pwm-backlight driver not being probed in u-boot
Hi everyone,
I've been trying to turn on my lcd backlight at the u-boot stage to no avail. The device tree has a top level node whose compatible is 'pwm-backlight'. That driver never seems to get probed. The same problem is described here https://stackoverflow.com/questions/62461096/pwm-backlight-driver-not-being-probed-in-u-boot
I'm new to u-boot so please bear with me. From what I can gather from the docs a device gets activated/probed when *uclass_get_device *and friends are called. However I keep getting NULL, while *uclass_id_count(UCLASS_PANEL_BACKLIGHT) *correctly reports 1 device. A *dm_dump_all* at this stage shows the backlight is probed. All these calls are made in *board_late_init.*
Does this have to do with the backlight being a top level device in the devicetree ?? Or is the a wrong assumption I'm making ? Any help would be greatly appreciated.
Brandon
+Anatolij Gustschin
Hi Cheo,
On Mon, 9 Jan 2023 at 07:47, Cheo Fusi fusibrandon13@gmail.com wrote:
Hi everyone,
What board is this?
You can use 'dm tree' to see devices and 'dm uclass' to see their sequence number. Probably you want uclass_first_device() if you don't know the sequence number.
If you are getting NULL you are calling something strange. You should get an integer error code which indicates what is wrong.
This should be done automatically when your video driver is set up, not in board_late_init(). With driver model, everything should be handled automatically.
If stdout contains 'vidconsole' it will probe the first UCLASS_VIDEO device. You might find the simple-panel driver helpful as it handles backlight, regulators, etc. Or, depending on your SoC perhaps you need code in your video driver to decode the device tree and do the right thing, like [1] ?
In general, if you are putting init code in your board.c file then you should look at how to do things using device tree and existing drivers. Some examples are rockchip and x86.
[1] drivers/video/rockchip/rk_edp.c
Cheo Fusi
