[U-Boot] [PATCH] arch/arm/lib/Makefile: Allow CONFIG_USE_ARCH_MEMSET/MEMCPY with SPL
CONFIG_USE_ARCH_MEMSET/MEMCPY are inside a "SPL" check, which makes it impossible to use CONFIG_USE_ARCH_MEMSET combined with a SPL that calls memset. This patch moves that outside of the "if spl" block, allowing the code to be used inside SPL.
One use case is that when using ECC on the Zynq platform, all the DDR RAM must be written to before it's read, otherwise the system will cause a bus error and hang. Without CONFIG_USE_ARCH_MEMSET it takes over 5 seconds to clear 256MB, enabling CONFIG_USE_ARCH_MEMSET reduces that time to less than 3 seconds.
Signed-off-by: Mike Looijmans mike.looijmans@topic.nl --- arch/arm/lib/Makefile | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 0051f76..eac6a5d 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -30,12 +30,12 @@ obj-$(CONFIG_CMD_BOOTI) += bootm.o obj-$(CONFIG_CMD_BOOTM) += bootm.o obj-$(CONFIG_CMD_BOOTZ) += bootm.o zimage.o obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o -obj-$(CONFIG_USE_ARCH_MEMSET) += memset.o -obj-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o else obj-$(CONFIG_SPL_FRAMEWORK) += spl.o obj-$(CONFIG_SPL_FRAMEWORK) += zimage.o endif +obj-$(CONFIG_USE_ARCH_MEMSET) += memset.o +obj-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o obj-$(CONFIG_SEMIHOSTING) += semihosting.o
obj-y += sections.o
Mike Looijmans
