[U-Boot] [PATCH 1/2] drivers/ddr/fsl: Update clk_adjust of sdram_clk_cntl
The clk_adjust is of SDRAM_CLK_CNTL[5:8] 4-bits on MPC85xx and P-series, but is of SDRAM_CLK_CNTL[5:9] 5-bits on T-series and LS-series SoCs. We should update it to adapt the case that clk_adjust is odd data.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com --- drivers/ddr/fsl/ctrl_regs.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/drivers/ddr/fsl/ctrl_regs.c b/drivers/ddr/fsl/ctrl_regs.c index 9073917..b26269c 100644 --- a/drivers/ddr/fsl/ctrl_regs.c +++ b/drivers/ddr/fsl/ctrl_regs.c @@ -1835,10 +1835,17 @@ static void set_ddr_sdram_clk_cntl(fsl_ddr_cfg_regs_t *ddr, /* Per FSL Application Note: AN2805 */ ss_en = 1; #endif - clk_adjust = popts->clk_adjust; + if (fsl_ddr_get_version(0) >= 0x40701) { + /* clk_adjust in 5-bits on T-series and LS-series */ + clk_adjust = (popts->clk_adjust & 0x1F) << 22; + } else { + /* clk_adjust in 4-bits on earlier MPC85xx and P-series */ + clk_adjust = (popts->clk_adjust & 0xF) << 23; + } + ddr->ddr_sdram_clk_cntl = (0 | ((ss_en & 0x1) << 31) - | ((clk_adjust & 0xF) << 23) + | clk_adjust ); debug("FSLDDR: clk_cntl = 0x%08x\n", ddr->ddr_sdram_clk_cntl); }
This patch updates clk_adjust to actual value for boards with T-series and LS-series SoCs to match the setting of clk_adjust in latest ddr driver.
Signed-off-by: Shengzhou Liu Shengzhou.Liu@nxp.com --- board/freescale/ls1021aqds/ddr.h | 28 ++++++++++++++-------------- board/freescale/ls1043aqds/ddr.h | 28 ++++++++++++++-------------- board/freescale/ls1043ardb/ddr.h | 6 +++--- board/freescale/ls2080aqds/ddr.h | 32 ++++++++++++++++---------------- board/freescale/ls2080ardb/ddr.h | 32 ++++++++++++++++---------------- board/freescale/t102xqds/ddr.c | 22 +++++++++++----------- board/freescale/t102xrdb/ddr.c | 12 ++++++------ board/freescale/t1040qds/ddr.h | 22 +++++++++++----------- board/freescale/t104xrdb/ddr.h | 26 +++++++++++++------------- board/freescale/t208xqds/ddr.h | 40 ++++++++++++++++++++-------------------- board/freescale/t208xrdb/ddr.h | 20 ++++++++++---------- board/freescale/t4qds/ddr.h | 38 +++++++++++++++++++------------------- board/freescale/t4rdb/ddr.h | 38 +++++++++++++++++++------------------- 13 files changed, 172 insertions(+), 172 deletions(-)
diff --git a/board/freescale/ls1021aqds/ddr.h b/board/freescale/ls1021aqds/ddr.h index f819c99..b39b561 100644 --- a/board/freescale/ls1021aqds/ddr.h +++ b/board/freescale/ls1021aqds/ddr.h @@ -31,21 +31,21 @@ static const struct board_specific_parameters udimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | */ #ifdef CONFIG_SYS_FSL_DDR4 - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {2, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, - {1, 1666, 0, 4, 8, 0x090A0B0B, 0x0C0D0E0C,}, - {1, 1900, 0, 4, 9, 0x0A0B0C0B, 0x0D0E0F0D,}, - {1, 2200, 0, 4, 10, 0x0B0C0D0C, 0x0E0F110E,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 1900, 0, 8, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 1666, 0, 8, 8, 0x090A0B0B, 0x0C0D0E0C,}, + {1, 1900, 0, 8, 9, 0x0A0B0C0B, 0x0D0E0F0D,}, + {1, 2200, 0, 8, 10, 0x0B0C0D0C, 0x0E0F110E,}, #elif defined(CONFIG_SYS_FSL_DDR3) - {1, 833, 1, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, - {1, 1350, 1, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {1, 833, 2, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, - {1, 1350, 2, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {2, 833, 4, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, - {2, 1350, 4, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {2, 1350, 0, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {2, 1666, 4, 4, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, - {2, 1666, 0, 4, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, + {1, 833, 1, 12, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {1, 1350, 1, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {1, 833, 2, 12, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {1, 1350, 2, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 833, 4, 12, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {2, 1350, 4, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 1350, 0, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 1666, 4, 8, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, + {2, 1666, 0, 8, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, #else #error DDR type not defined #endif diff --git a/board/freescale/ls1043aqds/ddr.h b/board/freescale/ls1043aqds/ddr.h index 8adb660..2400ecb 100644 --- a/board/freescale/ls1043aqds/ddr.h +++ b/board/freescale/ls1043aqds/ddr.h @@ -32,21 +32,21 @@ static const struct board_specific_parameters udimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | */ #ifdef CONFIG_SYS_FSL_DDR4 - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {2, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, - {1, 1666, 0, 4, 6, 0x0708090B, 0x0C0D0E0A,}, - {1, 1900, 0, 4, 9, 0x0A0B0C0B, 0x0D0E0F0D,}, - {1, 2200, 0, 4, 10, 0x0B0C0D0C, 0x0E0F110E,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 1900, 0, 8, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 1666, 0, 8, 6, 0x0708090B, 0x0C0D0E0A,}, + {1, 1900, 0, 8, 9, 0x0A0B0C0B, 0x0D0E0F0D,}, + {1, 2200, 0, 8, 10, 0x0B0C0D0C, 0x0E0F110E,}, #elif defined(CONFIG_SYS_FSL_DDR3) - {1, 833, 1, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, - {1, 1350, 1, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {1, 833, 2, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, - {1, 1350, 2, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {2, 833, 4, 6, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, - {2, 1350, 4, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {2, 1350, 0, 6, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, - {2, 1666, 4, 4, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, - {2, 1666, 0, 4, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, + {1, 833, 1, 12, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {1, 1350, 1, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {1, 833, 2, 12, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {1, 1350, 2, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 833, 4, 12, 8, 0x06060607, 0x08080807, 0x1f, 2, 0}, + {2, 1350, 4, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 1350, 0, 12, 8, 0x0708080A, 0x0A0B0C09, 0x1f, 2, 0}, + {2, 1666, 4, 8, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, + {2, 1666, 0, 8, 0xa, 0x0B08090C, 0x0B0E0D0A, 0x1f, 2, 0}, #else #error DDR type not defined #endif diff --git a/board/freescale/ls1043ardb/ddr.h b/board/freescale/ls1043ardb/ddr.h index b17eb80..efa00ee 100644 --- a/board/freescale/ls1043ardb/ddr.h +++ b/board/freescale/ls1043ardb/ddr.h @@ -31,9 +31,9 @@ static const struct board_specific_parameters udimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | */ #ifdef CONFIG_SYS_FSL_DDR4 - {1, 1666, 0, 6, 7, 0x07090800, 0x00000000,}, - {1, 1900, 0, 6, 7, 0x07090800, 0x00000000,}, - {1, 2200, 0, 6, 7, 0x07090800, 0x00000000,}, + {1, 1666, 0, 12, 7, 0x07090800, 0x00000000,}, + {1, 1900, 0, 12, 7, 0x07090800, 0x00000000,}, + {1, 2200, 0, 12, 7, 0x07090800, 0x00000000,}, #endif {} }; diff --git a/board/freescale/ls2080aqds/ddr.h b/board/freescale/ls2080aqds/ddr.h index b76ea61..eba62c3 100644 --- a/board/freescale/ls2080aqds/ddr.h +++ b/board/freescale/ls2080aqds/ddr.h @@ -28,10 +28,10 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {2, 1350, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, - {2, 1666, 0, 4, 7, 0x08090A0C, 0x0D0F100B,}, - {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, - {2, 2300, 0, 4, 8, 0x090A0C0F, 0x1012130C,}, + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 7, 0x08090A0C, 0x0D0F100B,}, + {2, 1900, 0, 8, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2300, 0, 8, 8, 0x090A0C0F, 0x1012130C,}, {} };
@@ -42,10 +42,10 @@ static const struct board_specific_parameters udimm2[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {2, 1350, 0, 4, 0xd, 0x0C0A0A00, 0x00000009,}, - {2, 1666, 0, 4, 0xd, 0x0C0A0A00, 0x00000009,}, - {2, 1900, 0, 4, 0xe, 0x0D0C0B00, 0x0000000A,}, - {2, 2200, 0, 4, 0xe, 0x0D0C0B00, 0x0000000A,}, + {2, 1350, 0, 8, 0xd, 0x0C0A0A00, 0x00000009,}, + {2, 1666, 0, 8, 0xd, 0x0C0A0A00, 0x00000009,}, + {2, 1900, 0, 8, 0xe, 0x0D0C0B00, 0x0000000A,}, + {2, 2200, 0, 8, 0xe, 0x0D0C0B00, 0x0000000A,}, {} };
@@ -55,10 +55,10 @@ static const struct board_specific_parameters rdimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {2, 1350, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, - {2, 1666, 0, 4, 7, 0x08090A0C, 0x0D0F100B,}, - {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, - {2, 2200, 0, 4, 8, 0x090A0C0F, 0x1012130C,}, + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 7, 0x08090A0C, 0x0D0F100B,}, + {2, 1900, 0, 8, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2200, 0, 8, 8, 0x090A0C0F, 0x1012130C,}, {} };
@@ -69,10 +69,10 @@ static const struct board_specific_parameters rdimm2[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {2, 1350, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, - {2, 1666, 0, 4, 7, 0x0B0A090C, 0x0D0F100B,}, - {2, 1900, 0, 4, 7, 0x09090B0D, 0x0E10120B,}, - {2, 2200, 0, 4, 8, 0x090A0C0F, 0x1012130C,}, + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 7, 0x0B0A090C, 0x0D0F100B,}, + {2, 1900, 0, 8, 7, 0x09090B0D, 0x0E10120B,}, + {2, 2200, 0, 8, 8, 0x090A0C0F, 0x1012130C,}, {} };
diff --git a/board/freescale/ls2080ardb/ddr.h b/board/freescale/ls2080ardb/ddr.h index bda9d4a..a9c1223 100644 --- a/board/freescale/ls2080ardb/ddr.h +++ b/board/freescale/ls2080ardb/ddr.h @@ -28,10 +28,10 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {2, 1350, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, - {2, 1666, 0, 4, 8, 0x08090B0D, 0x0E10100C,}, - {2, 1900, 0, 4, 8, 0x090A0C0E, 0x1012120D,}, - {2, 2300, 0, 4, 9, 0x0A0B0C10, 0x1114140E,}, + {2, 1350, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {2, 1666, 0, 8, 8, 0x08090B0D, 0x0E10100C,}, + {2, 1900, 0, 8, 8, 0x090A0C0E, 0x1012120D,}, + {2, 2300, 0, 8, 9, 0x0A0B0C10, 0x1114140E,}, {} };
diff --git a/board/freescale/t102xqds/ddr.c b/board/freescale/t102xqds/ddr.c index 2d4d10f..912d6a9 100644 --- a/board/freescale/t102xqds/ddr.c +++ b/board/freescale/t102xqds/ddr.c @@ -35,18 +35,18 @@ static const struct board_specific_parameters udimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ #if defined(CONFIG_SYS_FSL_DDR4) - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {2, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, - {1, 1666, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, - {1, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, - {1, 2200, 0, 4, 7, 0x08090A0D, 0x0F0F100C,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 1900, 0, 8, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 1666, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {1, 1900, 0, 8, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 2200, 0, 8, 7, 0x08090A0D, 0x0F0F100C,}, #elif defined(CONFIG_SYS_FSL_DDR3) - {2, 833, 0, 4, 6, 0x06060607, 0x08080807,}, - {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {1, 833, 0, 4, 6, 0x06060607, 0x08080807,}, - {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, - {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 833, 0, 8, 6, 0x06060607, 0x08080807,}, + {2, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {1, 833, 0, 8, 6, 0x06060607, 0x08080807,}, + {1, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09,}, + {1, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, #else #error DDR type not defined #endif diff --git a/board/freescale/t102xrdb/ddr.c b/board/freescale/t102xrdb/ddr.c index adf9fd5..60ab9ff 100644 --- a/board/freescale/t102xrdb/ddr.c +++ b/board/freescale/t102xrdb/ddr.c @@ -34,12 +34,12 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ - {2, 833, 0, 4, 6, 0x06060607, 0x08080807,}, - {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {1, 833, 0, 4, 6, 0x06060607, 0x08080807,}, - {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, - {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 833, 0, 8, 6, 0x06060607, 0x08080807,}, + {2, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {1, 833, 0, 8, 6, 0x06060607, 0x08080807,}, + {1, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09,}, + {1, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, {} };
diff --git a/board/freescale/t1040qds/ddr.h b/board/freescale/t1040qds/ddr.h index a6e1673..1e08746 100644 --- a/board/freescale/t1040qds/ddr.h +++ b/board/freescale/t1040qds/ddr.h @@ -29,18 +29,18 @@ static const struct board_specific_parameters udimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ #ifdef CONFIG_SYS_FSL_DDR4 - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {2, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, - {1, 1666, 0, 4, 6, 0x0708090B, 0x0C0D0E09,}, - {1, 1900, 0, 4, 6, 0x08080A0C, 0x0D0E0F0A,}, - {1, 2200, 0, 4, 7, 0x08090A0D, 0x0F0F100C,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 1900, 0, 8, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 1666, 0, 8, 6, 0x0708090B, 0x0C0D0E09,}, + {1, 1900, 0, 8, 6, 0x08080A0C, 0x0D0E0F0A,}, + {1, 2200, 0, 8, 7, 0x08090A0D, 0x0F0F100C,}, #elif defined(CONFIG_SYS_FSL_DDR3) - {2, 833, 0, 4, 6, 0x06060607, 0x08080807,}, - {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, - {1, 833, 0, 4, 6, 0x06060607, 0x08080807,}, - {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09,}, - {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A,}, + {2, 833, 0, 8, 6, 0x06060607, 0x08080807,}, + {2, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09,}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, + {1, 833, 0, 8, 6, 0x06060607, 0x08080807,}, + {1, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09,}, + {1, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A,}, #else #error DDR type not defined #endif diff --git a/board/freescale/t104xrdb/ddr.h b/board/freescale/t104xrdb/ddr.h index b9c02f7..012991c 100644 --- a/board/freescale/t104xrdb/ddr.h +++ b/board/freescale/t104xrdb/ddr.h @@ -29,20 +29,20 @@ static const struct board_specific_parameters udimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 */ #ifdef CONFIG_SYS_FSL_DDR4 - {2, 1600, 4, 4, 6, 0x07090A0c, 0x0e0f100a}, + {2, 1600, 4, 8, 6, 0x07090A0c, 0x0e0f100a}, #elif defined(CONFIG_SYS_FSL_DDR3) - {2, 833, 4, 4, 6, 0x06060607, 0x08080807}, - {2, 833, 0, 4, 6, 0x06060607, 0x08080807}, - {2, 1350, 4, 4, 7, 0x0708080A, 0x0A0B0C09}, - {2, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09}, - {2, 1666, 4, 4, 7, 0x0808090B, 0x0C0D0E0A}, - {2, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A}, - {1, 833, 4, 4, 6, 0x06060607, 0x08080807}, - {1, 833, 0, 4, 6, 0x06060607, 0x08080807}, - {1, 1350, 4, 4, 7, 0x0708080A, 0x0A0B0C09}, - {1, 1350, 0, 4, 7, 0x0708080A, 0x0A0B0C09}, - {1, 1666, 4, 4, 7, 0x0808090B, 0x0C0D0E0A}, - {1, 1666, 0, 4, 7, 0x0808090B, 0x0C0D0E0A}, + {2, 833, 4, 8, 6, 0x06060607, 0x08080807}, + {2, 833, 0, 8, 6, 0x06060607, 0x08080807}, + {2, 1350, 4, 8, 7, 0x0708080A, 0x0A0B0C09}, + {2, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09}, + {2, 1666, 4, 8, 7, 0x0808090B, 0x0C0D0E0A}, + {2, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A}, + {1, 833, 4, 8, 6, 0x06060607, 0x08080807}, + {1, 833, 0, 8, 6, 0x06060607, 0x08080807}, + {1, 1350, 4, 8, 7, 0x0708080A, 0x0A0B0C09}, + {1, 1350, 0, 8, 7, 0x0708080A, 0x0A0B0C09}, + {1, 1666, 4, 8, 7, 0x0808090B, 0x0C0D0E0A}, + {1, 1666, 0, 8, 7, 0x0808090B, 0x0C0D0E0A}, #else #error DDR type not defined #endif diff --git a/board/freescale/t208xqds/ddr.h b/board/freescale/t208xqds/ddr.h index 9c26fdf..255ab2c 100644 --- a/board/freescale/t208xqds/ddr.h +++ b/board/freescale/t208xqds/ddr.h @@ -28,17 +28,17 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ - {2, 1200, 0, 5, 7, 0x0708090a, 0x0b0c0d09}, - {2, 1400, 0, 5, 7, 0x08090a0c, 0x0d0e0f0a}, - {2, 1700, 0, 5, 8, 0x090a0b0c, 0x0e10110c}, - {2, 1900, 0, 5, 8, 0x090b0c0f, 0x1012130d}, - {2, 2140, 0, 5, 8, 0x090b0c0f, 0x1012130d}, - {1, 1200, 0, 5, 7, 0x0808090a, 0x0b0c0c0a}, - {1, 1500, 0, 5, 6, 0x07070809, 0x0a0b0b09}, - {1, 1600, 0, 5, 8, 0x090b0b0d, 0x0d0e0f0b}, - {1, 1700, 0, 4, 8, 0x080a0a0c, 0x0c0d0e0a}, - {1, 1900, 0, 5, 8, 0x090a0c0d, 0x0e0f110c}, - {1, 2140, 0, 4, 8, 0x090a0b0d, 0x0e0f110b}, + {2, 1200, 0, 10, 7, 0x0708090a, 0x0b0c0d09}, + {2, 1400, 0, 10, 7, 0x08090a0c, 0x0d0e0f0a}, + {2, 1700, 0, 10, 8, 0x090a0b0c, 0x0e10110c}, + {2, 1900, 0, 10, 8, 0x090b0c0f, 0x1012130d}, + {2, 2140, 0, 10, 8, 0x090b0c0f, 0x1012130d}, + {1, 1200, 0, 10, 7, 0x0808090a, 0x0b0c0c0a}, + {1, 1500, 0, 10, 6, 0x07070809, 0x0a0b0b09}, + {1, 1600, 0, 10, 8, 0x090b0b0d, 0x0d0e0f0b}, + {1, 1700, 0, 8, 8, 0x080a0a0c, 0x0c0d0e0a}, + {1, 1900, 0, 10, 8, 0x090a0c0d, 0x0e0f110c}, + {1, 2140, 0, 8, 8, 0x090a0b0d, 0x0e0f110b}, {} };
@@ -49,15 +49,15 @@ static const struct board_specific_parameters rdimm0[] = { * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ /* TODO: need tuning these parameters if RDIMM is used */ - {4, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906}, - {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, - {2, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, - {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, - {1, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, - {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07}, + {4, 1350, 0, 10, 9, 0x08070605, 0x06070806}, + {4, 1666, 0, 10, 11, 0x0a080706, 0x07090906}, + {4, 2140, 0, 10, 12, 0x0b090807, 0x080a0b07}, + {2, 1350, 0, 10, 9, 0x08070605, 0x06070806}, + {2, 1666, 0, 10, 11, 0x0a090806, 0x08090a06}, + {2, 2140, 0, 10, 12, 0x0b090807, 0x080a0b07}, + {1, 1350, 0, 10, 9, 0x08070605, 0x06070806}, + {1, 1666, 0, 10, 11, 0x0a090806, 0x08090a06}, + {1, 2140, 0, 8, 12, 0x0b090807, 0x080a0b07}, {} };
diff --git a/board/freescale/t208xrdb/ddr.h b/board/freescale/t208xrdb/ddr.h index 08cbb60..175cf56 100644 --- a/board/freescale/t208xrdb/ddr.h +++ b/board/freescale/t208xrdb/ddr.h @@ -28,16 +28,16 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | */ - {2, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, - {2, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, - {2, 1600, 2, 5, 8, 0x0808070b, 0x0c0d0e0a}, - {2, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, - {2, 1900, 0, 5, 7, 0x0808080c, 0x0b0c0c09}, - {1, 1200, 2, 5, 7, 0x0808090a, 0x0b0c0c0a}, - {1, 1500, 2, 5, 6, 0x07070809, 0x0a0b0b09}, - {1, 1600, 2, 5, 8, 0x0808070b, 0x0c0d0e0a}, - {1, 1700, 2, 4, 7, 0x080a0a0c, 0x0c0d0e0a}, - {1, 1900, 0, 5, 7, 0x0808080c, 0x0b0c0c09}, + {2, 1200, 2, 10, 7, 0x0808090a, 0x0b0c0c0a}, + {2, 1500, 2, 10, 6, 0x07070809, 0x0a0b0b09}, + {2, 1600, 2, 10, 8, 0x0808070b, 0x0c0d0e0a}, + {2, 1700, 2, 8, 7, 0x080a0a0c, 0x0c0d0e0a}, + {2, 1900, 0, 10, 7, 0x0808080c, 0x0b0c0c09}, + {1, 1200, 2, 10, 7, 0x0808090a, 0x0b0c0c0a}, + {1, 1500, 2, 10, 6, 0x07070809, 0x0a0b0b09}, + {1, 1600, 2, 10, 8, 0x0808070b, 0x0c0d0e0a}, + {1, 1700, 2, 8, 7, 0x080a0a0c, 0x0c0d0e0a}, + {1, 1900, 0, 10, 7, 0x0808080c, 0x0b0c0c09}, {} };
diff --git a/board/freescale/t4qds/ddr.h b/board/freescale/t4qds/ddr.h index 4d0e3c4..0b0cc9a 100644 --- a/board/freescale/t4qds/ddr.h +++ b/board/freescale/t4qds/ddr.h @@ -31,16 +31,16 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | */ - {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, - {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, - {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, - {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, + {2, 1350, 4, 8, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {2, 1350, 0, 10, 7, 0x0709090b, 0x0c0c0d09, 0xff, 2, 0}, + {2, 1666, 4, 8, 8, 0x080a0a0d, 0x0d10100b, 0xff, 2, 0}, + {2, 1666, 0, 10, 7, 0x080a0a0c, 0x0d0d0e0a, 0xff, 2, 0}, + {2, 1900, 0, 8, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, + {2, 2140, 0, 8, 8, 0x090a0b0e, 0x0f11120c, 0xff, 2, 0}, + {1, 1350, 0, 10, 8, 0x0809090b, 0x0c0c0d0a, 0xff, 2, 0}, + {1, 1700, 0, 10, 8, 0x080a0a0c, 0x0c0d0e0a, 0xff, 2, 0}, + {1, 1900, 0, 8, 8, 0x080a0a0c, 0x0e0e0f0a, 0xff, 2, 0}, + {1, 2140, 0, 8, 8, 0x090a0b0c, 0x0e0f100b, 0xff, 2, 0}, {} };
@@ -50,15 +50,15 @@ static const struct board_specific_parameters rdimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl | cpo |wrdata|2T * ranks| mhz| GB |adjst| start | ctl2 | ctl3 | |delay | */ - {4, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, - {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906, 0xff, 2, 0}, - {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, - {2, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, - {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, - {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, - {1, 1350, 0, 5, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, - {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, - {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, + {4, 1350, 0, 10, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, + {4, 1666, 0, 10, 11, 0x0a080706, 0x07090906, 0xff, 2, 0}, + {4, 2140, 0, 10, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, + {2, 1350, 0, 10, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, + {2, 1666, 0, 10, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, + {2, 2140, 0, 10, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, + {1, 1350, 0, 10, 9, 0x08070605, 0x06070806, 0xff, 2, 0}, + {1, 1666, 0, 10, 11, 0x0a090806, 0x08090a06, 0xff, 2, 0}, + {1, 2140, 0, 8, 12, 0x0b090807, 0x080a0b07, 0xff, 2, 0}, {} };
diff --git a/board/freescale/t4rdb/ddr.h b/board/freescale/t4rdb/ddr.h index 7b85476..f01ebb2 100644 --- a/board/freescale/t4rdb/ddr.h +++ b/board/freescale/t4rdb/ddr.h @@ -27,16 +27,16 @@ static const struct board_specific_parameters udimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {2, 1350, 4, 4, 8, 0x0809090b, 0x0c0c0d0a}, - {2, 1350, 0, 5, 7, 0x0709090b, 0x0c0c0d09}, - {2, 1666, 4, 4, 8, 0x080a0a0d, 0x0d10100b}, - {2, 1666, 0, 5, 7, 0x080a0a0c, 0x0d0d0e0a}, - {2, 1900, 0, 4, 8, 0x090a0b0e, 0x0f11120c}, - {2, 2140, 0, 4, 8, 0x090a0b0e, 0x0f11120c}, - {1, 1350, 0, 5, 8, 0x0809090b, 0x0c0c0d0a}, - {1, 1700, 0, 5, 8, 0x080a0a0c, 0x0c0d0e0a}, - {1, 1900, 0, 4, 8, 0x080a0a0c, 0x0e0e0f0a}, - {1, 2140, 0, 4, 8, 0x090a0b0c, 0x0e0f100b}, + {2, 1350, 4, 8, 8, 0x0809090b, 0x0c0c0d0a}, + {2, 1350, 0, 10, 7, 0x0709090b, 0x0c0c0d09}, + {2, 1666, 4, 8, 8, 0x080a0a0d, 0x0d10100b}, + {2, 1666, 0, 10, 7, 0x080a0a0c, 0x0d0d0e0a}, + {2, 1900, 0, 8, 8, 0x090a0b0e, 0x0f11120c}, + {2, 2140, 0, 8, 8, 0x090a0b0e, 0x0f11120c}, + {1, 1350, 0, 10, 8, 0x0809090b, 0x0c0c0d0a}, + {1, 1700, 0, 10, 8, 0x080a0a0c, 0x0c0d0e0a}, + {1, 1900, 0, 8, 8, 0x080a0a0c, 0x0e0e0f0a}, + {1, 2140, 0, 8, 8, 0x090a0b0c, 0x0e0f100b}, {} };
@@ -46,15 +46,15 @@ static const struct board_specific_parameters rdimm0[] = { * num| hi| rank| clk| wrlvl | wrlvl | wrlvl * ranks| mhz| GB |adjst| start | ctl2 | ctl3 */ - {4, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {4, 1666, 0, 5, 11, 0x0a080706, 0x07090906}, - {4, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, - {2, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {2, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, - {2, 2140, 0, 5, 12, 0x0b090807, 0x080a0b07}, - {1, 1350, 0, 5, 9, 0x08070605, 0x06070806}, - {1, 1666, 0, 5, 11, 0x0a090806, 0x08090a06}, - {1, 2140, 0, 4, 12, 0x0b090807, 0x080a0b07}, + {4, 1350, 0, 10, 9, 0x08070605, 0x06070806}, + {4, 1666, 0, 10, 11, 0x0a080706, 0x07090906}, + {4, 2140, 0, 10, 12, 0x0b090807, 0x080a0b07}, + {2, 1350, 0, 10, 9, 0x08070605, 0x06070806}, + {2, 1666, 0, 10, 11, 0x0a090806, 0x08090a06}, + {2, 2140, 0, 10, 12, 0x0b090807, 0x080a0b07}, + {1, 1350, 0, 10, 9, 0x08070605, 0x06070806}, + {1, 1666, 0, 10, 11, 0x0a090806, 0x08090a06}, + {1, 2140, 0, 8, 12, 0x0b090807, 0x080a0b07}, {} };
Applied to fsl-qoriq master branch. Awaiting upstream. Thanks.
York
- if (fsl_ddr_get_version(0) >= 0x40701) {
- } else {
- ddr->ddr_sdram_clk_cntl = (0 | ((ss_en & 0x1) << 31)
debug("FSLDDR: clk_cntl = 0x%08x\n", ddr->ddr_sdram_clk_cntl);| clk_adjust );
Shengzhou,
Your understanding is correct. However, we have done analysis that the additional bit is not used for finer adjustment. So unless you have a case requiring values in the middle, I suggest to keep current code.
York
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Tuesday, May 17, 2016 12:55 AM To: Shengzhou Liu shengzhou.liu@nxp.com; u-boot@lists.denx.de Subject: Re: [PATCH 1/2] drivers/ddr/fsl: Update clk_adjust of sdram_clk_cntl
Shengzhou,
York
York
On LS1046RDB, the clk_adj is 9, an odd instead of even data, so we have to update it, and there will be more new boards in future with possibly odd clk_adj.
Shengzhou
Shengzhou,
York
York
Shengzhou,
If you have to use an odd number for clk_adj, we can go ahead to merge these patches. In my experience, clk_adj is very forgivable. If you have only one value works, there is probably something wrong.
York
-----Original Message----- From: York Sun [mailto:york.sun@nxp.com] Sent: Wednesday, June 01, 2016 12:04 AM To: Shengzhou Liu shengzhou.liu@nxp.com; u-boot@lists.denx.de Shengzhou,
York
York, The odd clk_adj = 9 is the optimal with timing centralization, maybe it work if set it to 8, but not the optimal. Theoretically we should have the actual value instead of dividing 2 to avoid confusion for customers. Shengzhou
York
OK. Thanks for the explanation.
York
York
Shengzhou Liu
Shengzhou Liu
York Sun
