[U-Boot] UBIFS mount bug when mounting from multiple MTD partitions
I have a customer who has a NAND device with two MTD partitions and each of the partitions contains one UBI volume with a UBIFS filesystem.
Now U-Boot can mount the UBIFS from the first partition just fine, but if the UBIFS from the second partition is mounted afterwards this fails in some cases.
I can reproduce the error and tracked it down to uboot_ubifs_mount() in fs/ubifs/super.c. If this function is run for the second mount, the struct ubifs_fs_type is reused and it contains a list fs_supers, that still holds one entry for the first mount.
I guess, that if the second mount would happen on a volume that is on the same MTD partition as the first volume, than this will work. The second entry is added to ubifs_fs_type.fs_supers.
In my case however, the second entry being added to ubifs_fs_type.fs_supers is invalid and causes the mount error.
Reinitializing the list in uboot_ubifs_mount() before each mount, solves the problem, but I guess that it will cause failures in other setups, where there are actually multiple volumes on one MTD device.
So how can I solve this properly? Do we need one instance of struct ubifs_fs_type for each MTD device?
I tested this on an old version (2017.03), but looking at the current code, it looks like the same problem applies to current mainline.
Thanks for any help and suggestions! Frieder
Hello Frieder,
Am 10.04.2019 um 12:49 schrieb Schrempf Frieder:
I have a customer who has a NAND device with two MTD partitions and each > of the partitions contains one UBI volume with a UBIFS filesystem.
Bad idea ... why?
You may loose lifetime of the board, as UBI cannot use PEBs between the 2 MTD partitions on the nand ... better you would have one big MTD Partition with n ubi volumes in it ...
But ... okay... this must work also.
Sure?
fs_supers in struct file_system_type seems used only in none U-Boot code...
I cannot see this from looking into code ... so hard to say, but I only looked into mainline code ...
Hmm.. without digging into it, it is difficult to say...
Is there any chance to try it with current mainline ?
bye, Heiko
Hi Heiko,
On 10.04.19 14:44, Heiko Schocher wrote:
Hello Frieder,
Bad idea ... why?
Yeah, I only recently learned about the disadvantages of this setup. Maybe we can change it in the future, but for now they are using separate partitions.
Sure?
Right, I had a closer look and fs_supers seems to be unused indeed, but somehow it causes corruption in my case. When I apply 5a08cfee3967 (ubifs: remove useless code) the problem disappears.
Without this patch there still is hlist_add_head(&s->s_instances, &type->fs_supers) and this line somehow seems to cause the error.
I applied this debug diff:
--- a/fs/ubifs/super.c +++ b/fs/ubifs/super.c @@ -2428,7 +2428,15 @@ retry: #else strncpy(s->s_id, type->name, sizeof(s->s_id)); #endif + printf("%s:%d: ubi_num: %d, vol_id: %d\n", + __func__, __LINE__, + ((struct ubifs_info *)s->s_fs_info)->vi.ubi_num, + ((struct ubifs_info *)s->s_fs_info)->vi.vol_id); hlist_add_head(&s->s_instances, &type->fs_supers); + printf("%s:%d: ubi_num: %d, vol_id: %d\n", + __func__, __LINE__, + ((struct ubifs_info *)s->s_fs_info)->vi.ubi_num, + ((struct ubifs_info *)s->s_fs_info)->vi.vol_id); #ifndef __UBOOT__ spin_unlock(&sb_lock); get_filesystem(type);
And I'm getting this for the first mount:
sget:2431: ubi_num: 0, vol_id: 0 sget:2433: ubi_num: 0, vol_id: 0
And this for the second mount:
sget:2431: ubi_num: 0, vol_id: 0 sget:2433: ubi_num: -1678121552, vol_id: -1678120656
Yeah, I was probably wrong with these first wild guesses...
The problem is a bit strange and this what I'm actually worried about. It is persistent in a certain environment: U-Boot loaded from SPI NOR, environment set to certain values, data written to UBIFS partition in Linux and then power-cut.
If one of these conditions changes, the error usually disappears, for example if I use the exact same setup, but load the Bootloader from MMC or RAM. Or if no write access with power-cut happens.
So I wonder if there's some memory corruption somewhere else. Though, the error happens always at the same place. Debug prints or other code changes have no influence.
I really would like to understand what's going on so I can make sure that 5a08cfee3967 actually solves the real issue or just hides it.
Thanks, Frieder
Hello Frieder,
Am 10.04.2019 um 15:31 schrieb Schrempf Frieder:
Hi Heiko,
Hello Frieder,
Bad idea ... why?
Ok.
Sure?
Ah, 5a08cfee3967 is in mainline ... good ;-)
__func__, __LINE__,
__func__, __LINE__,
#ifndef __UBOOT__ spin_unlock(&sb_lock); get_filesystem(type);((struct ubifs_info *)s->s_fs_info)->vi.vol_id);
Hmm...
Please keep me informed ... I try to reproduce it here on a hw I have access to, but need some "free" time ...
bye, Heiko
On 10.04.19 15:59, Heiko Schocher wrote:
Hello Frieder,
Hi Heiko,
Hello Frieder,
Bad idea ... why?
Ok.
Sure?
Hmm...
So I got down to the roots of the problem. On the second mount operation, the fs_supers list contains a reference to the super_block of the previous mount, that has local scope and is not valid anymore.
Upon calling hlist_add_head(&s->s_instances, &type->fs_supers), the new super_block is added to the list fs_supers as a second entry. As this is a double linked list, the first entries pprev pointer is updated, what causes a corruption.
So 5a08cfee3967 is not just a simple cleanup change, as noted in the commit message. It also fixes a real bug by removing the update of the unused list.
Regards, Frieder
Heiko Schocher
Schrempf Frieder
