[PATCH 1/1] tools: image-host.c: use correct output format
When building on a 32bit host the following warning occurs:
tools/image-host.c: In function ‘fit_image_read_data’: tools/image-host.c:310:42: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘ssize_t’ {aka ‘int’} [-Wformat=] printf("Can't read all file %s (read %ld bytes, expexted %ld)\n", ~~^ %d filename, n, sbuf.st_size); ~
n is of type ssize_t so we should use %zd for printing.
Fixes: 7298e422504e ("mkimage: fit: add support to encrypt image with aes") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- tools/image-host.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/image-host.c b/tools/image-host.c index 4e57ddea96..5bb68965e7 100644 --- a/tools/image-host.c +++ b/tools/image-host.c @@ -307,7 +307,7 @@ static int fit_image_read_data(char *filename, unsigned char *data,
/* Check that we have read all the file */ if (n != sbuf.st_size) { - printf("Can't read all file %s (read %ld bytes, expexted %ld)\n", + printf("Can't read all file %s (read %zd bytes, expexted %ld)\n", filename, n, sbuf.st_size); goto err; } -- 2.25.1
Fixes: 7298e422504e ("mkimage: fit: add support to encrypt image with aes") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de Reviewed-by: Simon Glass sjg@chromium.org
