Re: [U-Boot] [PATCH 0/4] sf: Accessing > 16MBytes flashes in existing 3-byte addr mode.
Hello Jagan,
thanks for your contribution.
As there is currently no explicit custodian for sf, I would like to give some comments to your code.
Am 23.02.2013 12:38, schrieb Jagannadha Sutradharudu Teki:
The current implementation in spi_flash supports 3-byte address mode due to this up to 16MB amount of flash is able to access for those flashes which has an actual size of > 16MB.
List of flashes: S25FL256S N25Q256 N25Q256A W25Q256(not yet mainlined)
extended/bank address register contains an information to access the 4th byte addressing hence the flashes which has > 16MB can be accessible.
I don't see a config option described here (and also don't find it in the patches). Please keep in mind that the code size for existing boards should not increase! See http://www.denx.de/wiki/U-Boot/DesignPrinciples , points 1 and 5
The code might fit for your use-case, but has influence on other boards/systems, and this is not acceptable. Please add a config option for this new code and also use the existing options, like CONFIG_SPI_FLASH_SPANSION, in your code.
Thanks, Jagan.
Best Regards, Thomas
Hi Thomas,
-----Original Message----- From: Langer Thomas (LQDE RD ST PON SW) [mailto:thomas.langer@lantiq.com] Sent: 24 February 2013 21:21 To: Jagannadha Sutradharudu Teki; u-boot@lists.denx.de Cc: Michal@theia.denx.de; Jagannadha Sutradharudu Teki Subject: AW: [U-Boot] [PATCH 0/4] sf: Accessing > 16MBytes flashes in existing 3-byte addr mode.
Hello Jagan,
The main reason for not adding CONFIG macro is like this entire support requires spansion, winbond and numonyx flashes. I
As I have added support for spansion, I will send few more patches for winbond and numonyx support as well.
Can I send all the patches again including winbond and numonyx support with RESEND as prefix?
Is still a config macro required if the code opt for these 3 flashes?
Thanks, Jagan.
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
