[U-Boot] [PATCH] powerpc/ddr: fix fsl_ddr_get_dimm_params compile error
fsl_ddr_get_dimm_params() should be wrapped by CONFIG_SYS_DDR_RAW_TIMING, otherwise, when using fixed_sdram() instead of using SPD, it will cause compile error.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com Acked-by: York Sun yorksun@freescale.com --- arch/powerpc/cpu/mpc8xxx/ddr/main.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/main.c b/arch/powerpc/cpu/mpc8xxx/ddr/main.c index f52ad9f..c2a03e3 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/main.c +++ b/arch/powerpc/cpu/mpc8xxx/ddr/main.c @@ -366,7 +366,7 @@ fsl_ddr_compute(fsl_ddr_info_t *pinfo, unsigned int start_step, } }
-#else +#elif defined(CONFIG_SYS_DDR_RAW_TIMING) case STEP_COMPUTE_DIMM_PARMS: for (i = 0; i < CONFIG_NUM_DDR_CONTROLLERS; i++) { for (j = 0; j < CONFIG_DIMM_SLOTS_PER_CTLR; j++) {
Please copy me on 85xx patches
On Fri, Jun 29, 2012 at 4:36 AM, Shaohui Xie Shaohui.Xie@freescale.com wrote:
Applied, thanks
Andy Fleming
Shaohui Xie
