[PATCH v2] ls1028a: use default scan_dev_for_boot
scan_dev_for_efi is supposed to be called from scan_dev_for_boot. However this call is missing for ls1028ardb and ls1028aqds boards. As a result EFI boot doesn’t work. Fix this issue by removing custom definition of scan_dev_for_boot and use the default definition instead.
Signed-off-by: Mian Yousaf Kaukab ykaukab@suse.de --- Change-log: v2: -Rename. was: ls1028a: fix EFI boot https://patchwork.ozlabs.org/project/uboot/patch/20200721143354.14382-1-ykau... -Remove custom definition of scan_dev_for_boot
include/configs/ls1028aqds.h | 7 ------- include/configs/ls1028ardb.h | 7 ------- 2 files changed, 14 deletions(-)
diff --git a/include/configs/ls1028aqds.h b/include/configs/ls1028aqds.h index 7bb740f48e36..8ab943cc640a 100644 --- a/include/configs/ls1028aqds.h +++ b/include/configs/ls1028aqds.h @@ -129,13 +129,6 @@ "run scan_dev_for_boot; " \ "fi; " \ "done\0" \ - "scan_dev_for_boot=" \ - "echo Scanning ${devtype} " \ - "${devnum}:${distro_bootpart}...; " \ - "for prefix in ${boot_prefixes}; do " \ - "run scan_dev_for_scripts; " \ - "done;" \ - "\0" \ "boot_a_script=" \ "load ${devtype} ${devnum}:${distro_bootpart} " \ "${scriptaddr} ${prefix}${script}; " \ diff --git a/include/configs/ls1028ardb.h b/include/configs/ls1028ardb.h index 07450113269c..3c9358ca4b7a 100644 --- a/include/configs/ls1028ardb.h +++ b/include/configs/ls1028ardb.h @@ -112,13 +112,6 @@ "run scan_dev_for_boot; " \ "fi; " \ "done\0" \ - "scan_dev_for_boot=" \ - "echo Scanning ${devtype} " \ - "${devnum}:${distro_bootpart}...; " \ - "for prefix in ${boot_prefixes}; do " \ - "run scan_dev_for_scripts; " \ - "done;" \ - "\0" \ "boot_a_script=" \ "load ${devtype} ${devnum}:${distro_bootpart} " \ "${scriptaddr} ${prefix}${script}; " \
-----Original Message----- From: Mian Yousaf Kaukab ykaukab@suse.de Sent: 2020年7月23日 21:41 To: u-boot@lists.denx.de; Andy Tang andy.tang@nxp.com Cc: Priyanka Jain priyanka.jain@nxp.com; Rajesh Bhagat rajesh.bhagat@nxp.com; harninder.rai@nxp.com; sudhanshu.gupta@nxp.com; Poonam Aggrwal poonam.aggrwal@nxp.com; Mian Yousaf Kaukab ykaukab@suse.de Subject: [EXT] [PATCH v2] ls1028a: use default scan_dev_for_boot
Caution: EXT Email
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatch work.ozlabs.org%2Fproject%2Fuboot%2Fpatch%2F20200721143354.14382-1 -ykaukab%40suse.de%2F&data=02%7C01%7Candy.tang%40nxp.com%7 C729286cd9264486fe7e208d82f0e3e21%7C686ea1d3bc2b4c6fa92cd99c5c3 01635%7C0%7C1%7C637311085499253728&sdata=iS6R4NdV3LhAXttKf lgl29Su8TJqfFoBzTCnUl4mAQM%3D&reserved=0 -Remove custom definition of scan_dev_for_boot
"done;" \
"done;" \
-- 2.26.2
Reviewed-by: andy.tang@nxp.com
Caution: EXT Email
"done;" \
"done;" \
-- 2.26.2
Andy, Are you maintaining nxp tree through which you can queue this patch? Or should I ask Tom to cherry-pick it?
BR, Yousaf
Andy Tang
Mian Yousaf Kaukab
