[U-Boot-Users] [PATCH 3/5] OneNAND support
[PATCH] OneNAND support
Signed-off-by: Kyungmin Park kyungmin.park@samsung.com --- diff --git a/drivers/onenand/onenand_base.c b/drivers/onenand/onenand_base.c new file mode 100644 index 0000000..997bd00 --- /dev/null +++ b/drivers/onenand/onenand_base.c @@ -0,0 +1,1312 @@ +/* + * linux/drivers/mtd/onenand/onenand_base.c + * + * Copyright (C) 2005-2007 Samsung Electronics + * Kyungmin Park kyungmin.park@samsung.com + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#include <common.h> + +#ifdef CONFIG_CMD_ONENAND + +#include <linux/mtd/onenand.h> + +#undef __mem_pci +#include <asm/io.h> + +#ifdef __ARM__ +extern void memcpy32(void *, void *, size_t); + +static void *memcpy(void *dest, const void *src, size_t count) +{ + if (count < 32) { + unsigned short *_s = (unsigned short *)(src); + unsigned short *_d = (unsigned short *)(dest); + count >>= 1; + while (count--) + *_d++ = *_s++; + return _d; + } + + memcpy32(dest, (void *)src, count); + + return (void *)count; +} +#endif + +static const unsigned char ffchars[] = { + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 16 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 32 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 48 */ + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 64 */ +}; + +/** + * onenand_readw - [OneNAND Interface] Read OneNAND register + * @param addr address to read + * + * Read OneNAND register + */ +static unsigned short onenand_readw(void __iomem * addr) +{ + return readw(addr); +} + +/** + * onenand_writew - [OneNAND Interface] Write OneNAND register with value + * @param value value to write + * @param addr address to write + * + * Write OneNAND register with value + */ +static void onenand_writew(unsigned short value, void __iomem * addr) +{ + writew(value, addr); +} + +/** + * onenand_block_address - [DEFAULT] Get block address + * @param device the device id + * @param block the block + * @return translated block address if DDP, otherwise same + * + * Setup Start Address 1 Register (F100h) + */ +static int onenand_block_address(int device, int block) +{ + if (device & ONENAND_DEVICE_IS_DDP) { + /* Device Flash Core select, NAND Flash Block Address */ + int dfs = 0, density, mask; + + density = device >> ONENAND_DEVICE_DENSITY_SHIFT; + mask = (1 << (density + 6)); + + if (block & mask) + dfs = 1; + + return (dfs << ONENAND_DDP_SHIFT) | (block & (mask - 1)); + } + + return block; +} + +/** + * onenand_bufferram_address - [DEFAULT] Get bufferram address + * @param device the device id + * @param block the block + * @return set DBS value if DDP, otherwise 0 + * + * Setup Start Address 2 Register (F101h) for DDP + */ +static int onenand_bufferram_address(int device, int block) +{ + if (device & ONENAND_DEVICE_IS_DDP) { + /* Device BufferRAM Select */ + int dbs = 0, density, mask; + + density = device >> ONENAND_DEVICE_DENSITY_SHIFT; + mask = (1 << (density + 6)); + + if (block & mask) + dbs = 1; + + return (dbs << ONENAND_DDP_SHIFT); + } + + return 0; +} + +/** + * onenand_page_address - [DEFAULT] Get page address + * @param page the page address + * @param sector the sector address + * @return combined page and sector address + * + * Setup Start Address 8 Register (F107h) + */ +static int onenand_page_address(int page, int sector) +{ + /* Flash Page Address, Flash Sector Address */ + int fpa, fsa; + + fpa = page & ONENAND_FPA_MASK; + fsa = sector & ONENAND_FSA_MASK; + + return ((fpa << ONENAND_FPA_SHIFT) | fsa); +} + +/** + * onenand_buffer_address - [DEFAULT] Get buffer address + * @param dataram1 DataRAM index + * @param sectors the sector address + * @param count the number of sectors + * @return the start buffer value + * + * Setup Start Buffer Register (F200h) + */ +static int onenand_buffer_address(int dataram1, int sectors, int count) +{ + int bsa, bsc; + + /* BufferRAM Sector Address */ + bsa = sectors & ONENAND_BSA_MASK; + + if (dataram1) + bsa |= ONENAND_BSA_DATARAM1; /* DataRAM1 */ + else + bsa |= ONENAND_BSA_DATARAM0; /* DataRAM0 */ + + /* BufferRAM Sector Count */ + bsc = count & ONENAND_BSC_MASK; + + return ((bsa << ONENAND_BSA_SHIFT) | bsc); +} + +/** + * onenand_command - [DEFAULT] Send command to OneNAND device + * @param mtd MTD device structure + * @param cmd the command to be sent + * @param addr offset to read from or write to + * @param len number of bytes to read or write + * + * Send command to OneNAND device. This function is used for middle/large page + * devices (1KB/2KB Bytes per page) + */ +static int onenand_command(struct mtd_info *mtd, int cmd, loff_t addr, + size_t len) +{ + struct onenand_chip *this = mtd->priv; + int value, readcmd = 0; + int block, page; + /* Now we use page size operation */ + int sectors = 4, count = 4; + + /* Address translation */ + switch (cmd) { + case ONENAND_CMD_UNLOCK: + case ONENAND_CMD_LOCK: + case ONENAND_CMD_LOCK_TIGHT: + block = -1; + page = -1; + break; + + case ONENAND_CMD_ERASE: + case ONENAND_CMD_BUFFERRAM: + block = (int)(addr >> this->erase_shift); + page = -1; + break; + + default: + block = (int)(addr >> this->erase_shift); + page = (int)(addr >> this->page_shift); + page &= this->page_mask; + break; + } + + /* NOTE: The setting order of the registers is very important! */ + if (cmd == ONENAND_CMD_BUFFERRAM) { + /* Select DataRAM for DDP */ + value = onenand_bufferram_address(this->device_id, block); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS2); + + /* Switch to the next data buffer */ + ONENAND_SET_NEXT_BUFFERRAM(this); + + return 0; + } + + if (block != -1) { + /* Write 'DFS, FBA' of Flash */ + value = onenand_block_address(this->device_id, block); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS1); + } + + if (page != -1) { + int dataram; + + switch (cmd) { + case ONENAND_CMD_READ: + case ONENAND_CMD_READOOB: + dataram = ONENAND_SET_NEXT_BUFFERRAM(this); + readcmd = 1; + break; + + default: + dataram = ONENAND_CURRENT_BUFFERRAM(this); + break; + } + + /* Write 'FPA, FSA' of Flash */ + value = onenand_page_address(page, sectors); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS8); + + /* Write 'BSA, BSC' of DataRAM */ + value = onenand_buffer_address(dataram, sectors, count); + this->write_word(value, this->base + ONENAND_REG_START_BUFFER); + + if (readcmd) { + /* Select DataRAM for DDP */ + value = + onenand_bufferram_address(this->device_id, block); + this->write_word(value, + this->base + + ONENAND_REG_START_ADDRESS2); + } + } + + /* Interrupt clear */ + this->write_word(ONENAND_INT_CLEAR, this->base + ONENAND_REG_INTERRUPT); + /* Write command */ + this->write_word(cmd, this->base + ONENAND_REG_COMMAND); + + return 0; +} + +/** + * onenand_wait - [DEFAULT] wait until the command is done + * @param mtd MTD device structure + * @param state state to select the max. timeout value + * + * Wait for command done. This applies to all OneNAND command + * Read can take up to 30us, erase up to 2ms and program up to 350us + * according to general OneNAND specs + */ +static int onenand_wait(struct mtd_info *mtd, int state) +{ + struct onenand_chip *this = mtd->priv; + unsigned int flags = ONENAND_INT_MASTER; + unsigned int interrupt = 0; + unsigned int ctrl, ecc; + + while (1) { + interrupt = this->read_word(this->base + ONENAND_REG_INTERRUPT); + if (interrupt & flags) + break; + } + + ctrl = this->read_word(this->base + ONENAND_REG_CTRL_STATUS); + + if (ctrl & ONENAND_CTRL_ERROR) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_wait: controller error = 0x%04x\n", ctrl); + return -EAGAIN; + } + + if (ctrl & ONENAND_CTRL_LOCK) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_wait: it's locked error = 0x%04x\n", ctrl); + return -EIO; + } + + if (interrupt & ONENAND_INT_READ) { + ecc = this->read_word(this->base + ONENAND_REG_ECC_STATUS); + if (ecc & ONENAND_ECC_2BIT_ALL) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_wait: ECC error = 0x%04x\n", ecc); + return -EBADMSG; + } + } + + return 0; +} + +/** + * onenand_bufferram_offset - [DEFAULT] BufferRAM offset + * @param mtd MTD data structure + * @param area BufferRAM area + * @return offset given area + * + * Return BufferRAM offset given area + */ +static inline int onenand_bufferram_offset(struct mtd_info *mtd, int area) +{ + struct onenand_chip *this = mtd->priv; + + if (ONENAND_CURRENT_BUFFERRAM(this)) { + if (area == ONENAND_DATARAM) + return mtd->oobblock; + if (area == ONENAND_SPARERAM) + return mtd->oobsize; + } + + return 0; +} + +/** + * onenand_read_bufferram - [OneNAND Interface] Read the bufferram area + * @param mtd MTD data structure + * @param area BufferRAM area + * @param buffer the databuffer to put/get data + * @param offset offset to read from or write to + * @param count number of bytes to read/write + * + * Read the BufferRAM area + */ +static int onenand_read_bufferram(struct mtd_info *mtd, int area, + unsigned char *buffer, int offset, + size_t count) +{ + struct onenand_chip *this = mtd->priv; + void __iomem *bufferram; + + bufferram = this->base + area; + bufferram += onenand_bufferram_offset(mtd, area); + + memcpy(buffer, bufferram + offset, count); + + return 0; +} + +/** + * onenand_sync_read_bufferram - [OneNAND Interface] Read the bufferram area with Sync. Burst mode + * @param mtd MTD data structure + * @param area BufferRAM area + * @param buffer the databuffer to put/get data + * @param offset offset to read from or write to + * @param count number of bytes to read/write + * + * Read the BufferRAM area with Sync. Burst Mode + */ +static int onenand_sync_read_bufferram(struct mtd_info *mtd, int area, + unsigned char *buffer, int offset, + size_t count) +{ + struct onenand_chip *this = mtd->priv; + void __iomem *bufferram; + + bufferram = this->base + area; + bufferram += onenand_bufferram_offset(mtd, area); + + this->mmcontrol(mtd, ONENAND_SYS_CFG1_SYNC_READ); + + memcpy(buffer, bufferram + offset, count); + + this->mmcontrol(mtd, 0); + + return 0; +} + +/** + * onenand_write_bufferram - [OneNAND Interface] Write the bufferram area + * @param mtd MTD data structure + * @param area BufferRAM area + * @param buffer the databuffer to put/get data + * @param offset offset to read from or write to + * @param count number of bytes to read/write + * + * Write the BufferRAM area + */ +static int onenand_write_bufferram(struct mtd_info *mtd, int area, + const unsigned char *buffer, int offset, + size_t count) +{ + struct onenand_chip *this = mtd->priv; + void __iomem *bufferram; + + bufferram = this->base + area; + bufferram += onenand_bufferram_offset(mtd, area); + + memcpy(bufferram + offset, buffer, count); + + return 0; +} + +/** + * onenand_check_bufferram - [GENERIC] Check BufferRAM information + * @param mtd MTD data structure + * @param addr address to check + * @return 1 if there are valid data, otherwise 0 + * + * Check bufferram if there is data we required + */ +static int onenand_check_bufferram(struct mtd_info *mtd, loff_t addr) +{ + struct onenand_chip *this = mtd->priv; + int block, page; + int i; + + block = (int)(addr >> this->erase_shift); + page = (int)(addr >> this->page_shift); + page &= this->page_mask; + + i = ONENAND_CURRENT_BUFFERRAM(this); + + /* Is there valid data? */ + if (this->bufferram[i].block == block && + this->bufferram[i].page == page && this->bufferram[i].valid) + return 1; + + return 0; +} + +/** + * onenand_update_bufferram - [GENERIC] Update BufferRAM information + * @param mtd MTD data structure + * @param addr address to update + * @param valid valid flag + * + * Update BufferRAM information + */ +static int onenand_update_bufferram(struct mtd_info *mtd, loff_t addr, + int valid) +{ + struct onenand_chip *this = mtd->priv; + int block, page; + int i; + + block = (int)(addr >> this->erase_shift); + page = (int)(addr >> this->page_shift); + page &= this->page_mask; + + /* Invalidate BufferRAM */ + for (i = 0; i < MAX_BUFFERRAM; i++) { + if (this->bufferram[i].block == block && + this->bufferram[i].page == page) + this->bufferram[i].valid = 0; + } + + /* Update BufferRAM */ + i = ONENAND_CURRENT_BUFFERRAM(this); + this->bufferram[i].block = block; + this->bufferram[i].page = page; + this->bufferram[i].valid = valid; + + return 0; +} + +/** + * onenand_get_device - [GENERIC] Get chip for selected access + * @param mtd MTD device structure + * @param new_state the state which is requested + * + * Get the device and lock it for exclusive access + */ +static void onenand_get_device(struct mtd_info *mtd, int new_state) +{ + /* Do nothing */ +} + +/** + * onenand_release_device - [GENERIC] release chip + * @param mtd MTD device structure + * + * Deselect, release chip lock and wake up anyone waiting on the device + */ +static void onenand_release_device(struct mtd_info *mtd) +{ + /* Do nothing */ +} + +/** + * onenand_read_ecc - [MTD Interface] Read data with ECC + * @param mtd MTD device structure + * @param from offset to read from + * @param len number of bytes to read + * @param retlen pointer to variable to store the number of read bytes + * @param buf the databuffer to put data + * @param oob_buf filesystem supplied oob data buffer + * @param oobsel oob selection structure + * + * OneNAND read with ECC + */ +static int onenand_read_ecc(struct mtd_info *mtd, loff_t from, size_t len, + size_t * retlen, u_char * buf, + u_char * oob_buf, struct nand_oobinfo *oobsel) +{ + struct onenand_chip *this = mtd->priv; + int read = 0, column; + int thislen; + int ret = 0; + + DEBUG(MTD_DEBUG_LEVEL3, "onenand_read_ecc: from = 0x%08x, len = %i\n", + (unsigned int)from, (int)len); + + /* Do not allow reads past end of device */ + if ((from + len) > mtd->size) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_read_ecc: Attempt read beyond end of device\n"); + *retlen = 0; + return -EINVAL; + } + + /* Grab the lock and see if the device is available */ + onenand_get_device(mtd, FL_READING); + + while (read < len) { + thislen = min_t(int, mtd->oobblock, len - read); + + column = from & (mtd->oobblock - 1); + if (column + thislen > mtd->oobblock) + thislen = mtd->oobblock - column; + + if (!onenand_check_bufferram(mtd, from)) { + this->command(mtd, ONENAND_CMD_READ, from, + mtd->oobblock); + ret = this->wait(mtd, FL_READING); + /* First copy data and check return value for ECC handling */ + onenand_update_bufferram(mtd, from, 1); + } + + this->read_bufferram(mtd, ONENAND_DATARAM, buf, column, + thislen); + + read += thislen; + if (read == len) + break; + + if (ret) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_read_ecc: read failed = %d\n", ret); + break; + } + + from += thislen; + buf += thislen; + } + + /* Deselect and wake up anyone waiting on the device */ + onenand_release_device(mtd); + + /* + * Return success, if no ECC failures, else -EBADMSG + * fs driver will take care of that, because + * retlen == desired len and result == -EBADMSG + */ + *retlen = read; + return ret; +} + +/** + * onenand_read - [MTD Interface] MTD compability function for onenand_read_ecc + * @param mtd MTD device structure + * @param from offset to read from + * @param len number of bytes to read + * @param retlen pointer to variable to store the number of read bytes + * @param buf the databuffer to put data + * + * This function simply calls onenand_read_ecc with oob buffer and oobsel = NULL +*/ +int onenand_read(struct mtd_info *mtd, loff_t from, size_t len, + size_t * retlen, u_char * buf) +{ + return onenand_read_ecc(mtd, from, len, retlen, buf, NULL, NULL); +} + +/** + * onenand_read_oob - [MTD Interface] OneNAND read out-of-band + * @param mtd MTD device structure + * @param from offset to read from + * @param len number of bytes to read + * @param retlen pointer to variable to store the number of read bytes + * @param buf the databuffer to put data + * + * OneNAND read out-of-band data from the spare area + */ +int onenand_read_oob(struct mtd_info *mtd, loff_t from, size_t len, + size_t * retlen, u_char * buf) +{ + struct onenand_chip *this = mtd->priv; + int read = 0, thislen, column; + int ret = 0; + + DEBUG(MTD_DEBUG_LEVEL3, "onenand_read_oob: from = 0x%08x, len = %i\n", + (unsigned int)from, (int)len); + + /* Initialize return length value */ + *retlen = 0; + + /* Do not allow reads past end of device */ + if (unlikely((from + len) > mtd->size)) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_read_oob: Attempt read beyond end of device\n"); + return -EINVAL; + } + + /* Grab the lock and see if the device is available */ + onenand_get_device(mtd, FL_READING); + + column = from & (mtd->oobsize - 1); + + while (read < len) { + thislen = mtd->oobsize - column; + thislen = min_t(int, thislen, len); + + this->command(mtd, ONENAND_CMD_READOOB, from, mtd->oobsize); + + onenand_update_bufferram(mtd, from, 0); + + ret = this->wait(mtd, FL_READING); + /* First copy data and check return value for ECC handling */ + + this->read_bufferram(mtd, ONENAND_SPARERAM, buf, column, + thislen); + + read += thislen; + if (read == len) + break; + + if (ret) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_read_oob: read failed = %d\n", ret); + break; + } + + buf += thislen; + /* Read more? */ + if (read < len) { + /* Page size */ + from += mtd->oobblock; + column = 0; + } + } + + /* Deselect and wake up anyone waiting on the device */ + onenand_release_device(mtd); + + *retlen = read; + return ret; +} + +#ifdef CONFIG_MTD_ONENAND_VERIFY_WRITE +/** + * onenand_verify_page - [GENERIC] verify the chip contents after a write + * @param mtd MTD device structure + * @param buf the databuffer to verify + * @param block block address + * @param page page address + * + * Check DataRAM area directly + */ +static int onenand_verify_page(struct mtd_info *mtd, u_char * buf, + loff_t addr, int block, int page) +{ + struct onenand_chip *this = mtd->priv; + void __iomem *dataram0, *dataram1; + int ret = 0; + + this->command(mtd, ONENAND_CMD_READ, addr, mtd->oobblock); + + ret = this->wait(mtd, FL_READING); + if (ret) + return ret; + + onenand_update_bufferram(mtd, addr, 1); + + /* Check, if the two dataram areas are same */ + dataram0 = this->base + ONENAND_DATARAM; + dataram1 = dataram0 + mtd->oobblock; + + if (memcmp(dataram0, dataram1, mtd->oobblock)) + return -EBADMSG; + + return 0; +} +#else +#define onenand_verify_page(...) (0) +#endif + +#define NOTALIGNED(x) ((x & (mtd->oobblock - 1)) != 0) + +/** + * onenand_write_ecc - [MTD Interface] OneNAND write with ECC + * @param mtd MTD device structure + * @param to offset to write to + * @param len number of bytes to write + * @param retlen pointer to variable to store the number of written bytes + * @param buf the data to write + * @param eccbuf filesystem supplied oob data buffer + * @param oobsel oob selection structure + * + * OneNAND write with ECC + */ +static int onenand_write_ecc(struct mtd_info *mtd, loff_t to, size_t len, + size_t * retlen, const u_char * buf, + u_char * eccbuf, struct nand_oobinfo *oobsel) +{ + struct onenand_chip *this = mtd->priv; + int written = 0; + int ret = 0; + + DEBUG(MTD_DEBUG_LEVEL3, "onenand_write_ecc: to = 0x%08x, len = %i\n", + (unsigned int)to, (int)len); + + /* Initialize retlen, in case of early exit */ + *retlen = 0; + + /* Do not allow writes past end of device */ + if (unlikely((to + len) > mtd->size)) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_write_ecc: Attempt write to past end of device\n"); + return -EINVAL; + } + + /* Reject writes, which are not page aligned */ + if (unlikely(NOTALIGNED(to)) || unlikely(NOTALIGNED(len))) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_write_ecc: Attempt to write not page aligned data\n"); + return -EINVAL; + } + + /* Grab the lock and see if the device is available */ + onenand_get_device(mtd, FL_WRITING); + + /* Loop until all data write */ + while (written < len) { + int thislen = min_t(int, mtd->oobblock, len - written); + + this->command(mtd, ONENAND_CMD_BUFFERRAM, to, mtd->oobblock); + + this->write_bufferram(mtd, ONENAND_DATARAM, buf, 0, thislen); + this->write_bufferram(mtd, ONENAND_SPARERAM, ffchars, 0, + mtd->oobsize); + + this->command(mtd, ONENAND_CMD_PROG, to, mtd->oobblock); + + onenand_update_bufferram(mtd, to, 1); + + ret = this->wait(mtd, FL_WRITING); + if (ret) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_write_ecc: write filaed %d\n", ret); + break; + } + + written += thislen; + + /* Only check verify write turn on */ + ret = onenand_verify_page(mtd, (u_char *) buf, to, block, page); + if (ret) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_write_ecc: verify failed %d\n", ret); + break; + } + + if (written == len) + break; + + to += thislen; + buf += thislen; + } + + /* Deselect and wake up anyone waiting on the device */ + onenand_release_device(mtd); + + *retlen = written; + + return ret; +} + +/** + * onenand_write - [MTD Interface] compability function for onenand_write_ecc + * @param mtd MTD device structure + * @param to offset to write to + * @param len number of bytes to write + * @param retlen pointer to variable to store the number of written bytes + * @param buf the data to write + * + * This function simply calls onenand_write_ecc + * with oob buffer and oobsel = NULL + */ +int onenand_write(struct mtd_info *mtd, loff_t to, size_t len, + size_t * retlen, const u_char * buf) +{ + return onenand_write_ecc(mtd, to, len, retlen, buf, NULL, NULL); +} + +/** + * onenand_write_oob - [MTD Interface] OneNAND write out-of-band + * @param mtd MTD device structure + * @param to offset to write to + * @param len number of bytes to write + * @param retlen pointer to variable to store the number of written bytes + * @param buf the data to write + * + * OneNAND write out-of-band + */ +int onenand_write_oob(struct mtd_info *mtd, loff_t to, size_t len, + size_t * retlen, const u_char * buf) +{ + struct onenand_chip *this = mtd->priv; + int column, status; + int written = 0; + + DEBUG(MTD_DEBUG_LEVEL3, "onenand_write_oob: to = 0x%08x, len = %i\n", + (unsigned int)to, (int)len); + + /* Initialize retlen, in case of early exit */ + *retlen = 0; + + /* Do not allow writes past end of device */ + if (unlikely((to + len) > mtd->size)) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_write_oob: Attempt write to past end of device\n"); + return -EINVAL; + } + + /* Grab the lock and see if the device is available */ + onenand_get_device(mtd, FL_WRITING); + + /* Loop until all data write */ + while (written < len) { + int thislen = min_t(int, mtd->oobsize, len - written); + + column = to & (mtd->oobsize - 1); + + this->command(mtd, ONENAND_CMD_BUFFERRAM, to, mtd->oobsize); + + this->write_bufferram(mtd, ONENAND_SPARERAM, ffchars, 0, + mtd->oobsize); + this->write_bufferram(mtd, ONENAND_SPARERAM, buf, column, + thislen); + + this->command(mtd, ONENAND_CMD_PROGOOB, to, mtd->oobsize); + + onenand_update_bufferram(mtd, to, 0); + + status = this->wait(mtd, FL_WRITING); + if (status) + break; + + written += thislen; + if (written == len) + break; + + to += thislen; + buf += thislen; + } + + /* Deselect and wake up anyone waiting on the device */ + onenand_release_device(mtd); + + *retlen = written; + + return 0; +} + +/** + * onenand_erase - [MTD Interface] erase block(s) + * @param mtd MTD device structure + * @param instr erase instruction + * + * Erase one ore more blocks + */ +int onenand_erase(struct mtd_info *mtd, struct erase_info *instr) +{ + struct onenand_chip *this = mtd->priv; + unsigned int block_size; + loff_t addr; + int len; + int ret = 0; + + DEBUG(MTD_DEBUG_LEVEL3, "onenand_erase: start = 0x%08x, len = %i\n", + (unsigned int)instr->addr, (unsigned int)instr->len); + + block_size = (1 << this->erase_shift); + + /* Start address must align on block boundary */ + if (unlikely(instr->addr & (block_size - 1))) { + DEBUG(MTD_DEBUG_LEVEL0, "onenand_erase: Unaligned address\n"); + return -EINVAL; + } + + /* Length must align on block boundary */ + if (unlikely(instr->len & (block_size - 1))) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_erase: Length not block aligned\n"); + return -EINVAL; + } + + /* Do not allow erase past end of device */ + if (unlikely((instr->len + instr->addr) > mtd->size)) { + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_erase: Erase past end of device\n"); + return -EINVAL; + } + + instr->fail_addr = 0xffffffff; + + /* Grab the lock and see if the device is available */ + onenand_get_device(mtd, FL_ERASING); + + /* Loop throught the pages */ + len = instr->len; + addr = instr->addr; + + instr->state = MTD_ERASING; + + while (len) { + + /* TODO Check badblock */ + + this->command(mtd, ONENAND_CMD_ERASE, addr, block_size); + + ret = this->wait(mtd, FL_ERASING); + /* Check, if it is write protected */ + if (ret) { + if (ret == -EPERM) + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_erase: Device is write protected!!!\n"); + else + DEBUG(MTD_DEBUG_LEVEL0, + "onenand_erase: Failed erase, block %d\n", + (unsigned)(addr >> this->erase_shift)); + instr->state = MTD_ERASE_FAILED; + instr->fail_addr = addr; + goto erase_exit; + } + + len -= block_size; + addr += block_size; + } + + instr->state = MTD_ERASE_DONE; + + erase_exit: + + ret = instr->state == MTD_ERASE_DONE ? 0 : -EIO; + /* Do call back function */ + if (!ret) + mtd_erase_callback(instr); + + /* Deselect and wake up anyone waiting on the device */ + onenand_release_device(mtd); + + return ret; +} + +/** + * onenand_sync - [MTD Interface] sync + * @param mtd MTD device structure + * + * Sync is actually a wait for chip ready function + */ +void onenand_sync(struct mtd_info *mtd) +{ + DEBUG(MTD_DEBUG_LEVEL3, "onenand_sync: called\n"); + + /* Grab the lock and see if the device is available */ + onenand_get_device(mtd, FL_SYNCING); + + /* Release it and go back */ + onenand_release_device(mtd); +} + +/** + * onenand_block_isbad - [MTD Interface] Check whether the block at the given offset is bad + * @param mtd MTD device structure + * @param ofs offset relative to mtd start + */ +int onenand_block_isbad(struct mtd_info *mtd, loff_t ofs) +{ + /* + * TODO + * 1. Bad block table (BBT) + * -> using NAND BBT to support JFFS2 + * 2. Bad block management (BBM) + * -> bad block replace scheme + * + * Currently we do nothing + */ + return 0; +} + +/** + * onenand_block_markbad - [MTD Interface] Mark the block at the given offset as bad + * @param mtd MTD device structure + * @param ofs offset relative to mtd start + */ +int onenand_block_markbad(struct mtd_info *mtd, loff_t ofs) +{ + /* see above */ + return 0; +} + +/** + * onenand_unlock - [MTD Interface] Unlock block(s) + * @param mtd MTD device structure + * @param ofs offset relative to mtd start + * @param len number of bytes to unlock + * + * Unlock one or more blocks + */ +int onenand_unlock(struct mtd_info *mtd, loff_t ofs, size_t len) +{ + struct onenand_chip *this = mtd->priv; + int start, end, block, value, status; + + start = ofs >> this->erase_shift; + end = len >> this->erase_shift; + + /* Continuous lock scheme */ + if (this->options & ONENAND_CONT_LOCK) { + /* Set start block address */ + this->write_word(start, + this->base + ONENAND_REG_START_BLOCK_ADDRESS); + /* Set end block address */ + this->write_word(end - 1, + this->base + ONENAND_REG_END_BLOCK_ADDRESS); + /* Write unlock command */ + this->command(mtd, ONENAND_CMD_UNLOCK, 0, 0); + + /* There's no return value */ + this->wait(mtd, FL_UNLOCKING); + + /* Sanity check */ + while (this->read_word(this->base + ONENAND_REG_CTRL_STATUS) + & ONENAND_CTRL_ONGO) + continue; + + /* Check lock status */ + status = this->read_word(this->base + ONENAND_REG_WP_STATUS); + if (!(status & ONENAND_WP_US)) + printk(KERN_ERR "wp status = 0x%x\n", status); + + return 0; + } + + /* Block lock scheme */ + for (block = start; block < end; block++) { + /* Set start block address */ + this->write_word(block, + this->base + ONENAND_REG_START_BLOCK_ADDRESS); + /* Write unlock command */ + this->command(mtd, ONENAND_CMD_UNLOCK, 0, 0); + + /* There's no return value */ + this->wait(mtd, FL_UNLOCKING); + + /* Sanity check */ + while (this->read_word(this->base + ONENAND_REG_CTRL_STATUS) + & ONENAND_CTRL_ONGO) + continue; + + /* Set block address for read block status */ + value = onenand_block_address(this->device_id, block); + this->write_word(value, + this->base + ONENAND_REG_START_ADDRESS1); + + /* Check lock status */ + status = this->read_word(this->base + ONENAND_REG_WP_STATUS); + if (!(status & ONENAND_WP_US)) + printk(KERN_ERR "block = %d, wp status = 0x%x\n", + block, status); + } + + return 0; +} + +/** + * onenand_print_device_info - Print device ID + * @param device device ID + * + * Print device ID + */ +void onenand_print_device_info(int device, int verbose) +{ + int vcc, demuxed, ddp, density; + + if (!verbose) + return; + + vcc = device & ONENAND_DEVICE_VCC_MASK; + demuxed = device & ONENAND_DEVICE_IS_DEMUX; + ddp = device & ONENAND_DEVICE_IS_DDP; + density = device >> ONENAND_DEVICE_DENSITY_SHIFT; + printk(KERN_INFO "%sOneNAND%s %dMB %sV 16-bit (0x%02x)\n", + demuxed ? "" : "Muxed ", + ddp ? "(DDP)" : "", + (16 << density), vcc ? "2.65/3.3" : "1.8", device); +} + +static const struct onenand_manufacturers onenand_manuf_ids[] = { + {ONENAND_MFR_SAMSUNG, "Samsung"}, + {ONENAND_MFR_UNKNOWN, "Unknown"} +}; + +/** + * onenand_check_maf - Check manufacturer ID + * @param manuf manufacturer ID + * + * Check manufacturer ID + */ +static int onenand_check_maf(int manuf) +{ + int i; + + for (i = 0; onenand_manuf_ids[i].id; i++) { + if (manuf == onenand_manuf_ids[i].id) + break; + } + +#ifdef ONENAND_DEBUG + printk(KERN_DEBUG "OneNAND Manufacturer: %s (0x%0x)\n", + onenand_manuf_ids[i].name, manuf); +#endif + + return (i != ONENAND_MFR_UNKNOWN); +} + +/** + * onenand_probe - [OneNAND Interface] Probe the OneNAND device + * @param mtd MTD device structure + * + * OneNAND detection method: + * Compare the the values from command with ones from register + */ +static int onenand_probe(struct mtd_info *mtd) +{ + struct onenand_chip *this = mtd->priv; + int bram_maf_id, bram_dev_id, maf_id, dev_id; + int version_id; + int density; + + /* Send the command for reading device ID from BootRAM */ + this->write_word(ONENAND_CMD_READID, this->base + ONENAND_BOOTRAM); + + /* Read manufacturer and device IDs from BootRAM */ + bram_maf_id = this->read_word(this->base + ONENAND_BOOTRAM + 0x0); + bram_dev_id = this->read_word(this->base + ONENAND_BOOTRAM + 0x2); + + /* Check manufacturer ID */ + if (onenand_check_maf(bram_maf_id)) + return -ENXIO; + + /* Reset OneNAND to read default register values */ + this->write_word(ONENAND_CMD_RESET, this->base + ONENAND_BOOTRAM); + + { + int i; + for (i = 0; i < 10000; i++) ; + } + + /* Read manufacturer and device IDs from Register */ + maf_id = this->read_word(this->base + ONENAND_REG_MANUFACTURER_ID); + dev_id = this->read_word(this->base + ONENAND_REG_DEVICE_ID); + + /* Check OneNAND device */ + if (maf_id != bram_maf_id || dev_id != bram_dev_id) + return -ENXIO; + + /* Flash device information */ + onenand_print_device_info(dev_id, 0); + this->device_id = dev_id; + + density = dev_id >> ONENAND_DEVICE_DENSITY_SHIFT; + this->chipsize = (16 << density) << 20; + + /* OneNAND page size & block size */ + /* The data buffer size is equal to page size */ + mtd->oobblock = + this->read_word(this->base + ONENAND_REG_DATA_BUFFER_SIZE); + mtd->oobsize = mtd->oobblock >> 5; + /* Pagers per block is always 64 in OneNAND */ + mtd->erasesize = mtd->oobblock << 6; + + this->erase_shift = ffs(mtd->erasesize) - 1; + this->page_shift = ffs(mtd->oobblock) - 1; + this->ppb_shift = (this->erase_shift - this->page_shift); + this->page_mask = (mtd->erasesize / mtd->oobblock) - 1; + + /* REVIST: Multichip handling */ + + mtd->size = this->chipsize; + + /* Version ID */ + version_id = this->read_word(this->base + ONENAND_REG_VERSION_ID); +#ifdef ONENAND_DEBUG + printk(KERN_DEBUG "OneNAND version = 0x%04x\n", version_id); +#endif + + /* Lock scheme */ + if (density <= ONENAND_DEVICE_DENSITY_512Mb && + !(version_id >> ONENAND_VERSION_PROCESS_SHIFT)) { + printk(KERN_INFO "Lock scheme is Continues Lock\n"); + this->options |= ONENAND_CONT_LOCK; + } + + return 0; +} + +/** + * onenand_scan - [OneNAND Interface] Scan for the OneNAND device + * @param mtd MTD device structure + * @param maxchips Number of chips to scan for + * + * This fills out all the not initialized function pointers + * with the defaults. + * The flash ID is read and the mtd/chip structures are + * filled with the appropriate values. + */ +int onenand_scan(struct mtd_info *mtd, int maxchips) +{ + struct onenand_chip *this = mtd->priv; + + if (!this->read_word) + this->read_word = onenand_readw; + if (!this->write_word) + this->write_word = onenand_writew; + + if (!this->command) + this->command = onenand_command; + if (!this->wait) + this->wait = onenand_wait; + + if (!this->read_bufferram) + this->read_bufferram = onenand_read_bufferram; + if (!this->write_bufferram) + this->write_bufferram = onenand_write_bufferram; + + if (onenand_probe(mtd)) + return -ENXIO; + + /* Set Sync. Burst Read after probing */ + if (this->mmcontrol) { + printk(KERN_INFO "OneNAND Sync. Burst Read support\n"); + this->read_bufferram = onenand_sync_read_bufferram; + } + + onenand_unlock(mtd, 0, mtd->size); + + return onenand_default_bbt(mtd); +} + +/** + * onenand_release - [OneNAND Interface] Free resources held by the OneNAND device + * @param mtd MTD device structure + */ +void onenand_release(struct mtd_info *mtd) +{ +} + +/* + * OneNAND initialization at U-Boot + */ +struct mtd_info onenand_mtd; +struct onenand_chip onenand_chip; + +void onenand_init(void) +{ + memset(&onenand_mtd, 0, sizeof(struct mtd_info)); + memset(&onenand_chip, 0, sizeof(struct onenand_chip)); + + onenand_chip.base = (void *)CFG_ONENAND_BASE; + onenand_mtd.priv = &onenand_chip; + + onenand_scan(&onenand_mtd, 1); + + puts("OneNAND: "); + print_size(onenand_mtd.size, "\n"); +} + +#endif /* CFG_CMD_ONENAND */
- if (count < 32) {
count >>= 1;
while (count--)
*_d++ = *_s++;
return _d;
- memcpy32(dest, (void *)src, count);
- return (void *)count;
+} +#endif
Why exactly do we need this? And why do we need an additonal special function memcpy32?
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 16 */
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 32 */
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 48 */
- 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, /* 64 */
Using a dynamic buffer and a memset() call in the init code may helpt to reduce the memory footprint. What do you think?
- return readw(addr);
- writew(value, addr);
If this is all you do, you should probably use an inline or a macro.
- Get the device and lock it for exclusive access
- /* Do nothing */
- Deselect, release chip lock and wake up anyone waiting on the device
- /* Do nothing */
Inline? Macro?
- return onenand_read_ecc(mtd, from, len, retlen, buf, NULL, NULL);
Inline? Macro?
- return onenand_write_ecc(mtd, to, len, retlen, buf, NULL, NULL);
Inline? Macro?
* TODO
- onenand_block_markbad - [MTD Interface] Mark the block at the given offset as bad
- @param mtd MTD device structure
- @param ofs offset relative to mtd start
- /* see above */
Do we need these, then?
- onenand_release - [OneNAND Interface] Free resources held by the OneNAND device
Do we need this, then?
- if (count < 32) {
count >>= 1;
while (count--)
*_d++ = *_s++;
return _d;
+} +#endif
It's for performance. Now ARM used the char-based memcpy. Even though it's working with current char-based memcpy, I want to use the optimized memcpy. And basically OneNAND uses the 16-bit buswidth so we don't sure the correct behavior in OneNAND BufferRAM if we use the char-based memcpy.
Memcpy32 is 32-bytes aligned optimized. Since we know the memcpy usages in OneNAND driver, we guarantee the usage of memcpy32.
At first I want to sync between the linux OneNAND code and u-boot one. The current code of u-boot patch is the first implementation of linux OneNAND. There are a lot of works to sync. So after committing of patches, I will modify it.
It's same reason as above. In linux OneNAND, we can overwrite the readw and writew. But I'm now sure it's needed at u-boot. if (!this->read_word) this->read_word = onenand_readw; if (!this->write_word) this->write_word = onenand_writew;
- /* Do nothing */
- /* Do nothing */
Inline? Macro?
Also others are same. Some functions are don't needed at u-boot. But it was remained for easy adaptation from linux to u-boot.
Thank you, Kyungmin Park
In message 002501c7f347$e1d579c0$e1ac580a@swcenter.sec.samsung.co.kr you wrote:
- if (count < 32) {
count >>= 1;
while (count--)
*_d++ = *_s++;
return _d;
+} +#endif
How much difference does this optimization make in real life? Do you have any time measurements at hand?
I'm concerned about correctness. What happens in your coide when I write
memcpy (dst, src, 5);
How many bytes will be copied?
What happens when src or dst or both are pointing to odd addresses, i. e. in case of unaligned accesses?
I remember that ARM is terribly broken there... :-(
But the memcpy() you provide will also be used in all other partrs of U-Boot, won't it?
Agreed.
Understood and agreed.
Thank you,
Thank *you*.
-----Original Message----- From: wd@denx.de [mailto:wd@denx.de] Sent: Monday, September 10, 2007 4:07 PM To: kmpark@infradead.org Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] [PATCH 3/5] OneNAND support
- if (count < 32) {
count >>= 1;
while (count--)
*_d++ = *_s++;
return _d;
+} +#endif
optimized memcpy.
It's also discuss the at previous time http://sourceforge.net/mailarchive/message.php?msg_id=f3f1b91a0703141856n180...
Agreed
memcpy.
If you concern the portability issues, I can omit it at this time. How do you think about it?
In message 003101c7f37f$1fcb6cd0$e1ac580a@swcenter.sec.samsung.co.kr you wrote:
- if (count < 32) {
count >>= 1;
while (count--)
*_d++ = *_s++;
return _d;
Now I remember, thanks for the link.
Agreed
If my interpretation is right, that above implementation will copy only 4 bytes when I ask for 5 to be copied, then the answer is simple: fix it, or dump it.
Portability is one thing, but it seems to be not correct, which is a strict No, No to me.
Kyungmin Park
