/ide.c @@ -12,7 +12,7 @@ * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License @@ -42,7 +42,7 @@ int ide_preinit (void) struct mpc5xxx_sdma *psdma = (struct mpc5xxx_sdma *) MPC5XXX_SDMA;
reg = *(vu_long *) MPC5XXX_GPS_PORT_CONFIG; -#if defined(CONFIG_TOTAL5200) +#if defined(CONFIG_TOTAL5200) || defined(CONFIG_DIGSY_MTC) /* ATA cs0/1 on i2c2 clk/io */ reg = (reg & ~0x03000000ul) | 0x02000000ul; #else diff --git a/drivers/net/mpc5xxx_fec.c b/drivers/net/mpc5xxx_fec.c index f8618b1..a1c72d6 100644 --- a/drivers/net/mpc5xxx_fec.c +++ b/drivers/net/mpc5xxx_fec.c @@ -893,6 +893,7 @@ int mpc5xxx_fec_initialize(bd_t * bis) fec->rbdBase = (FEC_RBD *)(FEC_BD_BASE + FEC_TBD_NUM * sizeof(FEC_TBD)); #if defined(CONFIG_CANMB) || \ defined(CONFIG_CM5200) || \ + defined(CONFIG_DIGSY_MTC) || \ defined(CONFIG_HMI1001) || \ defined(CONFIG_ICECUBE) || \ defined(CONFIG_INKA4X0) || \ diff --git a/include/configs/digsymtc.h b/include/configs/digsymtc.h new file mode 100644 index 0000000..4942103 --- /dev/null +++ b/include/configs/digsymtc.h @@ -0,0 +1,341 @@ +/* + * (C) Copyright 2003-2004 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * (C) Copyright 2005-2007 + * Modified for InterControl digsyMTC MPC5200 board by + * Frank Bodammer, GCD Hard- & Software GmbH, + * frank.bodammer@gcd-solutions.de + * + * (C) Copyright 2009 Semihalf + * Optimized for digsyMTC by: Grzegorz Bernacki gjb@semihalf.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* + * High Level Configuration Options + */ + +#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ +#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ +#define CONFIG_DIGSY_MTC 1 /* ... on InterControl digsyMTC board */ + +#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 + +#define BOOTFLAG_COLD 0x01 +#define BOOTFLAG_WARM 0x02 + +#define CONFIG_SYS_CACHELINE_SIZE 32 + +/* + * Serial console configuration + */ +#define CONFIG_PSC_CONSOLE 4 /* console is on PSC4 */ +#define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ +#define CONFIG_SYS_BAUDRATE_TABLE \ + { 9600, 19200, 38400, 57600, 115200, 230400 } + +/* + * PCI Mapping: + * 0x40000000 - 0x4fffffff - PCI Memory + * 0x50000000 - 0x50ffffff - PCI IO Space + */ +#define CONFIG_PCI 1 +#define CONFIG_PCI_PNP 1 +#define CONFIG_PCI_SCAN_SHOW 1 + +#define CONFIG_PCI_MEM_BUS 0x40000000 +#define CONFIG_PCI_MEM_PHYS CONFIG_PCI_MEM_BUS +#define CONFIG_PCI_MEM_SIZE 0x10000000 + +#define CONFIG_PCI_IO_BUS 0x50000000 +#define CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_BUS +#define CONFIG_PCI_IO_SIZE 0x01000000 + +/* + * Partitions + */ +#define CONFIG_DOS_PARTITION +#define CONFIG_BZIP2 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DFL +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_DIAG +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_ELF +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_I2C +#define CONFIG_CMD_IDE +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_MII +#define CONFIG_CMD_PCI +#define CONFIG_CMD_PING +#define CONFIG_CMD_REGINFO +#define CONFIG_CMD_SAVES +#define CONFIG_CMD_USB + +#if (TEXT_BASE == 0xFF000000) +#define CONFIG_SYS_LOWBOOT 1 +#endif + +/* + * Autobooting + */ +#define CONFIG_BOOTDELAY 1 + +#undef CONFIG_BOOTARGS + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "console=ttyPSC1\0" \ + "kernel_addr_r=400000\0" \ + "fdt_addr_r=600000\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "addip=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:"\ + "${netmask}:${hostname}:${netdev}:off panic=1\0" \ + "addcons=setenv bootargs ${bootargs} console=${console},${baudrate}\0"\ + "rootpath=/opt/eldk/ppc_6xx\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile};" \ + "tftp ${fdt_addr_r} ${fdt_file};" \ + "run nfsargs addip addcons;" \ + "bootm ${kernel_addr_r} - ${fdt_addr_r}\0" \ + "load=tftp 200000 ${u-boot}\0" \ + "update=protect off FFF00000 +${filesize};" \ + "erase FFF00000 +${filesize};" \ + "cp.b 200000 FFF00000 ${filesize};" \ + "protect on FFF00000 +${filesize}\0" \ + "" + +/* + * I2C configuration + */ +#define CONFIG_HARD_I2C 1 +#define CONFIG_SYS_I2C_MODULE 1 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 0x7F + +/* + * EEPROM configuration + */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* 1010000x */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 70 + +/* + * RTC configuration + */ +#define CONFIG_RTC_DS1337 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 + +/* + * Flash configuration + */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 + +#define CONFIG_SYS_FLASH_BASE 0xFF000000 +#define CONFIG_SYS_FLASH_SIZE 0x01000000 + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_FLASH_16BIT +#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 + +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 + +#define OF_CPU "PowerPC,5200@0" +#define OF_SOC "soc5200@f0000000" +#define OF_TBCLK (bd->bi_busfreq / 4) +#define OF_STDOUT_PATH "/soc5200@f0000000/serial@2600" + +#define CONFIG_BOARD_EARLY_INIT_R +/* + * Environment settings + */ + +#define CONFIG_ENV_IS_IN_FLASH 1 +#if defined(CONFIG_LOWBOOT) +#define CONFIG_ENV_ADDR 0xFF060000 +#else /* CONFIG_LOWBOOT */ +#define CONFIG_ENV_ADDR 0xFFF60000 +#endif /* CONFIG_LOWBOOT */ +#define CONFIG_ENV_SIZE 0x10000 +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_OVERWRITE 1 + +/* + * Memory map + */ +#define CONFIG_SYS_MBAR 0xF0000000 +#define CONFIG_SYS_SDRAM_BASE 0x00000000 +#if !defined(CONFIG_SYS_LOWBOOT) +#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 +#else +#define CONFIG_SYS_DEFAULT_MBAR 0xF0000000 +#endif + +/* + * Use SRAM until RAM will be available + */ +#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM +#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE + +#define CONFIG_SYS_GBL_DATA_SIZE 4096 +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_BASE TEXT_BASE +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) +#define CONFIG_SYS_RAMBOOT 1 +#endif + +#define CONFIG_SYS_MONITOR_LEN (256 << 10) +#define CONFIG_SYS_MALLOC_LEN (4096 << 10) +#define CONFIG_SYS_BOOTMAPSZ (8 << 20) + +/* + * Ethernet configuration + */ +#define CONFIG_MPC5xxx_FEC 1 +#define CONFIG_PHY_ADDR 0x00 +#define CONFIG_PHY_RESET_DELAY 1000 + +#define CONFIG_NETCONSOLE /* include NetConsole support */ + +/* + * GPIO configuration + */ +#define CONFIG_SYS_GPS_PORT_CONFIG 0xA2552112 + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP +#define CONFIG_AUTO_COMPLETE 1 +#define CONFIG_SYS_PROMPT "=> " +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n" +#define CONFIG_AUTOBOOT_DELAY_STR " " + +#define CONFIG_LOOPW 1 +#define CONFIG_MX_CYCLIC 1 +#define CONFIG_ZERO_BOOTDELAY_CHECK + +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 32 +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE + +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_SYS_MEMTEST_SCRATCH 0x00001000 +#define CONFIG_SYS_MEMTEST_START 0x00010000 +#define CONFIG_SYS_MEMTEST_END 0x019fffff + +#define CONFIG_SYS_LOAD_ADDR 0x00100000 + +#define CONFIG_SYS_HZ 1000 + +#define CONFIG_LAST_STAGE_INIT + +/* + * Various low-level settings + */ +#define CONFIG_SYS_SDRAM_CS1 1 +#define CONFIG_SYS_XLB_PIPELINING 1 + +#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI +#define CONFIG_SYS_HID0_FINAL HID0_ICE + +#if defined(CONFIG_SYS_LOWBOOT) +#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE +#define CONFIG_SYS_BOOTCS_CFG 0x0002DD00 +#endif + +#define CONFIG_SYS_CS4_START 0x60000000 +#define CONFIG_SYS_CS4_SIZE 0x1000 +#define CONFIG_SYS_CS4_CFG 0x0008FC00 + +#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE +#define CONFIG_SYS_CS0_CFG 0x0002DD00 + +#define CONFIG_SYS_CS_BURST 0x00000000 +#define CONFIG_SYS_CS_DEADCYCLE 0x11111111 + +#if !defined(CONFIG_SYS_LOWBOOT) +#define CONFIG_SYS_RESET_ADDRESS 0xfff00100 +#else +#define CONFIG_SYS_RESET_ADDRESS 0xff000100 +#endif + +/* + * USB + */ +#define CONFIG_USB_OHCI +#define CONFIG_USB_STORAGE + +#define CONFIG_USB_CLOCK 0x00013333 +#define CONFIG_USB_CONFIG 0x00002000 + +/* + * IDE/ATA + */ + +#define CONFIG_IDE_RESET +#define CONFIG_IDE_PREINIT + +#define CONFIG_SYS_IDE_MAXBUS 1 +#define CONFIG_SYS_IDE_MAXDEVICE 1 + +#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 +#define CONFIG_SYS_ATA_BASE_ADDR MPC5XXX_ATA +#define CONFIG_SYS_ATA_DATA_OFFSET (0x0060) +#define CONFIG_SYS_ATA_REG_OFFSET (CONFIG_SYS_ATA_DATA_OFFSET) +#define CONFIG_SYS_ATA_ALT_OFFSET (0x005C) +#define CONFIG_SYS_ATA_STRIDE 4 + +#define CONFIG_ATAPI 1 +#define CONFIG_LBA48 1 + +#endif /* __CONFIG_H */ +
Dear Grzegorz,
General comment: there is a lot of code which could use a few comments so the reader has a chance to understand what exactly you are doing.
- long hi_addr_bit = hi_addr ? 0x01000000 : 0;
- long control = SDRAM_CONTROL | hi_addr_bit;
- /* unlock mode register */
- *(vu_long *)MPC5XXX_SDRAM_CTRL = control | 0x80000000;
- __asm__ volatile ("sync");
- /* precharge all banks */
- *(vu_long *)MPC5XXX_SDRAM_CTRL = control | 0x80000002;
- /* auto refresh */
- *(vu_long *)MPC5XXX_SDRAM_CTRL = control | 0x80000004;
- /* set mode register */
- *(vu_long *)MPC5XXX_SDRAM_MODE = SDRAM_MODE;
- /* normal operation */
- *(vu_long *)MPC5XXX_SDRAM_CTRL = control;
Please use proper I/O accessor functions instead of volatile pointer accesses, here and in all other similar places as well...
You can then get rid of the "sync"s as well.
- ulong dramsize = 0;
- ulong dramsize2 = 0;
- uint svr, pvr;
- ulong test1, test2;
- /* setup SDRAM chip selects */
- *(vu_long *)MPC5XXX_SDRAM_CS0CFG = 0x0000001C; /* 512MB at 0x0 */
- *(vu_long *)MPC5XXX_SDRAM_CS1CFG = 0x80000000; /* disabled */
... like here and below.
- if (s != NULL) { puts(", "); puts(s); }
Please use proper indentation.
Please add "static" here.
- set_ethaddr();
You should do this only as long as "ethaddr" is not already set in the environment.
You want to add some comments what all these magic defines mean...
Please don't arbitrarily reformat the code.
- "console=ttyPSC1\0" \
This looks fishy to me - is it PSC1 or PSC4 ?
Do we really need this?
Wolfgang Denk wrote:
Dear Grzegorz,
Could you point me out which parts of code except eeprom defines needs more comments?
I think this tab was inserted by mistake. In u-boot code there are both versions of license with and without this tab. Do you really want to leave it?
pozdrawiam, Grzesiek
Dear Grzegorz Bernacki,
Hm... ther eare longish code sequences without a single line of comment what you are doing, or why.
The original form of the code has 2 spaces there, as usual after a full stop. It seems this file has been run through "unexpand -a" (or an equivalent command), which inserted a TAB instead of the two spaces. This seems no problem to me, as the text still looks exactly the same (and we same one byte of disk storage :-).
Your patch makes the text look different, and the change is to the worse.
I looked over the code again and still don't find the place with long code sequence without any line of comment (except eeprom defines which I'm going to comment). Could you be more specific about where I should add the comments?
regards, Grzesiek
[snip]
Ahh, but two spaces vs. one tab have different meanings. They just happen to look the same at the moment (blithely ignoring the fact that this particular line of text isn't likely to change).
IMHO, replacing the two spaces with a tab was inadvertent whitespace damage apparently due to a whitespace cleanup and should be fixed back to being two spaces in all the header files.
Painting the bike shed, gvb
Dear Grzegorz,
Ok, I changed it in whole file.
- uint svr, pvr;
ok, done
ok, done
- set_ethaddr();
ok, done
comments added
ok, I restored original layout
Linux enumerates ttyPSC starting from zero, so PSC3 is ttyPSC0 and ttyPSC4 is ttyPSC4. Some time ago ttyPSC number could be enforced by setting port-number field in dts, but lately it was removed.
OF_CPU, OF_SOC and OF_TBCLK is used and I removed OF_STDOUT_PATH.
regards, Grzesiek
Grzegorz Bernacki
Jerry Van Baren
