[U-Boot] [PATCHv2] net: zynq_gem: Do not return -ENOSYS on success
The .read_rom_hwaddr net_ops hook does not check the return value, which is why it was never caught that we are currently returning 0 if the read_rom_hwaddr function return -ENOSYS and -ENOSYS otherwise.
In this case we can simplify this by just returning the result of the function.
Signed-off-by: Olliver Schinagl oliver@schinagl.nl --- Changes since v1: Check pdata for NULL before dereferencing.
drivers/net/zynq_gem.c | 8 +++----- 1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/net/zynq_gem.c b/drivers/net/zynq_gem.c index 86dd03feda..52beedfad0 100644 --- a/drivers/net/zynq_gem.c +++ b/drivers/net/zynq_gem.c @@ -589,14 +589,12 @@ __weak int zynq_board_read_rom_ethaddr(unsigned char *ethaddr)
static int zynq_gem_read_rom_mac(struct udevice *dev) { - int retval; struct eth_pdata *pdata = dev_get_platdata(dev);
- retval = zynq_board_read_rom_ethaddr(pdata->enetaddr); - if (retval == -ENOSYS) - retval = 0; + if (!pdata) + return -ENOSYS;
- return retval; + return zynq_board_read_rom_ethaddr(pdata->enetaddr); }
static int zynq_gem_miiphy_read(struct mii_dev *bus, int addr,
Acked-by: Michal Simek michal.simek@xilinx.com
Joe: Can you please take this via your tree?
Thanks, Michal
Hi Michal,
Will do.
-Joe
retval = 0;
- if (!pdata)
return -ENOSYS;
- return retval;
- return zynq_board_read_rom_ethaddr(pdata->enetaddr);
I have seen one series about mac address which should just replace the whole this function. Not sure if it was applied or not but worth to check because if this is in tree the whole this function should go away.
M
Not yet, i rebased against u-boot-net/master. As it is it is a bug however so we should just put the fix in for now.
On April 5, 2017 8:29:22 AM CEST, Michal Simek michal.simek@xilinx.com wrote:
which
char *ethaddr)
retval = 0;
- if (!pdata)
return -ENOSYS;
- return retval;
M
Joe Hershberger
Joe Hershberger
Michal Simek
Olliver Schinagl
