[U-Boot] [PATCH] driver: spi: add spansion s25fs-s family protect/unprotect
In order to support spansion s25fs512s flash protect/unprotect:
[1] Fill callbak flash->lock/unlock/is_locked by spansion_lock/ unlock/is_locked.
[2] Achieve protect/unprotected by operating sr1nv, cr1nv.
Signed-off-by: Yunhui Cui yunhui.cui@nxp.com --- drivers/mtd/spi/spi_flash.c | 195 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 195 insertions(+)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 64d4e0f..446e6e3 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -839,6 +839,194 @@ int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) } #endif
+#if defined(CONFIG_SPI_FLASH_SPANSION) +/* + * Return 1 if the entire region is locked, 0 otherwise + */ +static int spansion_is_locked_sr(struct spi_flash *flash, u32 ofs, u32 len, + u8 sr) +{ + loff_t lock_offs; + u64 lock_len; + + stm_get_locked_range(flash, sr, &lock_offs, &lock_len); + + return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs); +} + +/* + * Check if a region of the flash is (completely) locked. See spansion_lock() + * for more info. + * + * Returns 1 if entire region is locked, 0 if any portion is unlocked, and + * negative on errors. + */ +int spansion_is_locked(struct spi_flash *flash, u32 ofs, size_t len) +{ + u8 cmd[4]; + u32 sr1nv_offset = 0x0; + u8 sr1nv; + int ret; + + cmd[0] = CMD_SPANSION_RDAR; + cmd[1] = sr1nv_offset >> 16; + cmd[2] = sr1nv_offset >> 8; + cmd[3] = sr1nv_offset >> 0; + + ret = spi_flash_cmd_read(flash->spi, cmd, 4, &sr1nv, 1); + if (ret) + return -EIO; + + return spansion_is_locked_sr(flash, ofs, len, sr1nv); +} + +/* + * Lock a region of the flash. Compatible with Spansion s25fs-s family flash. + * Supports only the block protection bits BP{0,1,2} in the Status Register-1 + * Non-Volatile(SR1NV). + * + * Sample table portion for 64MB flash (S25FS512S): + * Configuration Register-1 Non-Volatile(CR1NV[5])== 0 + * + * | BP2 | BP1 | BP0 | Prot Length | Protected Portion + * ------------------------------------------------------------ + * | 0 | 0 | 0 | NONE | NONE + * | 0 | 0 | 1 | 1 MB | Upper 1/64 + * | 0 | 1 | 0 | 2 MB | Upper 1/32 + * | 0 | 1 | 1 | 4 MB | Upper 1/16 + * | 1 | 0 | 0 | 8 MB | Upper 1/8 + * | 1 | 0 | 1 | 16 MB | Upper 1/4 + * | 1 | 1 | 0 | 32 MB | Upper 1/2 + * | 1 | 1 | 1 | 64 MB | ALL + * + * When CR1NV[5] == 1, the Lower memory array are protected. + * + * Returns negative on errors, 0 on success. + */ +int spansion_lock(struct spi_flash *flash, u32 ofs, size_t len) +{ + u8 status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + int ret; + u8 cmd[4]; + u32 sr1nv_offset = 0x0; + u8 sr1nv; + + cmd[0] = CMD_SPANSION_RDAR; + cmd[1] = sr1nv_offset >> 16; + cmd[2] = sr1nv_offset >> 8; + cmd[3] = sr1nv_offset >> 0; + + ret = spi_flash_cmd_read(flash->spi, cmd, 4, &sr1nv, 1); + if (ret) + return -EIO; + status_old = sr1nv; + + /* SPI NOR always locks to the end */ + if (ofs + len != flash->size) { + /* Does combined region extend to end? */ + if (!stm_is_locked_sr(flash, ofs + len, flash->size - ofs - len, + status_old)) + return -EINVAL; + len = flash->size - ofs; + } + + /* + * Need smallest pow such that: + * + * 1 / (2^pow) <= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = ceil(log2(size / len)) = log2(size) - floor(log2(len)) + */ + pow = ilog2(flash->size) - ilog2(len); + val = mask - (pow << shift); + if (val & ~mask) + return -EINVAL; + + /* Don't "lock" with no region! */ + if (!(val & mask)) + return -EINVAL; + + status_new = (status_old & ~mask) | val; + + /* Only modify protection if it will not unlock other areas */ + if ((status_new & mask) <= (status_old & mask)) + return -EINVAL; + + cmd[0] = CMD_SPANSION_WRAR; + ret = spi_flash_cmd_write(flash->spi, cmd, 4, &status_new, 1); + if (ret) + return -EIO; + + return 0; +} + +/* + * Unlock a region of the flash. See spansion_lock() for more info + * + * Returns negative on errors, 0 on success. + */ +int spansion_unlock(struct spi_flash *flash, u32 ofs, size_t len) +{ + uint8_t status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + int ret; + + u8 cmd[4]; + u32 sr1nv_offset = 0x0; + u8 sr1nv; + + cmd[0] = CMD_SPANSION_RDAR; + cmd[1] = sr1nv_offset >> 16; + cmd[2] = sr1nv_offset >> 8; + cmd[3] = sr1nv_offset >> 0; + + ret = spi_flash_cmd_read(flash->spi, cmd, 4, &sr1nv, 1); + if (ret) + return -EIO; + status_old = sr1nv; + + /* Cannot unlock; would unlock larger region than requested */ + if (spansion_is_locked_sr(flash, ofs - flash->erase_size, + flash->erase_size, status_old)) + return -EINVAL; + /* + * Need largest pow such that: + * + * 1 / (2^pow) >= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = floor(log2(size / len)) = log2(size) - ceil(log2(len)) + */ + pow = ilog2(flash->size) - order_base_2(flash->size - (ofs + len)); + if (ofs + len == flash->size) { + val = 0; /* fully unlocked */ + } else { + val = mask - (pow << shift); + /* Some power-of-two sizes are not supported */ + if (val & ~mask) + return -EINVAL; + } + status_new = (status_old & ~mask) | val; + + /* Only modify protection if it will not lock other areas */ + if ((status_new & mask) >= (status_old & mask)) + return -EINVAL; + + cmd[0] = CMD_SPANSION_WRAR; + ret = spi_flash_cmd_write(flash->spi, cmd, 4, &status_new, 1); + if (ret) + return -EIO; + + return 0; +} +#endif +
#ifdef CONFIG_SPI_FLASH_MACRONIX static int macronix_quad_enable(struct spi_flash *flash) @@ -1134,6 +1322,13 @@ int spi_flash_scan(struct spi_flash *flash) flash->flash_is_locked = stm_is_locked; #endif break; +#if defined(CONFIG_SPI_FLASH_SPANSION) + case SPI_FLASH_CFI_MFR_SPANSION: + flash->flash_lock = spansion_lock; + flash->flash_unlock = spansion_unlock; + flash->flash_is_locked = spansion_is_locked; +#endif + break; default: debug("SF: Lock ops not supported for %02x flash\n", idcode[0]); }
Try to use existing lock code and add spansion on top of that.
[Yunhui] the spansion s25fs-s family cannot share the existing lock code, because it need some specific operations through SR1NV.thanks
-- Jagan Teki Free Software Engineer | www.openedev.com U-Boot, Linux | Upstream Maintainer Hyderabad, India.
Jagan Teki
Yunhui Cui
Yunhui Cui
